[tools] tester: Check for begin/end of test
Fri Oct 7 03:08:43 UTC 2022
OK
Thanks
On 6/10/2022 6:29 pm, Sebastian Huber wrote:
> Check for "BEGIN OF TEST" and "END OF TEST" to not use other information blocks
> such as "END OF GCOV" to determine the test status.
>  tester/rt/report.py | 6 +++---
>  1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/tester/rt/report.py b/tester/rt/report.py
> index d3bf1cb..21580e2 100644
> --- a/tester/rt/report.py
> +++ b/tester/rt/report.py
> @@ -144,11 +144,11 @@ class report(object):
>              if line[0] == output_prefix:
>                  if line[1].startswith('*** '):
>                      banner = line[1][4:]
> -                    if banner.startswith('BEGIN OF '):
> +                    if banner.startswith('BEGIN OF TEST '):
>                          start = True
> -                    elif line[1][4:].startswith('END OF '):
> +                    elif banner.startswith('END OF TEST '):
>                          end = True
> -                    elif line[1][4:].startswith('FATAL'):
> +                    elif banner.startswith('FATAL'):
>                          fatal = True
>                      elif banner.startswith('TIMEOUT TIMEOUT'):
>                          timeout = True
