[PATCH] libmisc/rtems-fdt: Update to support 64bit addresses
chrisj at rtems.org
chrisj at rtems.org
Fri Oct 7 04:23:44 UTC 2022
- Add support to get the parent address and size cells
- Propvide support to get a reg prop address map
- Change getting a set of properties to uintptr_t
- Improve the debug mode of the ls command to print all props
Closes #4729
cpukit/include/rtems/rtems-fdt.h | 99 +++++-
cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c | 350 ++++++++++++++-------
cpukit/libmisc/rtems-fdt/rtems-fdt.c | 214 +++++++++++--
3 files changed, 529 insertions(+), 134 deletions(-)
diff --git a/cpukit/include/rtems/rtems-fdt.h b/cpukit/include/rtems/rtems-fdt.h
index 62db32e912..3919593582 100644
--- a/cpukit/include/rtems/rtems-fdt.h
+++ b/cpukit/include/rtems/rtems-fdt.h
@@ -64,6 +64,21 @@ typedef struct
rtems_fdt_blob* blob; /**< The blob the handle references. */
} rtems_fdt_handle;
+ * FDT Address property. It is an address an optionally a size.
+ * Only 32bit addresses and sizes on 32bit machine. Ignore the upper
+ * 32bits.
+typedef struct
+ int node;
+ uint64_t address;
+ uint64_t size;
+ int address_cells;
+ int size_cells;
+} rtems_fdt_address_map;
* The following are mappings to the standard FDT calls.
@@ -165,9 +180,13 @@ typedef struct
* The blob cannot be unloaded as it is referenced.
#define RTEMS_FDT_ERR_REFERENCED 104
+ * The property length is invalid
+#define RTEMS_FDT_ERR_BADLENGTH 105
#define RTEMS_FDT_ERR_RTEMS_MIN 100
-#define RTEMS_FDT_ERR_MAX 104
+#define RTEMS_FDT_ERR_MAX 105
* Initialise a handle to a default state.
@@ -334,6 +353,39 @@ const char* rtems_fdt_get_name (rtems_fdt_handle* handle,
int nodeoffset,
int* length);
+ * Retrieve the offset for the first property for a node.
+ * @param handle The FDT handle to the current blob.
+ * @param nodeoffset Structure block offset of the starting node.
+ * @return int The offset of a node's first property.
+int rtems_fdt_first_prop_offset(rtems_fdt_handle* handle, int nodeoffset);
+ * Retrieve the next property of a node relative to the property
+ * @param propoffset Property offset to search from
+ * @return int Property offset or end if less than 0.
+int rtems_fdt_next_prop_offset(rtems_fdt_handle* handle, int propoffset);
+ * Retrieve the property value, name and length of name given a
+ * property offset.
+ * @param name If not NULL set the pointer to the name string.
+ * @param length Pointer to an integer variable (will be overwritten) or NULL.
+ * @return const void* The node's value data.
+const void* rtems_fdt_getprop_by_offset(rtems_fdt_handle* handle,
+ int propoffset,
+ const char** name,
+ int* length);
* Get property value based on substring. Identical to rtems_fdt_getprop(), but
* only examine the first namelen characters of name for matching the property
@@ -585,6 +637,14 @@ int rtems_fdt_next_node (rtems_fdt_handle* handle, int offset, int* depth);
const char* rtems_fdt_strerror (int errval);
+ * Return a parent property given a node offset. Travel up until found
+ * or the root node is reached
+bool rtems_fdt_get_parent_prop_value(rtems_fdt_handle* handle,
+ int nodeoffset,
+ const char* name,
+ uint32_t* value);
* Return a property given a path.
@@ -600,7 +660,7 @@ int rtems_fdt_prop_value(const char* const path,
int rtems_fdt_prop_map (const char* const path,
const char* const propname,
const char* const names[],
- uint32_t* values,
+ uintptr_t* values,
size_t count);
@@ -609,7 +669,7 @@ int rtems_fdt_prop_map (const char* const path,
int rtems_fdt_get_value (const char* const path,
const char* const property,
size_t size,
- uint32_t* value);
+ uintptr_t* value);
* Get the number of entries in an FDT handle.
@@ -631,7 +691,38 @@ int rtems_fdt_entry_offset(rtems_fdt_handle* handle, int id);
* Helper function to convert the void* property result to a 32bit unsigned int.
-uint32_t rtems_fdt_get_uint32 (const void* prop);
+uint32_t rtems_fdt_get_uint32(const void* prop);
+uint32_t rtems_fdt_get_offset_uint32(const void* prop, int offset);
+ * Helper function to convert the void* property result to a 64bit unsigned int.
+uint64_t rtems_fdt_get_uint64(const void* prop);
+uint64_t rtems_fdt_get_offset_uint64(const void* prop, int offset);
+ * Helper function to convert the void* property result to a uintptr_t
+uintptr_t rtems_fdt_get_uintptr(const void* prop);
+uintptr_t rtems_fdt_get_offset_uintptr(const void* prop, int offset);
+ * Find the address cells property in parent nodes.
+int rtems_fdt_getprop_address_cells(rtems_fdt_handle* handle, int nodeoffset);
+ * Find the size cells property in parent nodes.
+int rtems_fdt_getprop_size_cells(rtems_fdt_handle* handle, int nodeoffset);
+ * Get an address space property.
+int rtems_fdt_getprop_address_map(rtems_fdt_handle* handle,
+ const char* path,
+ const char* name,
+ rtems_fdt_address_map* addr_map);
#ifdef __cplusplus
diff --git a/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c b/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
index 76f5cd7dbb..0bf6c84208 100644
--- a/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
+++ b/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
@@ -127,32 +127,6 @@ rtems_fdt_get_value32 (const char* path,
size_t size,
uint32_t* value)
- const void* prop;
- int node;
- int length;
- node = rtems_fdt_path_offset(&cmd_fdt_handle, path);
- if (node < 0)
- rtems_fdt_check_error (node, "path lookup", path);
- return false;
- prop = rtems_fdt_getprop(&cmd_fdt_handle, node, property, &length);
- if (length < 0)
- rtems_fdt_check_error (length, "get property", path);
- return false;
- if (length != sizeof (uint32_t))
- printf ("error: property is not sizeof(uint32_t): %s\n", path);
- return false;
- *value = rtems_fdt_get_uint32 (prop);
return true;
@@ -185,7 +159,10 @@ rtems_fdt_shell_ls (int argc, char *argv[])
bool debug = false;
int arg = 1;
size_t path_len = 0;
+ int total_entries = 0;
int num_entries = 0;
+ int max_name_len = 0;
+ int name_offset = 0;
int i = 0;
while (arg < argc)
@@ -220,10 +197,15 @@ rtems_fdt_shell_ls (int argc, char *argv[])
++arg;
- if (!path)
+ if (path == NULL)
path = "";
+ else
+ if (path[0] != '/')
+ name_offset = 1;
/* Eliminate trailing slashes. */
path_len = strlen (path);
@@ -231,45 +213,99 @@ rtems_fdt_shell_ls (int argc, char *argv[])
if (path_len > 0 && path[path_len - 1] == '/')
path_len--;
- /* Loop through the entries, looking for matches. */
- num_entries = rtems_fdt_num_entries(&cmd_fdt_handle);
- printf("Total: %d\n", num_entries);
- for (i = 0; i < num_entries; i++)
+ /* Loop through the entries to get the mac name len. */
+ total_entries = rtems_fdt_num_entries(&cmd_fdt_handle);
+ for (i = 0; i < total_entries; i++)
/* Add it to the result set. */
const char *name = rtems_fdt_entry_name(&cmd_fdt_handle, i);
size_t name_len = strlen(name);
- if ((name_len > path_len) &&
- ((strncmp (path, name, path_len) == 0) && (name[path_len] == '/')) &&
- (recursive || (index(&name[path_len+1], '/') == 0)))
+ if ((name_len >= path_len + name_offset) &&
+ ((strncmp (path, name + name_offset, path_len) == 0) &&
+ ((name[path_len + name_offset] == '/' ||
+ name[path_len + name_offset] == '\0'))) &&
+ (recursive || name_len == path_len + name_offset ||
+ (strchr(&name[path_len + name_offset + 1], '/') == NULL)))
+ ++num_entries;
if (long_path)
- printf ("%s", name);
+ if (name_len > max_name_len)
+ max_name_len = name_len;
else if (name_len != path_len)
- printf ("%s", &name[path_len + 1]);
+ if (name_len - path_len > max_name_len)
+ max_name_len = name_len - path_len;
- if (debug)
+ printf("Total: %d of %d\n", num_entries, total_entries);
+ /* Add it to the result set. */
+ const char *name = rtems_fdt_entry_name(&cmd_fdt_handle, i);
+ size_t name_len = strlen(name);
+ const char* print_name = ".";
+ if (long_path)
- /* Get properties if we're in debug mode. */
- int proplen = 0;
- int offset = rtems_fdt_entry_offset(&cmd_fdt_handle, i);
- const void *prop = rtems_fdt_getprop(&cmd_fdt_handle, offset, "reg", &proplen);
- const void *prop2 = rtems_fdt_getprop(&cmd_fdt_handle, offset, "mask", &proplen);
+ print_name = name + name_offset;
+ else if (name_len != path_len + name_offset)
+ print_name = &name[path_len + name_offset + 1];
- if (prop)
- printf(" addr 0x%08" PRIx32, *(uint32_t *)prop);
+ printf ("%-*s", max_name_len, print_name);
- proplen = 0;
- if (prop2)
+ if (debug)
+ /* Get properties if we're in debug mode. */
+ int printed = 0;
+ const int noffset = rtems_fdt_entry_offset(&cmd_fdt_handle, i);
+ int poffset = rtems_fdt_first_prop_offset(&cmd_fdt_handle, noffset);
+ int address_cells =
+ rtems_fdt_getprop_address_cells(&cmd_fdt_handle, noffset);
+ int size_cells = rtems_fdt_getprop_size_cells(&cmd_fdt_handle, noffset);
+ printf("cells(a:%d s:%d) ", address_cells, size_cells);
+ while (poffset >= 0)
- printf(" mask 0x%08" PRIx32, *(uint32_t *)prop2);
+ int plen = 0;
+ const char* pname = NULL;
+ const uint8_t *pvalue =
+ rtems_fdt_getprop_by_offset(&cmd_fdt_handle, poffset, &pname, &plen);
+ if (pvalue != NULL)
+ int b;
+ if (printed > 0)
+ printf(",");
+ ++printed;
+ printf(" %s %i:", pname, plen);
+ for (b = 0; b < plen; ++b)
+ if (b > 0 && (b % 4) == 0)
+ printf(" ");
+ printf("%02" PRIx8, *pvalue++);
+ poffset = rtems_fdt_next_prop_offset(&cmd_fdt_handle, poffset);
@@ -283,9 +319,11 @@ rtems_fdt_shell_ls (int argc, char *argv[])
static int
rtems_fdt_shell_wr (int argc, char *argv[])
- uint32_t address;
- uint32_t offset = 0;
- uint32_t value;
+ rtems_fdt_address_map addr_map;
+ uint64_t offset = 0;
+ uint32_t value;
+ int fmt;
+ int r;
if ((argc < 3) || (argc > 4))
return rtems_fdt_wrong_number_of_args ();
@@ -296,18 +334,30 @@ rtems_fdt_shell_wr (int argc, char *argv[])
else
- offset = strtoul (argv[2], 0, 0);
+ offset = strtoull (argv[2], 0, 0);
value = strtoul (argv[3], 0, 0);
- if (!rtems_fdt_get_value32 (argv[1], "reg", sizeof (uint32_t), &address))
+ r = rtems_fdt_getprop_address_map(&cmd_fdt_handle, argv[1], "reg", &addr_map);
+ if (r < 0)
+ printf("error: invalid reg address map: %d: %s\n", -r, argv[1]);
return 1;
- address += offset;
+ if (offset >= addr_map.size)
+ printf("error: offset out of range: %" PRIu64 ": %s\n", addr_map.size, argv[1]);
+ return 1;
+ addr_map.address += offset;
+ fmt = addr_map.address >= 0x0000000100000000ULL ? 16 : 8;
- printf ("0x%08" PRIx32 " <= 0x%08" PRIx32 "\n", address, value);
+ printf ("0x%0*" PRIx64 " <= 0x%08" PRIx32 "\n", fmt, addr_map.address, value);
- rtems_fdt_write (address, value);
+ rtems_fdt_write (addr_map.address, value);
return 0;
@@ -315,8 +365,10 @@ rtems_fdt_shell_wr (int argc, char *argv[])
static int
rtems_fdt_shell_rd (int argc, char *argv[])
- uint32_t address;
+ uint32_t offset = 0;
+ int fmt;
+ int r;
if ((argc < 1) || (argc > 3))
@@ -324,12 +376,25 @@ rtems_fdt_shell_rd (int argc, char *argv[])
if (argc == 3)
+ if (r < 0)
return 1;
+ return 1;
- printf ("0x%08" PRIx32 " => 0x%08" PRIx32 "\n", address, rtems_fdt_read (address));
+ printf ("0x%0*" PRIx64 " => 0x%08" PRIx32 "\n",
+ fmt, addr_map.address, rtems_fdt_read (addr_map.address));
return 0;
@@ -337,11 +402,13 @@ rtems_fdt_shell_rd (int argc, char *argv[])
static int
rtems_fdt_shell_set (int argc, char *argv[])
- uint32_t address;
- uint32_t value;
- int mask_arg;
- uint32_t mask;
+ uint32_t value;
+ int mask_arg;
+ uint32_t mask;
+ int fmt;
+ int r;
@@ -354,24 +421,38 @@ rtems_fdt_shell_set (int argc, char *argv[])
mask_arg = 3;
+ if (r < 0)
+ return 1;
return 1;
if (isdigit ((unsigned char) argv[mask_arg][0]))
mask = strtoul (argv[mask_arg], 0, 0);
else
+ mask = 0;
if (!rtems_fdt_get_value32 (argv[mask_arg], "mask", sizeof (uint32_t), &mask))
return 1;
- value = rtems_fdt_read (address);
+ value = rtems_fdt_read (addr_map.address);
- printf ("0x%08" PRIx32 " <= 0x%08" PRIx32 " = 0x%08" PRIx32 " | 0x%08" PRIx32 "\n",
- address, value | mask, value, mask);
+ printf ("0x%0*" PRIx64 " <= 0x%08" PRIx32 " = 0x%08" PRIx32 " | 0x%08" PRIx32 "\n",
+ fmt, addr_map.address, value | mask, value, mask);
- rtems_fdt_write (address, value | mask);
+ rtems_fdt_write (addr_map.address, value | mask);
return 0;
@@ -379,11 +460,13 @@ rtems_fdt_shell_set (int argc, char *argv[])
static int
rtems_fdt_shell_cl (int argc, char *argv[])
- uint32_t address;
- uint32_t value;
- int mask_arg;
- uint32_t mask;
+ uint32_t value;
+ int mask_arg;
+ uint32_t mask;
+ int fmt;
+ int r;
@@ -396,25 +479,39 @@ rtems_fdt_shell_cl (int argc, char *argv[])
mask_arg = 3;
+ if (r < 0)
+ return 1;
return 1;
else
+ mask = 0;
return 1;
- printf ("0x%08" PRIx32 " <= 0x%08" PRIx32 " = 0x%08" PRIx32 \
+ printf ("0x%0*" PRIx64 " <= 0x%08" PRIx32 " = 0x%08" PRIx32 \
" & ~0x%08" PRIx32 " (0x%08" PRIx32 ")\n",
- address, value & ~mask, value, mask, ~mask);
+ fmt, addr_map.address, value & ~mask, value, mask, ~mask);
- rtems_fdt_write (address, value & ~mask);
+ rtems_fdt_write (addr_map.address, value & ~mask);
return 0;
@@ -422,12 +519,14 @@ rtems_fdt_shell_cl (int argc, char *argv[])
static int
rtems_fdt_shell_up (int argc, char *argv[])
- uint32_t address;
- uint32_t set;
- uint32_t value;
- int mask_arg;
- uint32_t mask;
+ uint32_t set;
+ uint32_t value;
+ int mask_arg;
+ uint32_t mask;
+ int fmt;
+ int r;
if ((argc < 4) || (argc > 5))
@@ -442,25 +541,39 @@ rtems_fdt_shell_up (int argc, char *argv[])
set = strtoul (argv[mask_arg + 1], 0, 0);
+ if (r < 0)
return 1;
+ return 1;
else
+ mask = 0;
return 1;
- printf ("0x%08" PRIx32 " <= 0x%08" PRIx32 " = (0x%08" PRIx32 \
+ printf ("0x%0*" PRIx64 " <= 0x%08" PRIx32 " = (0x%08" PRIx32 \
" & ~0x%08" PRIx32 " (0x%08" PRIx32 ")) | 0x%08" PRIx32 "\n",
- address, (value & ~mask) | set, value, mask, ~mask, set);
+ fmt, addr_map.address, (value & ~mask) | set, value, mask, ~mask, set);
- rtems_fdt_write (address, (value & ~mask) | set);
+ rtems_fdt_write (addr_map.address, (value & ~mask) | set);
return 0;
@@ -468,13 +581,15 @@ rtems_fdt_shell_up (int argc, char *argv[])
static int
rtems_fdt_shell_tst (int argc, char *argv[])
- uint32_t address;
- uint32_t test;
- uint32_t value = 0;
- int mask_arg;
- uint32_t mask;
- time_t start;
+ uint32_t test;
+ uint32_t value = 0;
+ int mask_arg;
+ uint32_t mask;
+ time_t start;
+ int fmt;
+ int r;
@@ -489,37 +604,50 @@ rtems_fdt_shell_tst (int argc, char *argv[])
test = strtoul (argv[mask_arg + 1], 0, 0);
+ if (r < 0)
return 1;
+ return 1;
else
- if (!rtems_fdt_get_value32 (argv[mask_arg], "mask", sizeof (uint32_t), &mask))
+ mask = 0;
+ if (!rtems_fdt_get_value32 (argv[mask_arg], "mask", sizeof (uint32_t), &mask))
return 1;
start = time (NULL);
- printf ("0x%08" PRIx32 " => (value & 0x%08" PRIx32 ") == 0x%08" PRIx32 \
+ printf ("0x%0*" PRIx64 " => (value & 0x%08" PRIx32 ") == 0x%08" PRIx32 \
" for %ld seconds\n",
- address, mask, test, rtems_fdt_test_timeout);
+ fmt, addr_map.address, mask, test, rtems_fdt_test_timeout);
while ((time (NULL) - start) < rtems_fdt_test_timeout)
int i;
for (i = 0; i < 10000; ++i)
if ((value & mask) == test)
return 0;
- printf ("0x%08" PRIx32 " => 0x%08" PRIx32 ": timeout\n", address, value);
+ printf ("0x%0*" PRIx64 " => 0x%08" PRIx32 ": timeout\n", fmt, addr_map.address, value);
return 1;
diff --git a/cpukit/libmisc/rtems-fdt/rtems-fdt.c b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
index bea01dbf78..4ec54ca20f 100644
--- a/cpukit/libmisc/rtems-fdt/rtems-fdt.c
+++ b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
@@ -782,6 +782,27 @@ rtems_fdt_get_name (rtems_fdt_handle* handle, int nodeoffset, int* length)
return name;
+int
+rtems_fdt_first_prop_offset(rtems_fdt_handle* handle, int nodeoffset)
+ return fdt_first_property_offset(handle->blob->blob, nodeoffset);
+int
+rtems_fdt_next_prop_offset(rtems_fdt_handle* handle, int propoffset)
+ return fdt_next_property_offset(handle->blob->blob, propoffset);
+const void*
+rtems_fdt_getprop_by_offset(rtems_fdt_handle* handle,
+ int propoffset,
+ int* length)
+ return fdt_getprop_by_offset(handle->blob->blob, propoffset, name, length);
const void*
rtems_fdt_getprop_namelen (rtems_fdt_handle* handle,
int nodeoffset,
@@ -987,11 +1008,29 @@ rtems_fdt_prop_value(const char* const path,
return 0;
+bool
+rtems_fdt_get_parent_prop_value(rtems_fdt_handle* handle,
+ int nodeoffset,
+ const char* name,
+ uint32_t* value)
+ const void* prop;
+ int plen = 0;
+ int node = rtems_fdt_parent_offset(handle, nodeoffset);
+ if (node < 0)
+ return false;
+ prop = rtems_fdt_getprop(handle, node, name, &plen);
+ if (plen < 0)
+ return false;
+ *value = rtems_fdt_get_uint32(prop);
+ return true;
int
rtems_fdt_prop_map(const char* const path,
- uint32_t* values,
size_t count)
rtems_fdt_handle fdt;
@@ -1006,10 +1045,9 @@ rtems_fdt_prop_map(const char* const path,
for (item = 0; item < count; item++)
- const void* prop;
- const uint8_t* p;
- int length;
- int subnode;
+ const void* prop;
+ int length;
+ int subnode;
subnode = rtems_fdt_subnode_offset (&fdt, node, names[item]);
if (subnode < 0)
@@ -1025,40 +1063,70 @@ rtems_fdt_prop_map(const char* const path,
return length;
+ if (length != sizeof (uintptr_t))
rtems_fdt_release_handle (&fdt);
return RTEMS_FDT_ERR_BADPATH;
- p = prop;
- values[item] = ((((uint32_t) p[0]) << 24) |
- (((uint32_t) p[1]) << 16) |
- (((uint32_t) p[2]) << 8) |
- (uint32_t) p[3]);
+ values[item] = rtems_fdt_get_uintptr(prop);
return 0;
uint32_t
-rtems_fdt_get_uint32 (const void* prop)
+rtems_fdt_get_offset_uint32 (const void* prop, int offset)
const uint8_t* p = prop;
uint32_t value;
- value = ((((uint32_t) p[0]) << 24) |
- (uint32_t) p[3]);
+ offset *= sizeof(uint32_t);
+ value = ((((uint32_t) p[offset + 0]) << 24) |
+ (((uint32_t) p[offset + 1]) << 16) |
+ (((uint32_t) p[offset + 2]) << 8) |
+ (uint32_t) p[offset + 3]);
return value;
+uint32_t
+rtems_fdt_get_uint32 (const void* prop)
+ return rtems_fdt_get_offset_uint32(prop, 0);
+uint64_t
+rtems_fdt_get_offset_uint64 (const void* prop, int offset)
+ uint64_t value = rtems_fdt_get_offset_uint32(prop, offset);
+ value = (value << 16) << 16;
+ return value | rtems_fdt_get_offset_uint32(prop, offset + 1);
+uint64_t
+rtems_fdt_get_uint64 (const void* prop)
+ return rtems_fdt_get_offset_uint64(prop, 0);
+uintptr_t
+rtems_fdt_get_uintptr (const void* prop)
+ return rtems_fdt_get_offset_uintptr(prop, 0);
+uintptr_t
+rtems_fdt_get_offset_uintptr (const void* prop, int offset)
+ if (sizeof(intptr_t) == sizeof(uint32_t))
+ return rtems_fdt_get_offset_uint32(prop, offset);
+ return rtems_fdt_get_offset_uint64(prop, offset);
int
rtems_fdt_get_value (const char* path,
const char* property,
size_t size,
- uint32_t* value)
+ uintptr_t* value)
const void* prop;
@@ -1081,7 +1149,7 @@ rtems_fdt_get_value (const char* path,
return length;
- if (length == sizeof (uint32_t))
+ if (length == sizeof (uintptr_t))
else
*value = 0;
@@ -1119,3 +1187,111 @@ rtems_fdt_entry_offset(rtems_fdt_handle* handle, int id)
return handle->blob->index.entries[id].offset;
+int
+rtems_fdt_getprop_address_cells(rtems_fdt_handle* handle, int nodeoffset)
+ if (!rtems_fdt_get_parent_prop_value(handle, nodeoffset, "#address-cells", &value))
+ return -1;
+ return value;
+int
+rtems_fdt_getprop_size_cells(rtems_fdt_handle* handle, int nodeoffset)
+ if (!rtems_fdt_get_parent_prop_value(handle, nodeoffset, "#size-cells", &value))
+ return -1;
+ return value;
+ const char* path,
+ const char* name,
+ const void* prop;
+ int plen = 0;
+ int poff = 0;
+ int len;
+ memset(addr_map, 0, sizeof(*addr_map));
+ addr_map->node = rtems_fdt_path_offset(handle, path);
+ if (addr_map->node < 0)
+ return -RTEMS_FDT_ERR_NOTFOUND;
+ addr_map->address_cells = rtems_fdt_getprop_address_cells(handle, addr_map->node);
+ addr_map->size_cells = rtems_fdt_getprop_size_cells(handle, addr_map->node);
+ prop = rtems_fdt_getprop(handle, addr_map->node, name, &plen);
+ if (plen < 0)
+ if (addr_map->address_cells == 0)
+ return -RTEMS_FDT_ERR_BADOFFSET;
+ if (addr_map->address_cells < 0)
+ if (addr_map->size_cells > 0)
+ addr_map->address_cells = 1;
+ if (addr_map->size_cells < 0)
+ addr_map->size = sizeof(uint32_t);
+ addr_map->size_cells = 0;
+ len = (addr_map->address_cells + addr_map->size_cells) * sizeof(uint32_t);
+ if (len != plen)
+ return -RTEMS_FDT_ERR_BADLENGTH;
+ switch (addr_map->address_cells)
+ case 1:
+ if (plen < sizeof(uint32_t))
+ addr_map->address = rtems_fdt_get_offset_uint32(prop, poff);
+ poff += 1;
+ plen -= sizeof(uint32_t);
+ break;
+ case 2:
+ if (plen < sizeof(uint64_t))
+ addr_map->address = rtems_fdt_get_offset_uint64(prop, poff);
+ poff += 2;
+ plen -= sizeof(uint64_t);
+ break;
+ default:
+ switch (addr_map->size_cells)
+ case 0:
+ break;
+ case 1:
+ addr_map->size = rtems_fdt_get_offset_uint32(prop, poff);
+ poff += 1;
+ break;
+ case 2:
+ addr_map->size = rtems_fdt_get_offset_uint64(prop, poff);
+ poff += 2;
+ break;
+ default:
+ return 0;
2.37.1
