[PATCH rtems-docs v2] user/bsps: Update riscv for PolarFire SoC
Padmarao Begari
padmarao.begari at microchip.com
Mon Oct 10 06:54:30 UTC 2022
Update the riscv documentation for the Microchip PolarFire SoC
BSP variant including information about SMP test procedure
for the Microchip PolarFire Icicle Kit.
user/bsps/bsps-riscv.rst | 126 ++++++++++++++++++++++++++++++++++++++-
1 file changed, 125 insertions(+), 1 deletion(-)
diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
index 5faa87b..48e7ee7 100644
--- a/user/bsps/bsps-riscv.rst
+++ b/user/bsps/bsps-riscv.rst
@@ -8,7 +8,7 @@ riscv (RISC-V)
riscv
-This BSP offers 13 variants:
+This BSP offers 15 variants:
* rv32i
@@ -38,6 +38,8 @@ This BSP offers 13 variants:
* frdme310arty
+* mpfs64imafdc
Each variant corresponds to a GCC multilib. A particular variant reflects an
ISA with ABI and code model choice.
@@ -47,6 +49,9 @@ be started im machine mode.
The reference platform for this BSP is the Qemu `virt` machine.
+The reference platform for the mpfs64imafdc BSP variant is the Microchip
+PolarFire SoC Icicle Kit.
Build Configuration Options
@@ -68,6 +73,13 @@ configuration INI file. The ``waf`` defaults can be used to inspect the values.
``BSP_FDT_BLOB_SIZE_MAX``
The maximum size of the device tree blob in bytes (default is 65536).
+``BSP_DTB_IS_SUPPORTED``
+ If defined to a non-zero value, then the device tree blob is embedded in
+ the BSP.
+``BSP_DTB_HEADER_PATH``
+ The path to the header file containing the device tree blob.
``BSP_CONSOLE_BAUD``
The default baud for console driver devices (default 115200).
@@ -94,6 +106,13 @@ configuration INI file. The ``waf`` defaults can be used to inspect the values.
Enables support sifive Freedom E310 Arty board if defined to a non-zero
value,otherwise it is disabled (disabled by default)
+``RISCV_ENABLE_MPFS_SUPPORT``
+ Enables support Microchip PolarFire SoC if defined to a non-zero
+ value, otherwise it is disabled (disabled by default).
+``RISCV_BOOT_HARTID``
+ The boot hartid (processor number) of risc-v cpu by default 0.
Interrupt Controller
@@ -124,6 +143,111 @@ They are initialized according to the device tree. The console driver does not
configure the pins or peripheral clocks. The console device is selected
according to the device tree "/chosen/stdout-path" property value.
+Microchip PolarFire SoC
+The PolarFire SoC is the 4x 64-bit RISC-V U54 cores and a 64-bit RISC-V
+E51 monitor core SoC from the Microchip.
+The ``mpfs64imafdc`` BSP variant supports the U54 cores but not the E51 because
+the E51 monitor core is reserved for the first stage bootloader
+(Hart Software Services). In order to boot from the first U54 core,
+``RISCV_BOOT_HARTID`` is set to 1 by default.
+The device tree blob is embedded in the ``mpfs64imafdc`` BSP variant by default
+with the ``BSP_DTB_IS_SUPPORTED`` enabled and the DTB header path
+``BSP_DTB_HEADER_PATH`` is set to bsp/mpfs-dtb.h.
+**SMP test procedure for the Microchip PolarFire Icicle Kit:**
+The "config.ini" file.
+.. code-block:: none
+ [riscv/mpfs64imafdc]
+ BUILD_TESTS = True
+ RTEMS_POSIX_API=True
+ RTEMS_SMP = True
+ BSP_START_COPY_FDT_FROM_U_BOOT=False
+ BSP_VERBOSE_FATAL_EXTENSION = False
+Build RTEMS.
+.. code-block:: shell
+ $ ./waf configure --prefix=$HOME/rtems-start/rtems/6
+ $ ./waf
+Convert .exe to .elf file.
+ $ riscv-rtems6-objcopy build/riscv/mpfs64imafdc/testsuites/smptests/smp01.exe build/riscv/mpfs64imafdc/testsuites/smptests/smp01.elf
+Generate a payload for the `smp01.elf` using the `hss-payload-generator <https://github.com/polarfire-soc/hart-software-services/blob/master/tools/hss-payload-generator>`_.
+* Copy `smp01.elf` file to the HSS/tools/hss-payload-generator/test directory.
+* Go to hss-payload-generator source directory.
+ $ cd hart-software-services/tools/hss-payload-generator
+* Edit test/uboot.yaml file for the hart entry points and correct name of the
+ binary file.
+ set-name: 'PolarFire-SoC-HSS::RTEMS'
+ hart-entry-points: {u54_1: '0x1000000000', u54_2: '0x1000000000', u54_3: '0x1000000000', u54_4: '0x1000000000'}
+ payloads:
+ test/smp01.elf: {exec-addr: '0x1000000000', owner-hart: u54_1, secondary-hart: u54_2, secondary-hart: u54_3, secondary-hart: u54_4, priv-mode: prv_m, skip-opensbi: true}
+* Generate payload
+ $ ./hss-payload-generator -c test/uboot.yaml payload.bin
+Once the payload binary is generated, it should be copied to the eMMC/SD.
+`FPGA design with HSS programming file <https://github.com/polarfire-soc/polarfire-soc-documentation/blob/master/boards/mpfs-icicle-kit-es/updating-icicle-kit/updating-icicle-kit-design-and-linux.md>`_.
+Program the eMMC/SD with the payload binary.
+* Power Cycle the Microchip PolarFire Icicle Kit and stop at the HSS.
+* type "mmc" and then "usbdmsc" on the HSS terminal(UART0).
+* Load the payload.bin from the Host PC.
+ $ sudo dd if=payload.bin of=/dev/sdb bs=512
+Reset the Microchip PolarFire SoC Icicle Kit.
+Serial terminal UART1 displays the SMP example messages
+ *** BEGIN OF TEST SMP 1 ***
+ *** TEST VERSION: 6.0.0.ef33f861e16de9bf4190a36e4d18062c7300986c
+ *** TEST STATE: EXPECTED_PASS
+ *** TEST BUILD: RTEMS_POSIX_API RTEMS_SMP
+ *** TEST TOOLS: 12.1.1 20220622 (RTEMS 6, RSB 3cb78b0b815ba05d17f5c6
+ 5865d246a8333aa087, Newlib ea99f21)
+ CPU 3 start task TA0
+ CPU 2 running Task TA0
+ CPU 3 start task TA1
+ CPU 1 running Task TA1
+ CPU 3 start task TA2
+ CPU 0 running Task TA2
+ *** END OF TEST SMP 1 ***
griscv
2.25.1
