Cygwin tools failure
Ryan Long
ryan.long at oarcorp.com
Tue Oct 11 18:26:49 UTC 2022
Cygwin has been unable to build the tools for awhile. This has been due
to an array subscript being a char while building DTC. The maintainers
didn't see an issue with the code itself, so it's going to go on being
broken for awhile I guess.
Joel recommended commented out the building of DTC through the RSB.
After doing so, I'm running into the following error. I was building
AArch64's tools. Disabling DTC and building with my Debian WSL instance
built it just fine.
[ 48/258] Compiling rtemstoolkit/elftoolchain/libelf/libelf_align.c
../rtemstoolkit/elftoolchain/libelf/elf.c:34:35: error: ‘LIBELF_ARCH’
undeclared here (not in a function); did you mean ‘LIBELF_ERROR’?
34 | .libelf_arch = LIBELF_ARCH,
| LIBELF_ERROR
../rtemstoolkit/elftoolchain/libelf/elf.c:35:35: error:
‘LIBELF_BYTEORDER’ undeclared here (not in a function); did you mean
‘LIBELF_ERROR’?
35 | .libelf_byteorder = LIBELF_BYTEORDER,
| LIBELF_ERROR
../rtemstoolkit/elftoolchain/libelf/elf.c:36:35: error: ‘LIBELF_CLASS’
36 | .libelf_class = LIBELF_CLASS,
Waf: Leaving directory
`/home/rtems-tester/rtems-cron-6/rtems-source-builder/rtems/build/rtems-tools-d0a65c72d1a170637258eb19f7d3e433be7c3c86-1/rtems-tools-d0a65c72d1a170637258eb19f7d3e433be7c3c86/build'
Does anyone know a fix for this?
Thanks,
Ryan
