docs not building to PDF
Frank Kühndel
frank.kuehndel at embedded-brains.de
Thu Oct 13 15:39:13 UTC 2022
Hello Sam,
Hello Chris,
Sam, your mermaid diagram misses only yet another loop. Beside of that
it looks really good and impressing. I like it very much. Many thanks
for your efforts and help.
Unfortunately, I made (yet another) mistake and did not recognize that
you already reproduced my diagram before I went through all the efforts
to produce an own new graphic and put it into a patch. I apologize that
I do not use your image. I simply have the patch ready now and do not
want to start over again.
Chris, I created a ditaa diagram as you suggested but in the end I
figured that it misinterprets the "=", "|" and "*" characters in the
text. I do not know how that can be prevented. I tried to replace them
by similar looking Unicode. That worked fine on OpenSUSE but failed (as
I presumed) on FreeBSD.
My current solution is an activity diagram in plantuml. Hopefully this
solution is acceptable. I will send the patch to the mailing list next.
Greetings
Frank
On 10/13/22 07:19, Sam Price wrote:
> Subject:
> Re: docs not building to PDF
> From:
> Sam Price <thesamprice at gmail.com>
> Date:
> 10/13/22, 07:19
> To:
> Chris Johns <chrisj at rtems.org>
> CC:
> Frank Kühndel <frank.kuehndel at embedded-brains.de>, Thomas Doerfler
> <Thomas.Doerfler at embedded-brains.de>, Development <devel at rtems.org>
> I forgot the loop backs. from close back to open.
> On Thu, Oct 13, 2022 at 1:12 AM Chris Johns<chrisj at rtems.org> wrote:
>> On 13/10/2022 4:06 pm, Sam Price wrote:
>>> example
>> https://mermaid.live/edit#pako:eNqFVG1vmzAQ_iuWP6UVaZM0DQGlkSYlnSJ1bUUyddmYkAlmYQEbGVP6sv732cdrtSrj0z0v9p19h1_xjgcU2ziTRNJFRH4JkvQfRy5zWcQi6WeBjVYqiEgcvVAUR76iSu2WyoKLwzu94lyWHBaRsNGOs0yi3Z4IdJrwnEkv5RGT6Aq5-FyGMnXxzBfnc0GzPNZ0cggi0UMdr4HW3sp5-PYV_amiz010dwKrdbWwAnK2e2mqh8CC9OdiFxsN7OZoSGez_LL2rlc3y_V2rWJvs71fepvrzf36iMlZflp4D85qs2xNLvZjvjtk6lquhoPR2CgiFvAC8Nh4pMLnGXVxWd6JPgJPKRPcRmGgitegh1Ii9wa685zF3e3NFimboES1xH-WNFMujXpqgYECIonn52FIhaHT6zw87HV5dFJvsItV7s5NAdb7aIPOXHxYxYNTV1GISNK2DIBtHQZkb3xHs-XQho6as6pv3XnRdSfBu-4C_sflMji8nmYUqkn0ynA202A-L2WEfpz-RP3-HFUzXtMVbKRmnFu5osACQ16LAEq6GsVGqTCIbVG1fIyBJeVc1GKJQNCtrGkdHyfh2rsKECCXTTiSvuhmL4CG1tY0gP_S7ypomQ9KKLOXnGreb9XetnkVDefSQ4ANnFCRkChQD9mrdrlY7mmi_i5bhQENiRoZ9fOzN2UlueTrZ7bDthQ5NXCeBu3Th-2QxJliU8K-c57UJgWx_YqfsD0cDs6soXk5mlyMR2PTmkwN_Kzo0dn4cmxZg4FlTqeTifVm4BfYQNkvLNMyzUvLvJhMp6b59hcqM78E
>>> SVG link
>> https://mermaid.ink/svg/pako:eNqFVG1v2jAQ_iuWP0GVtrxDIoo0CTohdaUCJsaWKXKIMzKIjRynKWX899mXV7SK5dM9L_adfRef8IZ7FFs4kkTScUB-CRLevrZsZrOABdKNPAtNVRCQffBO0T5wFZVqz1QmXOwu9IyzWbgbB8JCG84iiTZbItBNyGMmnQMPmEQPyMb30pcHGw9dcT8SNIr3mg53XiBqqOI10MKZzlffvqI_WfS5iGZ1WK2rhRWQs9xLUzUEFqQ_G9vYKGA1R0HOl5MvC-dx-jRZrBcqdpbrl4mzfFy-LK6Y5pNPY2c1ny4npcnG7p5vdpG6lodmo9UxkoB5PAHcMV6pcHlEbZyWV9dH4AfKBLeQ76niNaihA5FbA82c-Xj2_LRGyiYoUS1xj5JGyqVRTS0wkEckcdzY96kwdHqdh_u1Ko_q-QabvcpduSnAeh9t0JmTD6tYzfMqEhFIWpYBsKzDgOyF72q2GNpQUWOW9a06L7ru0LvoLuB_XDaDw-tpRr6aRCcNh0MNRqNURujHzU90eztC2YzndAYLqRjnUs4osMCQ5yKAlM5GsVAyDGJZVC5fY2BJOhe5mCIQdCtzWsfXSbj2qgIEyGkTrqRPqtkToKG1OQ3gv_RFBSXzQQlp9pRTzfut2ls2L6PhXHoIsIFDKkISeOohO2mXjeWWhurvslToUZ-okVE_PzsrK4klXxzZBltSxNTA8cErn76cPBD2nfMqxNYJv2Gr2Wzcmc1-t9Vrd1qdvtkbGPio6NZdp9sxzUbD7A8GvZ55NvA7bKDsbbNv9vtds9HtNcxm-_wXZ4G-ow
>>> I couldn't figure out how to get semi colons to work
>>> new lines are kind of a pain also.
>> You are a legend (pun intended) :D
>> It is looking goo but Frank has the final say.
>> Chris
>>> stateDiagram-v2
>>> initbsd:Initialize libbsd
>>> initNetwork:Initialize Network
>>> mkDir:const char *mount_point = "/tftp"<br/>result = mkdir( mount_point,
>> S_IRWXU
>>> | S_IRWXG | S_IRWXO)<br/>
>>> mountDir:result = mount( <br/> "",<br/> mount_point,<br/>
>>> RTEMS_FILESYSTEM_TYPE_TFTPS,<br/> RTEMS_FILESYSTEM_READ_WRITE,<br/>
>>> "blocksize=1024,windowsize=4,verbose" <br/>)
>>> openro:fd = open( path, O_RDONLY )
>>> read:bytes = read( fd, data_buffer, sizeof( data_buffer ) )
>>> readclose:result = close( fd )
>>> openw:fd = open( path, O_WRONLY )
>>> write:bytes = write( fd, data, size )
>>> writeclose:result = close( fd )
>>> umount:result = unmount( mount_point )
>>> rmdir:result = rmdir( mount_point )
>>> state fork_state <<fork>>
>>> [*] --> initbsd
>>> initbsd --> initNetwork
>>> initNetwork --> mkDir
>>> mkDir --> mountDir
>>> mountDir --> fork_state
>>> fork_state
>>> fork_state --> openro
>>> openro --> read
>>> read --> read
>>> read --> readclose
>>> readclose --> umount
>>> fork_state --> openw
>>> openw --> write
>>> write --> write
>>> write --> writeclose
>>> writeclose --> umount
>>> state umount <<join>>
>>> umount --> rmdir
> -- Sincerely, Sam Price
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone: +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
