[PATCH] TFTPFS: Adding missing diagram
Fri Oct 14 01:47:55 UTC 2022
I have built HTML and PDF and it looks is fine. Pushed.
Thank you for updating the image and sorting this out. It is appreciated.
On 14/10/2022 2:41 am, Frank Kuehndel wrote:
> From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
>  filesystem/trivial_ftp.rst          |   8 ++++--
>  images/filesystem/tftpfs_usage.png  | Bin 0 -> 47217 bytes
>  images/filesystem/tftpfs_usage.puml |  37 ++++++++++++++++++++++++++++
>  3 files changed, 43 insertions(+), 2 deletions(-)
>  create mode 100644 images/filesystem/tftpfs_usage.png
>  create mode 100644 images/filesystem/tftpfs_usage.puml
> diff --git a/filesystem/trivial_ftp.rst b/filesystem/trivial_ftp.rst
> index 3ef8bba..b8e1ae4 100644
> --- a/filesystem/trivial_ftp.rst
> +++ b/filesystem/trivial_ftp.rst
> @@ -275,16 +275,20 @@ repository):
>  Usage
> -The following diagram shows how the TFTP filesystem is used by an
> +The following diagram usage_ shows how the TFTP filesystem is used by an
>  application.  The mount point can be any directory.  The name ``/tftp``
>  used in the figure serves only as an example.  The final unmounting and
>  remove directory steps are optional.
> +.. _usage:
>  .. figure:: ../images/filesystem/tftpfs_usage.png
> -  :width: 90%
> +  :width: 75%
>    :align: center
>    :alt: TFTP Usage Diagram
> +  TFTP file system usage
>  Mounting the TFTP Filesystem
> diff --git a/images/filesystem/tftpfs_usage.png b/images/filesystem/tftpfs_usage.png
> new file mode 100644
> index 0000000000000000000000000000000000000000..5faa72f7222268a0742c50f32fa30380a3be33e7
> GIT binary patch
> literal 47217
> zcmb5Wby$>L+ci#zAl)E{bV!4eN_PuL!_b}5jg%6C(jX-zQVt=V64EW*NaxTE-$uOe
> z=Xu}n_<qOn;~$2Lnd{nd?tQLvt+glgrJ at uDDhVna92|y>w73c!9DElX9HKD_0=San
> z*c$|XJ#m)MbT+nk at USs8bB2>LwKH`zbT&1iF!G?VaCUa!XJd1)F|>1bv9)0}wztJ$
> z=X(SPhrnm~O4IqD>u~VkHts1!s>=40?AX2^TK#zU at GCyj#!|)SsZ`=JGT_JFBUXwM
> zdsHlKWAgmvm#b60Y+-HN7`k4i)!N<KiyiL<BHY(W=9UUh_hY34RQ3_YWHY5(^=J9h
> zOJ1-y&^qhgQ-6>8pa5eLMrq6!w-AZLxPZBlZbIdD^yz0w$8d9ut#Px<*CupWi+|;*
> zU|>3Q^mp4Q;VcFRQ=(_}U;O!xYLrPvbaUF#rc20=k*UY@&$}=Kmw#ad`m%3d_yxG{
> zj6tek_x&%zzDhmOu?@C5>8sGT{Vi<KgPH3!HE#Tv!+#U$`^SzwOlmD$83a$nrTfGC
> zkVo{Pao!azuilYGlOob(j3vML5Kn*pP+h?(LsBX<*vRR<5n1&38)6xJNsnj)yE-JI
> zea%b_oPkq?2fQ}YVR3z7t=+L2c~(VVohcVz%{TIt!LEyv5b1ICYdI9VZUSGD#4KGt
> zBG`$G8FmcKw?44zc0cx&QhMVRcX=rA-7 at TJN`%zsQDJP!AKW_X-JC`JHR-CvS=8f%
> z<1DMAu7#K{s(j&)K4+|d7{)<~KOlIUh|(z&D;JlMfid{lKbJ8Y{W-gG3)yj6AEv{4
> znuFw1`5f+)570M?wPz91Fb)lE13}h<9yvYC at e0c%*Hz=nCyxHf$3;1j9>%Wr^0j9}
> z+s>1px>}=N=|8;8`pD~KAZ~G;dE^if=27L`W<=m>KzNv}XB)J}FJ(=OtGb<$h$EDr
> z2)#nU*yktFSNXvW2loa}MqK2TJ7g>Mf#xf<n|35+C#lzRPBKNzTnehM=XzPXXnXaB
> ze>E2|OB}>?ZI4W!<U}hZiXh*^mp~9V7RT at OOOoBFT97oVqNN+Yd7d&mb(EH5C}~!I
> za3MJNZndv^HO*;fA*KJaFEz<4{7Qi;N}7i0YvMD1aquc0dm#?|E~IK^3Kgf)k_ghk
> z4HYj9LxIxZhMExIKxAleI~l3!qNQn~)x_Ot!AA>1U>lB}-m5z^J>5JpLwY}WhwD;m
> zhgd11Y^a(G3f3lPW4}Mpml)Y7Vi=tqsjHQQ{u*>*4c_kW_hQ~A!tJ!8s_W9{S^V&`
> z{1JTD*B7;4-<_ptmFwb_o=Ijl6TE*aQ0D2ev1VCYa3YK)KDLuwtr&H4%4SI(C9RIV
> zpw>6EvYLLVgH^a?IiQ61{mBi~x#&2k`~2LWEL2Y_g9o#YZ)5hXV5pBOikYRkzy_(}
> zn%9BQB6{cIET+!*g`MuOMiv59UCj>j*b at O>MkXdE9-foIEUBRe>L_MP at BtUc3Rb(e
> zp+u?o;TPA-L03>LI73yjtY;(&uCClT at g^8JkmWqmJt>#ho3UCibUR>yh1rQj7jHFo
> z(mpw`KYbd5B3Jqr1?m{9?ls at 5>_u{zWsM-25`$B82#Z|XEl at 8AEvB&!fia5dO(h2m
> zsNvOxnxkrM9j^PLo^aRl*wQyg7lLM>#~m+ZhREvelasIdixOTe90fL6kAJo-DJikE
> zv?Ph3<KfYmOr{ws3j=ooW1aQ*oI?qZbN955y2Yv?=Ox49;vy#}XK86E!y8&H*&vPT
> z^}W>E8aDL8Og8kyCDm|3rs>IhK9zboDzx<U=4NIpaB`)wpxLTBmKZQk4jZNqxJ+lw
> z!2+h;@hig$Jo*7oo&=M;dsV0zsYIlM_x-^PL9w%og at uKU4Ku>{)|QQBdbD&uO>@Dt
> z^XAL@?ys-ju|KBm`N<a-6Ej^n(f#2uS=-O%;D%^%!AA90pZ9DedlH&>qLrTf`Z9my
> z>CI5XWU&)HKR at 5mAziMW8W%^qt%|#zB<>!UY)6+9NW_Cn at Ip3GVJS9rqNmHU!~4OP
> zY<w$KSXiW}8&V$xA0NN<8<xd0l7HJ^!Vf7?F1MofyO9|w at ER%5c*>#dCg8t4Q|qSJ
> z8BH5Tz@(o4s?%xJsMSJF=7GgvCJv;+=FG~|^J}&+WpaXs#3M8>cYHTDH}lX+JKE!&
> znQz`_r9Ky~!k_aiWtt_|hjQo?A8F>P1n<n~n48n at J?Z$OQsjQNT*I5KS8FD8Qx_BW
> z_I{<+2r<U#e4v|rtM$jZ#iphv7z`E^6x7or|DT2uLf{8z<-S}UjqPz+o59OO*CQ|m
> zZ?}K=;NP)1c43H!TwyufIzZW at l=f(MAfq~cj`!FRHvf1y7t8OI-R0-|g{S6`xTSlv
> z#T7{RyszeeM4ilThGw0{UYv}WcD-=h8pnKQHd at G0q_atac(Sz~(M&GDf4-a$^8iZo
> z9E1)}Qm}^q+r}%x2#5Xw2nWRPiVMMSf)a%WgRHsEVlZ~4SKm;>SY!m3_J!T7eA97f
> z%t8by4>ovUNI1VcY)V7lCrat;p#POp|9(b>T$9$Ts5lq6+Tw+kmAC9k1fuS=6Uw)-
> zHvwb(*f9Vxd at kr)R_Qj3O3)S0tkv8>2 at AzD?4T>0VAG#%|HjR(QJ}8X(V0NO%J}pt
> zD&^Dk=6qoqo%))wH}HD>X)_VA1scC!R=s3ih%=D_tB|f>k&BJ3NVl3(S-GIZ at DjT<
> zKSW96+ok+hq90%0Nxc^TBpPPWaPPHph?>4vkzjfN_agz4LY9y`jl#sUpQI7rkp>HD
> zYcF;iH^24ZLS&8!7S!xY at gXH)$QV$)aKHVfs*j1uUc_kL%-bR*!Dv3+32fG1o0J3}
> z4i at PYTwdnd&2Rr6_E_mrrm%P1cS9q*JSbwTr`5&Qvm|>_g)IA9Rd|F^?ZwIN+#78K
> zM51SwLm%TtYu#$Ao!Su_^nH$S{^^F?0>R^FU%fzJ7OxS~+s(ef+C0}T&+kp<$#C7?
> z;N$D`M00j>LQD;ogKxYnMGGB+wx4W{;q0*?Oc}Sk5?kVOTm6E4dS;1zkp`EkEQmA_
> z9bLg?JBj`7nf-N`Hd%-4bHD3!d(56hjue<|Y1Zu`&k$mw2xqx0d;>02feSI)e)yZe
> zM(=I<;*(Z6V}O>u1_S)1E+s&xX5guT{6QYA9KM|`LWQrKJFS*(kj6tRw}?s=DTQTa
> z(UsKGQQqYPd!&2!upu&pL<?$fWy!W1Ydx{HhtnrxJXU99l;bT5yv<R;ZNcto`c=*l
> z**V>=ZPN}#n0s-!J0T-0R&Er`z$n<?-*)wTJ<_Z7GaB>r`=zvU#c%=p7M4oDGONKD
> z7o-u*1@?qo&aq%>)>;yRCgb3q!pAEG3_BnQWHMgb%r&IiNlV}MXdfS89ML{fS#8Jj
> zrgVpp(InKR|IL$8Z4Pfb(XoMnm-BIUxeB*$EFGzL(r}I6#GhK4c{hf+ at BP~Jrqm&7
> zs6L`}ShJWQgQ*F%Zm7jT`nF$vvRIKS@$1BDl}d_|&y*e#9cIm8<<{*MgzNkmCCf0d
> zmX;1V?Sd2N`e-5ohL5?>2_%l#xSA(nUgT$MP8yiT2Rqp**JgP;Wrd5gTc6;Jt%d#9
> zM5h1b19M93VT)&Z50I(Pm6WS0{ZBj_{fw>y<{IW4sFe-n^dm5N%N)-}5`}#e)O;u%
> zhL!YLcn56Xmx}AmxD{*HK{czDd(;<7g|)Rw&cj4CqLC!r<I1o at OwG-We}JsxW{-(N
> z`i$kfB-_l;_=s+O!v0KN7p?U}%^#|+^#ty1uFlTS&XMbb8ZrmsZd-54%3+9;1<xun
> zXOE>>A$el+s<DmI>8AE~cuvMa{F4<njdN&mX8S3;Q&&k@&boSq(KexJ2j<&XK?R=~
> z!!;+4)U&gcLW*dZLSc-44}#jxd01H$b5u%TEbQzb{ojV_1%Hoz;~2bCksqG at +=gn;
> za<TCB&Kmq7q9>w{s12=_OprzbHg%z7Rwu{_ii(mQgbyD+eEgWT)fr_Op(t;jPwvgw
> zJYP+%`V at rsc?xwO{%UyH&+07X0jxEQ!v`gCCbT#ZJqZeFJ3Bjdb;1BH10<%!prCs%
> z>G=6cszexw>=f2V*W0w;`BjV7w9qwAEIfMsg;zg?tB*|Jjjyo%=f7>=&^G!gQAg)M
> zSYSMVKSMWwtK4t7vT5@=ZtAwxDP(;(=8P{11cVJ}wRD0s#^Q*}HL1<DRo8zgH*JP~
> zWLU>cMlqL?rk#L**kx&bT<pGSP~(goN}~^u)#y-*_06?=dV7I8TPTg(pDSlYQ3y)3
> z?rryvuao1%qrqaOv3|1aYA3$@c$GWv+Lr{%gBQ7-KS1D>gZxo?9~UesiJZuNtP_iq
> zsTv1(s6oL{*7icBP at EZUlnH$^Q)gI>3xnADtmMMzO6#+k6G;CzbPTo;k%du`^`SzV
> z=q-Thv@}Yf7!hB8iLHOBEtho<bv-3jD@%Wd7fJ(mS((w1iIK1>9?5H`RYvRzliK0A
> zAnB)3(vJAx(R#}>eQIi3ggY6vGmLd*ue{D*hA&Y8v{?A<m-4k23A%}U4pzDJH)_z3
> z4bTwkQcwGtIDZwgH8Gax%@DBp1ZQqGAl6B$uhY(mP<3hqX(TbQ{evvYhJ`Q_G3p-g
> zpS_=3=9NSiY;e+;Ec=6bHd?_p;r)b})#Y${=G)mlmQCJ#^>hF`^{0}lw(W2`<#8aX
> zDrX;Vx^#2jf14rV9oMUu0-(}dooy`0W`#U%gQ9^1&)sH7eoE-cD03EKf1&m_u#@a>
> z1w=+z^X*GsDqD`lNYjPGHoR-xt~dO7qztd=UCCUonlOuw?@g5U-7x9leYaE!^j%wu
> z at g@C!b~bbaA8HbS0#*EyEVG`Ess}J8Bm#B5TDanK`VyJk$(1hA&xU2Mqb`CP0-jD?
> z&^{TycBR0g3w?5j8%Kl>h^1WKW=D?L+`iM^o@<nU-XZy6cX~!It3U1h>ahv!9zKOm
> z|GKJ~e{tt#Am at 7242_exy9-Iq1*@v(_ukHsl~tjMeBWp{8_=qJjr(6!RYHnsh9%rx
> zFlPk3WVEI)THo_sF40dleVSK5F`!<BzA6|I*NhIOs^fp>dpw6)Cs^nEG5yShl=o(D
> z4`5IH8T!_rKfmPUSU&qSty{x^k%tXhEmi`>l-UrBPd_$E))F}U4P%@kK$Xzd)s>W#
> z1S<`xnC3UQp?}(CQm%uwlhvS+Z(oe<%F_a8eM*$sI)(qjo1Co81$b+-)l7-wpFS&G
> zrc|b}>5i*b*jNhAMA?pT>!VMF-H0|Vf=Vp|z+M!Cva)rpMH=JVyO(0!1cmwt2*#!#
> z1VqFD1Y50DmH?nlSOmz^w4vU<MPG$~PrN6l#b;9A8pzlUP9R{4|6OK at mXEEihJTO>
> z>xo$P0T}g?2w{~O6B9G?{d+JNT3T8|egvU3xC<i>oXh4p3IOiBOd;xtk$@`nn5ip@
> znYr7J<iGay<@d5gfl5Hpd;vy~=;AOrY{Z0?5g{QVm24uCL`a at PsiMSho7vOM#GS8R
> zw6rUf=jj6VJhGyrvm*d-vi6%vC$2CgPldKWH5{jfftL2OM7X5;MCo$D`g#q!mhR_|
> zz1;;=k--8l!fI=4%UX3RalKCLG#b1o8hoBpXyfzb$tSJOdLNX3{v5oO^G0Kja$%vn
> zwTR^TsQLQPdWX~RpIB|-wR3fO7e14IH_v?*Tm8qY{PeFD-XXpYaM={RIT|B>njO!i
> zVK(r2hs(<SfkJPeqUU-Je=@g^VV%x=PY*+iV;o}|K$o22er9jSC>q=R{rwjf79Ko!
> zkd&14?=YFLLj3dp17IoLW48!2pV$cbdZVvtHO^v@@)j#3)4jzsy#I^e*<xpvC$j$0
> zi>mg+^%inL`BV;LUJ6<hV`MsdKaE<~BV??|kUd5|aa{=qSaapvPEbTs6H*f^#ONZ`
> zt%d<#t^~dV^U*j4cB8YU{=o{=W|}u4)!t$aH{++&he+40)1SHNk at za(_vcs~D(#BQ
> zdPxGs;H<&cQ~GBv+6vy}&-sQ+)>&FWiJ^_xB>s(CA7$ehiTQ&(1~Z=slh%HIARf=K
> z at WZGlhQ5WA$Bx1T5Az;&<M{?PJoJ)sk at 1^exK#4N!SFkb&8rFXEUCz?aPgoN6n7Cx
> z at hT#=pQR}r9M;$*2j<W0Qn276PT*dX9=f6_{^;$+$YAXj2K%gfkOuw0)8A^sZ!_wf
> zUA-^O?03HqFvdzWSuA0nwuZ8sT%4_ at ZY?i&UyRqJRcn`bi7GA#&lfr_hdp@$UubfT
> zEkgjuS{zP$nfm<Q#;DJAPm=V&qjfDU<bfBIq(lCCoewjX9GANex7Jy7VaxrZYw-Xu
> z55UP}QsO~mR>EK#_e!}T2m3>BvcG;E8E5xJK~O5TU+(G;^1QixI?|GLdUat%DN%eX
> z%sf)-YTG8ef`zjhl&e7c7Ud93fI+QN`mt(mL;p9v;<clp93ST7*)@XK9M_pqq}*%1
> z!i6WyK~Ca_8#_DK7rXfN(STAY!0QNbZ;O6p(So3R$>(LaWBBp`JhelaLx%m?z9|O5
> zX(v5(jf-^~g4hp1!Bl^tk34*5wMb~!SH5wlO(`iRh3!bbGMG4(s9x~ri)}MJb}8Z8
> z<<{nic_k&A6aIMgm>`yrWyMgYGbN~9x8wX;cwKGY<(hl!wYz!NB7t=_GhO|AuR(O|
> z4=x>fU?Ni29C+WQ9rt2uVrH?mH+j`C3R0k6?r}i(>zf|g<&e(j<YZD_hQdw1GgBg5
> zsQ!oDF(~z-e(U>rk~tc)H!AZ)ejx*lHaC0ihQ9(@N_?)p(Fgo?A*j!>Id+2{AcD32
> zDpwI>AsO)nWZ~v=wIz~lj at OO#lMosQL|IVO;PXu&)+}XRG&9rf(8Q(_d`$0UhKv&4
> zt7B`>4DY8%yeg!y*ue!MD-L#A;S*n`Q)QcC1%S<|uGg|oTz4Typu~%!zMy)u{1nAZ
> zC=5flGz=!o32H3*ftYt6oGYERGB2#?CrSl9pH+b^Ww|TP<6>J86tVjc at 0H~?-?JG9
> zHCYlvbAgk^u3TXBh2s3`iwQGDGA@@~jmkG~;Ql^ZjNTlI#WumZ+b5I``)Ip;c{nrT
> zwY9|`2_B{wq_O(4Z*N#LDGkyf&%fQty?1o_^03kId<=k`b+FbVFpqAYWvYxxO}snn
> zRH~@JtBpj3PKs4i$KHKBS9u3Yk|U*a#Ev#i6lW6;l|-U&R(pS-%78yrX`f4q8!eB&
> zFp_k*>4(VCzn;flad_4JAiqm54#OL}Mzo1(MlsnW^ET6t`>Mw6%r-LXwg$ejc`a1u
> z%3je~+r>#1Yh6j<jHKzW;Yp1CXDH>(m99vRMx{awM_RneuN21&i`G)!uYIlY!OwZl
> zaHa94h?0_WkqPmTK};nB^dPC2LSh=9%Qr2v>I9S at N`7Ur4MnD}sVx+eIY|WyVO#mS
> zrST<PpM?)8?EZ8)37Z3C$?xC4C$jj5 at x0w=V0o2k>wUr@#HQ;Ez<Pvuu<^N-b5l}W
> zH}vPd{n|(EYfb45x>e8_hhQ(#R4;{BzT^zWYE{f{`q~@ch-%z50-NI&y_ at E%7i48+
> zwGb9zuJiB}YAel1O__vOnb|LUJ;g8JK`fkqQag)UXGBUCX(zS%TVFVXDeol+A0?w^
> zszd~&fPesm3Lny98wEf at e5}5i*=rjb at aV=rNMO3s;0<d(_1FD_;3G}iCRxI;XHF2Y
> zzXjwo8<~#j40f(r88LM-gPW-!7?!+ at 2oG1yd&S&`ijHm~ZeWyvMkX at fAnI23OJax&
> zlkW9y#?!%^HBDzW{)c)BHnd5!%>`v)IO<u0CMG5{^z_sfVej9gV_^{mu(j&?V`lvW
> z;k}ffmkwC2 at jFx0;G~AKO0;Ks{nvvv6E~`>t3hTC$!EVQaaNF)hQrLv%KCxSs=I(m
> zJu_6Rxd~&_kapuu{D0pAf?kSJc(2dsAsQ>iimU_iw*DCltj2GddmR%Qj~_$t9VY(Q
> zut?hC=rn~O4K11X+RSE8$t3 at S;lZ0CKFZ$GV>CJ;0ug(oKb+Swab+5Afo{&bvFj at t
> z!4DdH5L}t~KUWTPsFBiSVPP0sS3FFALA1*3_H;;>0IN6A)yc4XeUiJpS_$c~EEYx7
> z5-nJBVX|b)<U4~qm!mTXkRR&Vk2ao*eFFGD6+Dt at V>AOj$BQ&L`9vwb2nir~)R{9~
> zsbC%JY`L;%=~BE~Al}x%{YtGQd8h~jR#Rr;bvbk8t#3((D-(I!qJpvlf{Wyc(^a!q
> zpyEle at ba`Q{ukb>&2H=J9d3LJhq%Do<Q*So5Ozx376p2FS(nBT?}UXo!CzF>k)R<3
> zo1+=;JFM*2zoEz4D3M!5=}O&JHTZfbWb<6j1-XCfnh89p2cO%n8Kfa8Rx!Tb?-9F>
> zo9X;^(j{vtb41?NX`kMDiW|oS3G~e416weeG?{?C8^(-PlssMcxN`Y<wt}XEt$i5&
> zy>FCL3tTsQ`bnFygXI?)!)_Y8QT(2hNh94{l*wnvuF=b at 1swkEbiK|n`nG5m3;FG*
> z1 at Q&%&hlT>8g#XnKXReI{)&(4m=FQ;+`SwDRDdYkU;KXExo^U$75@){N7U1G8L|)L
> z7SfkRKI<X`a})b5e*nbp)W}!3hLcW{(yc3+UCo-^Rf?@^NP`Ac_jOcloDLcEAN1}H
> z(EHrF3Fm~%zxbWVgEiY_ at BFlHW`^s0D{pRBL>+f-47_C|MbMNGCAm(JVHhdR%1*ED
> z%fH~=D at mTN_O?_A&zn;^>Vk8T4cmHPEm1f7FLw7Pis>{-D5rDBLm2NkV;Zq4ue*K2
> z^;RQ+yN~-7#attJf@$i_sk?X%YuL_jV`Jmtp&>wA+kJbnyKgK}_p^bYChtPC!3lIK
> zT;~qE<NpV{$1@{pS}z=RrhA}Pa_17Vta!zPCROzp4*3LAxF2xG$;PFmq$DLh>4qEC
> zcCUBaL9GD{eCV!L?ZrPtaVH%KnP#CT2cQElSwj&Ki9lMdw;X<Z$y%bo_K_J2V0u)+
> zd(4oBBqSuHq~UPf&vo8nnN<=($^f9>seMe|by9eg5))JBkinMD`g(9r`w&;YGL+u5
> zl_BE};dkvCdG)f8=jvBGwgEsLhIez2jx`27!Ap2cBA3AGatb@~yK<R!XYoX%=^h{R
> zLqR0}Ul3m<gtxIUcq|!7>3)6G*Lkl|PwpsBIy1bB&Y0iL6)M$-WBSxDo9n%vgof&z
> z^~4`N{XWVpBzDHTbTp>Fe{9F7X!GmqY>`gr;t(t3J&WoJ-vTyu`5MbdX5&C~{<{C7
> zqo0VU=)3-8GBbFG*~{@@s@(c`%Dx8LKHCVr1_GU0fqK5q$r%8m#JVlhEpm5UHDwb{
> z$X_lw at jLJFYP#FsYC+RDo>6Uox|*1}{Ijr4Ki~!dK3qglRYB1HZV`l_Q{l}ephx6J
> zZC>qYdLLs0lJ%CT`v8Ci!xm4W8*c(Pw-bIBEBPc&e2 at HBdxuA40gV<)@;xNq$%CKS
> zXkN_!u%A%&RFZANs9;iOZs(>kw_3{9^nGU2lUP|&xHD3)y**XKW=WjaUAP}bRgrBK
> zI<nE^d&M6nC#QI=IDQRS?zZwZTkeUR9vI0|B`-TW`->MZKu&%7R23CxH6eBHyzjZ5
> z;ElID1TuMfhBxO~z at h>;bY2Goo<dqSy~(k<GbU1=zWSFAhIXCNmYT-jw4N5I75tn;
> z2!V at gkKA^@JRL98GS;rN%j9}QC1W+HL(v8ASzOn4-?iNGK*_)3AxVw6iowk_nSZWY
> zfuOO+^z?LdO9H%!T!LczafR)H at _tubdWpIvMoKKCZXe^Rvx?{l4h|Ex)Wxau^->JZ
> z&rQxs at 8O8bB(mqu<i at gn-2>cnHl=b&Fm0NofH6>C5VGCk+M2m;Gjn?Qdx^&=4%jxO
> z=ppy!ybrkcdc?QZm(_4c{jQV3#*ya{&6O3^N8yX$RbU`8uwS)Blly5I<;W7C6QD#>
> zt%ydHTWhrI%UF7M2B-Z(!hxK%994+$z8nvJd00NSK??1j-dA|WzuiV;y+EF^%&xu0
> zZOyGur!`AgM<@dXldia{Xf=9^V6|-6KBxhhjgO*H1Yc8a)t`7$wcK&#y~q36^VS@%
> z4E|GPkh;%4xIbY(eF{&Sl%y;vi&vo_lqZTuOSmhFMRCpzNzhtO_I+*8pH at ySd1yKn
> z&4 at Z<*1OV8(>)b5M%9U5XH*_p6|Lv#b;{1gclMmn+fc2WllZ}*!`5KdkI8 at m%eJs2
> z`?|r9?PZxCV at 6+_Kp`S7QS?(XV+}{g-g42lp5EoiDy50Jeq>!CR<lm-Q9a3quv0hB
> zV9UFciCQ<ZsrXmQYupmhZ<fv0Q6{JmL-O=KrxkBFaaP^6sd_JK+aEbCKLWj$mT2 at F
> z>YxDIzGYQi{CG#Oe at st*OkDL at 25*Lk$$nNI24nEu)~-7Z^lc!lM_O5V%&Oe{d#Mu!
> zW|2w<6dn_^qJvqL&pNsNROTu2PZ!>?d_Dug<v#S_9V!2l`1amj+toh%o!Kj8 at 9mM7
> z$e(l?o;0|z<v{8`ZDocXuMf43$PAsC#pre24vcu65yw<nF3;$1vgZvy1gjhT^aTu?
> z;h2dxf8`l2iMjGVvD6v<f>Bc7aiH;QLpYw-;-y<*<U~1wSUEAH!@-KjNWR)PwSvhy
> z4?L@}Z<wN5sL)FpN)8$m9QE7ETp{hnI0~fvzGB$&6TO;WRj&m*LMt&`eUhNvypV`k
> z`>?=3BE=-mS1DAnbn61I`Tq^t5RFo;`yX1z#1dGNl^L#zwgr7AbF&jquu)ZKzjy3&
> zFO*AD)lD`jc0Hj7>o(vvw1PB9$7T4IvwP`u20+&Ub9-E-H%b$eI{4+i>+P(_)oF8)
> za6+n15vjxk9Sl^VkQ(yrsLs-pmUnqYIy_Hei*HAS)t$>%=Zkq+s5_UlM!wgH3dA$7
> zFOKQr%(!SN(=8yw3FnxE?dI1Lwf?l(wfIk51)%-0SD)l;_IMtSN1)8-t1)3b9E!O*
> z at 9VdpUg`|gTA`K-C?<-DulHV#^Sn5*4++&$1>##W&yB}1Y_Ux>ncMdCbdRG`DBSO0
> z_+sw6abP)8BjY8gn2IYw at eBg2+G+LUY<^pXeIU at URvS)@SRNgnZ?bJql&Py+WQfhV
> zZTu3AX5av0!ifg$KaP<5vG}9)LmSnkd(!1S!X8Dd8UDr(LXVqw%hMuws at Aw6zP`Sm
> z^`2anHc1Hy3Gu0^&zvpT^!3-*H?RDzKyfJV4x)EFG7>Tj_BCdo9|&`xeEt2K#~Q6;
> zXF>T9Updm8>0_a5J=-5purD#iq+F(E3m=!htedR-QQUY#(}eP?*6XAlRC>Or3&Qnk
> zXcb<8Vqyuup!!T)TqySFp#BxvPWM%jB^hY&aS~RKX1JYCP9!K%S_AnANKW-$l}!2#
> zKoB8=*^fG&v>LrbX^}{L!MrzNckP@}e4+P%%ZPy*bLRUxnoZWFdJ&12huS6B#cA}l
> z;!<9<N7_>mvKL4e4c0<RaD!wO8W9P*`{(kzr1e(fv9jcQlqh=!Eshma&jshuefL}F
> zmEMl!t6`8f-lPSIVxJn<I<3a<HcYwnrC=4;+t1w(8d(&@_V8!Rk~&F<Wv*k!haTIq
> zzrT^z)<&6X at D=dg9KAuQ4a#bL;%e`ZC3zG?zW$>-zE}AE0__3MoOg4jtj%roQ9;^H
> zvPkaOqY~*P4&&3Fq%72W`gnE^bPPIG at 7r#baPCQBy!1U^mv+UEH?yF`ZM<~koV&k}
> z{gRHIrm$GPP}%zMn?~Wi43)B-H*NV9$7B_7cJdmRzfbjgJa6>fPXL96Y%jM(yW*fS
> z#Qhyl?$_^jF|Gd3l_imcT|bgVQu(=H>hO#*vV;)AFpVNT()S?*H#q)rb!0_964Q2e
> zb{4yFP>g}PC$T{5B-$KL$l~0n%42fZ{NNjbYg<}bcXr$bfr{6^?+4G~$tAw<M2-n1
> zB+oqY)nIM`%iF$jCbZ~ekXZgf>!b}dirYY#ntt3wJ>uuCXPfNDSB!$w()1y2TDzD!
> zr|k>2h(CA(u0X<zNolAGLd#?d9A6vG70 at Yf(u_yg^g1rw2K)u20VaC%+zr!E3-3|g
> zO9o_0V)gRHk?+~IqEZjLnrzzdQy=3`23Fy=l`5_j5Kcv65YADho?V_1yL$1Jl#F^`
> zpD{*@mpp(<L|41ldwZm_W6oQRFj}M4-j4j?qOeVdrr92AJ(4V{R7>%!RO_d7K*RlZ
> zGsYq6m at AZv7O}r=J8hqqMP}=w9${k(;ck{x;Byx%4%<m~nVQ*sdZowjL*zRSwkxmQ
> zLr+PRpF$!ZO%RE=0sfI!yyM_()fnQD^H>%xn}!yRP2op@!4wa12IA}+f4K}QWP5h<
> z`b-S(!?3}&ry764gcZWk{NhDe_>HaSZm22$r2O|&?7ewHqR3(rKb)8L<Lpv8*!4z1
> zCHh^Y_K4~b;j*Q`8ByzBUSmwZ>FpSljrLfXW(=8lPS|I0_8N`Z{LW=UM{;OB%<d1q
> zT}@;1*oY0Qf8oQQX*aW)%;l9-Ut~9TJ<{Yq(+WSx*0?2l{T{synY``*z#UDh(aDgC
> z$1ixBAzyNW>n<Jj7O-U^dTv8Mt5}+dkr5wy7w<;KV`yv~JZIKWsmOaHP<^?-%b5r|
> z8KA^y-uI|&=V6tBKXlg1=wajFucy<OGHfEPQ=)Hy{Oj%+Z=Sw-xHDt7Grecg0t9)J
> zd*EXP<h3k?>s(exGe=#gq2X9OLl1}!XY#|Ka=X=uDuPbk at zB0Bf#VNCn21g&e&b>c
> zt)n`EFD!>Xml*p5C20OIxazJb!4!^-a7Fd1b at qtyaSu42zX{;EA0KIfxf)#geQS#*
> zg_?xoQRcFh3D{Nv0!RGKE)8RY)VjKEPmTnOeb>G1sso^B9|aE}zy9fum|Q%)(8%{$
> zr3i#*J&p41WF4Zr*ZT at I=r=}czNJ<)N!UJ`#p^ze_|j8<76S<gscd_A4dDHAS8qg3
> zzJEmQX<mrbhaD_~B(*H{IX&q2;MA&92eDKKk-4J$)0)Gy at Y#Jfd~XF&6||0v>kE6z
> zrz<pY^g%xt&0x#cXx}y$az2u`qt5jPl^{rbZmj_669J=HLtKQmRdy>mx#`}gcX3bn
> z!+b6oVn5$?4M*VgLaBMS6lv}wpYMxT3?khl9X50KTL4w=pP+eS;E6g;;MEnI(VgJe
> zm5X+pM_oOzD-ro=Y2lpSDpf`>X`f;0<mHKAkkmEh$}wC1Jel+BTrG(>8Vcj#s$!6o
> z$2cwR_r*vO2zh?X{cV=5&Dv`W_yCc{yT9hsJM{Ium(0t<w)S|d`Ri%V-CkT6v})Px
> zJua?D{RVIsxvclmh?IBDI8jSQ0G7X;Iu0aVLg}%fN>w>ux%l~eHKIduzei?`z9qFR
> zf*MXvSY`IAA3J-n$iGCAZ5prD)XhIFNI-<blU86u(v`jRNn)qnUd)w&O0q4L-)ch<
> zY6lMwA2eqEt8-$rMXsW|HtS-643w%jzwbD~jbr$Qqlq}D%V&!>K+2bSo&ajbVrcuj
> z0Q9bPeLP5bw%C;r5Eqw~D|YU`FyTx>2W5D9nKssP<Vz3$u@?oB>x0J~uqS`2TcSfy
> zbO(J4d+m!FY;<wFEg~Yq7{|!Rr<FA*y|-{#$_mNQzab5oeNk?~F*gVrnd5!q7?AHc
> z274=rqDMK;#mmdf$*EGLZf<HSGXXxp56SosN$AFtB=3p?XhH}5VR%3j#{EMR3Uh-W
> zYHI4|&vj5SR})xZp2xqS%Jx1%#OeY)Cxg4rWbyK at e5)qnQe&G13^O9 at jR-av4<6v?
> zKkVq~>FMo_3urkrMXRIQYOhuOb?OneILp}Im)oc%J2y%dqt}X}{XyxVWm?1CRgG1v
> zdz|DYg-v@~8$70PYnIf9?0E;@2?VIS{*c8pVC~}2K_IY4AMv5j5}#^?{8nUvc>m!K
> zk+hB*NXQ(_miGbeaYv^3SPd>Bl1VX4PpwT`XYOAJ`xiBv!W+Old^BA<ue61Qo#X&x
> zR_l#bIY0QZ8Ql2j8`F}1^vmasG+m78)~EWo-QJglv*^VExm%u0urS-taKdneaL8J3
> zzxhqwhx!RAXx5o#Km-532t at EG4&OwZKMbNtl6Hw}IF<Ox72Llj0C_)Q;bWVtDKqyg
> z9dS)&WME5s#Yo`Ag9a$XtG-rNV3nY&3uSaZInkw=5s8Mj9*_(_iXl^dj7L69j{Q+U
> z=ca-da&t{?$VH+61V%?k&e<PS)YL64Ey0z%b!AA=OJD!t5vS;5bj1_<5`QI5CeA0W
> zByJ_{C!Qu=zj?DYab6j*ckTvn=;Y*7R$2<14Tk(g0L3YM>SHpph}rh%I=nKGLq&w)
> z<(M~)!OqAs4b9F!vw!~jd9VFhyGeU&du#h4@;#IO(MH=38g%!y>U<ugv>CzIe{id~
> z7yanJ90Ah%1Ye%gaeb)}R+IN2f at g~HficDdO8}<{Xy at TP!~BuBbnM;zT}86PO#SMj
> zbw#!Y<0~=0$hiSIp8!yKECO}MyU-4gy08;K?%k^FEU9xOPhhVCG;9oZ8?|I;_yFZ!
> z8ozJ1D*0;XwbsKMKq$89$C>kN#XT0L>XZYV96=m^m(X<9jA<J at Jk-Ix^BCDn;s0_3
> zXw_}^A5_9YldPLv<F^ZcZ)Kocs^iMI{$UKqHQsG84nO#aq~<0#2JZ*hH<n&;s!kv@
> zM7y}SmQx*b&FC>C#kJKdu}rf5`=2<s=Nf7m1<eXX^&7rKI;CVjUnLxIfQdj|V}s%5
> ztM(N!Wc?rIzs8QNE2MBp&dv0*`14!e06%!JO~zV{V3W0Y&f_66nrLqccOO|Gf!8N{
> zoSCWcPn2H2ZnBx at s-C02WOc-ez)4PU(%_Gk!K7#|P#in{0=PqbwE`#%o+oKbcUJFr
> z(XYV+Krwaz-znJ~&GXKYJx}Uu3*ByI;#9_d)(yi3b9I(KZU8SC)=WUlKTduYlZJ1N
> zVceRgRsX`}@H@~v3}~drb`q*tUjQm{s6?@}S{Eec%S#~nvp+g{wg!DL8GEC_e-q-$
> zIZ^F>)fCzKt;S)YDLHF5wULqRkY=h&Vh<HKP+z)nvCo_w(0jC>8p_f=hXTdpE2G<t
> z);Cp8huF;*9&PZ;neGC7UIOD`v;;!WI!zv)0`IAh0&-Bob}R|WGF3l at vv4&P#J-h$
> zq^(HRY%efcK0bongjQl~lN3_zW!3ycp2&Tp9I@*NmOt{?-RUsx{?+;?IIZKp&JcC{
> zlYgA26$#x7N0YPoLEk`nxzwbISzi4;e2Kqf>uNu#7*t-biwU(PXN~;&i}q&kwJ$|<
> z=l(&<CbIunvB<E|zicAwj7qztBVV25$VLIMoeH6LnpE?D`yEpJ$^Hp`SXEWk`}gk)
> z3z<<3Y^leZH-A5ObI~W(l+Y*scn(xIZz`?Fg5?$^%|!|WZc}QEYL1SMW at dCq#T8N3
> z3tT7P at 4MF%SHzJA#2*Etd3D9J^yWVQg7s+pSAm9(U at 9|~bpW^FI5M*y*}nv0a$0~L
> zS~VfWo~)~hxAt0$Sm+*$H9Qp9=Fo`F_aAOq$i(c-$aw&5TjSf-s#Emx!scEE at v(?g
> z!aZbUDM`uvkqyw;^=S$%k#D!GU_a9>EBNknt5O>NdKnu$6qER;?5FQ`sdMe*SPNxQ
> zrpD;*=od{B;Xqg!KZ1{tq)sKJVG4nr$NHxM&I6s~SG^<#TV0(CQ;FNI>vDI(_EaTe
> zfME95S4<G!YE~FvM9b3sW;-!)EP}Vg2)ZAHdYyb@(kc}%F=_*9w8xI_`zosJ5Ee@@
> zfPWhr#9%}&ZLNi8fH7n!GHjVd#`5jnpKgRo8ja+~-HO1QP@$j6{uyQz9~y76H%96=
> zMhcP=tK#fcKoPe!*C;X#SK9M`lXCn#w{GgACxKGJN&uq$-=<Q8UtO^tJL4r}AIQm*
> zxvb?kM-|2?J*$s<2AMElJ2|0Y>EE|t)#E3dnyTo%*@XUP((wIh6-0kW>0#dhdAK*Z
> zvGnzCU9sM#b!IJ2jCasGMvqy!Bb2deBAEy8)a;|FadSbvxVul6(czo?+sf!L<;BC<
> zs at H)+H}Xe^%vh%ZWxzVz+r>}8*Q(-9fO)oEX|Y!U47xUN;tUqs!b_OR7Pgb^8_en+
> zF1ECVPE5!&@t~Tpb(TI`7=cjL37T?vvI1)<;b0G7StJ*M+jO^n49|KS9<ipB?dikS
> zPn2~ejl4}n472w~OPYxG)A{g1kJkk92U?jlj^(WAyZeJQyh6d;wylX2Zh*?&KfjoV
> zjct2v(7@(}ueZ$|=Y=w*0sZ+PXc5N at 1u9vX5V~kfSP!ZB{voGqZN&X4I_+$2LO><<
> z9$)mb`QPs1lAND9r|~)c0>nvY=NyaXJX*eb-eR at i&D+b%L*RN)`1I at -VbiVcSm?4C
> z36{!b{r;XIk3HR+!Le^`$=7Q4>g9n3lfvr&%)lVjQA%{aTYLwj{ks>NoYhjLNPC3y
> zX%>wwMR(`l4$%Gsw1FgSIbHRm#Q6Eg=-BT?fSm8RB`K_2D7p!8OHsNHNVw|glpgmu
> z*#c{bW_R*+8N=<fsAp5y4TW!G?pNNA2ENZMg|{QFKq62hw8s2PF+TkP^ceVNMpC13
> z2fpb&1#6WQ53&ukt+UpTlmY}{Io|wQkLl_rL3-K`6}skq;d@#8pG%xtD|i1Z^U0Xc
> zeVLZFOgm*#YWxXi#fAgv<^HIB$M(xsbego^P3<RJile`T`~+PL+3=rk%F=aD|Nnns
> z#i7sOu1J)wNH+x(Y%twc9Jycab6LO;{`*pY>T}=TPg>smNj3o1f}Rz$r6hat3JIku
> z(Z_6C|Cw0Y7*o6d#|szU)g>A>-L>xAWV_gbJ4^hsTS>hHbNZI<UEkl8Em at WmR+e|u
> zKmT+$nl^|^YWeQx=a at g{67;{3;+3tmU?C%DVvvpsy2EthSFe4za0`IvpmOJ6OJu?`
> zJv0JiY40TcReg;HAgA!~D*uWHZNTxamcLZ(#Nj;xIK_yE2Nk*IXOQ~I*#@5hcfjc=
> z#pnEeVxSgqOae0zTxpJ6uCdot#Tk%Oyn#ssQ18wA@*v{oo9r~->eqaS0z#A9F2x!J
> zN-+~nJM3`!iK|Sz+^Po`Ln5JYBP4|2WGCnJzsU7cW(D{11Qe*5&ih>8!y&W>lvC?{
> z&9~!#!qbe8gdO+t=syk8xOSjE#oHBSIG?mWiWoDsJ2TPx8wM4SmtmD<rI-frtV=>p
> zbhy?|^-=_%7)sp7Cdz6{U_6k7>g5<y%RdvqHRYK^J8OnR8^6JvDiI6TC#7<<s=cx#
> zjDD6j5<=^O1L-uno5qRJZsyM8)=)%btevQs81J+F20|7R+i6~+N6h*STUbIio!xR^
> z3q)7qUx0ya3vdhiwS+fIov$0Lcz7yPpEp)}ok;DKYsl#R+_TE|{!c&I%4nueb_?j`
> ziQlw&0p at 5t_e>i7fmTqQR|E+ph8~MMK*RlZk?k9wv3*PUm*1VJ_u8EEQyS7qcwHCP
> z-6+hX><oX`R54QF)=7O>sp(VZ+HbkZ3^f6FvzEjhDam3~6Pn4C_-DnWb`rKT&4>>Y
> z$p0B}lhU5Mq5t=V*@fs2HiZdu1)xHaaAunWv7#cJ7FB4&JpNJh<*<@$e3iiuRUW9Q
> zW%KGqu410&@!`+zJEr#V+NV4!o}HWzx5Ll8>806sf9UdTeQZ37zTS6>Fo*e$C?Bc!
> zYu&3R+lCTa8?m&bI_|!{HM4}MT!JUMGHlQ=umc~QAGz1}vX at X5HI!93n)+oVMexAU
> zu5HU~Cf%+0ibP$%%h&GvOSirt+J`iC^M>uXGcz-Q>1D`<vjwIp({==^qm7a2Qd0;7
> zqV4KBG>}p6?eh*s3q$7$&}hK$v<{8X)6WT`Pd- at fYl9;MXB>)na;spO>7|qh!JD=j
> zRX=Op{4POSMZE7kGKDU-!o=xVwbvs_Vo*n4WcW9Tq8~Wzo4AABl;+`k`4=)qwXVIs
> z*B<n84<2aUA`;iF?I~p7(F1n3_uE5%2+ at XF+`})#6SNf>+Q9JE;C+ at mp2%+4lr0nZ
> zehD9y?feNTr+$^XJ{m38_1sNxBTUo<41`Go74<u!PZKW at -=Ac2-A$UA&I?0qpZ8>&
> zPk~?{bN at G<Qc9KU_7<=z6~_W^+;^V~jpma1zS><^0bqJs5|(-3srr5^TGO5dBoxD$
> zPe~7he;ROD)6kdYC~85^n#<3%8NP7<S}Sp+(NF51hm!W&)WJ)74w3w`{fanqVUYTq
> zfA8;<i8q<2Pdi1J2Bai24&LrcZ;)ifh9%l#s+WzvMF*?KLB_x~<^ueNU_bH&_^LqN
> z=XgxNz0GvLEkLW;WW~IEmYX<lxu|l|2;;fa3PZ*{F+QyYLO#>_6*Tks?=QdZRj)da
> zwIX9~xt{F{-nFRVokFKgHhkedY5_}(zw47Q#u@|yir6XoW$SM-VoIDuVTv-_smp#r
> z(q3{jasiU*Jk at ZJ#~w2JD{+)|f21vcBzP$>S`1uIgr8KcgH_`n<?sY%2miEw*5)lC
> ziOIuJHY@(aTS>d+Znv*!!&?D(1w~CURYis~k!ueDq2a!1jhlUH+GEB?;UmjlyGK3U
> za>hx33e*DjE-_lz6G_)l+iXG^Uur(BmD`Xa?V`wQc8~ay2<_-tpfg*+i}<gJ<TRvH
> zAbI9m_<<%+3lHl6BYc`p!8tuQ{DbYp{>VgG`}JP?0`NWpqLo<O`>pK!?L3aZWbyU|
> z<7F0}QVRKBcOOl*$o?NOx at W`;L3PtLeRvv5f42YogOD9j!c!CJerUtFwBuH}_1<pd
> z4I#wSGyY_6o%x$6!zi|xR)o>IZD5r4X*0&MNfL`=m!~ZQ7$fgMEvh;61_sKfeuUmh
> zW~QUb9Vbgj*0VM5|86V<=?(s)e;BOSkSRbfs7I|=Y!r2)+-Cnc`HIFO&rQz1DRA4q
> z;GfTRnj|Ivxxv3LdMi#_ENYAinYvVRnJY4UM|DaaUIC$8==wCztGBo(M=k+~?VnOE
> z$@FoyR(b3|1lU}3L{Th(b5C*q2tn*a#2M)m5WLy|`@o}rmrd4Mq?YJ{gpjFV*(|s(
> zXPIOfkwnH`bHZ_OPt$T=>fD?6^ol`y$dXb}%h^kU3XF3iww=f1jaoXeGCiyhi(h9B
> ze<qF-RQv-pI&CtZo0T+&`*wLgMPm!Tz2(!6(;vvY-)%2EO_pTqgP9>O2>j{&=64(E
> z7q*%_ZQORI_h;N{`;rdeD^9kjZqvOtpCpN~k;eGYKQUJpypz~wlc&1!w9NLk&?ZY#
> zwQ`mxC<R(b17YM*CO?}S0mFQTI8h=aGbKC at DuYKtk0)zf at MwI`mX|&VdMc?z?)`T&
> zx6v}?EZacWZ<wa3a&5leyS?c{MLD#+L+12^1lK*IEvNoCe9rI-co+XPZ#~%Q-Y%;a
> zr!CNXug+asyNMuQeOLQ3fWP=2GTXCR;)ZmEbyS^yQm?z at AX!=Bnb~Gh-=S)JEX9s_
> zJ#C9c|JvZyglmC%1dn}MySaJ+B8CKX&Uf<zqu`mzy$jD9kPE1()L-Q-hT_sJ6WgQv
> z at q0fey$gii3ipZuva+BaFi&Dh<w_ at Iv(e;2g6c)u%SKc#YXd3$Tf0J*YXgvI<0Pf@
> zNH`Bbwx5Ce(Y+dMe2B=dUO<(wfv!g^D81`9HvYR)#P<+_km|OHQXNfB(pm#;G*-r{
> z6ZCYBt*`U;AQ#=e-L-lEE-^^jT~_0uZkhKZrv?6pWLy2}(njFP4n#gNU{m;C4K=xK
> zsOIfL%)VEDRam(MJQWvb5qRX+faHJK at Uhx?T_waEi~KqbD$TAadwR at txlzFOO_L+W
> zmedmchK;?1sn9K)IrML?)*allJ2DZO+TXI#N`UAb5o+Q7X+Beu4f6l{FJ`B|eKbpd
> zb<6orUDA`9`N-SY`FbSZ=t`SaY&Gh<z>m1g|GnHlotL`^Hb)9ND{KSDQc{-8dLe`j
> z?uR`MJ{R)<KD6?v`Gd25%~Q3O!KkJ_-u&PcV at WG0OG8^h4g1}0W+_46Ri^7~F?{dK
> zv*d}xpE`ulFJso3z5Leo+<SAjnQdZ&A%790v3%q8xtuW8R0RfvWwEdj5g^R^n`@nD
> zlBw^Or4AXpfuPKe*l4$#N8qs>ayZ)P2NvX&KC-!LC%M<xs=2Qq5Q3sXo9 at MtQr2@V
> zArHst(i^+Im(Ps;Y$Ghu91XzN!}WTx39JF<-C2^1boXme0RJx!O_`hyEUpui>{G&%
> z1Kry+eZivL at xfRhNY7ss^bK@!wD<PAUAn{USZP at aV^VxlJ6f`;YHOd%{m(-Eg0Jp0
> zTq+0E?#20PdY;?vHAB+E=lta4DL|r+5?*4*&tSk!04L3l9Y(mqUxiv~9qB;r(qmHZ
> zi8V0V(oDYv&A)#}kcSbuHF`XSpSro)b#{(?NzFY#dVL*}uW=&U69=kuGOrz7d9ZF?
> zL&&{hk#95_PTs%DDA&&AAmz8N(<q_)0YFlW&qHCAt>6G?6(-3qvR&KDH-j6`Rf`&i
> z7vu;lTkl4{T)N?<!yXgGytOcDnf3YM!s3$%t!KbgBOfT2aLi?Y-SsoVsT at h)?dI};
> zBLsD|KmBx6$5zXi*#KxNzlW8itkCF4=e at SZBf*i=-cMX_XKF$}c(On6w_K<_1dBm<
> z8wdq`i5$A#<b<=)nXLMwSFJI&=4O)cV$qj6mDkATly#TKIyV52v{usdx>F97-~b~A
> zSV>!o47^&wMtQ{0wQt~j0Q at us&d09E?TKMhTS<EFvt<)_sQ2!}yynSNv$aCEoy+?-
> zyg&?h6p?qP(`SCZIWR!0?Sm*;uq%I*hN;gvr&#|7po~#zy_my%e0e;gp^vX3j2$Et
> zqBb#`n8;<{a7Ka>P`r6E=fZ(TMI=uX?>Eg$-UA`5p!j)s$oyd<gb!5KdV5JkET01M
> zI#`*F8sdP}KePI;)xYmaNjAe?H`?^1Zq~#_GujB)a}3yU1V-{y5ktMbfb}2w6V5UK
> zIu~XAk{=%Bc{RajzIsIUv%mqL%I&RV3PQ8F>n?Eyyr);cG=ci|Giq}TS at o|k32(Zx
> zvu$mn`iPj;4LjcqdVTR!ddH?UjZ6J+cXY7N4Sndd4P+^raUIk6 at E&06R+sA6Et$|#
> zr2JUK!AXHhbl}l9V^31t0Bg?#nIsJ!=|lE{U at qzay1jl@V3I22s_Tox4>k_2=M4sa
> zm|(r?>Ua8nSG0uAPd_}KNiPca7-&j_B_3-YfhC8sshh&-b?*(N4wVMfh>8|(K7OtI
> z6Mbg64~4A7V?{*JaEyHqdg(pGxq>vf4bW4cfNi at oI-Z#G52r%d8EvoxTuNw9m>F?=
> z6Z<ox>*}6~Lo4mce-YlJ2H2BQNEG)HiI>|ZG0=I5&-0n4PVua6iO~wF{j=y-L5NWv
> zw<iwFD8~0-41GfH<)F0hg)Mh>Zk~m<sWOvo?@m<)p7NZ+!CM(R>9}Y90yV4XTLA7T
> z(c7)arT{Qa=RfkPc*7N`A#QE~7rquOUSDsXjk at WgoncN!csxfb=E-e21QY#Hgmz{G
> z4zgkp*PG{`IG;u<+@*8EP9pJyA?!Bq{Z5p<%Ou{{6u3@~(Kv43Ee1n^{Xw;{+H(ds
> zY_=de2hMh*oqZsi@;{<jVR5Alnr`$%4444iOtWoHkdd++IATK6cqUQ;hapz6q~(t*
> z2Scs2pS$d4qyLTn7HhY~t`93v*CGvem>`PgpOvZpyEia(WwN|XBw~F0XtBq05B20u
> zwKeDhsx3{!ao0&&24mrjWshh7IjE?BF9aM)&;LmEMBQ;T8a`{p?JjtRaK-)x&%?4D
> zNerk=%>5Fq0Gxo(Ra}IK2YB}l;5Bd0AmAB_iwSsn8plnR{3d;q$9v;<eL#sD#d2py
> zii(Vbf}_EVxTU~d{a_Ejry<t!%G0~im#jOEDUeuU_dxsJ!TY9w at 3vE8gW0#sTd-S_
> z9SN19kkCpwPkoJLDPXNn3DjuB7_~34TT_L|16wAB3sBpbILrPVHP*fCg>N`PSA*9n
> zA5J_<<9dHodpc1QZA5F%@{nB{(Yz}iQ@`|O*6X{}S1nz!oSOcqz0YOz4?dD*jkfhz
> zrEf2BO6B?!b<yD_I<se;ueWr~?@HO=L?8OM@~)7(tjHncop=k5sF)}6{{H_I9Qy($
> zgCDsuoqc~($@KOV53<RbGv~yUJFpmhk!&xR1OiGhRo)f#&#kN%6s5<9GJ|(CLQP7a
> z-oYQVlYXJyTN?x*f41=N2EW<ocxwk_B-px1sp?(UMLUV27CG7+TO95*$z{J=EOv2L
> z66u25|NYE=wc?mg#oIb_33zE;7!ZGNonwJB?9Y}!B>;Rr;R5+V@~)ElAFxIiT!1WG
> z5V5T7-YZb_gSVFWxF1ngp#;#q0N;lI_9?XuoS!2;_U|6WhS)OSaqb*_eTCY6SR(bl
> z;ClkLG|64Pj5#M{fMjSCtdso4b`IyyJDF|;6VJ8wOKczoY*a;3<Cl9P-=5>PWlm_Z
> zo_rTh&FIqUClCK*g7y-2E&|Rfw9T&vX-su5!#sgaJ5$qI0Y-PH6O`onHWfG?nKc(|
> zFFOLYuRs8{vL=9WF4Q at EgZ_$Bi~CNAP;cN;{&P}WfPq2!&tX98XC&)&x9t17vBsMQ
> z96x+`n{)hJ4|Uw6OLX6lark=B56xu-`xi~O$F~26z-x}wiRvg(CkhU$jQIo`l;`PF
> zQpBWopRm!lazFgcJS<Xe!Xm2ihQJ-k1bCsJg0I6UE6Y(0FhQzjfRvw|U3i^s7-`P+
> zuQS4HnKh6Qe9oU%)B2J%<cBm)f{RPl!1)oJbW2WVO2wsN>Hs>9UcKXTQ`H%Tjr^4_
> z81OSczTQBgP7|>PUjr$lF=gVB1q>g2>q>?=S at A+}SZ;BEi-~FT_NztCgi8Z}Zsd+Q
> zX7Mc4y5b#=H*(8sjkf<tPz_OEDRf3PvJm?Ub$z+$KF&$7W^x$y7edm2<$Y&Ez}cW^
> zQjDWd=^@G6Dm4Qpgz>dCi*oG<4yBBO-lZD%Hd1$2*JHNE%Yfx*tJ(bl*59#^8Fv0o
> z6Z1o$-#@R7R8_puuBOHpVXCET8t)PuZ02pZXiv-?7%_9ytGm_{)?|()HsrW=Zh8It
> z|Iqc;0ab0?7pQ>JAs`*nb?EL!DM9HFknZkA>5>MKMiA+e?v at 6X?(UM3e(UJfd%xd%
> z??2dk#ayxH+GmbA#!mFRD?v}MH0r^Vlh|NV9?&Z}(G#oo14M6_Um)))g?70|<&P^e
> z<JTIU41Qc>WcOxZwYMt#BG<mU-83v>y%yCdN}n_>!jGT1%exm#{b;pDBddXSo?;6<
> zR*IUm2EP}77=P at aD%);dDRrV6Razu?c)>Lu)n)CQsL063RGQ)%5AT(>IXcx4Q)?>X
> zm*dyqH{o~usY>ruRsNEsRDPEq at WV05!q2 at T6cS`{6e<FoEGG?$J6c|n&xuuhVl`m1
> zVe@!UW}x!zR1F%%kJ7-0h;lPAp?$zEEVv&_{rO)mw=^!!6UJ_)C#Cn)khS&zKS~AG
> zv^>52-XJjLUm{4XR3K)!y_||OAi~O2KlJRID)!&{2dSjil*1^!x$1BsEnRM+ie;1n
> z916LOnkUGD35z&HlUKF?Tm8kx$Zedd!%XmG&j~vUYmx5J-GZTtZG<u|UOas=07zG)
> zf;flB2aI#{S>LGs0<xd9gV})qL+iK7!VbTQ0WN*a1m_x(I@}bBL0O7k1t=_AwUH|(
> z`><NY^SP>O)=r6oj!ODmPO|iGxVU7fL``yRw|{>-r(i_td~brF at ZWm?O5SIfNnXNH
> z!#)29_}a`AfReJ!&u(x##GZz)yP_SHuul_X!~netSlkk-<%?=-HrD?kaa)|i>AEKD
> zF#bd0j%A7$Hs(8g&+hj2581tXggj%|Z=ypuL*@_C?VR?m9Lp-QV5)FYTN9GoAVZZ5
> zMYc=uwG{_`iWdsm8wBmY4gw72a41teyA$Yg1w11b$RJe`k8Oey<3mjg-<4ej4Gs+q
> zP_ at SzF#`J-*gMtO^v}_6QW521%R!<3eqL>$xPu2(+t5#LA2+460#qD8(b=MBr!s|J
> zl}R2_t3*uk{+UNfc|*x?o*7IYn<@=vw9AND8-<#&eXO#u{fyf~aciDt_QT#-NRBUr
> zGKLt+=r=yGvNB#r>Te&@S!>ue=cQ|uY&cw=?^KKZ779%E3u{+1c{2G4eFgi87p7)m
> zMu9`r7Y1AUTi5VOWj$Y44w>^-X7;Iqp)fu#mxSfEHKMQNxAFi64=X5ah=Xan8ALc9
> z;p}ff@!^uAnVADXea?q#po&ASDS8*Kd*f#I-VC=XsD|+4wh&*Vfx2<8OS{H`W`R(U
> zfM*|LvXyG3sg3T;)d!~#kvQl~e4-05wo*Mw!+-cN^Or!-_k{z&k(-sn*u4a5r_?#s
> zk1I@<L-%?w>n~bpyX9O3p|!%drV#rl>yP)M-uU~2_Zw0yEG!a|w8X^3gaqgF>Eds4
> z{;m_dg?5%Cy4h*D at Is+R(5YLoSSXt^!AvZ7P8#k()N*e`*8AEge68%zq6l^+6W6{B
> zRTCH|u{scSh=Kc<BCWxuEjH!{TOJNa_cTJC=5h?TcluWW;DRlxJd%dv#gY0eRS|Vw
> zz}{iQVfDiQy7?-bK7hJ9mRK3urR=$XVLPIn6*XTGusb->z8y<j<}Gwnj2efOfi>|D
> zKa_QVJqnonRwi;Abe=&>NGJ<Re*~pBqTiJX%tW?*Qgy>XP$JL>Ev7;MsTZr9ScoaL
> z!iXQZcSZW4L^?RQBRn?7@`P10(0{5-L>cf6_*HCjJOwHRhlh68k&%&5djO3rHV)}z
> zU^Xq}g{Rr^+tt-opgnQ at OiqsSpS#Cf+pkq3rtg$@2d^_Y3DN#Esc7}x;*7KpCv;NQ
> zffG2HA=>`8T3EfZ6}zI;AU%TozyB3cAEm)vypTJ`q2kN@`C97{RITAFP>^V6O^DF?
> zCt0Ki=zFaa_cf#uy{Mxl%3ppF{>SGu0T0C&`8ML+W8DfN_(E2TrL<fDYNz*9z at zZ_
> zfl0|5EtVhvRG>wA&u07e_ho>;R%Xw{Ed_{a4)>t8<p{B$DZMGnoi_Ylz~D5eS`yw@
> znF5GqtN6cW$5b7XZE at BW&D3g%7q~xP`pe_|vPT}+(@<z-8l<kFIhz9bWxtk;_FD|*
> zv1{U1=ON*ON0Adx=qf9;9r+q`<4+7O-<HOT(V+PxM$oSFKr#ud#Xl~GFBZCl%9rtL
> z_*L}&8`8kRyrlx`e&O_GgCk=4AD{E<Qm>Oiw=C+^r}s^d>TQjS<AGlzegamDBeeXq
> zGlJ#wG&ZftPfY#a`^KEg1j0dSwLE!o!ipaY2b_}w`jHh5whP$YfGHaL0X*amumlFc
> z3wZ|nC<IXRK`DYylkBUp^kvW?z=AAeWT^M)f$pVR_OxQ)%zicVJh at +ug0XiLJj;C9
> z>5;_);D&$5p at p(gt=rx%gVcEX<Iw{niCcTttESe<vV>$z?)sh1lf_R1bD`=OIX|kR
> zmx|tX;74OHFGRmpiKTXmJG79~r-R(OLd+^K53DCMf<J1`gMF^Ys9DM}5g_xFp%)9J
> z`>TX#Pnk8V9>yzI=;mExH(ef$aE>y1pxFu-oG&}e5WP_dki5Z7c!!hGH?g)X+ at N*t
> z<7<5o^)*JeA^@?JJHfa?yZdsXYQmJ9(XcT4pc62L1I01%@RDL;ViFRh at bukB{XQ2k
> z&NKx~h#O7qC)T7#mPHf`EZoxZ^16Y1K9F=ZIywr{+yc~_vSG|sHLE?5N&~-C%rSZH
> z5pmBjwzF67|G2;xgDj0b`rnqC%05LAv(8DjhfN_Dz&{FMM#slPlP>J5n3Hp3l1$vQ
> znSubWQL);=k7Ok}efMhQEQo9-ODiGP{}w`#=L{_C95==Nzn2-~!R71__#9Q^seS53
> zT#9~|8ps!3{m^2mM}NwWeF&bY2()f)=<<~DfclhiQ*1Qpl+c6u?2yBPr_jUx2C`-I
> z`^kgv#CGvL7W+vw at 9SV@Mpr(@2nLjlSgNM}n+mFl7v6C7#LFT;T at jkN^_7-Qzhmbr
> zlL+VZ5+)zDs8j8mv6<*H%U5$zt>*#i+MBH at hAs(P5xThbSC_)hAg2rPGjla%g1Qhr
> z*Yh&4ClI8Vwea|DHAlt|fSUqIdk;IXw4Y7rXCw>AIX}dZ#;2D~GNHy1gSIsgMuJ>3
> z9;51!rb806FI>qet(l$nwP_GM??4ph16EHN5Zqu$U=S1}_AP&A#ifJqh96ykJU8h#
> z at De-7I%mZ1Gw`w8F=|A*6*}@d8HmF+^^hP^Yf6UG5O3>GoJ76%kph6XlT%Pokd|)M
> zv%=OMR8krAar0kLt;U9 at x-}r8|0<u84WM>PlI=Tseh<YPS7$u5 at T#|-hO1L!$mTS$
> z<^};{W}L})*wvxMCR-;w<Zk^4s%(Tucr(&5CKNcp#S(1+tvWbJxUMQr!>B2u6sGk1
> ztIr|DCP*E&ruk>>?>f2Bq{G7xEd-<{+*8ojgwWu>25V6@>>SS2<KS>qgBK1d+@&#>
> zuimYytnnbj?O6tS^e!`M`=JtvQ-8h^iJ7RD1n5P!P}SqJlxxp- at 2B<Qk`=)e1t;x(
> z5g>D|-rop`@1gGTG3kPU?<vhWs~n&Eg5|-720(fZU!W#h$#{21r+B&G%w5-R7JzZ#
> z^%lk*I3%B>0jnf^_iy`d(7d)JmYO~9HK8T;hnn#7-(D at sw4ecEsodSdTPDKDAJvh;
> zxkA5)q$`hElyT34;_4&$s?3f8Tb}`K685vPcddqTCd(`>a@^e_N8gvbdcC`YldOWv
> zoj)zm*5z at 1y=z+OeeiSzZ2~`fz=a^ur2{fA>N2qj#0Z7iIu4eq{I7*#dx!QL1?WM#
> zD&dQKsC-cA9a{X`drz?<pG=f91?PGnhH1Gb95m+nw4_Fu-Cp-P`~b37g~40<_Bb=X
> z(^JYVCdS5m)2=G!ob{R39E^K at 6P_C-pBS8`?k?{kW54VH{QMlJ^S9evd?0Z%%ST`8
> z!)Su_p1!$d<NAh>@ZtIw#L^P*o9)n4F0ovZNh=}?7ZC4PW*_ at Kp`0q{_&V-3_%ct_
> z8^|{PJf`ZOr$4x22=hFc!dfMBt;rsh9 at lczn0{1>h?{MB{%n^&Ohlprs3x2(rQz at g
> zHnDxj+#i(v5Hn!aq;Ia=sEa%k+*i^Q{KHh*1 at rE5P$}YdnN%V8ZCFkWw72T&&g$Y2
> zBcD{ff}qKzEOR-Zq=F1Uv*T|U-zXbGfOHp~+~>Jb+Y0flknr&SFJHd&^;Jmcyecu{
> zjD4VO4mF~|@<f(|D?x;(LeAZHVpM<36aK-2e3gRLRimOVMlAYw5W+~K@?thd>);8X
> znfYmJV0-O4lrIp7+YQpjc5#=7f4#w at o1L~=s9 at scd}PTci99t`?emiZx)h<_#*zBw
> z0*&jqvx=7nlWMn}_YvTkKj}1h0D4(hC?4}}zD7B5##G{OW|sAZ)3?Y<I_+xC3}&K#
> z!XwH-KWt}s45;oi>tGWT6B7{Rs}+_%j6=tRgg^Pv`1Hf8D|ES;CDrqj&j!V%cMrQW
> z at Q*({eflr0_GPNgIgIy#Zl4^>7~q+TwDi}4;29n>pbMIyZT at Cf6)WY+HUmHakWbb)
> z%utXS)r#<cwEmlCV9(G04ZsdSF)uK20G-ci({qV>$4&++tO7`^&OnJpyzh4o0i;n9
> zDUHACp)TPMATSXTkXa`e5cuxNhnU~?8bAGzu~6F^hfui(_+ilmFAZ7r+;it|Z-`LQ
> z)G1ZJywaFPFD?2=6pDP?`Htl`Raba!AI at X$H<v39&*F%e)mt<;h&f-cMa{zEp^2N-
> zu17={;8p#Y>U;oDS$$L+z~fqWiZ}pS9&Jms3fFL$64aIUvjwUv*Kda1Q6mlUpQ`3B
> zyWcev&VV!n!Sk2B3qGFP!8st(gtzWbZiu?sUH-q?k6U)-6=s}TE}Vbh$EH`WZI71s
> zkB(BR9>|{`(!D)0H>)Mg7l-fo`r@!)beBo9;=ZS^cC}Sdb!N&)B|u9=elC*uh*s8!
> zwZ%4VZeoZKhukU8)ermLob~{n$exxQ5EW!IoIe9`@4zuY+|?7EuTPi+(t|(N`p@=e
> zU{>zA+lBlmTkz*_U%6oq&*2$_S<luSXw5Kbakh()9^`IqWdTGIdkAskjRdRC#$d|x
> zVl89)rA8vIf?&hIq|L}I3D2V`D*s(Tt^|sOM_b`|ic&eP)o2L=(`V}`r4Jr38L^;6
> z8rDh#uLF8S7&JU7|DIF2;{2bun at o1+IDXH1*pm;&PgekX3iBbPsC=%@vEOxJkKc3%
> zVRF94R-)2`#j>uP3RS&$iNT1Kk>o+CR>=g&NCEkCkLE|30l`ZoGtv`C906Fc1HZ}1
> z{PDa>`HAQfNMr&GUsl+|>I<MV6K(xlH}h#ck72jncjv6dIR_}y7y~ekQNAI$vl6gU
> z*v at -xKaKM;2RV-&MjBB0BDyRfU&NTgtGkG at 5!np at qsnuAlg2_I3KZ_8V7~+s4h?%Q
> zLC&X6YzdP_zP=g}OEO7p>a`A_z&sY at HSi*))E<1V%E9p=I#@58hRUj~D3MCmD$?Ex
> zc#R){$K32DZvL?V;T;M3gYZ_BC^=0$ecY7CCHOK at h1_3%E7Pruw>zZmicgNmQq-{X
> z6{3NCk8XEoQ5#WatzDyf%bAw<wVqu3;VVj<gIuUQ=SJHyY*twHE4oZ-5QvvC$M5;A
> zcBB!(D#P6rc)UK5voYLL_La(nBOp-j7h{ZuRSpkBc*%~E8YS2d7Vy_%j_grePSvyn
> z1V!()>;N7*AaCOc>sVPv7&=OQh+#>siDB#Ty#DFhwj<;@eg^a?S at hhpE`c)9!%zf-
> zJ8aKwl9DF{(QRc;&l`1{2x%EBPSDLL`^y17sDXgQGMpOP`9t>QPmsBFH17k_KbG#$
> z3=^mbe2bJCv1R*AJ*ji`DgTOvX1n+hZ!)Fw+?n{Cn3c`DiM?C|ywGyum2di0{3Fj#
> z7~&a;-z2NmIY<>jF3!Tefe3&G68o%l#5^nK&3$b{;uPR`y_OmyBM9c9__SEaB*9Wy
> z_2M!0{qG>bF59bkX~`l7nE+J|p$oG7!08ff#d0T!JD(<#BUoI6-P|m<rC|}}qv3~l
> zdZ%ys7+qNRyQZl4G|k=J%|Sk8XqZ+c+R~&c{>bzjDK+3jme#^>I8Jr<u<%0Sy!Y#3
> zK?W7o7L?byWG6u#j&X7FEk>uIdU=MWI?Ktrtt#a5)beP{;IEw?)@B2T!ruI_wyT5h
> zn+BR6Q~}I8gg@}z=!o4IVF}bTi2X$m at E>d7;a{BZoc_*Wdp(Bm<_*YSLjr<Y``7FH
> zbB_ZHbtYStU=K0?HUkn(EzO|0uuL2rvM+`8w16ZN<9=CDhsw*^ks6R~`X#7}bbSD1
> zjO>0x1v>>DP3LQwzI9{phfi<_+~kv^SDM8+4gX}b at RBHF?ywhKv9sT9If8M8i{~vx
> zo09f0j3E~RRy{c9-VWkKJ^{^ebDEqGit(^lTHl{WOtoJI6S`Eu^)e7OD0gM~^!mbA
> zxDaT8)yDX?=&tN}w+FyzPy^si;%8AcfYw*KFET#?Fs4#^_44#55FJ?dZU*E at APT_B
> zx&9<-KZ>3l>b6pNhC2 at 1H#2x_#lgcjm76Q(UvC(_bo0`7X;O4=IX0Qc`V!W*I>h5W
> zw{?hH at Nnx}9M=huLF^V<yZC0)vy_CNvnMQnB$isLSVutHOt(BQm#1Y?`6H_F<3+-9
> zuI}=>?9nfHy78l5P-{^Zd;-h6pVIYJqoJvvDcRz%<0n>kSZ3+1Ru at D%d1omAQQ?V_
> zWZqo5+|ac5gx at pUP`v7O4Xr|14!!SglDtT-F5CPm-%)w6_=Kk6)JX8W-C!<X<mFc9
> zBy{h$;zX`qDf>*K`|N at s`}AceIj at nlB0y3PD?)OSx;^5&(aA8b03&TWSuyG7K(#YI
> z5(xZj*!|k$jmF%B4`%G4CtuXTqghGAF^Ahut3?X*wtrG?+xsaJX?Q^v*p*Zm>h+=i
> z_GG!R#>I~YD&e!P3GiDVW~RCFk0Iv3kOQb8S)a6;#w0}66(e?)=2wJXz9 at 7R74>`2
> zbHuTEHzR;?NLSEwmomcqOtii+jAgPP;=uO$xrFVTM`EM*kSUa?LcX40ggnZBL#Ile
> z5 at 6)g at zF|Jn*8<s5OTKOQ!PKbB2n at 1MKtOpGNikO^;X`2-GQN@^r_vUYvJMZDO1Of
> z`+N%*`^m|J1WuG;5H71N at IL77Y3>xKi^D_W8<+XHpu!OWU(eU%gt1;&?Or`*mn^k*
> zJ(un<4RKJUW=A!m2&pV>-}_7QpOdxv5S_=6dvhTMxv at -hgrzkQh%$dudEQO5_FA>?
> zgv8dfBos#Z$f0f+W&EJ2I!D^Bn1y&h8%b3eA?<n|UE2lW43GQONjwt%JajL<*6TKk
> zoGppTuZXVH1cihk9<p`WhbO$Yk<7P{bM1i~b_mX3kTst35z{@Wcj0GRN={0ypNoLB
> z_zA=E;(N&-<r9U8 at oZ~a%v2CAS5;(FxVJiKm+D^zyXk&J!08IywZSqgni#BgBYDRw
> zD46PrtR}sZY!9uXW>aR&)d_j-v at XA`9sa7ra~h*O$R_`%oMlV31ZJAtRKhp}k#Ks_
> z2miQ>+W=@JYziMu;*3Ok#LZY~3LPQqp{Nydt at J-X#%AeQAB^-gZsNX~+^{TO(jLy^
> zAXJN?UY)$Gk~)H4q8dab#2l)s>}kQ9slebY$#>UVAH3)eksj~dy--(BK%Z<q6 at C-G
> zIUc!jsxO^wQEq(N3GrfzkB=8U7XZrYCZisP88R;htuqL638c98thY};+K(%(lpxx%
> z;wQbFgniuM8Qul^3<LfiQSJOwJ4~k!KC33$YKo2X%@f}aBlR0f8l9hhF(pDhP7EH>
> z!)ylmS&xgue!6j0nibn0@$Z?ndwsH5>2$w#KntBJ8~bTZcf@>x(%PJ3Davdm#>dH{
> z1Ej|k=4v(Yf~X2`wbis6=hxi`Jyv>qdrc~ny^`@!;eV7Pt-cT8_A^W<NAsvo6%li^
> z(|$<!=sgZ0-g|sP!uKg9q4}8-JVBei(f4hX>)R5?2uf=XJf<zGa34Ja!d9(#((>{V
> zy+#Ht`itRRndI%bMFHFB+OLR|m1aac#E!)%#g)bV#Vf^E#IYqLBpknSu`!*jKk-jT
> zm9eX2D&*6(Rd=rkx?#1o_|5!_65 at A)0G|-9>@s+bfuYApgQhPaQ#U;P*@(pV&AMNZ
> z|GNK^fR6$2fhK|7fiyuuLF*qa4Z=42B58yOVi&>G`8HyO6fe#AJ9D3mEp>F@$-NJf
> z*1F?Tas7Hpa*gyJju8Dl24PGU3ug%-x*A+sE!#82AgbD_#B{9Em$mCbq at GzpUr@sR
> zw}&vIRuo5wN9-&-Cxpx<BLh9ysoDmsPdeSkSe*)q#9rP<%V%&Z#9J9dH#WVy9X8f?
> zcFdy)Arh6SN7Fy8hwUyTQLu{A-$_!RJB0suD+GD-34`#f^{d7Lg^S#;n;&naaU2V;
> zuA7PJg7dE*Jd}LaiHcNeCSCukvEE;$CA4AZJV48&@XAZJI^ShtH?!+n6I0R~y_u7C
> z`|(^|(0wta_+wM4m-kl2NUnb*zdkw&H|Jjb86^E_f5ozcTsyM)7LNnvXC+0*rQcC&
> z^!k&gP;wNWC+(heViI2;fJ!R!1+3%9(r#8NPAl`z=RRubv<`+UMy(A8lkHPfpT1Ha
> zWL}3CYKsOyOjdvh_A()UsSSnUD^``0`MhpcRmyWJp}Wf?G*n-j`}TNG)dSlm1Vg+Q
> z{4 at WQT^12ZCu>7yzr2(<z&Ri%8$+CADNs-!k2 at qqlOc&vKi9v=$m;Any1QbZ|1MsT
> zHqchh!9d|QoDorr+Ff{6Hn&(%;UFIl<Awo~@6sCZak?6vu`!!`3=G(N(#CG=v(9$K
> zXOf|eAhIzrr*A&5q}|pOMa}$<w$+qw<^#5eQpyuWV8jaiXI+KiB-$aqu;OqL>NT<R
> zzBDT5ZTgQ7Y00FWqxp8>ICDI}j7MEBIzOMV$2bd~xL!QH?nPYIZ4FQj`mFO<RH6W;
> zyD)`p>iuKEmI`(e5jQqM!hBun>U9K`PwcC(oH>M`KAcT87D;mRL)ovi%t|XrB8U`d
> zJldf at Os24K(PZ!<)W<MQAfrpJ>*5#l6YDr%eT1psNRthWHy~Mh((w?+Qs9?vQzRBk
> zA}riK{74gV^AIhv7NOjV`tnvtyFHuS{Pj@*#n&kh9)0T?o6(UFqUa$t3VDq%u$KZ;
> zt*HA_1$*cvlJppa%7x$`Prv4cUUcBrAB{EuCEi?HQO72iQ6t<XoNo8*K0ijJz`mH0
> zrQ*<Ui(Y6d=e>O0Y$o0Cs_|>j6euXIu}MOFC;0WN3-8K`B7E|O6`C0FqE$7P3>71r
> zQ9Jeru(3XB!E7j3 at M%lj!mlK-_f;fFzbhLN;63Sk^QnH$bzxyfrBV)Ts?YC{N0ENt
> z&1tA_5M$}5WFfM22`!kzsZ at oHP=8+=TP#VXzf%89*7N4WCN5m|_Brc#EyrSco!IaS
> z5k*$pN#^oT{~i(3k__SDQiD!{m%VBfv1OgnY}W88DJP*ev%&d<KhXr;t)A7E?Qzl@
> z2Q~T~$%bc7qJHYjLH`gy>MXmC>mBO-B9MskqAKD`P$IdZ*34}rQ5UbRH0Xa7VW#`B
> zL+-gOKS~TsM5M=(s^Q+fYMpaoE}D9KTeG=vRgBZ`jbA9whG>YF)!CL&OEMJND!37D
> zkH_YkXb5)BUwH{&OT>Po=gi^6FO9dS)|aV<f+|>8?X2>E)VCgHZ66hB;B}oPxK#e4
> zeDLa<1p`KK3Cn2&1WB%f%V2S)h`h4;Db3|Gst(+pZ4*Cs2?lLh)ChH=KCDC|2#1 at 6
> zhQ{PjngF2sGT}l4iT3vPTL)cJD at l@K3vE5Nt~cqQwff_-cI47NFoM1bgD2Tm6DslU
> znqF}bglW@?7{4%)HkJ#0edH1R8R<Bcoin9)<mtou<eO&$`8qOJR|6v*2fACASTckg
> zspK-%?}M5l)?ZMz>db}m-a8*Qs2c~VRLA4vm%7q{Oa($7?T=Y?Q^+*v`EOFg+dOJ*
> zXf~HJj5aT^U?{uZrc!^4p0$#az=|hOno<J$Za%B5j1`=K`bCBkD3u9&^sR&eEt}&=
> zPTrvpCEf=Q+nGu0S7(#kLb!4&aywhyn&32^E3_L_hlx!jAzDgr1$0^ANF<XdFj2#I
> z?~qvCEiBXNvuRUj?#KmLN|%GX38H`QE=bcdniO(^mS<h!%ia}#rQ`UgO$2B`XG9%6
> ziu=F*3i&g`!tDW(wj%N6H!7a8l9KneG*RoDB{c$&8a7^}kW(ULk>@`DXX-2vO0t+<
> z+lo6McpRzPu^zE$O)-O>?3M@}TqlsKSv)y&DF2LkI+)ApGAXM%z5Pxb&@(Mq at fUIG
> zQO%6WL4`w63I6au-M<LQI&NRitY1;L=1v);i9^!G#>O7)69<!t`6kE-`Om~F`DvmU
> ze#@%osM+rWBJgr@&`eh1&lL}WwYzVE;-mgFi0~-aNW%FpMTV|1e9S@$f&w;$Br0c)
> z{2$Z!{ZwkW$SdRFv^1g9VUS5~oIMcTmxu+oG6v&RsNL~Ost%#ZG?}iD?$?glzE?k1
> ztY4Nr3pZXVAFmq!YmKVlTr;`#oh?1_dAblG$XO2vm0;S#V*P*L><Hasv%2|FKs4X_
> zy~R{&UmPqX9%l~h9}}jtu9fJoykKmcGZvEI)>so-?upNUB5c4t6Dpzp8S|OUX^M1u
> zOqbgEMZA^rUdfbL_(dg!>c}Z|`^uu6;}?#KNe}qnr(eO}Mas|<=3o`}VH<>x?zte<
> zBSN3DI5};3r`ei;lmDiK1(WoZAZt$D3tNLP?U6Buq_QK?27fk5mEu}4vSG1bK+h8?
> zp8dgS(@vi4w4Wy$w_aa#pzDD(<58Axg6HU;{(ShK!_WcmkFnWCsHj0<^H<;T-5yZ?
> zIS^N&8w8QBo&mLaU2OG=^gi`<a&*I={&3d*_hgh7ok$9KSf;0vR#HT}Bt)nL`=@aw
> zjoTh>8#cOIU%l=Wt*>AP43hpmChh(Vo*{4#UOgefPz$xy6Y*CmJl3rI>S8z)@H%1s
> zXZB_F8`@OAx#af)&+bd;zyeGR!JPa2_&Z1A4_dPG-<zQ$*R7bY#r;$gb2mCD;pcaa
> zPx}&->&Ud`Pewv;c=|4icc}0_T`IA?KQ~&Jdpuc!+Q|8oSB9hD$uGx6edLjQc%mrh
> zLM3>F%xC|^T*7lY>RSI+J*h>c&(_v`<TST3leQ|)f(`n3+A-_e-ny?{nHNTK@%x{h
> zrym~wz at bIc9)iAszi1>sPvbjeNX;P-qr7c2km}Ct{WuM?SUf;pDHo-6VSRvD-y9z`
> zFBlpWANu<tpk2mkeqx}F#yP&53XbaC-Pe76Uh&;3w;M|zEY+lVkid-}{ig8Ea8%&o
> zNCt*5of9bmU-czYeR6w0Na*}CkwaZ8MbU%!M5mP~f6datdvVn0-UmO2TOQ%z^%G!Z
> zl(4M%rGF2dHHUgta)@r}txLC;Z)wgQ(QA_XH=B9J{or)8zsUpd#b4atW9#Vg-xtc~
> zsq2A0XC3y9YViy5TaO;iaUM=@aW0uYG1m}b(uPqBPdO=1HI4atn#;K<<K2h$%jv#d
> zsj|a{n}LL(VESmquRELVa(;ZWAv7Zn)Ejcpo=qfu&7^gPRH5Zt(X$bELY%M}G0+q+
> zP_cXz;z^x8tiJkwBSfKxZ&|MKt1wn3?J47*!aMn2s3s at tz9TMeNN!2C6lp#n4SCs2
> z&c=qR&{w2pX`Y`JBe{901bdP*lv at CGz(M|QgQP8F)y4~bVS-D+pwgNzDfjqxh2<BO
> zApO|5I22^$u<-D}n+IS`?g`~P=377~Xo*bMQ2TTk{XPA40G$p!y`7g)zYkEdH>m_D
> z2;9(@fPcz|Dh)#?NP<DPpGEIA6Uj`O+Rr1-{FNTVz(Bg^^UKB&QFlYu0u&S!ixH at o
> zDAd%~!6M&IbMZZnsbYLm>5t<IOn<EhPHFDb;<DTY${G|A($U^H&+Um)2;(_&+Ypb%
> zcfT7BYGb*(Tb)`CeAEo#ljr>#>7FVE^lZJU&pxhBaJXjd?YFSs)H`zUwv|~JYG`Q4
> z%gX~X|J1ifv%rxVn9anwto07%6joGNiL{umQ5AXoS|_C=3r~+}Z=a1bDP$4S7-Aqf
> zmRfE#<)rUk6~0qhsE#3WHrZi1L{+YAJIkw7W0U5O&~md=deD^^8+~FmG#;AjQPSv|
> z(RHSmJe2#y4_h3s#7MEHNDVT~<m62s#4U&<aCm(jB|*eDi;dy>@!cc_T`E=az<{mi
> z$tE4+hK$g!CokWPTAM#(2>j3o7W60gNX^yfQi;_H1Ny=3XLG|^W#2oYa@{6hX%=eo
> zt*O*v?Brv|b4{x|_gGEmMVOS7jZ#*8RGK(?CZ^)DvXK&PvkN6u+oPO-TIYQ`MZwu*
> zi%*sl=npH}9ZJ6cI$G_xbeF=N`r>1ry`Npki_(+ny#;*oA}y|P`9O>JLRXQ~RhHmQ
> z(A#<Y`|Vzh8(pItoA+X?Ul7_32I(wX^KxdVmG1e^73-`QaIon>N}O(<=9O59o3`yp
> z=KQA at -he}E;W`+M5$v at 4ld9+<<IanL<zVQ*?G=x%*HQAvXGBe><96ewa}6!g at h3P9
> zCWTzD=k~@5{ksye`u43F=cJ`4I}5QJu6h&7((8g at _+HgsHNI-oZoJu0MK9eZmKEX=
> z2oLsjSnkv}(%u+8D16az-u_ at lB*FV^igEI>O<LSKHosUcE$O~Ig}$@>4H6MGj%uX|
> znx3AX65Vx9(Rfj^kmGt`d$C<^`mg7s at CZ2)6RYCn^7H`cbS)HVu2kFH;G at FC0qG|H
> z=ULA~8xJ~0KU}q285>WvwXLiVAl17tp)`j%I=ap^CJVUk-v?VNP#Y6_%0seKw!tz8
> zhue03wV!39BP9W{aD3iUxekJU9V)!mniWP2M+7G{uhe^ET6OqbYXU*6!;ZV5p-rc5
> zj=&9TypmPdy)dD~MR$xZ-owTP7vtPWW3nPicl(8=v-_iL<l6wCRCsRiPIZ>w)K%0&
> zQE(xdtYNHcrnj%)Ly>k3`te4K%<ZbT(tfJB`3%`NckLyax8%cl-WbO(rH9uN<Rm7#
> zOS&Q2p$O<+H{X at -Q1qr33*?f}C7+g3PCTzY7PTHPP>q{h3w|s=EcorV<!;bswwBxt
> zoe*idxt3R|7Kcrylz{LmNiTZ|N7m<N4AwijuV6<_SXkK3FQzMWIMW|4upOeg+qcI|
> z9X~g<yAMCy*$y2SM at _&SZt3%Ehk*U0L}DK3^G~|pTWPACRjKwO=6u=`PUPpSYa(0J
> zp!P(jlppMA-YiYD=?C)BbK6*iRu?}ANcaWCO1hCn=v@^y at 2YL)B5H8bSMh)384KvA
> z>m?qn{u<i%<*G7P^yVFgLIqQxo!WA>53!tR9!}Xf*=kz-?*B<D93hicL<Gx&;8hzY
> zC2SxMTAiuB^L;#ooQc%;^;M1=8~ZIS!o)hAN>Wn2yRsS?X?$^=+8nlPE=gFjR at _TA
> zhXb^!uW9v#9OWjhkC3Suo^JY>_u6yl=!GpUrQa9R5H%9~@x>o#s7_T|?-=$Nkg2&5
> z8865kgl-7LNo(jdp0=WvVV$vuAI3RMz*{~HcTjUcP5!xx|ISozqsDFR>qr$_m0MtX
> z`!~fJf1aHQ-+Ov<QNouG>%2PB5SlkF#*1JU9Ciu&`W at dABNY~17QC#n8A4&<<)vTj
> zTY68#`3VoN24=o2 at ePZjp5B7U?W7_uZJ>H7X;Ak%bH8 at oTy8*xK+4?QV#(}2svy$N
> z)ILl{+Ov8Gw|!SSKAVp_a%_ULahd1yo_m8l!Dx@?QRXoSzdNrFsQ31k&W*>+V-LI1
> zBtO&8nLQQN!)bQNM4FTe$cQgIXhyM~D2Xgfg#-sR`fL-g7<y($j7~hBcchj1z27|3
> zEKfF at D@|K;-Oq>CD~IPVUXZ53imJBDVAtvMTWKiT5q)=i(#@0M!%y-)N3*h9Mn<pg
> zBEIdAz9F9Yi2Y5?`q!`icCfHFh==19#@~pzixf?Wcv)X9waYAqDhj(NIm at STGiByc
> zmOC`aAyKCe?%UYybp9G6fdan%koQ$}TlM--8krz>4kVaoEQ`24*%^iDpH(9r`?S>H
> zek|^G*M)bysLjfD)Gr$Yh8rgv<!WNAT7X;_-Vir(zsa*j!~Q^o4Ml_=Qt3|O#dK8N
> z9w#AzJ8+wt at 9_$+b0;di+WwyrTNbK4TW~jhR3|6bOezMxqoDlQn=>@c`uitgI|s2L
> z!l5)d680PcFGxEc05F*8rdoV^9EXLFBVjh4YihzTsdaW9C)*8b*Z81rkh~g+5=p-v
> zkzndY>%*qqpA|<#C+(TGzy6uE>h at 5(&MrSrmFG=e_+(nKk`Yg>vw<so$?iBu>R$U6
> ze!OBD|FnMN4~Af#yhH!P)sexXUxx#5E5>7JoYHiYk$nszqT*t-pOqS&bIv=zrJB30
> zwQn!)=R`$es33aMFXm;qs83(z6qyX*%atriOHW59)G!R3BgDEz`kI-&Od)^X&KC2i
> z&n6^vNvSa`U%ga;k8i2nAqoWV$YEfHQTnOl(@3V9Z|)HL^AXYSjla#bZPB4f4NhG3
> zdT7q$IG63x$bVe}%jTX&8!9-MTu?%Me}i~$x{BO&iOPxFIB75%MSYrUHF**>wm5T>
> zriox?q&1lsTjr=To5;Z6`CE0~D`|!K>(#iZ!=VR)dWPL6hVN9{9oX9P#{qLJa7~w%
> z at 3Evp<JX&MypAQ2F66bQbgCb8rUms5Bg<U}fJD>K?vVZ#kc}o=%RD~lNPN6}W at MH0
> zfPX<|^5YGA at WA>z>99`P9`>PyhuHoOjm+BIO at P6Uez(;Q_h7>*j;4u`5l`8CON>S6
> zrF-nL*lH(auGE{&=2nv{r+>pTP=KE1;FK!nDWCFKLQ;Y;5Im6|^2J*B`5b?AgfVp#
> zITGz^YjF{0Rkdan$=pqtwl=${<Ru}G+ILh?5FiqBq&s!P=z=07=CGWwKLI`kXbo=?
> znMN}!6Yujm at 0j=FU~6>r!z}Wt6s_PV!@(1uOX7Mn9Bk}x8e5hWC<NR=L&K5k^JSv#
> z_Wl}akM71oV2^A_q@|AzRgBM`z*lH*k~`p+es4LW{_+=*IJbZPUS+BdE}~R~!y}PZ
> z*P5q_aLUGF4WZQ37M_ at x8)2TevCa7atvrc%hy~&DsKBj^xWr~wfHB%`maHUaWo$~!
> z&!`*Xis9}FdFt{M+6mG>o$#jE;d2|I%}~rL#*?1RH9Qt?B;>Ke>9&0FlBRcj=6v4r
> zW<OFY;seo3sZ=5ZHjEQz-WKA`9th4+&;zWuM4bsvjeQYvrW>x_ZVU~Sa8pc0E;2oZ
> zgnCy>Drz5{JPZ}D$ZPtn?@B|zCNSe^ydzADg!{;fTIsl<Fz*+TEMXF7)x`9Z9wlCG
> zVNv$f^V_({VV&bBcYQK8PiH51C(1`nbllS#pRtXyns1busV+`pPIFn76tvYKo39m<
> zWI%&;Qes`jI=~B$q(f6Qb~Pev2pnVHa#LNg)O&xN|MV5aokOKDF!G0}4$J)Gt3$Gn
> z_L)c85+Fd)3327!+sPYh(|lx!wZ!s3zhE)}a<+{NF??3X(@AAVuWOE$2&c*IU}P(u
> zt(<q}vU%9KK8R8WDHpJLo@?QMFYOU(9aV(-yoLK?&Gkc-U(>3w7yDM7tND!NM at Qqc
> zh}(4J52iW-X^Dpe{ql1*-3fZ46F6^hmJ_a6-|gfLJCaaDsQd9?pm;im&pw=)SY!H;
> z7p`9aGEAMpf9?7-iAiYb`uza$<Cb#eyu4rij-ZXf!z>S#ZvWd|h<XC(PD%4cjNmJN
> zD`r~&^(2TMGlZeAi9GxV>M^o(bK^bl6V0-WV*l(Z!RWYY^`sk(&HQE9ge;-|nkZdI
> zFPFewxglE__rC1zTOuP@`8Zim!|TJdr at U~Avlpr)>3#cOL|sq{b+C>KzD_g~hYh95
> zc=x;X8-UdvA7R4r%|G>&SK-=z*;jJXN;Wg$a-}~2QtGOMRK#|~X0v%ZyKh9gs~|ee
> zU66z}2kC>;@A*xuiuwm*`?X@*Xt14WdSgrZyKhmAYRaamaZ9(o_xfS at 8GivvBb&5(
> zK}_$7&ViP|W%=-gR!2=cx}~aAVzlAT1a22mKpZEfS(_ozxJi^ROLgv^QuALxiCcTB
> zAC`}gZxKd+;<TFMXuI#%pw+ef*MMfd133PYSWHDHN)3Bx-6wP*dyzyc`O{>gv=1bh
> z^Em|*=3-v&;;J<ag?AQu=v_JZq07n0AnnSisi_TQpT4-EdCGOrVaKeT*{Jp6ndia&
> zP2z793Q_HgvO^QjGS0j<Bd(dNnfIYz*^Y<y!+3*Q2Z;f4<}OR>+%|{IQXcmoh`eaN
> zKbO>in!G>ps#L7qY^JP-|GgtM&#&{*a-W0pmj6t<!BN5dM6-M?5{fs$3`tb6fVl9?
> zt9LcTXWU*(rVYYcI7deoCZk#_%g%(O_h+Q={|CJaRoN^NFNh_D)XgKWjf{h!xArS(
> zwwHC}>ksqYR0a7lo$2v;q?-xr?A;jD{&5Z!0-`YmdRIU6v2lm6<Kp55O*ppJTT5c$
> zVns{F&F}r3{&ZQOJ(Q8jS38JMjAV_>gtCWHjB3r4R$Q}3poISWw<k`7LQZ-r3D1{~
> z-_K<_Sp(do{L89?M^yU7YL-BT^T`u<Cu;)(gI6L`%@|JZs9NM!ZL*&>${tj6AX&o|
> z!&@UTA?_jmpAMu at w;n=+1vsV1PiU1Chu#vc_Ere6N6(34#B|=1Vs!G}VzkRiNKC}V
> z!|Qn4wuE5%wk*z$Q;QLomocl~@GEk)<HpssyxjN^tr at x*mzjW>nAuaaXJ*P~nr3=t
> z#%7jVR!zm<|M~rFyRs?yiGkV)lO!`Fu!JQ+OdR);%W9}ylZrTTWKHH9vdm6PkcWa+
> zi$4JQL<_}c#84{ok(nU08c2Ppzat5jLo*qRo09xVz_^#2mtUQ0U!ZKn25OPBFrshs
> zi3q;^Rg;e>|K;z%5^u;vB~maxahmi(UplwCl^+E(_!aW{lo8t)C---7;;llCqYTFL
> zPGAxyTUoksc2Rabh$?(=>lzJpD%$C~TA2<*f8KeF1Px5S66%-Kl%fZ5 at SY<NqNlW9
> zb4$_`<h;&|XUGUC;2s^xgJ0tz_!`6PFVtQ at S5B=_O-&^SHPvLNV|i2Za%2uBtbWD^
> zUeeQ#q7&!e&WhZcbh!9On`L<UW6susV8R}%w|XRoR)i^m2)DyZ0tf#n;uD?^*l81M
> z_oQAheJ9C8w14n79!k!m>;3^d8KJSM;Q<&8{hrNu&#Y<eG~6R{<~M(by4t;C?fq8a
> zGd==cwxB5HGR0pjJ3`%>id#lQ#qInk5)kObQy=VT()2ONg6I=3UTKXpH-8Ka0-cgO
> zuvzn8o4*}-Xe)wl|KFA9Le<}pKB1NEfC)3Y4|)B+^ZLVWEqiP<6xrU7VhY3zDd7J`
> za5J$>34?5$E%A%!&i($H&8kZxT2s%3suu4NpLXLJfB=4;<WVsG4eUDKo7)~|)p)UO
> zZ{UflUEb&s#KU at epc(TwqWQPL3!i+>dUFw_npuw^_1~~&?mrL$dZzXqAv{D at l|8um
> zv1*Ng3XAqI8Qp7#+ahV4-+S+0GYVb~FoLf(WT%`6HIrj)*V!3TH3nnRZ48I0Wc{C*
> zb^bG}{?{WqTs*rEPEkuiVD~2nx$7U)<4+9x`})S300=T3luVFpySv`(|NoWyc&(J5
> z?{d%4^`4Ad6i*e^p9t%phGtt|-*Qa31)c+d5aCah_MegUp#iH|$19v)E#cT&$b9%e
> zhSnj>V8HKJ-URrGz|{Q>AOEQ<v?{NKewxbR&gTp3!190R!}AOA8O-<N->Bt3k=p-+
> z?Oy}L at _8>5yHtn5r+?$Z76`<d(jY!BzA0Y8CE})UY%JVp&@TJeGIU<i7+4VDUTPau
> z%RX4B6zbshUZ&tv6#qv4$AUdSxJUGUV0$sQ1DG+*TyC<dbP(cnLaayf7d;R*7y7tc
> zvT#gc>zB<xSK*HfVCe!VOe4jpeL%A-`0hRHnS{Is>EAYw4+2vN9^buNhns{6%ica?
> zy}Vqpt?SC%QR1ZKxOb1MLPk<dMJ|9Wt at vFT)}N?()o^hI5lBqAf~5gbdblwX)jZ4Z
> zBK6e5TtOm_9q<4iV$<KRCa=NvC*B<v3qD8jY4aq#TK)NQTq*HF>!GPQ6q5+Kw(1I~
> z`WK3kMZXEZ4~e<B6>ZF?hSAa6CN{0a!B+bV710}{%=omRg;@*XgLRddNb-213D_;|
> z6 at N@iXm{~1WY9Hyf7<gaN}p?EPpus)-L3_jw;I at m)BO<-U^Cw~p93H>lk^vqSPr7-
> z)A%c@$TMin3q#zM!h#VZXmwx^-)W`F37!YbkUT+>_(tDV^H{w8!6$%NTx%r;lti-W
> zl0={QmP$Bp3~Kae_|2jKV-o>z9Z`JFuZRDh{Xu^_VMLl<luo(%oqE>Al6^~eE?%CA
> zUeV=Vwa@(<wJ+n~J?^+r1FN39+s#?jV^IYjfi4z0WCC>nI9je|(gSu1Y6tjI86Nne
> zJRaW81x1lE2q|<IK5|8%Bh)Z<B^H)I24?a>0m?%2%?5paeGt9^pERq{U<5BO_ at zIx
> zEDa;nU+m8tm1zo!xY5%TL2)^%$jZ5_*o-nN?GL)|;nUP2)VqE)>s>n~3w at 1e16z?7
> zlxvmop8fPH8L59zO?oVv;c(dxb`wn07&>(Oy*nZIhkFzX;1WbPMu03{t|hw^)1?(#
> zP2i0C={h4rN3})?Q1mVA1=B;*nKQ5n at 6S@x0@!d%e4-n_^c-v{$*b<+?f at JpHubYl
> zAK;Bj!O)4ld!kTn&<@2OzgRy-3ZE(fM}5SR2g1cv7?LG)cOe=;uVO*3T69c-9rUY-
> za8~_uLH<X&krMNvAt9|+xhOhBhK&pZP;?#_)T*_^9-o{(Q)HI!_j#C41t@;>z!Hxr
> zb at hsb5GqFW=Q-fOl%%23kGk3E$<c&lrBnI~qt4w%w!K0`LkkpUG=VTN18Dxu_&upn
> z42%kAy5~a}&jY>$Q!#plO9=IpPFr!OJfp#Gq at kfPsQwDOl0b9O)=x0uQMyVak+Z-H
> z96;MWsSssRk9GpApG=NBB|w<=^Jh-C!QS3BtK0|O5aX9J8nMMoH?%8vWEA^ZbkszQ
> z=e9Iihs;0qrXRJr<wjKmP*3%triW3Qk=ghY-;D<hD4}oiXo186 at op+@wLV1+Zf$VV
> zbf%36-C~kL^I=ZW?UY(<uZe#xBQZEfX`P~c0}$r6y8y_0 at j~As+PV{WD*(p?a(npD
> zp6EX}uPUvfxUW<JUVV>9yT8q;LF4 at Et0*?;+=r<M{4IGy^sAU4%)iC_HNaX at kiyQb
> zJYEv3 at nF-vK*UZ&eg25e4jKJ<z<=si!SU#Scua~qMiL56?{t{I74{^saKX_mi1xS9
> zF!A44kpEthwTFWiLH&Dy{~q-Je+vMZl?U|ahWOW3=;8R}A)c57AP<2V`2YO(L3|pM
> z{sIbGZ(3MwNSTKY%r8uqNbHdvIB|DG)5(|6<ZnFHI=MDU5AaK&hX!J{-w(Om(Pvkf
> z*bZn&rO(loFHp#2vpgFO8~OcgoGC-tf1k4mKcl&*5M?t{MIg(tPEoEA>IfsnHuqn2
> zcSU%0_ppH6j~*V$H~(Y?K~Lillo6qM;Ap at b0j4Ay8x#Dl%}BqOFBv|T?vhYEaG@{#
> z_mAElK~Ka;vak#DEuJTOzQ;FB1<O@<;E=wR53&4j18YgL&#K^BBP9<>Z7p5||68 at B
> ztYz4V8?@=mzRdowVfKOH1Q*@!by}kj!+5H``~6#i*}!JD$7Qcd=JD<Q0QkQ(I*IaY
> zU-$sPlD7>zp3RIKpWX0znVpg|5<_10HBHNSV;qXgpJ8`~*IwU at K3?~&%Da(1bD)(K
> zM^bG3 at hz4_9a-^sXS6W$@AT=4ZN0Euf2d76sv<yUI5Hzrs^R>#Y|V>*1&JYyXSJCF
> zK{qh2K#mq|##gu5#rL2W1YX1z6t%sNhauPer&xd2DP-dqK#qok%%jg>qe?VY0T>BI
> zCFK*+grXleB3iIikCAO&9b1kQ{px%grpNaiEzTNGWe>~i^;?_S2qItNN8JdrZ$UW1
> z;4!IH!2%@<V at Yl8WJCHsx!^o>r=auRrU>_<YgwJ_U4N at sYyTq3N4?qIEpp0EWu at R1
> z<|>qezM|^f$C9vbgD+k1PJ6DU2(|5K;d38L20>;PuwNV>_ji6~fqm&*R1~knWJ<bL
> z)X_G&l0b`b!Q3f@>2*zNsN6H>dNG7xu#axyZw<HrmO58U(Ed)8UhTz8L}G#R1Loeo
> zAMXRe4oBFCwH{u0Td)upahJ$uhr6<3TQquMU;^W-)_K)S%r8(cQ%VHHcoQm=JR65N
> z_Y6bd9wkC6Vz1Lw`$mOcKIQqiZR$;*Mnfemln7GKZeHHr(tSP{ttt%M@^g5xp+uQ!
> zLutw^BQHPD+gq+xoSRGPZH=}v_UzHXl=PbfI!C+1Ux{g*R~P#8N!6oyhdde<pD0-B
> z-7|D_{PBZi6cm_2Mhi3Z*(y3C$nBzQQL!i*O*Yy|KcoDRa?+Nf^`2^}Jchu3VR-{K
> zEVjbmggw$TFevE#;5u-h?d{@<`>h5bXYBisZH(J9jMN~WD$ZW;dIE6DVTd}iqnJ9s
> zkD!{y=5vQc{%U<DVljc1Swc+An0N0GNhV{lhHut*e`mP;I1S#e78FFawJ?t at Y)OB8
> zRuyE8xen``CRmr}b5q~$V4PiB9UsqhbLF~}_%Cc3uZ^e;zQ6}_WvZ!Jov~1fj(v9i
> zW$$?hIb=LIFtDq06427{@Qzd33|rltAq_;+=}nk-U+ix0OJc_pU*ml~0NAfS^K(3+
> z5D-#e)aKUV^;gcuDFtzUpWX7{;Zzv|Ih+3hE9)G8EaSu{UswYrYIn%$)~xW1tt~2w
> zTG<2wKq^}Z1mPolb_PXCU(ySDi?MEMI at 32zaQ>4zpc<a((8uDr<3>RGC9t4l%Zs0K
> z;6awnTs^H#Dh^SIN^DG at tY`}NU<S7}YR&5T0`|_>Rj{3ce&d^Zm%V%Bkkn+H?@ZtA
> zHm`Bu{o9P#b8~ZXaB+Wtv61<VXf>uk<BjKVmwB1;dR2>7R;#@D(lqLBQ^lylq<gA}
> z8N^aMW&Pn#f%e+B0#)Uo$ID$Oui at Ybxr;>H?07bV#Y3kW_m6sJ#3vuz7ra}EdSQgg
> zeKn~<5r~A80=`7%yx at HflJKu;7MAOX-e8ruHNfOg6l)_O3QzWxwrJI+)VeV3?A1I4
> zU|o*&%s7aQQ0l?8Hx+!YIsOAp;y|IvCIC%l-FNxXg_mJI{drW|77ed^2S^2*4tXW0
> ze*w`;X9r;}fs2flMaty=hK`UCgbJD6r+?Z$=j-7v8YI2bwd!wvZk`w%^vH%?ZT31`
> zuQ)^yL`plKNp_~q=z&j50g>#Nnwl<lhqZi;Z^)*}emMLWVeF+aIO<Db&;tPA<zWZX
> z+8SRt?lS_`OcYmY<&P1>d=)&MYx&Ba0#0rQ$LoPE=LJe-#}7Lne!yeSvFGWWX at X*q
> zsXR8s0E8 at H)&2Ih+8MyJrO}1Q_@!gw#!_7v$1Sg{L_7%%(B_nm)YHqXpJVYSRX~JT
> zL&|UZJAM|@hW$JZ{~~JASYZ#>rUDR-*ry`buRPY1&+cw)T~@l$$i2u%$^65 at mEFRh
> zhpKBhMiMsrUY9?fPm13SzGtldV?wVwB%qlonM2seFi$~oW)8A6)KTE&<rOfYF*WCJ
> ztPj6=9P6OpDBe=*ykpWRUc#zd2=irJf>Oj!F_!11Lwl{RT}`Z4<;6>Br*EyF;C1<K
> zwX0UF8q<ZFl2UoG0ju=hqxFra%|B#Y0EqY&A5(fi2NJFx8V&~#{3F at P1W~8<EkSLc
> zT at BP-ncSu(to=s2s#z}ou&~%Eg57RNQJqZOm3!bz{YEu7k%7t^#Yd?d$TM(jMIeMR
> zb2W>od_y{gX+O{PyI1kjGVp=+5o)8n_NmJlO8rB4g^r2hl;d`kY7XOu{8d(6>igQS
> z=XY}D5Eu&ivj_+l4n0cq6!xecW9JL!K<C$Eg~8- at b<_!O<_k*?(sV25+-~+8M!?61
> z4w38H-JE$gl&#@Dt`5F~SfR$VgOIYVyHVNJ>-i~jghqp1RE)MMw+BGa&2cD|EY=<h
> zo&6~M4V|f~tP+4EiL0W$n(T+}pvXdvEm7y}Y#p}S5pv$fLr2r$kNl^~_b2z?Jg{wB
> z2Xi%_7xmb+^rJihpNG>ze-cNgFVNhIOW|Sp+ at NkmJ)0IB%WbXo2)7&TqpL<Z1bD`m
> zyhy at dXfqli5$cuhbD3f~zoxA|sjn|yq4dC9<bEmA$k-Yzit-1?laZ}?cK#UJOfuc!
> zU$B=ac%;+aKYITc_&RplJd{*Rd_90m+Dxo4pj~Cb at 4RiM+xP}N`*5Zw=)Q5os`mD>
> zEk0=nEiFFh`z%1SPtetR<R(?nUGjMS8L3Y#&Q(85gD3Uu#nDQzII$ztQd))Ci#1WZ
> zLtgzxAOQ#__WZY*3DB6A>rF<)d_0FC>B`RI24h;9BKg at 1+Xw0S9l;W?u<3Y-{iCNl
> z3ssgAL9;)xurF%fj08g1bmzo|X5>I*qo8)H(;QRwW8V;opIapHX?jh>o!VaQafX4A
> z+8+oi7<|An4WN_i8bdf2c^Vyk!_fM`*J&E&A*H}bNg?UzhI`rh{i?bc&728v!o?gJ
> z7L@*6RkcJR`(@VPq^RC#W^z624mZ`b6kpxfO(JJ?CBCeS-*I@<*pvEh%;;C8HhBb^
> z46b<;?;%jBs7{G-L_UL+5Ep0FRn0s3gmXqZgcmR<s*db)ML`~BsqE}T at qCF#Z<-&a
> zklU^6r)~N@^t|Hif}n3E9`c>w><3BbR<2lQQa at 5&S5Jz5AKR2naDCi at S#OuC9&xvh
> zwAk_LJGT7?5PXhMcO~0!WtBuP-I5MRlVs?XHl|M4j#5x at KX+vfa_@(lghB4OdG(V{
> zf=iOr_)EaSbe&_KI=<4%kq6dOS_gfnY+2i@<g8#njAb>6Rk7KDlw(Q?3NqcMWhdFI
> zqp%Oy^rUH at uvS#*Tf9vCJg(d?ko6O?A8k%=eg4$l^v;Dv>=(Q-2C;!R6VaWj#Y8_e
> zbR{O+KH6^jfUOG7chT+s10rvMyU$j2Woj=J@^^P(`r|qPgXLYMHb}{>Q->G4&ST^c
> zQ(w9#l5o}yql8<Eg at +K(fmjYXIvfpUVAIvf+&otfm00kf?gw~4q{tzEk+ at D@RQPSi
> z>uM{V&$ty_Imosb<kfGNRe4*Z=Is4;KgM>rB}AXURZs~%+J+q|tk5c^=SbuLu`8SJ
> z$D8j}e_Ar--A@~jka5gBd)NJXAS{v!iW}%2*#__ffTZo7h)WMl`)FuwyPN9&)7Y2C
> zL-oGz)0CaDM7HcvNtCiLQBo2~Oj#zf6+$Y;zK&g#6d^<^yUITHUD=X-C)t<DHum2=
> zZSVKz^ZI>X-*11Jb57?x=bYzx&V66^bzKk5a;ln|T0+rDK9g56JuefC(>o4H+qqUe
> z(e&smT*nPJFm$})yHuaEVkJL;XRCSlST)}xTHfO#ZYV9U?x at d(X5dz at 13xvCfSBKR
> z+{(dx;$hwRd9%MRaXqdM^N>`+n3rzV6;CVfdfqhHJ!JTX#o<IgePjTuw77MX;1`oa
> zUHWW(UhZl6rZabK!%+F#`d$`lbMSPecXd7SsWcMCBc>A4(mmD^s;tUYoo;M-Mz4(r
> z?R6LT>55QstSNl7B^0a?V{O0FH)s3trvtB%gpeDeCO;~7DD6`|?R+V3aCH^)uurkZ
> zIsMwfIErh8IrF#1RjHw at SwXy%R=Ik>O*?t=WWp{p6B8nm at -YJ!7hMnO_Q|uSNsl1s
> zIP%IJ97d(jV9(^989&3Uq at wgt>9rD^*|}>>948BeG!*UBt1*l6w=yyelbb5>Clz*h
> z`^qGM at lR5%1STH$?w$C`Wx6+ZQ2Da5>GfkQ^>mZZqf;rNwqdt7`dRvz=3Cta<pjM1
> z`-Gr`R|!Q4UlOKq^CPx{2eZytr|rOC!xnnJdR0<V%b|~4eCB~)wYyNSJQ3V<L#hKi
> z>*;<&@ATu3J62LV5uFRef6vu at 4Xd`4X><tVhBFVl$=dhc)@+}GLriJouAFsxM~###
> zS*<V;w->@;JI<l6b8_wi7PLj#L3J%)?flULSz%q;j~nue^<~_*{G2!LbXZ);hiab@
> z&XW0eUaNbS$W{C(cS=BB>_QaXVbpI%Vbr56_R#Yos0`&bf-0spW6&}Hm0%aapm0{p
> zAV7@&N>Jo_BhVBr#x_J~s_b?@^+nWqoQ=iK<HHsc^h-LJvRb_^Pn}XIx-*>HzDC21
> zy_)VJYDkx7RNLg0nRXy_*H4Q2cRHRXg!W1+iwm at DHCedN-`L!{lgm9Gv{Ukc4YG;Z
> z6AbT}i!#xtb~r|l{Z6zq at -X{;RE~zM6zOxZxdM$dgyt#d0AVa)?gh!RKCix`%9%Xp
> zE`n{qhu=6wzRVc2hTaGMQFY|9x#ffAIB8^Yj>fyKmMTTJye|%-Y3D8MFMFD%IsQkp
> z#L*1|Tljvy@^9ubnG<ku$}q|y57l at uxI}i?yK%isC|+=d-8Q{rpR3U<;phi<amk;<
> z^TfYf+Kd^0q_MyFw1E9r7lw?DzUKQ{bRF-@@Z-_&7Q&6Naw}i(L-ZDjE?fL^le)GK
> zYiH(Mm{?>C!uKZ*&C}c{c^q<K|9|Pgil*Cq*RKrJ1}+iCI|RN5->qFV6u8>3$cL8y
> z_m#h6O71#t<)@ZLRTve>Rz}m>Uu at ex(<q)dqWyeH=$df<ixZfoe?Oy*u@#9&yWizr
> zu<g>`WBJ`XoX_C~Yw<&|=fua#c$<HB1+-=$YR{uxK_*+y-HgK$J~w@(kiXxhyfC_O
> zm|)9 at 86eoMSIpe)V8sO~lHOzdb2=NGGX*fv<HM~lPm578bv|qjPgN#DI7ATQVf}#n
> z%ogO#m>S=Q45z at lEd%`v#3%vS8q^@s5sI}pr4A$hh_Q%db`-^j$e3(E`h=^8CS;K8
> zS9K<JMQhU#le+ot^q+KXDpSbZ0w`yW-M*lcs9*96QIS!S(LZ5qNcyky^l==K)wjRp
> zqP~8pkl(hULD!6udXvOu&t_G8g3!MkS+bu%04(M;p=_lORlMFlui~C36PaznME3?q
> zNGZI>9Vc0R_f&G at -?lI8vovxnc^MKG|4yR|7}n_Ri~vRdrJiXq<HX_ at iudDysvgCg
> zsv&8O?Yn&;@^2&2wAYlamv-=X{gtp{3Oo2+S?|7R9e_M5eX;YF_HP37$WQc7SS+uE
> z+3XLvd<L{jzd)xm_qLQk7{<Z+*6}Nz_HkRN%fg+t_aeq=rs>S#o!fEXmcwiz%y6;W
> zxBTM8?Ki3&Go*Moi|x`KP@#FwQ8}KEm)Vg<bl6Lb&=0+%pan>>h-uXP>De0jZUCM&
> zj;t!V>S7I;Z9=}uGADvuO25#3L+(184E2?<w_`K>>bZOB8MwNf?bJW)fJ*p>dAhXJ
> zETXp4#ZZ9ea&%*i*-XiK2iFccQ at v|5Uf-V~7+)SNE>_Y!d}@Qh{8>+^pUsUbox*Rg
> z{*SnzR+2I1cU;Gl$Io|6vFqf!R7RLMNYZT0ht`0=sYc^a7dlM+CQpclKVJ_!*bdbX
> zSoE8_aYQOu&d;AOS$pUvTRJCpq5Gy}wA7|IPpT(A=o%tCBc<06h}(ghq0&1}$pi5f
> zPkftR$e>sg82O0Mr`pR}RxU1^oa-Rz0h)7GYzal5nyYhq&Up*%jLgn(`K`-*6gpyP
> z2FLq3(~eoV`BcNzQVC?g)9pt8O4eLq3H`+OqamnORlRJ(Zkbtx$Pj;kAsn7R`qkqu
> z^ZxzSAyGP!+1wOW*ZA~#bsDtU8)`_eBPG$4gq!*Sy+$~`mzRt?#5)|3F{E7bguH8&
> zR3N7*8uh7uJiTX(8E>GL`tsep7@*t?EqjT-ZLY~{8_E!WhwX#kx09JzJ}~1=;fk87
> z$B3Je<gj^<FD1ujJv}CrRq7BQ-yS$Z9gbM=jLFs_Wh&1tM!PceMeY?g7asM3CZJ*I
> z(y5z%-d6m(L(||w>Qh0I)#?vWtsHF#syc>;GUfmad1mO%T=<a3s0(5)tE*T4-ucOM
> z`B=zh at -B0mfk^PkdiIPARwk2<$_RMlg%84Ts~qVW?)4C-#5w|!^LJ}??oXik at 9zhO
> z!8}Kmy56#81;{4M=<U^_EIMC<QTggEYoE}XE0xJJ>O~PcO$EF4V!OGjdY?|{VG!E8
> zFPW9(K=xNH3lI<c_L-rfyeQkDnO^EUg~bcVr_u_N-UUps+o~SmvsAXl89}BQy?R}M
> z>&S09$14hZV at TkPU3MovluypI5C{`x`E&+WE{`1JY(m1giTX==B=kqTAY(ii$3Svc
> zTOHECDwUZe>mHJBq{Wx#C26hj=w&E936w38U4K at 8O?G(lh24%i#V8v*)4_A=udm)u
> z8cca%cmY<Dn*zX-{^uJz2}LwWfu2+ggECT%4I22VAnFEvyM4l3<C!=cj5hVpx4BRS
> zQjP+Nlp7v9d-vi6h;NVIwpPz>ZcQ777vc#J`uTjLs}!;gF$Y;b$9wX;+zah7`vycT
> zYemO7@~riWZZ8!%kSD?${H<@~MxQWd&?JMKVu#wyIYx>5Kk5i#tksALj0z56oM#W#
> zZv-cZ$*bGTVGBu)^|+w5WvhQwc7Q7JdNN<2ViJrw2G32EUkGN at -<|TCg|OhUpIwP7
> z=)=!LKu{VW^y-*?pqMcOk`yi|^-JCtxcyJr%%@H3u;dJ3f`+hYUCCQo!wi=wP}8y|
> zlREjXO1QH1ftm}~!Nz{Kx1>}$p-1~!8ypMy;5ktB&y^f!^h;46Z+gFi=HITZ$?X2P
> zo7TFuSa5UfOR)BbkyEr-`<R3wsvhU<Wv5@~ZS at kEeLO|&+ctGYK)-5Jla7+om{m|(
> zx-cOj0i?;Im3(O0T480{C)qc&C#VqDlm+yoE3~UBD;?(h+5XHAaB*80U5O1K^HkF1
> zdhsJs?EG9%lkVilTR1*;1ni-V{aW`Q1O9Akc`zct9G>RwtJkkbMMmbjbko!~`Pg1M
> zlrE;<lPR1|>Om5Gn<NC~D;OSV&j^FL4Z)g4ahZqdpdb{8UNON%8;KG);aA-7=SILG
> z;-A9srw+ZK^(_C{VUQX=1$q8w-E&Cjca{~Guba$xg=ah#*;Gn?Vg#f36tY(M72n at 7
> z)LlILvhn1qEe+XO at NHWr&KY-o at Ih~>FLvXyf$>4miD@$b&|vD_Rb71!&e{iOO+`%I
> zV2z=}zbJf&f at Mne^w at FVzkM^x<LiaabdMZ{IepfyIV07=tz5m|=PU4`)@kX^7Bqck
> zUv91P5uWZS-31&vd6|NLFP;k8?+EkrBz*|#oJeEyv+M;dzA-L{=LJl1TER?xCf#!5
> zHNrTrcOET4JbFJj5=$b;<?Xw{>#HSrXI>G<wQVn=%*^{XHJn5RhE<Fu*;Y|Qb*->z
> zT8{a1AJLMQcxI(j<ixv&%r&HRCnU^c$7O~G9hMa))-hE}ASg+D=<aRfgw9$7aI{3x
> z#hXcC+|_CCbV+cv@=~C7_P)&kCpUa#YxLwM25~j=pHcow1 at 7VD5kQx1zJex}I<V`l
> zj3GXS<>wpg0LUH(bqK~R7|(4;IR7*d2m<ch;n3*2_J#vS{xX92K)@*LEUxy{Obd+P
> zUZQaO>CIAmkXd23or*dV8J2j^;{I+tvB|<-v^G0V*ahUdB&f})sH`_Zkl!<Qpf+#1
> zWl&Nz at eD9O$JNo!5+h<mrvmcIF|Rdin#!mo*+h`EeuyI=?wQ3efcB=7y>!J at CP|;U
> zhQod+8j)3bv52vI7|anqpkr)o`l)9hZ?#A^zu_9;plE~n_GzK>tHZCg={cpRyp$%c
> zI_T(rPr9P4vlVGUJMjKZ$=t{{#m~E`?_YT at 2vl!EJ+T4W{e9C#MUwUyNSnB{4)52@
> zZ at j;h;&FSXmM#kY;5&^%g_4O8?&{c&HC0~yh#lMN-1a+_2udttdk(D?ud()!fo}_U
> zJE&406s%7~cI*1Af^Mq>Q?^J at N=%NFG&wF{UHd$duxudWg;(>(O at X|u*x-0JMHuJ)
> z#zdRQiTOK<)mzm8=~ezGj8DTO-j~U#XqMh4t%&hj%vMS?ZDh~eCzE|5xDysoHm<aU
> z&j;030Y<jk3Mj3WCS=$r?}B26R3)csmZM{%qM{-qOmg)uUAi~Ru>fl5JrG3n3|YKd
> z^i)cWz1rD*C&k?DUj>I+x^$Eee)?$sj(#(Nu#0oWF5XsZ=)#ZXR4R*HY$lgmEu0hD
> zYpm}W^{3PTYw4V3&C0Z2$rrb~aQ$pPMHtJpjFY`4ELejbAI$t!9AJ26bsnT8?(Quz
> z>fNA!@_DYTn;sSr0KN>qbk-Ls6*BvSD=-fupZM&0pB*)@^j*B2cw7Q4db9a at o^_EO
> zSr)zRL>5|ptJ?$_FC8Het9_^t?UL;`5$~~88_HjK(KOX=J34x3b+S!MN*o1JC-3Kg
> z{`(SZ4b`S*X2fCxtv?3(aHf6YG~3&WcD9i=zONbjL)6sc!J(+E`Pv^2?(He-?J1!Q
> z%_%RxX3FQRIL`HwD(hZvrZO-M?sEDB#t;oFq-h<ElANRR5MBnwVz6TwN<Pj>=U47@
> zq#oIF!r$5`_aX%_l3T8TWBI`!3DHOt4FzVWjytKIZ<d#8f#bAgISaT<r5YA at x~&bM
> z0564=_9kp7)CxxDd<KZZ8dLnJqh6l%Mm;|=<&CWn78d<@so+L~t3=n-*}87dJ<gs@
> z3R8G6T;63$+m&gi#Cxm{#2B!wNky06=M`$lQkS&@Po9*H&ZWvadgkA`okYomw(Ku3
> z265SO!}r_l=Wgk1WOy{a=n=OlZS3Pi382sZhrTM at R;t<sDl^Q{c&a*m5d8d at m~3;i
> zXktg{K0C-MX9IAolrvO8RBh%nV<hiSG{+53tR1^iZFBwbd`VCSy at U05<J!)~%;rzG
> zxl!@t*1EbnQ$1Sg_m&;UFl8ond{M^R8_4=nFCrcbj9`L|)I&>Ke>zQICAYp?`Eb8d
> zkjL-1LBYgOz(65F?(t<+)vRLYmBnmhd5aczLuY8dqR3tSx<{H+pKciAEJ2Zudd!wJ
> zizj=h2dF*c;eSwjiRDNhS6&OEw#^{6Qs0+@<?C3a$kqz#61;0)Y$Y3y8V?hQ&mKQL
> zyYL=}!I2qd$)<|cZ0X@!4aev64h{#(QWm|^R2<MCUX{D~60ET(c+3KePdy=qHmvEv
> z$h$d<O5YcNb-qate{KnL9glRk^OnAKj;FBf*g=+C<k{ZAh?CTX3nSDd%^p3cxn)@p
> zE;f!w{INvDepTE0$h=FCY&nx7<Eg!|giE%c-mO$o#hfa<2_0`t2j-cgpbvN|w~iO5
> zt<I=M#_6G7-v4%i6<6pa?l at 2+Es8Ue^*DA^&HTP9ra$OlIpY&_VwLi|%a=qSakHx$
> zG7lO%krTs<W>p!qIj;*Aj?9y2_FwED6t>l$wbsbkEnZOW%eCVF_wD?~+Y{cupA8AI
> zRoH$YlWh6HJT&4-Y3kd0aaILTps5O{F(w;VZEUXI^;wLQb=<R1P-4eRdlHrozP7HY
> z5{~9|64k1AQ8a6;2Td8eG?p|D|L9<RKh7y}Yh}ry^l}Uf7JJW>%Ryu0>hv6mZ99mo
> zw6v@;4Wz3}RvY_RiuK-f+Dc at B*hknl7)ljCU#}K@)<pAbI<_w*FyuhFr6Ae0dd>&x
> zj&f`LNn)DNcTCOL>aAf_%n`YdI%z4|ZyvGu)qqrQIJsj4oDiR&d1L4tsGSxP%cO}^
> zVMlkM3V$;%f}Su~yfjva#Fq1o&&E1Dzj}wfz}soMGh^v{OqEfyg4@;(p-KXmY^OhK
> z8K<`!!e-Ky=@y at _0;QYNWVLB&1xrIzr~X3f#j5lH{b?O(DDwMd6i22(ZwErd`}kW$
> zc8tP5Z1*Knqi*4dGd8Ml!>U8E#;<TJ{#I`436qTzpN|?BZr03&e(Crt+Q_U|tYO!6
> ze}qq^g}yef+e6zIeq4BAD~0*>ncel4ii;6wmS at E`kJeb-xB-h}R{1`6cH+~-Qm$Ka
> z)TT+m2lPy(NzzF&O%^VZ!%wvv>0YpPe002Uf#TQBa^zC!sSdisyGz-`kHNQ8K2i9_
> zzAcwLf&Tf`Iqu=Hzj^9WreTw!(UrqJGSAsbkDqMT3&N+eiJ_;$rI)uS1-&HI=%|n!
> z`_&$OLHMXQZL&M607^#|0!x1XEWtlnVfT2d3A=+vl at n$fankX|QP5*XJ$-vg#v<8?
> zxHtdacq$)z-7bwc(cBcL^0>(iQ6!_x{_UM)tXZcna-M9T>{|!jGS;7-$_!;@ffP{K
> ze4m4s96QjLFhf;Ag%3jdv=I-L-dPg8hZw{vSa({r+irPv8Eer!C at g2}a-i4Fj{zs5
> z`c82Fo{uDTeVUl>gI8mciuB=9?N1JiW{-1}oOXK9baX41r7<(1{RLD^2)=hXZyT)d
> zYv=@$ms0-=QXnq1c4g~jKxT;Vqxnp2a<}ZmyN*M-Exz2(MHKIJ+bhJiWdt4Lt?SGZ
> z36i7`no=|J at esL@CuzhvHe;*3d!*Ku);jO~^L^#YMgp@%&a%*CuhR3tfsbuBGc&t!
> z>{<OdN2R}dsC8S5gElMn*2?giG2x2Oei`)X;cvb<3s(!{$oo8<{`v1uM+A>OI6F+B
> zq@|_p!9T2 at 4ozG_`HF5?cd4fFDWIE<=~)@zG*n-Rao?(uy2n*!U~#LoyVkeQottDp
> z=Yq~p<h$ai5$k7NVjRK^IQM?hpE!2}S5So!PaUI|!R>a+#g5AE^Ct~~oUT~FMRLjW
> zL^+ocV>T5l*$16V5XSAfcs;E{@5+_%$B#)%o<v2lMl at 7A=qKdgYGpE})>X#&iDc96
> z&$yp3RY78e5JOzw6GFO565**+E*6!cw`WX8WS9puy&}ht`|VJ0O51&T4%s*P6L41I
> zr*ak+lsA?YE&c7RwBwmVj_{-{r!k at wBkM+}@6jc#GRm{03_(5Q<)t=cl&~1tOaJKb
> zWJdB-VDie%vpB(wp$cgAuS-klRB*ATLuB6JW|zdGfuLR?;?C7p?ifxFZ#Z?`g$_!H
> zaAkRrt~d-&7#Q<>q=uNAg=n1Q;be at n2je6`$S}W-R<E*3XgcAkY>lRez`TfsxbfB2
> z)jP`wH%)hwLN{9+`a;WT$!S_5;fWZ=s$3J0y`A&UygYC&#~P=cr+o4Iu+dIB#VctD
> zzL^W7ZWt}ESh&jU&iIHzRPVvXuo5=^CwXszbn at +`(RP!jP-hOeEnakzr6abhyVGY~
> zocGtI#|dPDQ|ny|A^RW3$G_8ko|IMz4C7z>UISY=V{O`MrleOU`(e at OWs!42#6&3K
> z;72L2Y!Ji~6Z&mPVcs^^eD;oFL0F^6EFEiN^a9+W+5KLx=j;Nyzz2%JM1KzacXSmc
> zcX7WXd-hI<?BQ_q3;x*TLrSvGZkATs8lB66qc{LnoKW96mD$9znkl2k5p?%7kIPow
> z8$Ru$jkZ7Z54JHuHNJfPD}Tc-jrUk<e*p>xY?xaq#PvFaYg!`j4iAQJHgh&99%1Rl
> zcl+h`j12|f?K#lf^`kYs@^WoZj0gUp=OoOb`5 at E5S8Zhtm-n^12b_Lzsph8Btj~fL
> zdwbzi!zr&k(YB`=N+`|!_zcfUNKV&Cdz^27Gmskmk>Y_#lS5(7y!!a&RYCY<ikB9x
> zGZ0}%#?Z?!qi+&`lM|j{_v5e}g%*1!1otlS9LB(FlI5f0)_n_U>p(TMKF at t7q_DCI
> z`Pzvnh1xCixr|(H(2%_n5Z2pC3szK#?@zvNC&<tFkDewSn6~%AzH5_qo?M1??A5Qw
> zfeREJ5N-W3(@t9lFTOoHrRwzIyLjnNj=saK%IUpOdJJD${Q+9Qqc-lMa^J3OXhCdG
> zpY=Ft at X|k=BB`R#XAm@#L*8TtiaEK#E6&<#VUm2 at oaH~=eLxWc)gK3=(_mLM-M_UI
> zG)InzpV=Ts)P>biQRfOob1zPe3$t?Xw%R)UWe&}jTe5;1)Dd}0EM{BYzIf3nDJ?>1
> z4OTlsUC&H4N(yB^P5<nE<dgTWJ$8>*+BdyTKi1c>a6_8XigsX+ImL}!Ua&y`rv{nq
> zLx%`w?3=vtsWOnb4hP8Oi(bWKw=r{M{pIwq-x_0<*Z}i at p@Mt9l2t$!;C7iE5x02a
> z`zckROR==u!uSnUSNtzp4_18X!SU03KGPT3nf)<8(1rUOIuW2-4#i_?9ppuMa2P;J
> zytEmxpBg;Ck(K$tByNB_a8US0N6O`;H<vm1V^d!mtP|`7@^&%}WzW=8eJb3;;mJm{
> zuJiMIGK0`fi(FtmCk*r2qbdxxD))bk?jJn;8{LP~{f+J!n#nkis9)&5R_u_mIbWQm
> z5!VY#8n+D4KeaoQhg>WL?n3*UFfUZMjq6rz{ty?XmHTp=KOHCG#b>0IJHEyOY%iBP
> z^{Wc?Co-sZW(T*i$;nxmKKp_ltFHG6*&xci+n0wfdcZD_+pX&7#3JerAI6k0xgSQ(
> z8xDbCn&16PUWkpnt_|f_T^Jhw@*44_&)#y|s`K+p=_Q>(7AHPDyNn06!bmJy9V&xZ
> zEY`J-M~@V^cR)kp%mg3ahWP)c=nM~Mp%%Cc3yW<AKf{OH8^~Oy48=E+3f3A2$T16J
> zV<smv{1R^DTC(7Va!lH8dbpLjZ<CwOBoL`Mr4>_4PY!8g^(|2QtUOtZ?07 at -Mf_*t
> zPnvzJe_S%sHx9ZrP`&4XGC3!VrcbZ%hx~QdvD(6LLccsikhP4A^8oY-f7%&om(`h{
> z_X3iC83)&^KsTsO%Y?UnP#WLJl^LFzYuO>-v|NQuv3PlBcWBrAEQ<OIl|9R7dVv%+
> zpF+~gAP_ZA)w5Q%V>wdlKYtYGHQ*WUjh2YMackz#p-p3rdcmB#J%);(k%?QI3xUa;
> zMfq_u@*>-h3xhAYy3Pws20<V!J9Sq&*Ig>-_CQfID8WNehG2Roqfs+6)$Y;|D5Mq4
> zf;?mF?*2_UYuRV19mMwyb9biF8Dw`}i_+Pl4jV|XxoK&gEG}5?1OnUW-3!edBf@(%
> z%6nk_x?r!CpDBUdJt3vbm4Ri;d9iwm>Dj>5!Hz=!JWT~7^4?K&VwN75JWRfQul?z#
> zKHf)C()N3%zT^b<fc2aB9|(;Uj5Ocp{qru9B^w(X;EnBWlQ at u3B`xKuZ>RVub|r%A
> zP;6?1{g<StJN37)aIt$XS-86(zoqNi9dJwpNixH;`;ghd6sJ at 7?hp0me at O-QKr#DY
> zsX%twKdAs>csxK%8?!)8M{~Wvj?sEMLUS-O0CfeF>{Qfa-HK+J9^lXcU9QAc8d0=#
> zP*$N3y24c0XG4S0vH0|&Rd(jw?~RdX`>p;o^KV)p_vfid{GTZ|Cch~+#+ at PT9pueU
> z<6Et90nhm>)kjJc?~Q`c*W0J=V%-b at f0j3!*fwq%T!c`VXT+L6w~fmDca+RVeSb}j
> zg2HEQFiDXd;v~DjIyI&$GhF%W2`ZY at cIR3RP27Df^t)@=Z07H2`T9pBKEO|LZhrhb
> zFzpK4G_|_2Ji0OsIqZuym1oPCjd0VX#8>>2Bv2bNRVS9_J3fCP%i^+D at PV?W2B8J2
> zPfqXsdUlR<W?S;trg0G`ydR%*&K6A)*u?&aQ~<l-G_F=#r)av_#hT?zv|;S#a^*gy
> zjmb`2PFW_kW!FbiP*PT4IsmJkhcEQ2?q_bo!izb5MY`+p{-L==tYE;4A%;cs!`DoM
> z=H_()mI;SXm1<We83!xM9lAdty8}up>z4r?X-D|@`g5uY6=~VSH(jV5uandk at au?k
> zBZ5rJ29N^yl5?pcL3v81o%G?}HjAGzAk%>eM&iv&k{;}Ssxj7t+>4fVYgyDfEMLD$
> z6ScV&b?<({3~*CP at j+F0X5hfJdw?{-2Yc4d=3LK>KCz_3ald_yYPpzr^%MUl1#nw7
> zheVGxU(YHYe_R2sv6W-=uTT6}#of=}|9%$Da1u=}EffX4#4Bb4q}mZ~AgsP`{<+E~
> zU6)9R26v`8o3BjlFASJ?df2b-QwY$9II4(wGWB{!=j=yB+gS^-(w&47(lK|vywPOi
> zPwNlJ#^<~pww!8$KDyhoTRqI#CQBPj`@GTAZ*3+ at 4NDDqGG))C-i4<}^*{$WFvCxY
> zPIL}d7rwn+<I`KokCS`#G5OhcsA$Wn%q{P|!rzX7+7wT<Ai_fZQ2|2|>uHDrynEUP
> zB&;Q at Qd`Pp18nb|ljf%WKN$esxFN*-<}^bpe9T2@;i<`WYMJ at U(jTSF(;&*rAnW$U
> zidVzp2OoOWWu(Y_yf}mQ+Q-r1WeP$m{t8iPMIQB}0(757{v=yBEjJ;72mFy_PM<h&
> zLNFq5Zsm+cohL at 9)uGk9^-=4K)|A%wt);Dvt(~o-Q5hSgW4XPaCh5QIQ;WpyhAX5^
> z0DI^3X9?a%cVTiiihf~lFP$EJFM}Ra?|wa&-UE7Uz3h6NA9NHUm=qT<O;oM=ek at k8
> zl9Vzo?o_p`SDp`xuY;*JbMFBk9e*R7GkyPC?1y?~;-0DtDmErKJ__%*P)G9S2{;PT
> dF8rw6C3mA|d@#J#olFA%E~;pp%TzY<{(p*>T|EE*
> literal 0
> HcmV?d00001
> diff --git a/images/filesystem/tftpfs_usage.puml b/images/filesystem/tftpfs_usage.puml
> index 0000000..ebd449c
> --- /dev/null
> +++ b/images/filesystem/tftpfs_usage.puml
> @@ -0,0 +1,37 @@
> +' TFTP file system : usage
> +' Copyright (c) 2022 Frank Kuehndel <frank.kuehndel at embedded-brains.de>
> +' All rights reserved.
> + at startuml
> +:Initialize libbsd;
> +:Initialize Networking;
> +:const char *mount_point = "/tftp"
> +result = mkdir( mount_point, S_IRWXU | S_IRWXG | S_IRWXO );
> +:result = mount(
> +    mount_point,
> +    RTEMS_FILESYSTEM_TYPE_TFTPFS,
> +    RTEMS_FILESYSTEM_READ_WRITE,
> +    "blocksize=1024,windowsize=4,verbose"
> +repeat
> +    if () then
> +        :fd = open( path, O_RDONLY );
> +        repeat
> +            :bytes = read( fd, data_buffer,
> +            sizeof( data_buffer ) );
> +        repeat while ()
> +        :result = close( fd );
> +    else
> +        :fd = open( path, O_WRONLY );
> +        repeat
> +            :bytes = write( fd, data, size );
> +        repeat while ()
> +    endif
> +repeat while ()
> +:result = unmount( mount_point );
> +:result = rmdir( mount_point );
> + at enduml
