[PATCH v2 00/13] More robust idle thread creation and TLS handling
Sebastian Huber
Fri Oct 14 09:54:56 UTC 2022
On 10.10.22 10:17, Sebastian Huber wrote:
> On 06/10/2022 10:23, Sebastian Huber wrote:
>> This patch set started with an 8 byte overwrite of the interrupt stack
>> while
>> porting an application from RTEMS 5 to 6.
>> The overwrite was due to a mismatch of the size returned by
>> _TLS_Get_allocation_size() and the actual usage of the area. To fix
>> this issue
>> it was necessary to add a new CPU port option:
>> CPU_THREAD_LOCAL_STORAGE_VARIANT. I checked also the glibc
>> implementations.
>> It seems that on some architectures (for example powerpc) the TCB is
>> used for a
>> couple of more things. For RTEMS, we don't really need the DTV and
>> TCB. It
>> could be useful for debuggers, however, then we probably need also
>> some glibc
>> compatibility.
>> Add a new fatal error to catch a failing idle thread initialization:
>> INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED. This can only happen if a
>> thread
>> create extension fails for an idle thread.
>> By default, allocate the IDLE task storage areas from the RTEMS
>> Workspace.
>> This avoids having to estimate the thread-local storage size in the
>> default
>> configuration.
>> Add the application configuration option
>> CONFIGURE_IDLE_TASK_STORAGE_SIZE to
>> request a static allocation of the task storage area for IDLE tasks.
>> v2:
>> * Add CONFIGURE_IDLE_TASK_STORAGE_SIZE instead of
>> CONFIGURE_IDLE_TASK_MINIMUM_STACK_SIZE.
> Any objections to commit this version?
I checked in the patch set. All BSPs did build except:
microblaze/kcu105
microblaze/kcu105_qemu
They failed due to:
./librtemscpu.a(threadqops.c.52.o): in function
`_Thread_queue_Queue_enqueue':
/home/EB/sebastian_h/src/rtems/cpukit/score/src/threadqops.c:102:(.text._Thread_queue_Queue_enqueue+0xb4):
relocation truncated to fit: R_MICROBLAZE_32_PCREL_LO against symbol
`__assert_func' defined in .text.__assert_func section in
./librtemscpu.a(__assert.c.52.o)
This seems to be unrelated to the patch set.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
