Ping on ticket 4728 + patch
Joel Sherrill
joel at rtems.org
Fri Oct 14 13:19:14 UTC 2022
Pushed. Thanks for pinging. It does help.
Since you are looking at the riscv BSPs, could you look at the four
BSP build failures reported here:
https://lists.rtems.org/pipermail/build/2022-September/036496.html
I think they are all variants so one fix (maybe repeated) should do it.
The reported message isn't much help:
1 smp riscv/rv32iac build:
configure: /home/tester/rtems-cron-6/rtems/waf configure\
--prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
/rtems-cron-6/rtems --rtems-config=config-riscv-rv32iac-smp.ini
error: ld/collect2:0 error: no error message found!
It might be nothing more than a test which doesn't fit in some section
but I have no idea beyond that they are all noted as SMP. Chris may be
helpful decoding the precise configuration.
--joel
On Thu, Oct 13, 2022 at 8:27 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Hi,
> Sorry, I did not set a message subject in my previous email.
> Ping on this patch. I built all of the riscv/riscv BSPs that use it.
> It works for the generic riscv/qemu BSP, the PolarFire BSP, and the
> RISC-V BSP I am working on where the macro failed.
> https://lists.rtems.org/pipermail/devel/2022-September/073390.html
> Thanks,
> Alan
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221014/640d8bbb/attachment.htm>
