[PATCH rtems] Remove remnants of rtems_io_lookup_name
Joel Sherrill
joel at rtems.org
Fri Oct 14 14:23:52 UTC 2022
Updates #3420.
cpukit/include/adainclude/rtems-io.adb | 21 ---------------------
testsuites/sptests/sp21/sp21.scn | 3 ---
2 files changed, 24 deletions(-)
diff --git a/cpukit/include/adainclude/rtems-io.adb b/cpukit/include/adainclude/rtems-io.adb
index 41a315c..addc2e2 100644
--- a/cpukit/include/adainclude/rtems-io.adb
+++ b/cpukit/include/adainclude/rtems-io.adb
@@ -67,27 +67,6 @@ package body RTEMS.IO is
end Register_Name;
- procedure Lookup_Name
- (Name : in String;
- Device_Info : out RTEMS.Driver_Name_t;
- Result : out RTEMS.Status_Codes)
- is
- function Lookup_Name_Base
- (Name : Interfaces.C.char_array;
- Device_Info : access RTEMS.Driver_Name_t)
- return RTEMS.Status_Codes;
- pragma Import (C, Lookup_Name_Base, "rtems_io_lookup_name");
- Device_Info_Base : aliased RTEMS.Driver_Name_t;
- begin
- Result :=
- Lookup_Name_Base
- (Interfaces.C.To_C (Name),
- Device_Info_Base'Unchecked_Access);
- Device_Info := Device_Info_Base;
- end Lookup_Name;
procedure Open
(Major : in RTEMS.Device_Major_Number;
Minor : in RTEMS.Device_Minor_Number;
diff --git a/testsuites/sptests/sp21/sp21.scn b/testsuites/sptests/sp21/sp21.scn
index 6c099df..87c798d 100644
--- a/testsuites/sptests/sp21/sp21.scn
+++ b/testsuites/sptests/sp21/sp21.scn
@@ -25,8 +25,5 @@ rtems_io_register_driver - RTEMS_SUCCESSFUL - overwrite NULL
rtems_io_register_driver - RTEMS_TOO_MANY - no slots
rtems_io_register_driver - RTEMS_RESOURCE_IN_USE - major in use
rtems_io_unregister_driver - RTEMS_SUCCESSFUL
-rtems_io_lookup_name( "", &info ) - RTEMS_UNSATISFIED
-rtems_io_lookup_name( "/dev", &info ) - RTEMS_UNSATISFIED
-rtems_io_lookup_name( "/dev/null", &info ) - RTEMS_SUCCESSFUL
----- TESTING THE ZERO DRIVER CHECKS -----
*** END OF TEST 21 ***
1.8.3.1
