Ping on ticket 4728 + patch
Joel Sherrill
joel at rtems.org
Tue Oct 18 13:55:19 UTC 2022
On Tue, Oct 18, 2022 at 8:44 AM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> The log does have the error, and I get it when building by hand too:
> start.o: in function `.L0 ':
> /home/alan/rtems/test-build/rtems-tmp/build/riscv/rv32imafdc/../../../bsps/riscv/shared/start/start.S:86:(.bsp_start_text+0x5c):
> relocation truncated to fit: R_RISCV_GPREL_I against symbol
> `bsp_section_bss_size' defined in *ABS* section in
> /home/alan/rtems/test-build/rtems-tmp/build/riscv/rv32imafdc/testsuites/samples/minimum.exe
> collect2: error: ld returned 1 exit status
Hmmm.. that's weird. You should never get a truncation error linking
minimum.exe.
It should always fit within the BSP's memory and not have any issues with
branches
or calls needing fixup.
Unless the wrong type of branch/jump/call instruction is used at
start.S:86, I have
no idea.If it's a form that assumes a short distance to the destination but
is going
to a symbol outside start.S and thus could be further.
--joel
> On Mon, Oct 17, 2022 at 10:43 PM Chris Johns <chrisj at rtems.org> wrote:
> > On 18/10/2022 1:13 pm, Joel Sherrill wrote:
> > > On Sun, Oct 16, 2022 at 9:32 AM Alan Cudmore <alan.cudmore at gmail.com
> > > <mailto:alan.cudmore at gmail.com>> wrote:
> > > On Fri, Oct 14, 2022 at 9:19 AM Joel Sherrill <joel at rtems.org
> > > <mailto:joel at rtems.org>> wrote:
> > > > Pushed. Thanks for pinging. It does help.
> > > > Since you are looking at the riscv BSPs, could you look at the
> four
> > > > BSP build failures reported here:
> https://lists.rtems.org/pipermail/build/2022-September/036496.html
> https://lists.rtems.org/pipermail/build/2022-September/036496.html>
> > > > I think they are all variants so one fix (maybe repeated) should
> do it.
> > > > The reported message isn't much help:
> > > > 1 smp riscv/rv32iac build:
> > > > configure: /home/tester/rtems-cron-6/rtems/waf configure\
> > > > --prefix=/home/tester/rtems-cron-6/tools/6/bsps
> --top=/home/tester\
> > > > /rtems-cron-6/rtems
> --rtems-config=config-riscv-rv32iac-smp.ini
> > > > error: ld/collect2:0 error: no error message found!
> > > I ran the bsp builder on the riscv BSPs with an updated toolchain
> and
> > > latest rtems master. I was able to reproduce only one of the
> failures
> > > with the rv32imafdc SMP configuration:
> > > Failures:
> > > 1 smp riscv/rv32imafdc build:
> > > configure: /home/alan/rtems/test-build/rtems/waf configure\
> > > --prefix=/home/alan/rtems/test-build/bsps\
> > > --top=/home/alan/rtems/test-build/rtems
> --rtems-config=config-riscv-\
> > > rv32imafdc-smp.ini
> > > Average BSP Build Time: 0:00:26.253927
> > > Total Time 1:04:45.581263
> > > Passes: 147 Failures: 1
> > > This is the detail from the log:
> > > [1424/1437] Compiling
> ../../../rtems/testsuites/samples/nsecs/init.c
> /home/alan/rtems/test-build/rtems/build/riscv/rv32imafdc/../../../bsps/riscv/shared/start/start.S:86:(.bsp_start_text+0x5
> > > c): relocation truncated to fit: R_RISCV_GPREL_I against symbol
> > > `bsp_section_bss_size' defined in *ABS* section in /home/
> alan/rtems/test-build/rtems/build/riscv/rv32imafdc/testsuites/samples/minimum.exe
> > > This seems to be similar to the error I get when I try to build the
> > > frdme310arty BSP with the testsuite and posix enabled:
> > > [4152/4326] Compiling testsuites/validation/tr-sem-surrender.c
> /home/alan/rtems/test-build/rtems-tmp/build/riscv/frdme310arty/../../../bsps/riscv/shared/start/start.S:86:(.bsp_start_te
> > > xt+0x28): relocation truncated to fit: R_RISCV_GPREL_I against
> symbol
> /home/alan/rtems/test-build/rtems-tmp/build/riscv/frdme310arty/testsuites/validation/ts-validation-io-kernel.exe
> > > I need to investigate this more.
> > > There are two issues.
> > > (1) The test in question does not fit on this target and needs to be
> disabled.
> > > (2) Somewhere there is parsing of this output which may be able to be
> more helpful.
> > > Chris... any pointers on (2)? Can the output of bsp builder be
> improved?
> > 1) There should be a log of all the build details. Check in that for the
> error.
> > 2) Can you build it by hand and see the error?
> > Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221018/eb3e4924/attachment.htm>
