Ping on ticket 4728 + patch
Alan Cudmore alan.cudmore at gmail.com
Thu Oct 20 01:48:54 UTC 2022
On Wed, Oct 19, 2022 at 12:24 AM Sebastian Huber
> On 18/10/2022 21:02, Alan Cudmore wrote:
> > *From: *Sebastian Huber <mailto:sebastian.huber at embedded-brains.de>
> > *Sent: *Tuesday, October 18, 2022 11:15 AM
> > *To: *Alan Cudmore <mailto:alan.cudmore at gmail.com>; joel at rtems.org
> > <mailto:joel at rtems.org>
> > *Cc: *rtems-devel at rtems.org <mailto:devel at rtems.org>
> > *Subject: *Re: Ping on ticket 4728 + patch
> > On 18/10/2022 16:36, Alan Cudmore wrote:
> >  > On Tue, Oct 18, 2022 at 9:55 AM Joel Sherrill<joel at rtems.org>  wrote:
> >  >> On Tue, Oct 18, 2022 at 8:44 AM Alan
> > Cudmore<alan.cudmore at gmail.com>  wrote:
> >  >>> The log does have the error, and I get it when building by hand too:
> >  >>> start.o: in function `.L0 ':
> > /home/alan/rtems/test-build/rtems-tmp/build/riscv/rv32imafdc/../../../bsps/riscv/shared/start/start.S:86:(.bsp_start_text+0x5c):
> >  >>> relocation truncated to fit: R_RISCV_GPREL_I against symbol
> >  >>> `bsp_section_bss_size' defined in*ABS*  section in
> > /home/alan/rtems/test-build/rtems-tmp/build/riscv/rv32imafdc/testsuites/samples/minimum.exe
> >  >>> collect2: error: ld returned 1 exit status
> >  >> Hmmm.. that's weird. You should never get a truncation error linking
> > minimum.exe.
> >  >> It should always fit within the BSP's memory and not have any issues
> > with branches
> >  >> or calls needing fixup.
> >  >> Unless the wrong type of branch/jump/call instruction is used at
> > start.S:86, I have
> >  >> no idea.If it's a form that assumes a short distance to the
> > destination but is going
> >  >> to a symbol outside start.S and thus could be further.
> >  > Also, 6 of the samples such as hello.exe link without error.
> >  > The rv32imafdc BSP variant does not have CPU_CFLAGS.
> >  > rv32imafd links fine and has specific CPU_CFLAGS, rv32imafdc does not
> >  > have the flags.
> >  > (I'll research the gcc defaults and architecture differences next..)
> >  > I get a similar error on the frdme310arty BSP but only on a specific
> >  > POSIX testsuite executable:
> > /home/alan/rtems/test-build/rtems-tmp/build/riscv/frdme310arty/../../../bsps/riscv/shared/start/start.S:86:(.bsp_start_text+0x28):
> > /home/alan/rtems/test-build/rtems-tmp/build/riscv/frdme310arty/testsuites/validation/ts-validation-io-kernel.exe
> > My off hand guess is that this is a tool chain issue on certain host
> > systems. For example, I never got this error on our OpenSUSE machines.
> > I can set up a OpenSUSE virtual machine and try it. I noticed the RSB
> > documentation does not have a set of packages for OpenSUSE – I could
> > send a docs patch after a successful build. What release do you use? Do
> > you have a list of packages to install?
> We use openSUSE Leap 15.3 and 15.4. To get the packages maybe try this:
> zypper in -t pattern devel_C_C++ devel_python3
I was able to set up an openSUSE Leap 15.4 (64 bit) VM and the above
packages worked for the RSB build.
Unfortunately, I still get the same link error for minimum.exe. Do you
think this is a linker error? Is it worth trying a Clang build?
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
