Ping on ticket 4728 + patch
Alan Cudmore
alan.cudmore at gmail.com
Fri Oct 21 03:23:53 UTC 2022
On Thu, Oct 20, 2022 at 2:13 AM Sebastian Huber
> On 20/10/2022 03:48, Alan Cudmore wrote:
> > On Wed, Oct 19, 2022 at 12:24 AM Sebastian Huber
> >> On 18/10/2022 21:02, Alan Cudmore wrote:
> >>> *From: *Sebastian Huber <mailto:sebastian.huber at embedded-brains.de>
> >>> *Sent: *Tuesday, October 18, 2022 11:15 AM
> >>> *To: *Alan Cudmore <mailto:alan.cudmore at gmail.com>; joel at rtems.org
> >>> <mailto:joel at rtems.org>
> >>> *Cc: *rtems-devel at rtems.org <mailto:devel at rtems.org>
> >>> *Subject: *Re: Ping on ticket 4728 + patch
> >>> On 18/10/2022 16:36, Alan Cudmore wrote:
> >>> > On Tue, Oct 18, 2022 at 9:55 AM Joel Sherrill<joel at rtems.org> wrote:
> >>> >> On Tue, Oct 18, 2022 at 8:44 AM Alan
> >>> Cudmore<alan.cudmore at gmail.com> wrote:
> >>> >>> The log does have the error, and I get it when building by hand too:
> >>> >>> start.o: in function `.L0 ':
> >>> /home/alan/rtems/test-build/rtems-tmp/build/riscv/rv32imafdc/../../../bsps/riscv/shared/start/start.S:86:(.bsp_start_text+0x5c):
> >>> >>> relocation truncated to fit: R_RISCV_GPREL_I against symbol
> >>> >>> `bsp_section_bss_size' defined in*ABS* section in
> >>> /home/alan/rtems/test-build/rtems-tmp/build/riscv/rv32imafdc/testsuites/samples/minimum.exe
> >>> >>> collect2: error: ld returned 1 exit status
> >>> >> Hmmm.. that's weird. You should never get a truncation error linking
> >>> minimum.exe.
> >>> >> It should always fit within the BSP's memory and not have any issues
> >>> with branches
> >>> >> or calls needing fixup.
> >>> >> Unless the wrong type of branch/jump/call instruction is used at
> >>> start.S:86, I have
> >>> >> no idea.If it's a form that assumes a short distance to the
> >>> destination but is going
> >>> >> to a symbol outside start.S and thus could be further.
> >>> > Also, 6 of the samples such as hello.exe link without error.
> >>> > The rv32imafdc BSP variant does not have CPU_CFLAGS.
> >>> > rv32imafd links fine and has specific CPU_CFLAGS, rv32imafdc does not
> >>> > have the flags.
> >>> > (I'll research the gcc defaults and architecture differences next..)
> >>> > I get a similar error on the frdme310arty BSP but only on a specific
> >>> > POSIX testsuite executable:
> >>> /home/alan/rtems/test-build/rtems-tmp/build/riscv/frdme310arty/../../../bsps/riscv/shared/start/start.S:86:(.bsp_start_text+0x28):
> >>> /home/alan/rtems/test-build/rtems-tmp/build/riscv/frdme310arty/testsuites/validation/ts-validation-io-kernel.exe
> >>> My off hand guess is that this is a tool chain issue on certain host
> >>> systems. For example, I never got this error on our OpenSUSE machines.
> >>> I can set up a OpenSUSE virtual machine and try it. I noticed the RSB
> >>> documentation does not have a set of packages for OpenSUSE – I could
> >>> send a docs patch after a successful build. What release do you use? Do
> >>> you have a list of packages to install?
> >> We use openSUSE Leap 15.3 and 15.4. To get the packages maybe try this:
> >> zypper in -t pattern devel_C_C++ devel_python3
> > I was able to set up an openSUSE Leap 15.4 (64 bit) VM and the above
> > packages worked for the RSB build.
> > Unfortunately, I still get the same link error for minimum.exe. Do you
> > think this is a linker error? Is it worth trying a Clang build?
> I am not really sure what it its, since I never got this error on one of
> our machines.
> What happens if you compile the attached files with:
> riscv-rtems6-gcc start.S abs.S -Wl,-gc-sections
This produces a.out without error. I can post the symbols or objdump
header info if that would help.
For the minimum.exe failure, I can add:
volatile int x = 0;
to the Init function and the error goes away.
I can also get the error to go away if I add RTEMS_POSIX_API=True to config.ini
I suspect that what I am doing is adding just enough code or data to
move the bss symbol close enough to the global pointer. I can try to
compare the map for minimum.exe for both the original and modified
version that does link. The original version will produce an
executable if I use -Wl,--noinhibit-exec
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
