[PATCH] bsps/microblaze: Fix console interrupt build errors
Alex White alex.white at oarcorp.com
Tue Oct 25 01:36:05 UTC 2022
This fixes build errors seen when building with console interrupts
enabled. A few places were missing bspopts.h includes, and one of the
UART functions was not defined.
 bsps/microblaze/include/dev/serial/uartlite.h  |  1 +
 .../microblaze/include/dev/serial/uartlite_l.h | 18 ++++++++++++++++++
 bsps/microblaze/shared/dev/serial/uartlite.c   |  3 ++-
 3 files changed, 21 insertions(+), 1 deletion(-)
diff --git a/bsps/microblaze/include/dev/serial/uartlite.h b/bsps/microblaze/include/dev/serial/uartlite.h
index 6e288d4dc7..2fda3796b3 100644
--- a/bsps/microblaze/include/dev/serial/uartlite.h
+++ b/bsps/microblaze/include/dev/serial/uartlite.h
@@ -36,6 +36,7 @@
 #ifndef LIBBSP_MICROBLAZE_SHARED_UARTLITE_H
 #define LIBBSP_MICROBLAZE_SHARED_UARTLITE_H
+#include <bspopts.h>
 #include <rtems/termiostypes.h>
 #include <dev/serial/uartlite_l.h>
diff --git a/bsps/microblaze/include/dev/serial/uartlite_l.h b/bsps/microblaze/include/dev/serial/uartlite_l.h
index 8c0598e191..834fbb5f75 100644
--- a/bsps/microblaze/include/dev/serial/uartlite_l.h
+++ b/bsps/microblaze/include/dev/serial/uartlite_l.h
@@ -234,6 +234,24 @@ static inline void Xil_Out32(UINTPTR Addr, u32 Value)
   ((XUartLite_GetStatusReg((BaseAddress)) & XUL_SR_RX_FIFO_VALID_DATA) != \
+#ifdef __rtems__
+* Check to see if the transmitter is empty.
+* @param	BaseAddress is the  base address of the device
+* @return	TRUE if the transmitter is empty, FALSE otherwise.
+* @note		C-style Signature:
+* 		int XUartLite_IsTransmitEmpty(u32 BaseAddress);
+#define XUartLite_IsTransmitEmpty(BaseAddress) \
+  ((XUartLite_GetStatusReg((BaseAddress)) & XUL_SR_TX_FIFO_EMPTY) == \
+	XUL_SR_TX_FIFO_EMPTY)
+#endif /* __rtems__ */
diff --git a/bsps/microblaze/shared/dev/serial/uartlite.c b/bsps/microblaze/shared/dev/serial/uartlite.c
index 7387e22635..a5fc4fe82b 100644
--- a/bsps/microblaze/shared/dev/serial/uartlite.c
+++ b/bsps/microblaze/shared/dev/serial/uartlite.c
@@ -35,6 +35,7 @@
 #include <bsp/irq.h>
 #include <dev/serial/uartlite.h>
 #ifdef BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
 static void microblaze_uart_interrupt( void *arg )
@@ -47,7 +48,7 @@ static void microblaze_uart_interrupt( void *arg )
     rtems_termios_enqueue_raw_characters( tty, &c, 1 );
-  while ( ctx->transmitting && !XUartLite_IsTransmitEmpty( ctx ) ) {
+  while ( ctx->transmitting && !XUartLite_IsTransmitEmpty( ctx->address ) ) {
     rtems_termios_dequeue_characters( tty, 1 );
2.34.1
