rtems-libbsd support RISC-V or not
Hesham Almatary Hesham.Almatary at cl.cam.ac.uk
Tue Oct 25 09:32:59 UTC 2022
I tested building a RISC-V BSP (rv64imafdc_medany) for QEMU today.
Things build out the box. I also tried to run the tests and got the
following results:
Passed:        31
Failed:         4
User Input:    21
Expected Fail:  0
Indeterminate:  0
Benchmark:      0
Timeout:        0
Test too long:  0
Invalid:        0
Wrong Version:  0
Wrong Build:    0
Wrong Tools:    0
Wrong Header:   0
Total:         56
Failures:
 commands01.exe
 lagg01.exe
 ping01.exe
 vlan01.exe
User Input:
 arphole.exe
 dhcpcd02.exe
 dhcpcd01.exe
 ftpd01.exe
 foobarserver.exe
 evdev01.exe
 foobarclient.exe
 ipsec01.exe
 mcast01.exe
 nfs01.exe
 netshell01.exe
 media01.exe
 ppp01.exe
 pf02.exe
 telnetd01.exe
 termios.exe
 usbkbd01.exe
 usb01.exe
 usbserial01.exe
 usbmouse01.exe
 zerocopy01.exe
Average test time: 0:00:01.029167
Testing time     : 0:00:57.633379
Supporting/adding a virtio-net device should be straightforward.
On Mon, 17 Oct 2022 at 14:05, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Oct 17, 2022, 2:19 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> Hello Padmarao,
>> I am not sure if rtems-libbsd was used on riscv before, however, adding
>> the architecture support wouldn't be difficult.
> I agree with Sebastian that I don't think riscv has been used before but FreeBSD supports it. The driver added for Microblaze was added to support a secure voting machine which is using CHERI and riscv.
> Shouldn't be a huge deal especially if the driver is already in FreeBSD.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax:   +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
