[PATCH 1/2] user: Add documentation for NOEL-V BSP
Daniel Cederman cederman at gaisler.com
Wed Oct 26 11:34:58 UTC 2022
 user/bsps/bsps-riscv.rst | 57 ++++++++++++++++++++++++++++++++++++++++
 1 file changed, 57 insertions(+)
diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
index 48e7ee7..73a6038 100644
--- a/user/bsps/bsps-riscv.rst
+++ b/user/bsps/bsps-riscv.rst
@@ -248,6 +248,63 @@ Serial terminal UART1 displays the SMP example messages
     *** END OF TEST SMP 1 ***
+noel
+This BSP supports the `NOEL-V <https://gaisler.com/noel-v>`_ systems from Cobham
+Gaisler. The NOEL-V is a synthesizable VHDL model of a processor that
+implements the RISC-V architecture. It is part of the open source
+`GRLIB <https://gaisler.com/grlib>`_ IP Library. The following BSP
+variants correspond to common NOEL-V configurations:
+* noel32im
+* noel32imafd
+* noel64imac
+* noel64imafd
+* noel64imafdc
+The start of the memory is set to 0x0 to match a standard NOEL-V system,
+but can be changed using the ``RISCV_RAM_REGION_BEGIN`` configuration
+option. The size of the memory is taken from the information available
+in the device tree.
+Reference Designs
+The BSP has been tested with NOEL-V reference designs for
+`Digilent Arty A7 <https://gaisler.com/noel-artya7>`_,
+`Microchip PolarFire Splash Kit <https://gaisler.com/noel-pf>`_,
+and `Xilinx KCU105 <https://gaisler.com/noel-xcku>`_.
+See the accompanying quickstart guide for each reference design
+to determine which BSP configuration to use.
+Build Configuration Options
+The following options can be used in the BSP section of the ``waf``
+configuration INI file. The ``waf`` defaults can be used to inspect the values.
+``BSP_CONSOLE_USE_INTERRUPTS``
+     Use the Termios interrupt mode in the console driver (true by default).
+``BSP_FDT_BLOB_SIZE_MAX``
+    The maximum size of the device tree blob in bytes (262144 by default).
+``RISCV_CONSOLE_MAX_APBUART_DEVICES``
+     The maximum number of APBUART devices supported by the console driver
+     (2 by default).
+``RISCV_RAM_REGION_BEGIN``
+     The begin of the RAM region for linker command file (0x0 by default).
+``RISCV_MAXIMUM_EXTERNAL_INTERRUPTS``
+     The maximum number of external interrupts supported by the BSP (64 by
+     default).
 griscv
2.34.1
