[PATCH 1/2] bsps/aarch64: Ensure FPU trap state is consistent
Thu Oct 27 22:45:45 UTC 2022
On 28/10/2022 9:25 am, Kinsey Moore wrote:
> On Thu, Oct 27, 2022 at 5:10 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 28/10/2022 9:05 am, Kinsey Moore wrote:
>     > RTEMS may be booted from a dirty environment. Ensure that FPU trap
>     > settings are consistent.
>     >  bsps/aarch64/shared/start/start.S | 10 ++++++++++
>     >  1 file changed, 10 insertions(+)
>     > diff --git a/bsps/aarch64/shared/start/start.S
>     b/bsps/aarch64/shared/start/start.S
>     > index 8bd4f86f4e..de0fdf4c80 100644
>     > --- a/bsps/aarch64/shared/start/start.S
>     > +++ b/bsps/aarch64/shared/start/start.S
>     > @@ -307,6 +307,16 @@ _el1_start:
>     >    /* FPU does not need to be enabled on AArch64 */
>     > +  /* Ensure FPU traps are disabled by default */
>     > +  mrs x0, FPCR
>     > +  bic x0, x0, #(1 << 8)
>     > +  bic x0, x0, #(1 << 9)
>     > +  bic x0, x0, #(1 << 10)
>     > +  bic x0, x0, #(1 << 11)
>     > +  bic x0, x0, #(1 << 12)
>     > +  bic x0, x0, #(1 << 15)
>     Does `bic x0, x0, #((1 << 8) | (1 << 9) | (1 << 10) | ...)` work?
> The assembler complains about the operand being out of range. I can split it
> into 8-12 in one and 15 by itself and everything seems to work.
Huh? If you use a hex value does it work?
