[PATCH 1/2] bsps/aarch64: Ensure FPU trap state is consistent
Chris Johns
chrisj at rtems.org
Thu Oct 27 22:59:44 UTC 2022
On 28/10/2022 9:57 am, Kinsey Moore wrote:
> On Thu, Oct 27, 2022 at 5:46 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 28/10/2022 9:25 am, Kinsey Moore wrote:
> > On Thu, Oct 27, 2022 at 5:10 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> > On 28/10/2022 9:05 am, Kinsey Moore wrote:
> > > RTEMS may be booted from a dirty environment. Ensure that FPU trap
> > > settings are consistent.
> > > bsps/aarch64/shared/start/start.S | 10 ++++++++++
> > > 1 file changed, 10 insertions(+)
> > > diff --git a/bsps/aarch64/shared/start/start.S
> > b/bsps/aarch64/shared/start/start.S
> > > index 8bd4f86f4e..de0fdf4c80 100644
> > > --- a/bsps/aarch64/shared/start/start.S
> > > +++ b/bsps/aarch64/shared/start/start.S
> > > @@ -307,6 +307,16 @@ _el1_start:
> > > /* FPU does not need to be enabled on AArch64 */
> > > + /* Ensure FPU traps are disabled by default */
> > > + mrs x0, FPCR
> > > + bic x0, x0, #(1 << 8)
> > > + bic x0, x0, #(1 << 9)
> > > + bic x0, x0, #(1 << 10)
> > > + bic x0, x0, #(1 << 11)
> > > + bic x0, x0, #(1 << 12)
> > > + bic x0, x0, #(1 << 15)
> > Does `bic x0, x0, #((1 << 8) | (1 << 9) | (1 << 10) | ...)` work?
> > The assembler complains about the operand being out of range. I can split it
> > into 8-12 in one and 15 by itself and everything seems to work.
> Huh? If you use a hex value does it work?
> I think the equivalent value would be 0x9f00. That generates the same error as
> putting all the components on the same line. I think there's a 6-bit immediate
> involved that's the limitation.
Ah, must be an aarch64 thing. I have been using ARM and thumb mode asm this week :)
I will leave this with you to sort out which is best.
