[PATCH v2 2/2] cpukit/aarch64: Emulate FPSR for FENV traps
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Oct 27 23:04:24 UTC 2022
The AArch64 TRM specifies that when FPCR is set to trap floating point
exceptions, the FPSR exception bits are not set. This ensures that FPSR
is updated as FENV expects even if floating point exception traps are
enabled.
.../cpu/aarch64/aarch64-exception-default.c | 20 +++++++++++++++++++
1 file changed, 20 insertions(+)
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.c b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
index 3494c88ea6..f1591cbd5d 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.c
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
@@ -48,6 +48,26 @@
void _AArch64_Exception_default( CPU_Exception_frame *frame )
+ uint64_t EC = AARCH64_ESR_EL1_EC_GET( frame->register_syndrome );
+ /* Emulate FPSR flags for FENV if a FPU exception occurred */
+ if ( EC == 0x2c ) {
+ * This must be done because FENV depends on FPSR values, but trapped FPU
+ * exceptions don't set FPSR bits. In the case where a signal is mapped, the
+ * signal code executes after the exception frame is restored and FENV
+ * functions executed in that context will need this information to be
+ * accurate.
+ uint64_t ISS = AARCH64_ESR_EL1_EC_GET( frame->register_syndrome );
+ /* If the exception bits are valid, use them */
+ if ( ( ISS & ( 1 << 23 ) ) != 0 ) {
+ /* The bits of the lower byte match the FPSR exception bits */
+ frame->register_fpsr |= ( ISS & 0xff );
rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
2.30.2
