[PATCH] user: Add openSUSE host details
Joel Sherrill
joel at rtems.org
Sat Oct 29 16:33:51 UTC 2022
Looked ok to me. I pushed it.
Thanks.
On Fri, Oct 28, 2022 at 7:54 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> This patch adds details on the packages needed for the RTEMS
> source builder on openSUSE Leap 15.4 64 bit. The commands
> were tested on a new install with the RTEMS source builder
> master branch.
> user/hosts/posix.rst | 15 +++++++++++++--
> 1 file changed, 13 insertions(+), 2 deletions(-)
> diff --git a/user/hosts/posix.rst b/user/hosts/posix.rst
> index 9769e07..d263247 100644
> --- a/user/hosts/posix.rst
> +++ b/user/hosts/posix.rst
> @@ -179,8 +179,19 @@ than the usual zlib-dev):
> openSUSE
> -This has been reported to work but no instructions were provided. This is
> an
> -opportunity to contribute. Please submit any guidance you can provide.
> +The RTEMS Source Builder has been tested on openSUSE Leap 15.4 64bit.
> +Starting with a clean install with source repositories enabled, the
> following
> +zypper command installs the required packages:
> +.. code-block:: none
> + # sudo zypper in -t pattern devel_C_C++ devel_python3
> +In addition, the following command can set python3 as the default python
> interpreter:
> + # sudo update-alternatives --install /usr/bin/python python
> /usr/bin/python3 1
> .. _FreeBSD:
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221029/44825c3c/attachment.htm>
