RPi 4B MMU seems to be enabled but throwing aarch64-default-exception error
Noor Aman nooraman5718 at gmail.com
Fri Sep 2 15:48:07 UTC 2022
Hey all,
Raspberry Pi 4B MMU seems to be enabled, as reported by openocd but gdb is
showing to run in a loop from aarch64-defaulit-exception.S file starting
from code line number 143 to 220.
>From what I can gather, it is being caused by the wrong MMU address.
 Here's a RAM and MMU allocation sizes and base
  MEMORY {
  RAM_MMU  : ORIGIN = 0x0, LENGTH = (0x1000 *
${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
  RAM      : ORIGIN = 0x80000, LENGTH = 1024M
Relevant Openocd info
bcm2711.cpu0 halted in AArch64 state due to debug-request, current mode:
EL1T
cpsr: 0x200003c4 pc: 0x8e208
MMU: enabled, D-Cache: enabled, I-Cache: enabled
Info : New GDB Connection: 1, Target bcm2711.cpu0, state: halted
Any ideas?
Thanks,
Noor
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220902/6b00cc26/attachment.htm>
