[PATCH rtems-lwip 4/5] lwip.py: Add STM32 lwIP port to build
Chris Johns
chrisj at rtems.org
Sun Sep 4 23:05:28 UTC 2022
On 4/9/2022 11:25 am, Duc Doan wrote:
> lwip.py | 20 +++++++++++++++++++-
> 1 file changed, 19 insertions(+), 1 deletion(-)
> diff --git a/lwip.py b/lwip.py
> index 84eef2c..d806b64 100644
> --- a/lwip.py
> +++ b/lwip.py
> @@ -92,6 +92,17 @@ common_source_files = [
> 'rtemslwip/bsd_compat/rtems-kernel-program.c'
> +stm32f4_drv_incl = [
> + 'rtemslwip/stm32f4',
> + 'stm32',
> + 'stm32/driver'
> +stm32f4_drv_src = [
> + 'stm32',
> + 'stm32/driver'
Please group the BSP specific file sets together rather than spreading them
across the common source files. I suggest after the Xilinx ones.
> def build(bld):
> source_files = []
> @@ -150,13 +161,20 @@ def build(bld):
> driver_source.extend(walk_sources('rtemslwip/zynqmp_hardware'))
> driver_source.extend(xilinx_aarch64_driver_source)
> drv_incl.extend(xilinx_aarch64_drv_incl)
> + # These files will only compile for STM32F4 BSPs
> + if bld.env.RTEMS_ARCH_BSP.startswith('arm-rtems6-stm32f4'):
This is wrong because the version is hard coded. I see you have copied what is
in the file and they are also wrong.
The formal arch and bsp format is arch/bsp and these tests expose an internal
implementation detail from rtems_waf.
I suggest the code be changed to add:
arch = rtems.arch(bld.env.RTEMS_ARCH_BSP)
bsp = rtems.bsp(bld.env.RTEMS_ARCH_BSP)
and all the tests changed to:
if arch == 'arm' and bsp == 'stm32f4':
> + driver_source.extend(walk_sources('rtemslwip/stm32f4'))
> + drv_incl.extend(stm32f4_drv_incl)
> + for s in stm32f4_drv_src:
> + driver_source.extend(walk_sources(s))
> lwip_obj_incl = []
> lwip_obj_incl.extend(drv_incl)
> lwip_obj_incl.extend(bsd_compat_incl)
> lwip_obj_incl.extend(common_includes)
> - bld(features='c',
> + bld(features ='c',
The coding standard tool has the previous format.
> target='lwip_obj',
> cflags='-g -Wall -O0',
> includes=' '.join(lwip_obj_incl),
Thanks
