[rtems-central] Add POSIX Timer FACE Behavior Configuration
Mon Sep 5 13:12:50 UTC 2022
On Mon, Sep 5, 2022, 2:04 AM Sebastian Huber <
> Hello Joel,
> On 02/09/2022 18:25, Joel Sherrill wrote:
> > Updates #4691.
> >   config.yml                                 |  2 ++
> >   spec/acfg/if/group-face.yml                | 30
> >   spec/acfg/if/posix-timer-face-behavior.yml | 23 +++++++++++++++++++++++
> >   3 files changed, 55 insertions(+)
> >   create mode 100644 spec/acfg/if/group-face.yml
> >   create mode 100644 spec/acfg/if/posix-timer-face-behavior.yml
> thanks for adding the items. I check it in and regenerated the files in
> RTEMS and the documentation. Sorry for the bad state of rtems-central, I
> hope to clean this up in the next months.
At least I figured out how to get it to generate. Needs to be and stay in
sync and have some improvement in error messages. But it did work.
It looks like you pushed everything. Is that right?
Thanks.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220905/ca2f923d/attachment.htm>
