For GSoC: RTEMS release notes new generator
Mahmoud Abumandour
ma.mandourr at gmail.com
Mon Sep 5 13:57:06 UTC 2022
Bump. Please consider reviewing as the final submissions open today.
Thanks,
Mahmoud
On Wed, Aug 31, 2022 at 8:43 PM Mahmoud Abumandour <ma.mandourr at gmail.com>
wrote:
> Hello all,
> Here, I present the current output of the new release notes generator that
> will be used in the release generation process. Currently, the generator is
> capable is generating markdown and reStructuredText. Both have minor flaws
> that, in my opinion, are somewhat acceptable.
> You can find a sample Markdown PDF for the 4.11.3 milestone here:
> https://drive.google.com/file/d/1S_aKZcJi6c2DX7bCXgt6R9gvVdXgn5Sm/view?usp=sharing
> And its reStructuredText counterpart here:
> https://drive.google.com/drive/folders/1mntfWm6gnHPUpliwHS_ClJYjjnMOhZZV
> The generator has been tested on generating files for the following dot
> releases 4.11.3, 5.1, 5.2, and 6.1 and it produces decent documents for all
> of them.
> You can access the code here and test it yourself:
> https://github.com/i3abghany/release-notes-generator
> For integrating the generator in the release workflow, do you recommend a
> certain way to go by in doing this? Maybe use the code as a submodule in
> the `rtems-release` repository and call it from the `rtems-release-notes`
> script in it?
> Also, the generator was initially designed to produce notes for *one* dot
> release at a time, but I found out the current generator goes up from the
> supplied *version *to the specified *revision*. Is this the desired
> behaviour in the new generator as well? I am asking as I took over
> development in the new generator and it did not conform to this behaviour,
> and I didn't know that it was followed in the `rtems-release` scripts.
> Thanks,
> Mahmoud
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220905/cce26412/attachment.htm>
