[PATCH rtems-lwip v2 5/7] RTEMS port of lwIP for STM32 and STM32F4 BSP
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Sep 6 19:30:05 UTC 2022
I think you may have accidentally squashed the lwipopts.h and netstart.c
changes into this commit instead of 4/7.
Changes to imported code should follow the same rules as rtems-libbsd
for easier updating. It looks like you did this in most places, but a
few instances are called out below where you didn't.
More comments inline below.
On 9/6/2022 11:20, Duc Doan wrote:
> rtemslwip/stm32f4/lwipopts.h | 24 ++-
> rtemslwip/stm32f4/netstart.c | 29 +++-
> rtemslwip/stm32f4/stm32f4_lwip.c | 14 ++
> rtemslwip/stm32f4/stm32f4_lwip.h | 9 +
> stm32/ethernetif.c | 288 +++++++++++++++++++++++++++++--
> stm32/ethernetif.h | 14 +-
> stm32/lwip.c | 103 +++--------
> stm32/lwip.h | 2 +
> 8 files changed, 374 insertions(+), 109 deletions(-)
> create mode 100644 rtemslwip/stm32f4/stm32f4_lwip.c
> create mode 100644 rtemslwip/stm32f4/stm32f4_lwip.h
> diff --git a/rtemslwip/stm32f4/lwipopts.h b/rtemslwip/stm32f4/lwipopts.h
> index 49a19e4..41cc68f 100644
> --- a/rtemslwip/stm32f4/lwipopts.h
> +++ b/rtemslwip/stm32f4/lwipopts.h
> @@ -28,7 +28,7 @@
> /* Within 'USER CODE' section, code will be kept by default at each generation */
> /* USER CODE BEGIN 0 */
> +#include <stm32f4xx_hal.h>
> /* USER CODE END 0 */
> #ifdef __cplusplus
> @@ -38,7 +38,7 @@
> /* STM32CubeMX Specific Parameters (not defined in opt.h) ---------------------*/
> /* Parameters set in STM32CubeMX LwIP Configuration GUI -*/
> /*----- WITH_RTOS disabled (Since FREERTOS is not set) -----*/
> -#define WITH_RTOS 0
> +#define WITH_RTOS 1
> /*----- CHECKSUM_BY_HARDWARE disabled -----*/
> #define CHECKSUM_BY_HARDWARE 0
> @@ -50,11 +50,11 @@
> /*----- Value in opt.h for NO_SYS: 0 -----*/
> #define NO_SYS 0
> /*----- Value in opt.h for SYS_LIGHTWEIGHT_PROT: 1 -----*/
> -#define SYS_LIGHTWEIGHT_PROT 0
> +#define SYS_LIGHTWEIGHT_PROT 1
> /*----- Value in opt.h for MEM_ALIGNMENT: 1 -----*/
> #define MEM_ALIGNMENT 4
> /*----- Default Value for H7 devices: 0x30044000 -----*/
> -#define LWIP_RAM_HEAP_POINTER 0x20017f58
> +//#define LWIP_RAM_HEAP_POINTER 0x20017f58
> /*----- Value supported for H7 devices: 1 -----*/
> #define LWIP_SUPPORT_CUSTOM_PBUF 1
> /*----- Value in opt.h for LWIP_ETHERNET: LWIP_ARP || PPPOE_SUPPORT -*/
> @@ -70,13 +70,13 @@
> /*----- Value in opt.h for TCP_WND_UPDATE_THRESHOLD: LWIP_MIN(TCP_WND/4, TCP_MSS*4) -----*/
> #define TCP_WND_UPDATE_THRESHOLD 536
> /*----- Value in opt.h for LWIP_NETIF_LINK_CALLBACK: 0 -----*/
> -#define LWIP_NETIF_LINK_CALLBACK 1
> +//#define LWIP_NETIF_LINK_CALLBACK 0
> /*----- Value in opt.h for LWIP_NETCONN: 1 -----*/
> #define LWIP_NETCONN 1
> /*----- Value in opt.h for LWIP_SOCKET: 1 -----*/
> #define LWIP_SOCKET 1
> /*----- Value in opt.h for RECV_BUFSIZE_DEFAULT: INT_MAX -----*/
> -#define RECV_BUFSIZE_DEFAULT 2000000000
> +//#define RECV_BUFSIZE_DEFAULT 2000000000
> /*----- Value in opt.h for LWIP_STATS: 1 -----*/
> #define LWIP_STATS 0
> /*----- Value in opt.h for CHECKSUM_GEN_IP: 1 -----*/
> @@ -115,9 +115,19 @@
> #define LWIP_IPV6 1
> #define LWIP_TCPIP_CORE_LOCKING 1
> +#define TCPIP_THREAD_STACKSIZE 1024
> +#define TCPIP_THREAD_PRIO 24
> +#define TCPIP_MBOX_SIZE 6
> +#define SLIPIF_THREAD_STACKSIZE 1024
> +#define SLIPIF_THREAD_PRIO 3
> +#define DEFAULT_THREAD_STACKSIZE 1024
> +#define DEFAULT_THREAD_PRIO 3
> +#define DEFAULT_UDP_RECVMBOX_SIZE 6
> +#define DEFAULT_TCP_RECVMBOX_SIZE 6
> +#define DEFAULT_ACCEPTMBOX_SIZE 6
> #define LWIP_DHCP 1
> -#define DHCP_DOES_ARP_CHECK 0
> +#define DHCP_DOES_ARP_CHECK 1
> #define LWIP_DNS 1
> diff --git a/rtemslwip/stm32f4/netstart.c b/rtemslwip/stm32f4/netstart.c
> index 88e846a..6ddcc81 100644
> --- a/rtemslwip/stm32f4/netstart.c
> +++ b/rtemslwip/stm32f4/netstart.c
> @@ -26,7 +26,10 @@
> #include <netstart.h>
> #include <lwip/tcpip.h>
> -#include <ethernetif.h>
> +#include "lwip.h"
> +#include "lwip/init.h"
> +#include "lwip/netif.h"
> +#include "ethernetif.h"
> int start_networking(
> struct netif *net_interface,
> @@ -38,15 +41,35 @@ int start_networking(
> tcpip_init( NULL, NULL );
> - netif_add(net_interface, ipaddr, netmask, gw, NULL, ðernetif_init, &tcpip_input);
> + set_mac_addr(mac_ethernet_address);
> + netif_add(
> + net_interface,
> + &ipaddr->u_addr.ip4,
> + &netmask->u_addr.ip4,
> + &gateway->u_addr.ip4,
> + NULL,
> + ethernetif_init,
> + tcpip_input
> netif_set_default(net_interface);
> if (netif_is_link_up(net_interface)) {
> netif_set_up(net_interface);
> + sys_thread_new(
> + "stm32f4_ethernet_link_thread",
> + ethernet_link_thread,
> + net_interface,
> + 1024,
> + DEFAULT_THREAD_PRIO
> + return 0;
> } else {
> netif_set_down(net_interface);
> - return 0;
> + return -1;
> diff --git a/rtemslwip/stm32f4/stm32f4_lwip.c b/rtemslwip/stm32f4/stm32f4_lwip.c
> new file mode 100644
> index 0000000..1f4f07e
> --- /dev/null
> +++ b/rtemslwip/stm32f4/stm32f4_lwip.c
> @@ -0,0 +1,14 @@
> +#include "stm32f4_lwip.h"
> +extern ETH_HandleTypeDef heth;
> +__attribute__((weak)) void Error_Handler(void) {
> + __disable_irq();
> + while (1)
> +void ETH_IRQHandler(void) {
> + HAL_ETH_IRQHandler(&heth);
> diff --git a/rtemslwip/stm32f4/stm32f4_lwip.h b/rtemslwip/stm32f4/stm32f4_lwip.h
> index 0000000..8a2b03a
> --- /dev/null
> +++ b/rtemslwip/stm32f4/stm32f4_lwip.h
> @@ -0,0 +1,9 @@
> +#ifndef LIPLWIP_RTEMSLWIP_STM32F4_STM32F4_LWIP_H
> +#define LIPLWIP_RTEMSLWIP_STM32F4_STM32F4_LWIP_H
> +void ErrorHandler(void);
> +void ETH_IRQHandler(void);
> +#endif /* LIPLWIP_RTEMSLWIP_STM32F4_STM32F4_LWIP_H */
> diff --git a/stm32/ethernetif.c b/stm32/ethernetif.c
> index e54c8b6..a8e9f76 100644
> --- a/stm32/ethernetif.c
> +++ b/stm32/ethernetif.c
> @@ -19,10 +19,14 @@
> /* USER CODE END Header */
> /* Includes ------------------------------------------------------------------*/
> +#ifndef __rtems__
> #include "main.h"
> +#endif /* __rtems__ */
> +#ifdef __rtems__
The preceeding two lines can be condensed into a #else, applies elsewhere.
> +#include <bsp.h>
> +#include <bsp/irq.h>
> #include "lwip/opt.h"
> -#include "lwip/mem.h"
> -#include "lwip/memp.h"
Bad removal, applies elsewhere.
> #include "lwip/timeouts.h"
> #include "netif/ethernet.h"
> #include "netif/etharp.h"
> @@ -30,6 +34,10 @@
> #include "dp83848.h"
> #include <string.h>
> +#ifndef __rtems__
> +#include "cmsis_os.h"
> +#include "lwip/tcpip.h"
Bad addition, applies elsewhere.
> @@ -37,7 +45,18 @@
> /* Private define ------------------------------------------------------------*/
> +/* The time to block waiting for input. */
> +#ifndef __rtems__
> +#define TIME_WAITING_FOR_INPUT ( portMAX_DELAY )
> +#ifdef __rtems__
> +#define TIME_WAITING_FOR_INPUT ( RTEMS_NO_TIMEOUT )
> +/* USER CODE BEGIN OS_THREAD_STACK_SIZE_WITH_RTOS */
> +/* Stack size of the interface thread */
> +#define INTERFACE_THREAD_STACK_SIZE ( 350 )
> +/* USER CODE END OS_THREAD_STACK_SIZE_WITH_RTOS */
> /* Network interface name */
> #define IFNAME0 's'
> #define IFNAME1 't'
> @@ -104,9 +123,20 @@ ETH_DMADescTypeDef DMATxDscrTab[ETH_TX_DESC_CNT]; /* Ethernet Tx DMA Descriptor
> /* USER CODE END 2 */
> +#ifndef __rtems__
> +osSemaphoreId RxPktSemaphore = NULL; /* Semaphore to signal incoming packets */
> +osSemaphoreId TxPktSemaphore = NULL; /* Semaphore to signal transmit packet complete */
> +#else
> +rtems_id RxPktSemaphore; /* Semaphore to signal incoming packets */
> +rtems_id TxPktSemaphore; /* Semaphore to signal transmit packet complete */
> /* Global Ethernet handle */
> ETH_TxPacketConfig TxConfig;
> +#ifdef __rtems__
> +static uint8_t *MACAddr;
> /* Private function prototypes -----------------------------------------------*/
> int32_t ETH_PHY_IO_Init(void);
> @@ -129,8 +159,56 @@ dp83848_IOCtx_t DP83848_IOCtx = {ETH_PHY_IO_Init,
> /* Private functions ---------------------------------------------------------*/
> void pbuf_free_custom(struct pbuf *p);
> -/* USER CODE BEGIN 4 */
> + * @brief Ethernet Rx Transfer completed callback
> + * @param handlerEth: ETH handler
> + * @retval None
> +void HAL_ETH_RxCpltCallback(ETH_HandleTypeDef *handlerEth)
> +#ifndef __rtems__
> + osSemaphoreRelease(RxPktSemaphore);
> +#else
> + rtems_semaphore_release(RxPktSemaphore);
> + * @brief Ethernet Tx Transfer completed callback
> + * @retval None
> +void HAL_ETH_TxCpltCallback(ETH_HandleTypeDef *handlerEth)
> +#ifndef __rtems__
> + osSemaphoreRelease(TxPktSemaphore);
> +#else
> + rtems_semaphore_release(TxPktSemaphore);
> + * @brief Ethernet DMA transfer error callback
> + * @retval None
> +void HAL_ETH_ErrorCallback(ETH_HandleTypeDef *handlerEth)
> + if((HAL_ETH_GetDMAError(handlerEth) & ETH_DMASR_RBUS) == ETH_DMASR_RBUS)
> +#ifndef __rtems__
> +#else
> +/* USER CODE BEGIN 4 */
> +#ifdef __rtems__
> +void set_mac_addr(uint8_t *mac_addr)
> + MACAddr = mac_addr;
> /* USER CODE END 4 */
> @@ -146,17 +224,33 @@ void pbuf_free_custom(struct pbuf *p);
> static void low_level_init(struct netif *netif)
> HAL_StatusTypeDef hal_eth_init_status = HAL_OK;
> +/* USER CODE BEGIN OS_THREAD_ATTR_CMSIS_RTOS_V2 */
> +#ifndef __rtems__
> + osThreadAttr_t attributes;
> +/* USER CODE END OS_THREAD_ATTR_CMSIS_RTOS_V2 */
> + uint32_t duplex, speed = 0;
> + int32_t PHYLinkState = 0;
> + ETH_MACConfigTypeDef MACConf = {0};
> /* Start ETH HAL Init */
> +#ifndef __rtems__
> uint8_t MACAddr[6] ;
> heth.Instance = ETH;
> +#ifndef __rtems__
> MACAddr[0] = 0x02;
> MACAddr[1] = 0x00;
> MACAddr[2] = 0x00;
> MACAddr[3] = 0x00;
> MACAddr[4] = 0x00;
> MACAddr[5] = 0x01;
> +#ifndef __rtems__
> heth.Init.MACAddr = &MACAddr[0];
> +#else
> + heth.Init.MACAddr = MACAddr;
> heth.Init.MediaInterface = HAL_ETH_RMII_MODE;
> heth.Init.TxDesc = DMATxDscrTab;
> heth.Init.RxDesc = DMARxDscrTab;
> @@ -202,6 +296,51 @@ static void low_level_init(struct netif *netif)
> netif->flags |= NETIF_FLAG_BROADCAST;
> #endif /* LWIP_ARP */
> + /* create a binary semaphore used for informing ethernetif of frame reception */
> +#ifndef __rtems__
> + RxPktSemaphore = osSemaphoreNew(1, 1, NULL);
> +#else
> + rtems_semaphore_create(
> + rtems_build_name('R', 'x', 'p', 'k'),
> + 1,
> + RTEMS_SIMPLE_BINARY_SEMAPHORE,
> + 0,
> + &RxPktSemaphore
> + /* create a binary semaphore used for informing ethernetif of frame transmission */
> +#ifndef __rtems__
> + TxPktSemaphore = osSemaphoreNew(1, 1, NULL);
> +#else
> + rtems_build_name('T', 'x', 'p', 'k'),
> + 1,
> + 0,
> + &TxPktSemaphore
> + /* create the task that handles the ETH_MAC */
> +/* USER CODE BEGIN OS_THREAD_NEW_CMSIS_RTOS_V2 */
> +#ifndef __rtems__
> + memset(&attributes, 0x0, sizeof(osThreadAttr_t));
> + attributes.name = "EthIf";
> + attributes.stack_size = INTERFACE_THREAD_STACK_SIZE;
> + attributes.priority = osPriorityRealtime;
> + osThreadNew(ethernetif_input, netif, &attributes);
> +#else
> + sys_thread_new(
> + "ethernetif_input_thread",
> + ethernetif_input,
> + netif,
> + RTEMS_MINIMUM_STACK_SIZE,
> +#endif /* __rtem__ */
> +/* USER CODE END OS_THREAD_NEW_CMSIS_RTOS_V2 */
> /* USER CODE BEGIN PHY_PRE_CONFIG */
> /* USER CODE END PHY_PRE_CONFIG */
> @@ -213,8 +352,64 @@ static void low_level_init(struct netif *netif)
> if (hal_eth_init_status == HAL_OK)
> - /* Get link state */
> - ethernet_link_check_state(netif);
> + PHYLinkState = DP83848_GetLinkState(&DP83848);
> + /* Get link state */
> + if(PHYLinkState <= DP83848_STATUS_LINK_DOWN)
> + netif_set_link_down(netif);
> + netif_set_down(netif);
> + else
> + switch (PHYLinkState)
> + case DP83848_STATUS_100MBITS_FULLDUPLEX:
> + duplex = ETH_FULLDUPLEX_MODE;
> + speed = ETH_SPEED_100M;
> + break;
> + case DP83848_STATUS_100MBITS_HALFDUPLEX:
> + duplex = ETH_HALFDUPLEX_MODE;
> + break;
> + case DP83848_STATUS_10MBITS_FULLDUPLEX:
> + speed = ETH_SPEED_10M;
> + break;
> + case DP83848_STATUS_10MBITS_HALFDUPLEX:
> + break;
> + default:
> + break;
> + /* Get MAC Config MAC */
> + HAL_ETH_GetMACConfig(&heth, &MACConf);
> + MACConf.DuplexMode = duplex;
> + MACConf.Speed = speed;
> + HAL_ETH_SetMACConfig(&heth, &MACConf);
> +#ifdef __rtems__
> + rtems_interrupt_handler_install(
> + STM32F4_IRQ_ETH,
> + NULL,
> + RTEMS_INTERRUPT_UNIQUE,
> + HAL_ETH_IRQHandler,
> + &heth
> + HAL_ETH_Start_IT(&heth);
> + netif_set_up(netif);
> + netif_set_link_up(netif);
> +/* USER CODE BEGIN PHY_POST_CONFIG */
> +/* USER CODE END PHY_POST_CONFIG */
> else
> @@ -277,7 +472,20 @@ static err_t low_level_output(struct netif *netif, struct pbuf *p)
> TxConfig.TxBuffer = Txbuffer;
> TxConfig.pData = p;
> - HAL_ETH_Transmit(&heth, &TxConfig, ETH_DMA_TRANSMIT_TIMEOUT);
> + pbuf_ref(p);
> + HAL_ETH_Transmit_IT(&heth, &TxConfig);
> +#ifndef __rtems__
> + while(osSemaphoreAcquire(TxPktSemaphore, TIME_WAITING_FOR_INPUT)!=osOK)
> +#else
> + while (rtems_semaphore_obtain(TxPktSemaphore, RTEMS_DEFAULT_OPTIONS,
> + TIME_WAITING_FOR_INPUT) != RTEMS_SUCCESSFUL)
> + HAL_ETH_ReleaseTxPacket(&heth);
> return errval;
> @@ -311,21 +519,33 @@ static struct pbuf * low_level_input(struct netif *netif)
> * @param netif the lwip network interface structure for this ethernetif
> -void ethernetif_input(struct netif *netif)
> +void ethernetif_input(void* argument)
> struct pbuf *p = NULL;
> + struct netif *netif = (struct netif *) argument;
> - do
> + for( ;; )
> - p = low_level_input( netif );
> - if (p != NULL)
> +#ifndef __rtems__
> + if (osSemaphoreAcquire(RxPktSemaphore, TIME_WAITING_FOR_INPUT) == osOK)
> +#else
> + if (rtems_semaphore_obtain(RxPktSemaphore, RTEMS_DEFAULT_OPTIONS,
> + TIME_WAITING_FOR_INPUT) == RTEMS_SUCCESSFUL)
> - if (netif->input( p, netif) != ERR_OK )
> + do
> - pbuf_free(p);
> + p = low_level_input( netif );
> + if (p != NULL)
> + if (netif->input( p, netif) != ERR_OK )
> + pbuf_free(p);
> + } while(p!=NULL);
> - } while(p!=NULL);
> #if !LWIP_ARP
> @@ -423,12 +643,17 @@ void pbuf_free_custom(struct pbuf *p)
> if (RxAllocStatus == RX_ALLOC_ERROR)
> RxAllocStatus = RX_ALLOC_OK;
> - RxPkt = 1 ;
> +#ifndef __rtems__
> +#else
> /* USER CODE BEGIN 6 */
> +#ifndef __rtems__
> * @brief Returns the current time in milliseconds
> * when LWIP_TIMERS == 1 and NO_SYS == 1
> @@ -439,6 +664,7 @@ u32_t sys_now(void)
> return HAL_GetTick();
> /* USER CODE END 6 */
> @@ -488,6 +714,11 @@ void HAL_ETH_MspInit(ETH_HandleTypeDef* ethHandle)
> GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
> HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
> + /* Peripheral interrupt init */
> +#ifndef __rtems__
> + HAL_NVIC_SetPriority(ETH_IRQn, 5, 0);
> + HAL_NVIC_EnableIRQ(ETH_IRQn);
> /* USER CODE BEGIN ETH_MspInit 1 */
> /* USER CODE END ETH_MspInit 1 */
> @@ -521,6 +752,9 @@ void HAL_ETH_MspDeInit(ETH_HandleTypeDef* ethHandle)
> HAL_GPIO_DeInit(GPIOB, GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13);
> + /* Peripheral interrupt Deinit*/
> + HAL_NVIC_DisableIRQ(ETH_IRQn);
> /* USER CODE BEGIN ETH_MspDeInit 1 */
> /* USER CODE END ETH_MspDeInit 1 */
> @@ -605,17 +839,24 @@ int32_t ETH_PHY_IO_GetTick(void)
> * @param argument: netif
> * @retval None
> -void ethernet_link_check_state(struct netif *netif)
> +void ethernet_link_thread(void* argument)
> uint32_t linkchanged = 0U, speed = 0U, duplex = 0U;
> +/* USER CODE BEGIN ETH link init */
> +/* USER CODE END ETH link init */
> + for(;;)
> if(netif_is_link_up(netif) && (PHYLinkState <= DP83848_STATUS_LINK_DOWN))
> - HAL_ETH_Stop(&heth);
> + HAL_ETH_Stop_IT(&heth);
> @@ -660,6 +901,16 @@ void ethernet_link_check_state(struct netif *netif)
> +/* USER CODE BEGIN ETH link Thread core code for User BSP */
> +/* USER CODE END ETH link Thread core code for User BSP */
> +#ifndef __rtems__
> + osDelay(100);
> +#else
> + sys_arch_delay(100);
> void HAL_ETH_RxAllocateCallback(uint8_t **buff)
> @@ -735,3 +986,4 @@ void HAL_ETH_TxFreeCallback(uint32_t * buff)
> /* USER CODE END 8 */
> diff --git a/stm32/ethernetif.h b/stm32/ethernetif.h
> index 76eb91b..552671a 100644
> --- a/stm32/ethernetif.h
> +++ b/stm32/ethernetif.h
> @@ -23,23 +23,31 @@
> #include "lwip/err.h"
> +#ifndef __rtems__
> +#ifdef __rtems__
> +void set_mac_addr(uint8_t *mac_addr);
> /* Exported functions ------------------------------------------------------- */
> err_t ethernetif_init(struct netif *netif);
> -void ethernetif_input(struct netif *netif);
> -void ethernet_link_check_state(struct netif *netif);
> +void ethernetif_input(void* argument);
> +void ethernet_link_thread(void* argument );
Why is the signature of this function being changed? The implementation
is altered to blindly cast to this type, as well.
> void Error_Handler(void);
> u32_t sys_jiffies(void);
> +#ifndef __rtems__
> u32_t sys_now(void);
> /* USER CODE BEGIN 1 */
> /* USER CODE END 1 */
> #endif
> diff --git a/stm32/lwip.c b/stm32/lwip.c
> index 9b2af8a..82a09fe 100644
> --- a/stm32/lwip.c
> +++ b/stm32/lwip.c
> @@ -19,6 +19,7 @@
> +#ifndef __rtems__
> #include "lwip.h"
> @@ -26,29 +27,29 @@
> #include "lwip/sio.h"
> #endif /* MDK ARM Compiler */
> +#include <string.h>
> static void ethernet_link_status_updated(struct netif *netif);
> -static void Ethernet_Link_Periodic_Handle(struct netif *netif);
> /* ETH Variables initialization ----------------------------------------------*/
> -uint32_t EthernetLinkTimer;
> /* Variables Initialization */
> struct netif gnetif;
> ip4_addr_t ipaddr;
> ip4_addr_t netmask;
> ip4_addr_t gw;
> -uint8_t IP_ADDRESS[4];
> -uint8_t NETMASK_ADDRESS[4];
> -uint8_t GATEWAY_ADDRESS[4];
> +#define INTERFACE_THREAD_STACK_SIZE ( 1024 )
> +osThreadAttr_t attributes;
> /* USER CODE BEGIN 2 */
> @@ -59,33 +60,16 @@ uint8_t GATEWAY_ADDRESS[4];
> void MX_LWIP_Init(void)
You've made a bunch of changes to this function, but it's prototype has
been #if'd out of the header. Is this file or the associated header even
necessary?
Kinsey
