bsp builder and versal ilp32
Wed Sep 7 23:50:19 UTC 2022
On Wed, Sep 7, 2022, 4:47 PM Chris Johns <chrisj at rtems.org> wrote:
> On 8/9/2022 12:37 am, Joel Sherrill wrote:
> > Hi
> > Do these references to the ilp32 need to be removed?
> > rtems-tools]$ grep -r ilp32 | grep versal
> > config/rtems-bsps-aarch64.ini:       xilinx_versal_ilp32_qemu,
> > xilinx_versal_ilp32_vck190,
> > config/rtems-bsps-tiers.ini:    xilinx_versal_ilp32_qemu,
> xilinx_versal_lp64_qemu,
> > config/rtems-bsps-tiers.ini:bsps_aarch64 = xilinx_versal_ilp32_vck190,
> Yes they do. Could the BSP builder ask `rtems-bsps` for the list these
> days?
> That would help avoid this issue.
Yes. For "all" but not for the tiers. But all is what is used by the OAR
builders so that would be an improvement and avoid patches like this and
the next one which updates the RSB to use a new rtems-tools hash
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220907/afc0d1c6/attachment.htm>
