[RSB] Support deployment
chrisj at rtems.org chrisj at rtems.org
Thu Sep 8 01:25:54 UTC 2022
Hi,
These patches update the RSB to support deployment. With this change you can
create a directory anywhere and in it add a buildset file and build an RTEMS
vertical software stack. For example:
  mkdir project
  cd project
  mkdir config
  vi config/project.bset
And in the buildset file add:
  %define with_rtems_bsp aarch64/xilinx_versal_aiedge
  6/rtems-aarch64
  6/rtems-kernel
The changes:
- Clean up the kernel and BSP support in the RSB to better handle
  options and configurations
- Add better support kernel config.ini files
- Change bset tarfiles to package the staged files
- Use python's tarfile support
I have a new section for the User manual ready.
Once these patches are merged I will backport some to RTEMS 5 so deployment
can be supported in 5.2.
After that is completed I will reformat the RSB using yapf.
