[PATCH] score: Improve formatting
Chris Johns
chrisj at rtems.org
Thu Sep 8 06:56:53 UTC 2022
Hi,
Is the score going to be run through clang-format? If it is should we
bother going this?
On 8/9/2022 4:09 pm, Sebastian Huber wrote:
> cpukit/include/rtems/score/basedefs.h | 14 ++++++++++----
> 1 file changed, 10 insertions(+), 4 deletions(-)
> diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
> index af732df3d3..c182ea02ec 100644
> --- a/cpukit/include/rtems/score/basedefs.h
> +++ b/cpukit/include/rtems/score/basedefs.h
> @@ -474,12 +474,18 @@ extern "C" {
> ( const_cast<_type>( _var ) )
> #elif defined(__GNUC__)
> #define RTEMS_DEQUALIFY_DEPTHX( _ptr_level, _type, _var ) \
> - __builtin_choose_expr( __builtin_types_compatible_p( \
> + __builtin_choose_expr( \
> + __builtin_types_compatible_p( \
> RTEMS_TYPEOF_REFX( _ptr_level, _var ), \
> RTEMS_TYPEOF_REFX( _ptr_level, _type ) \
> - ) || __builtin_types_compatible_p( _type, void * ), \
> - (_type) ( _var ), \
> - RTEMS_DEQUALIFY_types_not_compatible() )
> + _type, \
> + void * \
> + (_type) ( _var ), \
> + RTEMS_DEQUALIFY_types_not_compatible() \
> #else
> ( (_type) (uintptr_t) (const volatile void *)( _var ) )
