[PATCH 03/15] Implement SHA-512 truncated (224 and 256 bits)
Sebastian Huber
Thu Sep 8 13:27:20 UTC 2022
This implements SHA-512/256, which generates a 256 bit hash by
calculating the SHA-512 then truncating the result. A different initial
value is used, making the result different from the first 256 bits of
the SHA-512 of the same input. SHA-512 is ~50% faster than SHA-256 on
64bit platforms, so the result is a faster 256 bit hash.
The main goal of this implementation is to enable support for this
faster hashing algorithm in ZFS. The feature was introduced into ZFS
in r289422, but is disconnected because SHA-512/256 support was missing.
A further commit will enable it in ZFS.
This is the follow on to r292782
Reviewed by: cem
Sponsored by: ScaleEngine Inc.
Differential Revision: https://reviews.freebsd.org/D6061
cpukit/include/sha512t.h | 66 +++++++++++++++++++++++++++++++
cpukit/libmd/sha512c.c | 84 ++++++++++++++++++++++++++++++++++++++++
2 files changed, 150 insertions(+)
create mode 100644 cpukit/include/sha512t.h
diff --git a/cpukit/include/sha512t.h b/cpukit/include/sha512t.h
new file mode 100644
index 0000000000..20f206f141
--- /dev/null
+++ b/cpukit/include/sha512t.h
@@ -0,0 +1,66 @@
+ * Copyright (c) 2015 Allan Jude <allanjude at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _SHA512T_H_
+#define _SHA512T_H_
+#include "sha512.h"
+#ifndef _KERNEL
+#include <sys/types.h>
+#endif
+#define SHA512_224_DIGEST_LENGTH 28
+#define SHA512_224_DIGEST_STRING_LENGTH (SHA512_224_DIGEST_LENGTH * 2 + 1)
+#define SHA512_256_DIGEST_LENGTH 32
+#define SHA512_256_DIGEST_STRING_LENGTH (SHA512_256_DIGEST_LENGTH * 2 + 1)
+__BEGIN_DECLS
+void SHA512_224_Init(SHA512_CTX *);
+void SHA512_224_Update(SHA512_CTX *, const void *, size_t);
+void SHA512_224_Final(unsigned char [static SHA512_224_DIGEST_LENGTH], SHA512_CTX *);
+#ifndef _KERNEL
+char *SHA512_224_End(SHA512_CTX *, char *);
+char *SHA512_224_Data(const void *, unsigned int, char *);
+char *SHA512_224_File(const char *, char *);
+char *SHA512_224_FileChunk(const char *, char *, off_t, off_t);
+#endif
+void SHA512_256_Init(SHA512_CTX *);
+void SHA512_256_Update(SHA512_CTX *, const void *, size_t);
+void SHA512_256_Final(unsigned char [static SHA512_256_DIGEST_LENGTH], SHA512_CTX *);
+#ifndef _KERNEL
+char *SHA512_256_End(SHA512_CTX *, char *);
+char *SHA512_256_Data(const void *, unsigned int, char *);
+char *SHA512_256_File(const char *, char *);
+char *SHA512_256_FileChunk(const char *, char *, off_t, off_t);
+#endif
+__END_DECLS
+#endif /* !_SHA512T_H_ */
diff --git a/cpukit/libmd/sha512c.c b/cpukit/libmd/sha512c.c
index a93d8a44d8..abc5fd113b 100644
--- a/cpukit/libmd/sha512c.c
+++ b/cpukit/libmd/sha512c.c
@@ -1,5 +1,6 @@
* Copyright 2005 Colin Percival
@@ -33,6 +34,7 @@ __FBSDID("$FreeBSD$");
#include "sha512.h"
+#include "sha512t.h"
#include "sha384.h"
#if BYTE_ORDER == BIG_ENDIAN
@@ -320,6 +322,88 @@ SHA512_Final(unsigned char digest[static SHA512_DIGEST_LENGTH], SHA512_CTX *ctx)
memset(ctx, 0, sizeof(*ctx));
+/*** SHA-512t: *********************************************************/
+ * the SHA512t transforms are identical to SHA512 so reuse the existing function
+void
+SHA512_224_Init(SHA512_CTX * ctx)
+ /* Zero bits processed so far */
+ ctx->count[0] = ctx->count[1] = 0;
+ /* Magic initialization constants */
+ ctx->state[0] = 0x8c3d37c819544da2ULL;
+ ctx->state[1] = 0x73e1996689dcd4d6ULL;
+ ctx->state[2] = 0x1dfab7ae32ff9c82ULL;
+ ctx->state[3] = 0x679dd514582f9fcfULL;
+ ctx->state[4] = 0x0f6d2b697bd44da8ULL;
+ ctx->state[5] = 0x77e36f7304c48942ULL;
+ ctx->state[6] = 0x3f9d85a86a1d36c8ULL;
+ ctx->state[7] = 0x1112e6ad91d692a1ULL;
+void
+SHA512_224_Update(SHA512_CTX * ctx, const void *in, size_t len)
+ SHA512_Update(ctx, in, len);
+void
+SHA512_224_Final(unsigned char digest[static SHA512_224_DIGEST_LENGTH], SHA512_CTX * ctx)
+ /* Add padding */
+ SHA512_Pad(ctx);
+ /* Write the hash */
+ be64enc_vect(digest, ctx->state, SHA512_224_DIGEST_LENGTH);
+ /* Clear the context state */
+ memset(ctx, 0, sizeof(*ctx));
+void
+SHA512_256_Init(SHA512_CTX * ctx)
+ ctx->state[0] = 0x22312194fc2bf72cULL;
+ ctx->state[1] = 0x9f555fa3c84c64c2ULL;
+ ctx->state[2] = 0x2393b86b6f53b151ULL;
+ ctx->state[3] = 0x963877195940eabdULL;
+ ctx->state[4] = 0x96283ee2a88effe3ULL;
+ ctx->state[5] = 0xbe5e1e2553863992ULL;
+ ctx->state[6] = 0x2b0199fc2c85b8aaULL;
+ ctx->state[7] = 0x0eb72ddc81c52ca2ULL;
+void
+SHA512_256_Update(SHA512_CTX * ctx, const void *in, size_t len)
+void
+SHA512_256_Final(unsigned char digest[static SHA512_256_DIGEST_LENGTH], SHA512_CTX * ctx)
+ /* Add padding */
+ SHA512_Pad(ctx);
+ be64enc_vect(digest, ctx->state, SHA512_256_DIGEST_LENGTH);
/*** SHA-384: *********************************************************/
* the SHA384 and SHA512 transforms are identical, so SHA384 is skipped
2.35.3
