[PATCH 09/15] libtests/sha: Add tests for SHA384
    Sebastian Huber
    Thu Sep  8 13:27:26 UTC 2022
 testsuites/libtests/sha/init.c | 58 ++++++++++++++++++++++++++++++++++
 1 file changed, 58 insertions(+)
diff --git a/testsuites/libtests/sha/init.c b/testsuites/libtests/sha/init.c
index 49cc17db44..43ba8e843d 100644
--- a/testsuites/libtests/sha/init.c
+++ b/testsuites/libtests/sha/init.c
@@ -31,6 +31,7 @@
 #include <sha224.h>
 #include <sha256.h>
+#include <sha384.h>
 #include <sha512.h>
@@ -99,6 +100,39 @@ test_sha256_results[RTEMS_ARRAY_SIZE(test_vectors)][SHA256_DIGEST_LENGTH] = {
+static const unsigned char
+test_sha384_results[RTEMS_ARRAY_SIZE(test_vectors)][SHA384_DIGEST_LENGTH] = {
+    0xcb, 0x00, 0x75, 0x3f, 0x45, 0xa3, 0x5e, 0x8b,
+    0xb5, 0xa0, 0x3d, 0x69, 0x9a, 0xc6, 0x50, 0x07,
+    0x27, 0x2c, 0x32, 0xab, 0x0e, 0xde, 0xd1, 0x63,
+    0x1a, 0x8b, 0x60, 0x5a, 0x43, 0xff, 0x5b, 0xed,
+    0x80, 0x86, 0x07, 0x2b, 0xa1, 0xe7, 0xcc, 0x23,
+    0x58, 0xba, 0xec, 0xa1, 0x34, 0xc8, 0x25, 0xa7
+    0x38, 0xb0, 0x60, 0xa7, 0x51, 0xac, 0x96, 0x38,
+    0x4c, 0xd9, 0x32, 0x7e, 0xb1, 0xb1, 0xe3, 0x6a,
+    0x21, 0xfd, 0xb7, 0x11, 0x14, 0xbe, 0x07, 0x43,
+    0x4c, 0x0c, 0xc7, 0xbf, 0x63, 0xf6, 0xe1, 0xda,
+    0x27, 0x4e, 0xde, 0xbf, 0xe7, 0x6f, 0x65, 0xfb,
+    0xd5, 0x1a, 0xd2, 0xf1, 0x48, 0x98, 0xb9, 0x5b
+    0x33, 0x91, 0xfd, 0xdd, 0xfc, 0x8d, 0xc7, 0x39,
+    0x37, 0x07, 0xa6, 0x5b, 0x1b, 0x47, 0x09, 0x39,
+    0x7c, 0xf8, 0xb1, 0xd1, 0x62, 0xaf, 0x05, 0xab,
+    0xfe, 0x8f, 0x45, 0x0d, 0xe5, 0xf3, 0x6b, 0xc6,
+    0xb0, 0x45, 0x5a, 0x85, 0x20, 0xbc, 0x4e, 0x6f,
+    0x5f, 0xe9, 0x5b, 0x1f, 0xe3, 0xc8, 0x45, 0x2b
+    0x09, 0x33, 0x0c, 0x33, 0xf7, 0x11, 0x47, 0xe8,
+    0x3d, 0x19, 0x2f, 0xc7, 0x82, 0xcd, 0x1b, 0x47,
+    0x53, 0x11, 0x1b, 0x17, 0x3b, 0x3b, 0x05, 0xd2,
+    0x2f, 0xa0, 0x80, 0x86, 0xe3, 0xb0, 0xf7, 0x12,
+    0xfc, 0xc7, 0xc7, 0x1a, 0x55, 0x7e, 0x2d, 0xb9,
+    0x66, 0xc3, 0xe9, 0xfa, 0x91, 0x74, 0x60, 0x39
 test_sha512_results[RTEMS_ARRAY_SIZE(test_vectors)][SHA512_DIGEST_LENGTH] = {
@@ -205,6 +239,29 @@ static void test_sha256(void)
+static void test_sha384(void)
+  size_t i;
+  printf("test SHA384\n");
+  for (i = 0; i < RTEMS_ARRAY_SIZE(test_vectors); ++i) {
+    SHA384_CTX ctx;
+    unsigned char r[SHA384_DIGEST_LENGTH];
+    const char *s = test_vectors[i];
+    SHA384_Init(&ctx);
+    SHA384_Update(&ctx, s, strlen(s));
+    SHA384_Final(r, &ctx);
+    print_result(&r[0], sizeof(r));
+    rtems_test_assert(
+      memcmp(&r[0], &test_sha384_results[i][0], sizeof(r)) == 0
 static void test_sha512(void)
   size_t i;
@@ -234,6 +291,7 @@ static void Init(rtems_task_argument arg)
   test_sha224();
   test_sha256();
+  test_sha384();
   test_sha512();
   rtems_stack_checker_report_usage();
2.35.3
