[PATCH] minimum: Do not use unified work areas
Sebastian Huber
Thu Sep 8 14:15:32 UTC 2022
The CONFIGURE_UNIFIED_WORK_AREAS option pulls in a system initialization
handler which initializes the unified heap.
Close #4108.
testsuites/samples/minimum/init.c | 15 ---------------
1 file changed, 15 deletions(-)
diff --git a/testsuites/samples/minimum/init.c b/testsuites/samples/minimum/init.c
index 347b6ce991..ee14a1aef4 100644
--- a/testsuites/samples/minimum/init.c
+++ b/testsuites/samples/minimum/init.c
@@ -104,21 +104,6 @@ static void *Init( uintptr_t ignored )
#define CONFIGURE_MAXIMUM_PRIORITY 15
- * This configures RTEMS to use a single memory pool for the RTEMS Workspace
- * and C Program Heap. If not defined, there will be separate memory pools
- * for the RTEMS Workspace and C Program Heap. Having separate pools
- * does haved some advantages in the event a task blows a stack or writes
- * outside its memory area. However, in low memory systems the overhead of
- * the two pools plus the potential for unused memory in either pool is
- * very undesirable.
- * In high memory environments, this is desirable when you want to use
- * the RTEMS "unlimited" objects option. You will be able to create objects
- * until you run out of memory.
-#define CONFIGURE_UNIFIED_WORK_AREAS
* In this application, the initialization task performs the system
* initialization and then transforms itself into the idle task.
2.35.3
