[PATCH RSB] rtems-tools-6.cfg: Bump hash to update BSP list
Joel Sherrill
joel at rtems.org
Thu Sep 8 15:25:41 UTC 2022
rtems/config/tools/rtems-tools-6.cfg | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index d7522fd..14ee346 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
%define rtems_tools_source rtems-tools-%{rtems_tools_version}
%define rtems_tools_ext xz
%else
- %define rtems_tools_version 1cd476e155b3bb236b9bf5f79614cdced8d416a0
+ %define rtems_tools_version 53a8d8591433f72052c2216433fd53b37f018f65
%define rtems_tools_ext bz2
%endif
%source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
%hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
- oJ5RzHDsye/mM8cicHE9lD8avxlv/ZYbXjNO2MPMCwHHhDThSh7O0hi70ywaGLrQXSt1mywvKwDwBNH3hJRiEQ==
+ e9HwcZQlo9Vk8ZDL/K3oN+77UF4FJ/R3HjZdqZExnByEwB65bRSxdt2JyI74Z8paQudJtrR1dbB0OCMoEyO8zA==
# Optionally enable/disable building the RTEMS Tools via the command line.
1.8.3.1
