[PATCH rtems-lwip v3 5/7] RTEMS port of lwIP for STM32 and STM32F4 BSP
Duc Doan
dtbpkmte at gmail.com
Thu Sep 8 16:34:42 UTC 2022
rtemslwip/stm32f4/stm32f4_lwip.c | 14 ++++
rtemslwip/stm32f4/stm32f4_lwip.h | 9 +++
stm32/ethernetif.c | 110 ++++++++++++++++++++++++++++++-
stm32/ethernetif.h | 8 ++-
stm32/lwip.h | 2 +
5 files changed, 140 insertions(+), 3 deletions(-)
create mode 100644 rtemslwip/stm32f4/stm32f4_lwip.c
create mode 100644 rtemslwip/stm32f4/stm32f4_lwip.h
diff --git a/rtemslwip/stm32f4/stm32f4_lwip.c b/rtemslwip/stm32f4/stm32f4_lwip.c
new file mode 100644
index 0000000..1f4f07e
--- /dev/null
+++ b/rtemslwip/stm32f4/stm32f4_lwip.c
@@ -0,0 +1,14 @@
+#include "stm32f4_lwip.h"
+extern ETH_HandleTypeDef heth;
+__attribute__((weak)) void Error_Handler(void) {
+ __disable_irq();
+ while (1)
+void ETH_IRQHandler(void) {
+ HAL_ETH_IRQHandler(&heth);
diff --git a/rtemslwip/stm32f4/stm32f4_lwip.h b/rtemslwip/stm32f4/stm32f4_lwip.h
index 0000000..8a2b03a
--- /dev/null
+++ b/rtemslwip/stm32f4/stm32f4_lwip.h
@@ -0,0 +1,9 @@
+#ifndef LIPLWIP_RTEMSLWIP_STM32F4_STM32F4_LWIP_H
+#define LIPLWIP_RTEMSLWIP_STM32F4_STM32F4_LWIP_H
+#include <stm32f4xx_hal.h>
+void ErrorHandler(void);
+void ETH_IRQHandler(void);
+#endif /* LIPLWIP_RTEMSLWIP_STM32F4_STM32F4_LWIP_H */
diff --git a/stm32/ethernetif.c b/stm32/ethernetif.c
index 7a82c51..e71ac8f 100644
--- a/stm32/ethernetif.c
+++ b/stm32/ethernetif.c
@@ -19,7 +19,12 @@
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
+#ifndef __rtems__
#include "main.h"
+#else
+#include <bsp.h>
+#include <bsp/irq.h>
+#endif /* __rtems__ */
#include "lwip/opt.h"
#include "lwip/timeouts.h"
#include "netif/ethernet.h"
@@ -28,7 +33,9 @@
#include "ethernetif.h"
#include "dp83848.h"
+#ifndef __rtems__
#include "cmsis_os.h"
#include "lwip/tcpip.h"
/* Within 'USER CODE' section, code will be kept by default at each generation */
@@ -38,7 +45,12 @@
/* Private define ------------------------------------------------------------*/
/* The time to block waiting for input. */
+#ifndef __rtems__
#define TIME_WAITING_FOR_INPUT ( portMAX_DELAY )
+#else
+#define TIME_WAITING_FOR_INPUT ( RTEMS_NO_TIMEOUT )
/* USER CODE BEGIN OS_THREAD_STACK_SIZE_WITH_RTOS */
/* Stack size of the interface thread */
#define INTERFACE_THREAD_STACK_SIZE ( 350 )
@@ -109,12 +121,20 @@ ETH_DMADescTypeDef DMATxDscrTab[ETH_TX_DESC_CNT]; /* Ethernet Tx DMA Descriptor
/* USER CODE END 2 */
+#ifndef __rtems__
osSemaphoreId RxPktSemaphore = NULL; /* Semaphore to signal incoming packets */
osSemaphoreId TxPktSemaphore = NULL; /* Semaphore to signal transmit packet complete */
+#else
+rtems_id RxPktSemaphore; /* Semaphore to signal incoming packets */
+rtems_id TxPktSemaphore; /* Semaphore to signal transmit packet complete */
/* Global Ethernet handle */
ETH_TxPacketConfig TxConfig;
+#ifdef __rtems__
+static uint8_t *MACAddr;
/* Private function prototypes -----------------------------------------------*/
int32_t ETH_PHY_IO_Init(void);
@@ -144,7 +164,11 @@ void pbuf_free_custom(struct pbuf *p);
void HAL_ETH_RxCpltCallback(ETH_HandleTypeDef *handlerEth)
+#ifndef __rtems__
osSemaphoreRelease(RxPktSemaphore);
+#else
+ rtems_semaphore_release(RxPktSemaphore);
* @brief Ethernet Tx Transfer completed callback
@@ -153,7 +177,11 @@ void HAL_ETH_RxCpltCallback(ETH_HandleTypeDef *handlerEth)
void HAL_ETH_TxCpltCallback(ETH_HandleTypeDef *handlerEth)
+#ifndef __rtems__
osSemaphoreRelease(TxPktSemaphore);
+#else
+ rtems_semaphore_release(TxPktSemaphore);
* @brief Ethernet DMA transfer error callback
@@ -164,12 +192,21 @@ void HAL_ETH_ErrorCallback(ETH_HandleTypeDef *handlerEth)
if((HAL_ETH_GetDMAError(handlerEth) & ETH_DMASR_RBUS) == ETH_DMASR_RBUS)
- osSemaphoreRelease(RxPktSemaphore);
+#ifndef __rtems__
+ osSemaphoreRelease(RxPktSemaphore);
+#else
/* USER CODE BEGIN 4 */
+#ifdef __rtems__
+void set_mac_addr(uint8_t *mac_addr)
+ MACAddr = mac_addr;
/* USER CODE END 4 */
@@ -186,15 +223,20 @@ static void low_level_init(struct netif *netif)
HAL_StatusTypeDef hal_eth_init_status = HAL_OK;
/* USER CODE BEGIN OS_THREAD_ATTR_CMSIS_RTOS_V2 */
+#ifndef __rtems__
osThreadAttr_t attributes;
/* USER CODE END OS_THREAD_ATTR_CMSIS_RTOS_V2 */
uint32_t duplex, speed = 0;
int32_t PHYLinkState = 0;
ETH_MACConfigTypeDef MACConf = {0};
/* Start ETH HAL Init */
+#ifndef __rtems__
uint8_t MACAddr[6] ;
heth.Instance = ETH;
+#ifndef __rtems__
MACAddr[0] = 0x02;
MACAddr[1] = 0x00;
MACAddr[2] = 0x00;
@@ -202,6 +244,9 @@ static void low_level_init(struct netif *netif)
MACAddr[4] = 0x00;
MACAddr[5] = 0x01;
heth.Init.MACAddr = &MACAddr[0];
+#else
+ heth.Init.MACAddr = MACAddr;
heth.Init.MediaInterface = HAL_ETH_RMII_MODE;
heth.Init.TxDesc = DMATxDscrTab;
heth.Init.RxDesc = DMARxDscrTab;
@@ -248,18 +293,48 @@ static void low_level_init(struct netif *netif)
#endif /* LWIP_ARP */
/* create a binary semaphore used for informing ethernetif of frame reception */
+#ifndef __rtems__
RxPktSemaphore = osSemaphoreNew(1, 1, NULL);
+#else
+ rtems_semaphore_create(
+ rtems_build_name('R', 'x', 'p', 'k'),
+ 1,
+ RTEMS_SIMPLE_BINARY_SEMAPHORE,
+ 0,
+ &RxPktSemaphore
/* create a binary semaphore used for informing ethernetif of frame transmission */
+#ifndef __rtems__
TxPktSemaphore = osSemaphoreNew(1, 1, NULL);
+#else
+ rtems_build_name('T', 'x', 'p', 'k'),
+ 1,
+ 0,
+ &TxPktSemaphore
/* create the task that handles the ETH_MAC */
/* USER CODE BEGIN OS_THREAD_NEW_CMSIS_RTOS_V2 */
+#ifndef __rtems__
memset(&attributes, 0x0, sizeof(osThreadAttr_t));
attributes.name = "EthIf";
attributes.stack_size = INTERFACE_THREAD_STACK_SIZE;
attributes.priority = osPriorityRealtime;
osThreadNew(ethernetif_input, netif, &attributes);
+#else
+ sys_thread_new(
+ "ethernetif_input_thread",
+ ethernetif_input,
+ netif,
+ RTEMS_MINIMUM_STACK_SIZE,
+ DEFAULT_THREAD_PRIO
+#endif /* __rtem__ */
/* USER CODE END OS_THREAD_NEW_CMSIS_RTOS_V2 */
/* USER CODE BEGIN PHY_PRE_CONFIG */
@@ -313,6 +388,15 @@ static void low_level_init(struct netif *netif)
MACConf.Speed = speed;
HAL_ETH_SetMACConfig(&heth, &MACConf);
+#ifdef __rtems__
+ rtems_interrupt_handler_install(
+ STM32F4_IRQ_ETH,
+ NULL,
+ RTEMS_INTERRUPT_UNIQUE,
+ HAL_ETH_IRQHandler,
+ &heth
HAL_ETH_Start_IT(&heth);
netif_set_up(netif);
netif_set_link_up(netif);
@@ -387,7 +471,12 @@ static err_t low_level_output(struct netif *netif, struct pbuf *p)
pbuf_ref(p);
HAL_ETH_Transmit_IT(&heth, &TxConfig);
+#ifndef __rtems__
while(osSemaphoreAcquire(TxPktSemaphore, TIME_WAITING_FOR_INPUT)!=osOK)
+#else
+ while (rtems_semaphore_obtain(TxPktSemaphore, RTEMS_DEFAULT_OPTIONS,
+ TIME_WAITING_FOR_INPUT) != RTEMS_SUCCESSFUL)
@@ -433,7 +522,12 @@ void ethernetif_input(void* argument)
for( ;; )
+#ifndef __rtems__
if (osSemaphoreAcquire(RxPktSemaphore, TIME_WAITING_FOR_INPUT) == osOK)
+#else
+ if (rtems_semaphore_obtain(RxPktSemaphore, RTEMS_DEFAULT_OPTIONS,
+ TIME_WAITING_FOR_INPUT) == RTEMS_SUCCESSFUL)
do
@@ -545,12 +639,17 @@ void pbuf_free_custom(struct pbuf *p)
if (RxAllocStatus == RX_ALLOC_ERROR)
RxAllocStatus = RX_ALLOC_OK;
+#ifndef __rtems__
+#else
/* USER CODE BEGIN 6 */
+#ifndef __rtems__
* @brief Returns the current time in milliseconds
* when LWIP_TIMERS == 1 and NO_SYS == 1
@@ -561,6 +660,7 @@ u32_t sys_now(void)
return HAL_GetTick();
/* USER CODE END 6 */
@@ -611,8 +711,10 @@ void HAL_ETH_MspInit(ETH_HandleTypeDef* ethHandle)
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* Peripheral interrupt init */
+#ifndef __rtems__
HAL_NVIC_SetPriority(ETH_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(ETH_IRQn);
/* USER CODE BEGIN ETH_MspInit 1 */
/* USER CODE END ETH_MspInit 1 */
@@ -799,7 +901,11 @@ void ethernet_link_thread(void* argument)
/* USER CODE END ETH link Thread core code for User BSP */
+#ifndef __rtems__
osDelay(100);
+#else
+ sys_arch_delay(100);
diff --git a/stm32/ethernetif.h b/stm32/ethernetif.h
index 85c1acf..552671a 100644
--- a/stm32/ethernetif.h
+++ b/stm32/ethernetif.h
@@ -23,11 +23,15 @@
#include "lwip/err.h"
#include "lwip/netif.h"
+#ifndef __rtems__
/* USER CODE BEGIN 0 */
+#ifdef __rtems__
+void set_mac_addr(uint8_t *mac_addr);
/* USER CODE END 0 */
/* Exported functions ------------------------------------------------------- */
@@ -38,7 +42,9 @@ void ethernet_link_thread(void* argument );
void Error_Handler(void);
u32_t sys_jiffies(void);
+#ifndef __rtems__
u32_t sys_now(void);
/* USER CODE BEGIN 1 */
diff --git a/stm32/lwip.h b/stm32/lwip.h
index 02df90e..fbaf786 100644
--- a/stm32/lwip.h
+++ b/stm32/lwip.h
@@ -47,6 +47,7 @@
/* Global Variables ----------------------------------------------------------*/
+#ifndef __rtems__
/* LWIP init function */
void MX_LWIP_Init(void);
@@ -62,6 +63,7 @@ void MX_LWIP_Process(void);
/* USER CODE END 1 */
#endif /* WITH_RTOS */
#ifdef __cplusplus
#endif
2.37.2
