[PATCH] user: Document RSB --with/without-newlib-tls
Chris Johns
chrisj at rtems.org
Fri Sep 9 05:24:36 UTC 2022
Thanks for adding this. Please push.
On 9/9/2022 3:18 pm, Sebastian Huber wrote:
> Update #4560.
> user/rsb/project-sets.rst | 9 +++++++++
> 1 file changed, 9 insertions(+)
> diff --git a/user/rsb/project-sets.rst b/user/rsb/project-sets.rst
> index 54a3f8e..ce839c5 100644
> --- a/user/rsb/project-sets.rst
> +++ b/user/rsb/project-sets.rst
> @@ -116,6 +116,15 @@ build sets:
> ``--with-objc``
> Attempt to build a C++ compiler.
> +``--with-newlib-tls`` or ``--without-newlib-tls``
> + Enable or disable the ``--enable-newlib-reent-thread-local`` Newlib
> + configuration option. This option is enabled by default on the aarch64, arm,
> + nios2, powerpc, riscv, and sparc targets. If this option is enabled, then
> + each member of the Newlib struct _reent is replaced by a dedicated
> + thread-local object. The thread-local objects are defined in translation
> + units which use the corresponding object so that only objects used by the
> + application are linked in.
> The RSB provides build sets for some BSPs. These build sets will build:
> - Compiler, linker, debugger and RTEMS Tools.
