RSB vs. Python 2.7
Fri Sep 9 05:53:20 UTC 2022
On 9/9/2022 3:50 pm, Sebastian Huber wrote:
> On 09.09.22 07:49, Chris Johns wrote:
>> On 9/9/2022 3:30 pm, Sebastian Huber wrote:
>>> Hello,
>>> it seems that the recent RSB no longer runs with Python 2.7:
>>> download:https://codeload.github.com/RTEMS/gnu-mirror-gcc/tar.gz/6678700:
>>> error: <urlopen error unknown url type: https>
>> https should be ok with python2?
> My default "python" command is
> Python 2.7.18
The doco says https is supported ...
https://docs.python.org/2.7/library/urllib.html
> With it, the RSB stops with the above error. With Python 3 it works fine.
Strange. I will take a look once the current run of tests finish. Some build
take a while even on fast hardware.
