[PATCH rtems-lwip v4 2/7] lwip.py: Use ant_glob instead of os.walk()
Duc Doan
dtbpkmte at gmail.com
Fri Sep 9 23:13:11 UTC 2022
Updates #4714
lwip.py | 10 +---------
1 file changed, 1 insertion(+), 9 deletions(-)
diff --git a/lwip.py b/lwip.py
index 2b0c205..2d93d3e 100644
--- a/lwip.py
+++ b/lwip.py
@@ -110,15 +110,7 @@ def build(bld):
source_files.extend(common_source_files)
def walk_sources(path):
- sources = []
- for root, dirs, files in os.walk(path):
- for name in files:
- ext = os.path.splitext(name)[1]
- src_root = os.path.split(root)
- path = os.path.join(src_root[0], src_root[1])
- if ext == '.c' or ext == '.S':
- sources.append(os.path.join(path, name))
- return sources
+ return bld.path.ant_glob([path + '/**/*.c', path + '/**/*.S'])
if arch == 'arm':
# These files will not compile for BSPs other than TMS570
2.37.2
