[PATCH rtems-lwip v4 4/7] rtemslwip: Add STM32F4 lwipopts.h and netstart.c
Duc Doan dtbpkmte at gmail.com
Fri Sep 9 23:13:13 UTC 2022
 rtemslwip/stm32f4/lwipopts.h | 147 +++++++++++++++++++++++++++++++++++
 rtemslwip/stm32f4/netstart.c |  73 +++++++++++++++++
 2 files changed, 220 insertions(+)
 create mode 100644 rtemslwip/stm32f4/lwipopts.h
 create mode 100644 rtemslwip/stm32f4/netstart.c
diff --git a/rtemslwip/stm32f4/lwipopts.h b/rtemslwip/stm32f4/lwipopts.h
new file mode 100644
index 0000000..aa6b95b
--- /dev/null
+++ b/rtemslwip/stm32f4/lwipopts.h
@@ -0,0 +1,147 @@
+/* USER CODE BEGIN Header */
+  * File Name          : Target/lwipopts.h
+  * Description        : This file overrides LwIP stack default configuration
+  *                      done in opt.h file.
+  * @attention
+  * Copyright (c) 2022 STMicroelectronics.
+  * All rights reserved.
+  * This software is licensed under terms that can be found in the LICENSE file
+  * in the root directory of this software component.
+  * If no LICENSE file comes with this software, it is provided AS-IS.
+/* USER CODE END Header */
+/* Define to prevent recursive inclusion --------------------------------------*/
+#ifndef __LWIPOPTS__H__
+#define __LWIPOPTS__H__
+/* Current version of LwIP supported by CubeMx: 2.1.2 -*/
+/* Within 'USER CODE' section, code will be kept by default at each generation */
+/* USER CODE BEGIN 0 */
+#include <stm32f4xx_hal.h>
+/* USER CODE END 0 */
+#ifdef __cplusplus
+ extern "C" {
+#endif
+/* STM32CubeMX Specific Parameters (not defined in opt.h) ---------------------*/
+/* Parameters set in STM32CubeMX LwIP Configuration GUI -*/
+/*----- WITH_RTOS disabled (Since FREERTOS is not set) -----*/
+#define WITH_RTOS 1
+/*----- CHECKSUM_BY_HARDWARE disabled -----*/
+#define CHECKSUM_BY_HARDWARE 0
+/* LwIP Stack Parameters (modified compared to initialization value in opt.h) -*/
+/*----- Default value in ETH configuration GUI in CubeMx: 1524 -----*/
+#define ETH_RX_BUFFER_SIZE 1536
+/*----- Value in opt.h for NO_SYS: 0 -----*/
+#define NO_SYS 0
+/*----- Value in opt.h for SYS_LIGHTWEIGHT_PROT: 1 -----*/
+#define SYS_LIGHTWEIGHT_PROT 1
+/*----- Value in opt.h for MEM_ALIGNMENT: 1 -----*/
+#define MEM_ALIGNMENT 4
+/*----- Default Value for H7 devices: 0x30044000 -----*/
+//#define LWIP_RAM_HEAP_POINTER 0x20017f58
+/*----- Value supported for H7 devices: 1 -----*/
+#define LWIP_SUPPORT_CUSTOM_PBUF 1
+/*----- Value in opt.h for LWIP_ETHERNET: LWIP_ARP || PPPOE_SUPPORT -*/
+#define LWIP_ETHERNET 1
+/*----- Value in opt.h for LWIP_DNS_SECURE: (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) -*/
+#define LWIP_DNS_SECURE 7
+/*----- Value in opt.h for TCP_SND_QUEUELEN: (4*TCP_SND_BUF + (TCP_MSS - 1))/TCP_MSS -----*/
+#define TCP_SND_QUEUELEN 9
+/*----- Value in opt.h for TCP_SNDLOWAT: LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) -*/
+#define TCP_SNDLOWAT 1071
+/*----- Value in opt.h for TCP_SNDQUEUELOWAT: LWIP_MAX(TCP_SND_QUEUELEN)/2, 5) -*/
+#define TCP_SNDQUEUELOWAT 5
+/*----- Value in opt.h for TCP_WND_UPDATE_THRESHOLD: LWIP_MIN(TCP_WND/4, TCP_MSS*4) -----*/
+#define TCP_WND_UPDATE_THRESHOLD 536
+/*----- Value in opt.h for LWIP_NETIF_LINK_CALLBACK: 0 -----*/
+//#define LWIP_NETIF_LINK_CALLBACK 0
+/*----- Value in opt.h for LWIP_NETCONN: 1 -----*/
+#define LWIP_NETCONN 1
+/*----- Value in opt.h for LWIP_SOCKET: 1 -----*/
+#define LWIP_SOCKET 1
+/*----- Value in opt.h for RECV_BUFSIZE_DEFAULT: INT_MAX -----*/
+//#define RECV_BUFSIZE_DEFAULT 2000000000
+/*----- Value in opt.h for LWIP_STATS: 1 -----*/
+#define LWIP_STATS 0
+/*----- Value in opt.h for CHECKSUM_GEN_IP: 1 -----*/
+#define CHECKSUM_GEN_IP 0
+/*----- Value in opt.h for CHECKSUM_GEN_UDP: 1 -----*/
+#define CHECKSUM_GEN_UDP 0
+/*----- Value in opt.h for CHECKSUM_GEN_TCP: 1 -----*/
+#define CHECKSUM_GEN_TCP 0
+/*----- Value in opt.h for CHECKSUM_GEN_ICMP: 1 -----*/
+#define CHECKSUM_GEN_ICMP 0
+/*----- Value in opt.h for CHECKSUM_GEN_ICMP6: 1 -----*/
+#define CHECKSUM_GEN_ICMP6 0
+/*----- Value in opt.h for CHECKSUM_CHECK_IP: 1 -----*/
+#define CHECKSUM_CHECK_IP 0
+/*----- Value in opt.h for CHECKSUM_CHECK_UDP: 1 -----*/
+#define CHECKSUM_CHECK_UDP 0
+/*----- Value in opt.h for CHECKSUM_CHECK_TCP: 1 -----*/
+#define CHECKSUM_CHECK_TCP 0
+/*----- Value in opt.h for CHECKSUM_CHECK_ICMP: 1 -----*/
+#define CHECKSUM_CHECK_ICMP 0
+/*----- Value in opt.h for CHECKSUM_CHECK_ICMP6: 1 -----*/
+#define CHECKSUM_CHECK_ICMP6 0
+/*----- Default Value for ETHARP_DEBUG: LWIP_DBG_OFF ---*/
+/* USER CODE BEGIN 1 */
+//#define LWIP_DEBUG 1
+#define LWIP_ARP 1
+#define LWIP_NETIF_API 1
+#define NO_SYS_NO_TIMERS 0
+#define IP_REASSEMBLY                   0
+#define IP_FRAG                         0
+#define LWIP_IPV4                       1
+#define LWIP_IPV6                       1
+#define LWIP_TCPIP_CORE_LOCKING         1
+#define TCPIP_THREAD_STACKSIZE 1024
+#define TCPIP_THREAD_PRIO 24
+#define TCPIP_MBOX_SIZE 6
+#define SLIPIF_THREAD_STACKSIZE 1024
+#define SLIPIF_THREAD_PRIO 3
+#define DEFAULT_THREAD_STACKSIZE 1024
+#define DEFAULT_THREAD_PRIO 3
+#define DEFAULT_UDP_RECVMBOX_SIZE 6
+#define DEFAULT_TCP_RECVMBOX_SIZE 6
+#define DEFAULT_ACCEPTMBOX_SIZE 6
+#define LWIP_DHCP                       1
+#define DHCP_DOES_ARP_CHECK             1
+#define LWIP_DNS                        1
+#define LWIP_AUTOIP                     1
+#define LWIP_DHCP_AUTOIP_COOP           ((LWIP_DHCP) && (LWIP_AUTOIP))
+#define LWIP_TIMEVAL_PRIVATE 0
+#define LWIP_COMPAT_SOCKETS 1
+#define LWIP_RAW 0
+#define SO_REUSE 1
+/* USER CODE END 1 */
+#ifdef __cplusplus
+#endif
+#endif /*__LWIPOPTS__H__ */
diff --git a/rtemslwip/stm32f4/netstart.c b/rtemslwip/stm32f4/netstart.c
index 0000000..fed7aae
--- /dev/null
+++ b/rtemslwip/stm32f4/netstart.c
@@ -0,0 +1,73 @@
+ * Copyright (C) 2022 Duc Doan (dtbpkmte at gmail.com)
+ * are met:
+#include <netstart.h>
+#include <lwip/tcpip.h>
+#include "lwip/init.h"
+#include "lwip/netif.h"
+#include "ethernetif.h"
+int start_networking(
+  struct netif  *net_interface,
+  ip_addr_t     *ipaddr,
+  ip_addr_t     *netmask,
+  ip_addr_t     *gateway,
+  unsigned char *mac_ethernet_address
+  tcpip_init( NULL, NULL );
+  set_mac_addr(mac_ethernet_address);
+  netif_add(
+    net_interface,
+    &ipaddr->u_addr.ip4,
+    &netmask->u_addr.ip4,
+    &gateway->u_addr.ip4,
+    NULL,
+    ethernetif_init,
+    tcpip_input
+  netif_set_default(net_interface);
+  if (netif_is_link_up(net_interface)) {
+    netif_set_up(net_interface);
+    sys_thread_new(
+      "stm32f4_ethernet_link_thread",
+      ethernet_link_thread,
+      net_interface,
+      1024,
+      DEFAULT_THREAD_PRIO
+    return 0;
+  } else {
+    netif_set_down(net_interface);
+  return -1;
2.37.2
