[PATCH rtems-lwip] lwip.py: Allow lwIP to build against stale install
Chris Johns
chrisj at rtems.org
Sun Sep 11 01:22:02 UTC 2022
On 10/9/2022 12:07 pm, Kinsey Moore wrote:
> This removes the default BSP include path from environment variables so
> that rtems-lwip can build even when there's a stale version with
> outdated headers installed in the BSP.
I am not following what this does and what problem you are attempting to
solve?
I am not comfortable seeing rtems_waf being overridden like this.
> lwip.py | 22 ++++++++++++++++------
> 1 file changed, 16 insertions(+), 6 deletions(-)
> diff --git a/lwip.py b/lwip.py
> index 84eef2c..3d9cb29 100644
> --- a/lwip.py
> +++ b/lwip.py
> @@ -99,6 +99,9 @@ def build(bld):
> drv_incl = []
> arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> bld.env.RTEMS_ARCH_BSP)
> + bsp_incl = os.path.relpath(
> + os.path.join(bld.env.PREFIX, arch_lib_path, 'include')
> with open('file-import.json', 'r') as cf:
> files = json.load(cf)
> for f in files['files-to-import']:
> @@ -155,6 +158,7 @@ def build(bld):
> lwip_obj_incl.extend(drv_incl)
> lwip_obj_incl.extend(bsd_compat_incl)
> lwip_obj_incl.extend(common_includes)
> + lwip_obj_incl.append(bsp_incl)
> bld(features='c',
> target='lwip_obj',
> @@ -166,9 +170,7 @@ def build(bld):
> drv_obj_incl = []
> drv_obj_incl.extend(drv_incl)
> drv_obj_incl.extend(common_includes)
> - drv_obj_incl.append(os.path.relpath(
> - os.path.join(bld.env.PREFIX, arch_lib_path, 'include')
> + drv_obj_incl.append(bsp_incl)
> bld(features='c',
> target='driver_obj',
> @@ -203,9 +205,7 @@ def build(bld):
> test_app_incl.extend(drv_incl)
> test_app_incl.extend(common_includes)
> test_app_incl.append('rtemslwip/test/')
> - test_app_incl.append(
> - os.path.relpath(os.path.join(arch_lib_path, 'include'))
> + test_app_incl.append(bsp_incl)
> bld.program(features='c',
> target='networking01.exe',
> source='rtemslwip/test/networking01/sample_app.c',
> @@ -235,8 +235,18 @@ def add_flags(flags, new_flags):
> flags.append(flag)
> +def strip_bsp_include(bsp_include_path, current_flags):
> + # this does not handle quted strings; maybe needed
> + for bsp_path in bsp_include_path:
> + current_flags = [flag for flag in current_flags if flag != bsp_path]
> + return current_flags
> def bsp_configure(conf, arch_bsp):
> conf.env.LIB += ['m']
> section_flags = ["-fdata-sections", "-ffunction-sections"]
> add_flags(conf.env.CFLAGS, section_flags)
> add_flags(conf.env.CXXFLAGS, section_flags)
> + conf.env.CFLAGS = strip_bsp_include(conf.env.IFLAGS, conf.env.CFLAGS)
> + conf.env.CXXFLAGS = strip_bsp_include(conf.env.IFLAGS, conf.env.CXXFLAGS)
> + conf.env.LINKFLAGS = strip_bsp_include(conf.env.IFLAGS, conf.env.LINKFLAGS)
