[PATCH rtems-lwip] lwip.py: Allow lwIP to build against stale install
Chris Johns
chrisj at rtems.org
Sun Sep 11 23:51:59 UTC 2022
On 11/9/22 11:30 pm, Kinsey Moore wrote:
> On 9/10/2022 20:22, Chris Johns wrote:
>> On 10/9/2022 12:07 pm, Kinsey Moore wrote:
>>> This removes the default BSP include path from environment variables so
>>> that rtems-lwip can build even when there's a stale version with
>>> outdated headers installed in the BSP.
>> I am not following what this does and what problem you are attempting to solve?
>> I am not comfortable seeing rtems_waf being overridden like this.
>> Chris
> This is approximately the same change that you did for libbsd that shuffles the
> include paths so that lwip builds against local headers first and isn't broken
> by a stale install of rtems-lwip in the BSP install directory.
Yes it is the workaround to the problem. It is not 100% fool proof but it is
good enough for most cases (eg does not handle deleting a header that is
installed). The correct method is sandboxing the prefix into a separate
directory so you can delete the package you are working on.
I am wondering if rtems_waf handle this so we avoid coping the solution to
multiple places? Would having rtems_waf always append the BSP include work?
