[PATCH] Update build system related sections for RTEMS 6
Sebastian Huber
Mon Sep 12 07:10:38 UTC 2022
Update sections which contained the word "bsp_specs".
bsp-howto/coding-doxygen-bsp.rst | 7 +-
bsp-howto/miscellanous_support.rst | 38 ----
user/installation/kernel.rst | 308 +++++++----------------------
user/tracing/examples.rst | 4 +-
4 files changed, 77 insertions(+), 280 deletions(-)
diff --git a/bsp-howto/coding-doxygen-bsp.rst b/bsp-howto/coding-doxygen-bsp.rst
index 59c0e0b..5f3b46a 100644
--- a/bsp-howto/coding-doxygen-bsp.rst
+++ b/bsp-howto/coding-doxygen-bsp.rst
@@ -151,8 +151,8 @@ directories contain implementations of these features.
$ cd raspberrypi
$ ls
- bsp_specs configure.ac include make misc README
- clock console irq Makefile.am preinstall.am startup
+ include misc README clock console irq
+ start
Another way to get an idea of the structure of bsps/ is to navigate
to a directory and execute the "tree -f" command. This outputs a nice
@@ -164,8 +164,7 @@ directory.
$ pwd
~/rtems/bsps/arm/raspberrypi
$ tree -f
- |-- ./bsp_specs
|-- ./clock
| `-- ./clock/clockdrv.c
|-- ./configure.ac
diff --git a/bsp-howto/miscellanous_support.rst b/bsp-howto/miscellanous_support.rst
index 015adb4..10b45f7 100644
--- a/bsp-howto/miscellanous_support.rst
+++ b/bsp-howto/miscellanous_support.rst
@@ -10,44 +10,6 @@ Miscellaneous Support Files
This chapter contains outdated and confusing information.
-GCC Compiler Specifications File
-The file ``bsp_specs`` defines the start files and libraries that are always
-used with this BSP. The format of this file is admittedly cryptic and this
-document will make no attempt to explain it completely. Below is the
-``bsp_specs`` file from the PowerPC psim BSP:
-.. code-block:: c
- %rename endfile old_endfile
- %rename startfile old_startfile
- %rename link old_link
- *startfile:
- %{!qrtems: %(old_startfile)} \
- %{!nostdlib: %{qrtems: ecrti%O%s rtems_crti%O%s crtbegin.o%s start.o%s}}
- *link:
- %{!qrtems: %(old_link)} %{qrtems: -Qy -dp -Bstatic -e _start -u __vectors}
- *endfile:
- %{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s ecrtn.o%s}
-The first section of this file renames the built-in definition of some
-specification variables so they can be augmented without embedded their
-original definition. The subsequent sections specify what behavior is expected
-when the ``-qrtems`` option is specified.
-The ``*startfile`` section specifies that the BSP specific file ``start.o``
-will be used instead of ``crt0.o``. In addition, various EABI support files
-(``ecrti.o`` etc.) will be linked in with the executable.
-The ``*link`` section adds some arguments to the linker when it is invoked by
-GCC to link an application for this BSP.
-The format of this file is specific to the GNU Compiler Suite. The argument
-used to override and extend the compiler built-in specifications is available
-in all recent GCC versions. The ``-specs`` option is present in all ``egcs``
-distributions and ``gcc`` distributions starting with version 2.8.0.
README Files
diff --git a/user/installation/kernel.rst b/user/installation/kernel.rst
index fca4ed7..d61f17f 100644
--- a/user/installation/kernel.rst
+++ b/user/installation/kernel.rst
@@ -18,10 +18,9 @@ Create a new location to build the RTEMS kernel:
.. code-block:: none
- $ cd
- $ cd development/rtems
- $ mkdir kernel
- $ cd kernel
+ $ cd $HOME/development/rtems
+ $ mkdir src
+ $ cd src
Clone the RTEMS respository:
@@ -36,209 +35,72 @@ Clone the RTEMS respository:
Resolving deltas: 100% (390053/390053), done.
Checking connectivity... done.
-Tools Path Set Up
-We need to set our path to include the RTEMS tools we built in the previous
-section. The RTEMS tools needs to be first in your path because RTEMS provides
-specific versions of the ``autoconf`` and ``automake`` tools. We want to use
-the RTEMS version and not your host's versions:
-.. code-block:: none
- $ export PATH=$HOME/development/rtems/5/bin:$PATH
-.. _bootstrapping:
-Bootstrapping
-The developers version of the code from git requires we ``bootstrap`` the
-source code. This is an ``autoconf`` and ``automake`` bootstrap to create the
-various files generated by ``autoconf`` and ``automake``. RTEMS does not keep
-these generated files under version control. The bootstrap process is slow so
-to speed it up we provide a command that can perform the bootstrap in
-parallel using your available cores. We need to enter the cloned source
-directory then run the bootstrap commands:
- $ cd rtems
- $ ./bootstrap -c && ./rtems-bootstrap
- removing automake generated Makefile.in files
- removing configure files
- removing aclocal.m4 files
- RTEMS Bootstrap, 5 (089327b5dcf9)
- 1/139: autoreconf: configure.ac
- 2/139: autoreconf: cpukit/configure.ac
- 3/139: autoreconf: tools/cpu/configure.ac
- 4/139: autoreconf: tools/cpu/generic/configure.ac
- 5/139: autoreconf: tools/cpu/sh/configure.ac
- 6/139: autoreconf: tools/cpu/nios2/configure.ac
- 7/139: autoreconf: tools/build/configure.ac
- 8/139: autoreconf: doc/configure.ac
- 124/139: autoreconf: c/src/make/configure.ac
- 125/139: autoreconf: c/src/librtems++/configure.ac
- 126/139: autoreconf: c/src/ada-tests/configure.ac
- 127/139: autoreconf: testsuites/configure.ac
- 128/139: autoreconf: testsuites/libtests/configure.ac
- 129/139: autoreconf: testsuites/mptests/configure.ac
- 130/139: autoreconf: testsuites/fstests/configure.ac
- 131/139: autoreconf: testsuites/sptests/configure.ac
- 132/139: autoreconf: testsuites/tmtests/configure.ac
- 133/139: autoreconf: testsuites/smptests/configure.ac
- 134/139: autoreconf: testsuites/tools/configure.ac
- 135/139: autoreconf: testsuites/tools/generic/configure.ac
- 136/139: autoreconf: testsuites/psxtests/configure.ac
- 137/139: autoreconf: testsuites/psxtmtests/configure.ac
- 138/139: autoreconf: testsuites/rhealstone/configure.ac
- 139/139: autoreconf: testsuites/samples/configure.ac
- Bootstrap time: 0:02:47.398824
Building a BSP
-We build RTEMS in a directory outside of the source tree we have just cloned
-and ``bootstrapped``. You cannot build RTEMS while in the source tree. Lets
-create a suitable directory using the name of the BSP we are going to build:
+We build RTEMS in a directory within the source tree we have just cloned. For
+the details, see the :ref:`BSPBuildSystem`. We will build for the ``erc32``
+BSP with POSIX enabled. Firstly, create the file :file:`config.ini` in the
+source tree root directory with the BSP build configuration, for example:
+.. code-block:: ini
- $ cd ..
- $ mkdir erc32
- $ cd erc32
+ [sparc/erc32]
+ RTEMS_POSIX_API = True
-Configure RTEMS using the ``configure`` command. We use a full path to
-``configure`` so the object files built contain the absolute path of the source
-files. If you are source level debugging you will be able to access the source
-code to RTEMS from the debugger. We will build for the ``erc32`` BSP with POSIX
-enabled and the networking stack disabled:
+Configure RTEMS using the ``waf configure`` command:
- $ $HOME/development/rtems/kernel/rtems/configure --prefix=$HOME/development/rtems/5 \
- --target=sparc-rtems5 --enable-rtemsbsp=erc32 --enable-posix \
- --disable-networking
- checking for gmake... no
- checking for make... make
- checking for RTEMS Version... 4.11.99.0
- checking build system type... x86_64-pc-linux-gnu
- checking host system type... x86_64-pc-linux-gnu
- checking target system type... sparc-unknown-rtems5
- checking for a BSD-compatible install... /usr/bin/install -c
- checking whether build environment is sane... yes
- checking for a thread-safe mkdir -p... /bin/mkdir -p
- checking for gawk... no
- checking for mawk... mawk
- checking whether make sets $(MAKE)... yes
- checking whether to enable maintainer-specific portions of Makefiles... no
- checking that generated files are newer than configure... done
- checking rtems target cpu... sparc
- checking for sparc-rtems5-strip... sparc-rtems5-strip
- configure: creating ./config.status
- config.status: creating Makefile
- target architecture: sparc.
- available BSPs: erc32.
- 'make all' will build the following BSPs: erc32.
- other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
-Build RTEMS using two cores:
+ $ cd $HOME/development/rtems/src/rtems
+ $ ./waf configure --prefix=$HOME/development/rtems/6
+ Setting top to : $HOME/development/rtems/src/rtems
+ Setting out to : $HOME/development/rtems/src/rtems/build
+ Regenerate build specification cache (needs a couple of seconds)...
+ Configure board support package (BSP) : sparc/erc32
+ Checking for program 'sparc-rtems6-gcc' : $HOME/development/rtems/6/bin/sparc-rtems6-gcc
+ Checking for program 'sparc-rtems6-g++' : $HOME/development/rtems/6/bin/sparc-rtems6-g++
+ Checking for program 'sparc-rtems6-ar' : $HOME/development/rtems/6/bin/sparc-rtems6-ar
+ Checking for program 'sparc-rtems6-ld' : $HOME/development/rtems/6/bin/sparc-rtems6-ld
+ Checking for program 'ar' : $HOME/development/rtems/6/bin/sparc-rtems6-ar
+ Checking for program 'g++, c++' : $HOME/development/rtems/6/bin/sparc-rtems6-g++
+ Checking for program 'gas, gcc' : $HOME/development/rtems/6/bin/sparc-rtems6-gcc
+ Checking for program 'gcc, cc' : $HOME/development/rtems/6/bin/sparc-rtems6-gcc
+ Checking for asm flags '-MMD' : yes
+ Checking for c flags '-MMD' : yes
+ Checking for cxx flags '-MMD' : yes
+ Checking for program 'rtems-bin2c' : $HOME/development/rtems/6/bin/rtems-bin2c
+ Checking for program 'gzip' : /usr/bin/gzip
+ Checking for program 'xz' : /usr/bin/xz
+ Checking for program 'rtems-ld' : $HOME/development/rtems/6/bin/rtems-ld
+ Checking for program 'rtems-syms' : $HOME/development/rtems/6/bin/rtems-syms
+ 'configure' finished successfully (7.996s)
+Build RTEMS:
- $ make -j 2
- Making all in tools/build
- make[1]: Entering directory '/home/chris/development/rtems/kernel/erc32/tools/build'
- make all-am
- make[2]: Entering directory '/home/chris/development/rtems/kernel/erc32/tools/build'
- gcc -DHAVE_CONFIG_H -I. -I/home/chris/development/rtems/kernel/rtems/tools/build -g -O2 -MT cklength.o -MD -MP -MF .deps/cklength.Tpo -c -o cklength.o /home/chris/development/rtems/kernel/rtems/tools/build/cklength.c
- gcc -DHAVE_CONFIG_H -I. -I/home/chris/development/rtems/kernel/rtems/tools/build -g -O2 -MT eolstrip.o -MD -MP -MF .deps/eolstrip.Tpo -c -o eolstrip.o /home/chris/development/rtems/kernel/rtems/tools/build/eolstrip.c
- mv -f .deps/cklength.Tpo .deps/cklength.Po
- mv -f .deps/eolstrip.Tpo .deps/eolstrip.Po
- gcc -DHAVE_CONFIG_H -I. -I/home/chris/development/rtems/kernel/rtems/tools/build -g -O2 -MT compat.o -MD -MP -MF .deps/compat.Tpo -c -o compat.o /home/chris/development/rtems/kernel/rtems/tools/build/compat.c
- gcc -DHAVE_CONFIG_H -I. -I/home/chris/development/rtems/kernel/rtems/tools/build -g -O2 -MT packhex.o -MD -MP -MF .deps/packhex.Tpo -c -o packhex.o /home/chris/development/rtems/kernel/rtems/tools/build/packhex.c
- mv -f .deps/compat.Tpo .deps/compat.Po
- gcc -DHAVE_CONFIG_H -I. -I/home/chris/development/rtems/kernel/rtems/tools/build -g -O2 -MT unhex.o -MD -MP -MF .deps/unhex.Tpo -c -o unhex.o /home/chris/development/rtems/kernel/rtems/tools/build/unhex.c
- mv -f .deps/packhex.Tpo .deps/packhex.Po
- gcc -DHAVE_CONFIG_H -I. -I/home/chris/development/rtems/kernel/rtems/tools/build -g -O2 -MT rtems-bin2c.o -MD -MP -MF .deps/rtems-bin2c.Tpo -c -o rtems-bin2c.o /home/chris/development/rtems/kernel/rtems/tools/build/rtems-bin2c.c
- mv -f .deps/unhex.Tpo .deps/unhex.Po
- gcc -DHAVE_CONFIG_H -I. -I/home/chris/development/rtems/kernel/rtems/tools/build -g -O2 -MT binpatch.o -MD -MP -MF .deps/binpatch.Tpo -c -o binpatch.o /home/chris/development/rtems/kernel/rtems/tools/build/binpatch.c
- mv -f .deps/rtems-bin2c.Tpo .deps/rtems-bin2c.Po
- gcc -g -O2 -o cklength cklength.o
- mv -f .deps/binpatch.Tpo .deps/binpatch.Po
- gcc -g -O2 -o eolstrip eolstrip.o compat.o
- gcc -g -O2 -o packhex packhex.o
- gcc -g -O2 -o rtems-bin2c rtems-bin2c.o compat.o
- gcc -g -O2 -o unhex unhex.o compat.o
- gcc -g -O2 -o binpatch binpatch.o
- make[2]: Leaving directory '/home/chris/development/rtems/kernel/erc32/tools/build'
- make[1]: Leaving directory '/home/chris/development/rtems/kernel/erc32/tools/build'
- Making all in tools/cpu
- make[1]: Entering directory '/home/chris/development/rtems/kernel/erc32/tools/cpu'
- Making all in generic
- make[2]: Entering directory '/home/chris/development/rtems/kernel/erc32/tools/cpu/generic'
- make[2]: Nothing to be done for 'all'.
- make[2]: Leaving directory '/home/chris/development/rtems/kernel/erc32/tools/cpu/generic'
- make[2]: Entering directory '/home/chris/development/rtems/kernel/erc32/tools/cpu'
- make[2]: Nothing to be done for 'all-am'.
- make[2]: Leaving directory '/home/chris/development/rtems/kernel/erc32/tools/cpu'
- make[1]: Leaving directory '/home/chris/development/rtems/kernel/erc32/tools/cpu'
- Making all in testsuites/tools
- make[1]: Entering directory '/home/chris/development/rtems/kernel/erc32/testsuites/tools'
- make[2]: Entering directory '/home/chris/development/rtems/kernel/erc32/testsuites/tools/generic'
- make[2]: Leaving directory '/home/chris/development/rtems/kernel/erc32/testsuites/tools/generic'
- make[2]: Entering directory '/home/chris/development/rtems/kernel/erc32/testsuites/tools'
- make[2]: Leaving directory '/home/chris/development/rtems/kernel/erc32/testsuites/tools'
- make[1]: Leaving directory '/home/chris/development/rtems/kernel/erc32/testsuites/tools'
- Making all in sparc-rtems5/c
- make[1]: Entering directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/c'
- Making all in .
- make[2]: Entering directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/c'
- Configuring RTEMS_BSP=erc32
- checking host system type... sparc-unknown-rtems5
- sparc-rtems5-gcc -B../../../../../erc32/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I. -I/home/chris/development/rtems/kernel/rtems/c/src/../../testsuites/samples/nsecs -I.. -I/home/chris/development/rtems/kernel/rtems/c/src/../../testsuites/samples/../support/include -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o /home/chris/development/rtems/kernel/rtems/c/src/../../testsuites/samples/nsecs/init.c
- sparc-rtems5-gcc -B../../../../../erc32/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I. -I/home/chris/development/rtems/kernel/rtems/c/src/../../testsuites/samples/nsecs -I.. -I/home/chris/development/rtems/kernel/rtems/c/src/../../testsuites/samples/../support/include -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT empty.o -MD -MP -MF .deps/empty.Tpo -c -o empty.o /home/chris/development/rtems/kernel/rtems/c/src/../../testsuites/samples/nsecs/empty.c
- mv -f .deps/empty.Tpo .deps/empty.Po
- mv -f .deps/init.Tpo .deps/init.Po
- sparc-rtems5-gcc -B../../../../../erc32/lib/ -specs bsp_specs -qrtems -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wl,--gc-sections -mcpu=cypress -o nsecs.exe init.o empty.o
- sparc-rtems5-nm -g -n nsecs.exe > nsecs.num
- sparc-rtems5-size nsecs.exe
- text data bss dec hex filename
- 121392 1888 6624 129904 1fb70 nsecs.exe
- cp nsecs.exe nsecs.ralf
- make[6]: Leaving directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/ c/erc32/testsuites/samples/nsecs'
- make[5]: Leaving directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/ c/erc32/testsuites/samples'
- make[4]: Leaving directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/ c/erc32/testsuites/samples'
- make[4]: Entering directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/ c/erc32/testsuites'
- make[4]: Nothing to be done for 'all-am'.
- make[4]: Leaving directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/ c/erc32/testsuites'
- make[3]: Leaving directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/ c/erc32/testsuites'
- make[2]: Leaving directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/ c/erc32'
- make[1]: Leaving directory '/home/chris/development/rtems/kernel/erc32/sparc-rtems5/c'
- make[1]: Entering directory '/home/chris/development/rtems/kernel/erc32'
- make[1]: Nothing to be done for 'all-am'.
- make[1]: Leaving directory '/home/chris/development/rtems/kernel/erc32'
+ $ ./waf
+ Waf: Entering directory `$HOME/development/rtems/src/rtems/build'
+ Waf: Leaving directory `$HOME/development/rtems/src/rtems/build'
+ 'build' finished successfully (0.051s)
+ Waf: Entering directory `$HOME/development/rtems/src/rtems/build/sparc/erc32'
+ [ 1/1524] Compiling bsps/shared/dev/serial/mc68681_reg2.c
+ [ 2/1524] Compiling bsps/shared/dev/rtc/mc146818a_ioreg.c
+ [ 3/1524] Compiling bsps/shared/dev/flash/am29lv160.c
+ [1521/1524] Linking $HOME/development/rtems/src/rtems/build/sparc/erc32/libz.a
+ [1522/1524] Linking $HOME/development/rtems/src/rtems/build/sparc/erc32/librtemscxx.a
+ [1523/1524] Linking $HOME/development/rtems/src/rtems/build/sparc/erc32/testsuites/samples/paranoia.exe
+ [1524/1524] Linking $HOME/development/rtems/src/rtems/build/sparc/erc32/libmghttpd.a
+ Waf: Leaving directory `$HOME/development/rtems/src/rtems/build/sparc/erc32'
+ 'build_sparc/erc32' finished successfully (4.894s)
Installing A BSP
@@ -252,46 +114,20 @@ RTEMS with the following command:
- $ make install
- Making install in tools/build
- /bin/mkdir -p '/home/chris/development/rtems/5/bin'
- /usr/bin/install -c cklength eolstrip packhex unhex rtems-bin2c '/home/chris/development/rtems/5/bin'
- /usr/bin/install -c install-if-change '/home/chris/development/rtems/5/bin'
- make[2]: Nothing to be done for 'install-data-am'.
- Making install in tools/cpu
- Making install in generic
- make[3]: Entering directory '/home/chris/development/rtems/kernel/erc32/tools/cpu/generic'
- make[3]: Nothing to be done for 'install-exec-am'.
- make[3]: Nothing to be done for 'install-data-am'.
- make[3]: Leaving directory '/home/chris/development/rtems/kernel/erc32/tools/cpu/generic'
- make[3]: Entering directory '/home/chris/development/rtems/kernel/erc32/tools/cpu'
- make[3]: Leaving directory '/home/chris/development/rtems/kernel/erc32/tools/cpu'
- make[2]: Entering directory '/home/chris/development/rtems/kernel/erc32'
- make[2]: Nothing to be done for 'install-exec-am'.
- /bin/mkdir -p '/home/chris/development/rtems/5/make'
- /usr/bin/install -c -m 644 /home/chris/development/rtems/kernel/rtems/make/main.cfg /home/chris/development/rtems/kernel/rtems/make/leaf.cfg '/home/chris/development/rtems/5/make'
- /bin/mkdir -p '/home/chris/development/rtems/5/share/rtems5/make/Templates'
- /usr/bin/install -c -m 644 /home/chris/development/rtems/kernel/rtems/make/Templates/Makefile.dir /home/chris/development/rtems/kernel/rtems/make/Templates/Makefile.leaf /home/chris/development/rtems/kernel/rtems/make/Templates/Makefile.lib '/home/chris/development/rtems/5/share/rtems5/make/Templates'
- /bin/mkdir -p '/home/chris/development/rtems/5/make/custom'
- /usr/bin/install -c -m 644 /home/chris/development/rtems/kernel/rtems/make/custom/default.cfg '/home/chris/development/rtems/5/make/custom'
- make[2]: Leaving directory '/home/chris/development/rtems/kernel/erc32'
+ $ ./waf install
+ 'install' finished successfully (0.074s)
+ + install $HOME/development/rtems/6/sparc-rtems6/erc32/lib/include/libchip/am29lv160.h (from bsps/include/libchip/am29lv160.h)
+ + install $HOME/development/rtems/6/sparc-rtems6/erc32/lib/include/libchip/mc146818a.h (from bsps/include/libchip/mc146818a.h)
+ + install $HOME/development/rtems/6/sparc-rtems6/erc32/lib/include/libchip/mc68681.h (from bsps/include/libchip/mc68681.h)
+ + install $HOME/development/rtems/6/sparc-rtems6/erc32/lib/include/rtems/version.h (from cpukit/include/rtems/version.h)
+ + install $HOME/development/rtems/6/sparc-rtems6/erc32/lib/include/rtems/vmeintr.h (from cpukit/include/rtems/vmeintr.h)
+ + install $HOME/development/rtems/6/sparc-rtems6/erc32/lib/include/rtems/watchdogdrv.h (from cpukit/include/rtems/watchdogdrv.h)
+ 'install_sparc/erc32' finished successfully (0.637s)
Contributing Patches
@@ -313,7 +149,7 @@ has changed:
- $ cd ../rtems
$ git status
On branch master
Your branch is up-to-date with 'origin/master'.
diff --git a/user/tracing/examples.rst b/user/tracing/examples.rst
index d0bef0b..2b673d4 100644
--- a/user/tracing/examples.rst
+++ b/user/tracing/examples.rst
@@ -61,7 +61,7 @@ to your installation.
sparc-rtems5-gcc -Bsparc-rtems5/erc32/lib/ \
- -specs bsp_specs -qrtems -mcpu=cypress -O2 -g -ffunction-sections \
+ -qrtems -mcpu=cypress -O2 -g -ffunction-sections \
-fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration \
-Wstrict-prototypes -Wnested-externs -Wl,--gc-sections -mcpu=cypress \
-o sparc-rtems5/c/erc32/testsuites/samples/fileio.exe sparc-rtems5/c/erc32/\
@@ -75,7 +75,7 @@ the wrapper c file.
rtems-tld -C fileio-trace.ini -W fileio-wrapper -- -Bsparc-rtems5/erc32/lib/ \
2.35.3
