eng: Add Formal Verification chapter v2
Andrew.Butterfield at scss.tcd.ie Andrew.Butterfield at scss.tcd.ie
Tue Sep 13 09:44:21 UTC 2022
Dear RTEMS Developers,
  The inlined patch file below adds a new Formal Verification chapter as discussed in the previous email thread
regarding "Integrating the Formal Methods part of Qualification"
(see https://lists.rtems.org/pipermail/devel/2022-July/072167.html ).
This is just the documentation for what was done. None of the files or tools mentioned are contained
in the patch. Most of those would be deployed to rtems-central or the "main" rtems repo.
Best Regards,
  Andrew
From ca8d303e7b25b02d9c4aad3b7f76dbdc1cdfa396 Mon Sep 17 00:00:00 2001
From: Andrew Butterfield <andrew.butterfield at scss.tcd.ie>
Date: Mon, 23 May 2022 17:02:21 +0100
Subject: [PATCH] eng: Add Formal Verification chapter
 common/refs.bib        |   56 ++
 eng/fv/index.rst       |   32 +
 eng/fv/maintenance.rst |   70 ++
 eng/fv/methodology.rst |  228 +++++++
 eng/fv/model-guide.rst | 1482 ++++++++++++++++++++++++++++++++++++++++
 eng/fv/overview.rst    |   33 +
 eng/fv/promela.rst     |  320 +++++++++
 eng/fv/refinement.rst  |  359 ++++++++++
 eng/fv/tool-setup.rst  |   80 +++
 eng/index.rst          |    2 +
 10 files changed, 2662 insertions(+)
 create mode 100644 eng/fv/index.rst
 create mode 100644 eng/fv/maintenance.rst
 create mode 100644 eng/fv/methodology.rst
 create mode 100644 eng/fv/model-guide.rst
 create mode 100644 eng/fv/overview.rst
 create mode 100644 eng/fv/promela.rst
 create mode 100644 eng/fv/refinement.rst
 create mode 100644 eng/fv/tool-setup.rst
diff --git a/common/refs.bib b/common/refs.bib
index 066d746..6b25fae 100644
--- a/common/refs.bib
+++ b/common/refs.bib
@@ -9,6 +9,25 @@
   year        = {1973},
   pages       = {46-61},
+ at article{Djikstra:1975:GCL,
+author = {Dijkstra, Edsger W.},
+title = {Guarded Commands, Nondeterminacy and Formal Derivation of Programs},
+year = {1975},
+issue_date = {Aug. 1975},
+publisher = {Association for Computing Machinery},
+address = {New York, NY, USA},
+volume = {18},
+number = {8},
+issn = {0001-0782},
+url = {https://doi.org/10.1145/360933.360975},
+doi = {10.1145/360933.360975},
+abstract = {So-called “guarded commands” are introduced as a building block for alternative and repetitive constructs that allow nondeterministic program components for which at least the activity evoked, but possibly even the final state, is not necessarily uniquely determined by the initial state. For the formal derivation of programs expressed in terms of these constructs, a calculus will be be shown.},
+journal = {Commun. ACM},
+month = {aug},
+pages = {453–457},
+numpages = {5},
+keywords = {correctness proof, programming methodology, program semantics, case-construction, termination, nondeterminancy, programming languages, derivation of programs, sequencing primitives, repetition, programming language semantics}
 @inproceedings{Varghese:1987:TimerWheel,
   author      = {Varghese, G. and Lauck, T.},
   title       = {{Hashed and Hierarchical Timing Wheels: Data Structures for the Efficient Implementation of a Timer Facility}},
@@ -95,6 +114,16 @@
   url           = {http://www.rfc-editor.org/rfc/rfc2119.txt},
   note          = {\url{http://www.rfc-editor.org/rfc/rfc2119.txt}},
+ at ARTICLE{Holzmann:1997:SPIN,
+  author={Holzmann, G.J.},
+  journal={IEEE Transactions on Software Engineering},
+  title={The model checker SPIN},
+  year={1997},
+  volume={23},
+  number={5},
+  pages={279-295},
+  doi={10.1109/32.588521}
 @article{Blumofe:1999:WS,
   author      = {Blumofe, Robert D. and Leiserson, Charles E.},
   title       = {{Scheduling multithreaded computations by work stealing}},
@@ -373,6 +402,33 @@
   title     = {{RTEMS CPU Architecture Supplement}},
   url       = {https://docs.rtems.org/branches/master/cpu-supplement.pdf},
+ at mastersthesis{Jennings:2021:FV,
+  author =       {Robert Jennings},
+  title =        {{Formal Verification of a Real-Time Multithreaded Operating System}},
+  school =       {School of Computer Science and Statistics},
+  year =         {2021},
+  type =         {Master of Science in {Computer Science (MCS)}},
+  address =      {Trinity College, Dublin 2, Ireland},
+  month =        {August},
+ at mastersthesis{Jaskuc:2022:TESTGEN,
+  author =       {Jerzy Ja{\'{s}}ku{\'{c}}},
+  title =        {{SPIN/Promela-Based Test Generation Framework for RTEMS Barrier Manager}},
+  year =         {2022},
+  month =        {April},
+ at mastersthesis{Lynch:2022:TESTGEN,
+  author =       {Eoin Lynch},
+  title =        {{Using Promela/SPIN to do Test Generation for RTEMS-SMP}},
+  school =       {School of Engineering},
+  year =         {2022},
+  type =         {Master of {Engineering (Computer Engineering)}},
+  month =        {April},
 % ECSS
 % Sort lexicographically
 @manual{ECSS_E_ST_10_02C_R1,
diff --git a/eng/fv/index.rst b/eng/fv/index.rst
new file mode 100644
index 0000000..71000ff
--- /dev/null
+++ b/eng/fv/index.rst
@@ -0,0 +1,32 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2022 Trinity College Dublin
+.. _FormalVerif:
+Formal Verification
+|  **IMPORTANT NOTE**                                                          |
+This is **draft** documentation that explains how to use the formal verification
+tools for RTEMS, developed as part of the pre-qualification effort.
+This is a *proposal* about how everything should work, looking for initial
+feedback from RTEMS developers.
+The actual tools and models referred to below have **not yet** been installed.
+In particular, the folder ``formal`` does not yet exist in ``rtems-central``.
+.. toctree::
+    overview
+    tool-setup
+    promela
+    refinement
+    methodology
+    maintenance
+    model-guide
diff --git a/eng/fv/maintenance.rst b/eng/fv/maintenance.rst
index 0000000..34efcf6
--- /dev/null
+++ b/eng/fv/maintenance.rst
@@ -0,0 +1,70 @@
+.. _FormalMaint:
+Test Generation Maintenance
+The standard RTEMS technique of emailing a patch-set for review shall be used.
+the basic principle is that any file modified as a result of changes, *including
+generated C test code* will be included in the patch-sets. A complication is
+that most model changes will apply to ``rtems-central``, while the resulting
+test code changes will take place in the ``rtems`` sub-module. Changes to the
+overall configuration (new testsuites mainly) may affect both respositories.
+Key pathnames, as viewed from ``rtems-central``:
+Formal Models
+    ``formal/promela/models/``
+    Every distinct model has a name (``mymodel`` say), and the relevant model
+    files shall live in ``formal/promela/models/mymodel``
+Configuration
+    ``spec/testsuites/model-0.yml`` whose main role is provide meta-data about
+    the testsuite. The key parts of these are as follows:
+    .. code-block:: yaml
+      enabled-by: RTEMS_SMP
+      test-suite-name: Model0
+      test-target: testsuites/validation/ts-model-0.c
+    ``modules/rtems/spec/build/testsuites/validation/model-0.yml`` contains a
+    listing of all the C test code that is deployed to this testsuite.
+Generated Test Code
+    ``modules/rtems/testsuites/validation/`` will contain ``ts-model-0.c`` plus
+    any other supporting source files.
+Changing an existing model
+Having made the required changes to model and generation files (``.pml``,
+``-rfn.yml``, ``.c``, ``.h``), run the test generation process and deploy the
+generated test code to ``testsuites/validation/``.
+Adding a new model into an existing testsuite
+Assume the new model is called ``newmodel``. The new model and generation files
+(``.pml``, ``-rfn.yml``, ``.c``, ``.h``) are added into
+``formal/promela/models/newmodel``. The test generation process is then run,
+and then the generated C can be deployed. Before building the tests, however,
+it is necessary to update the overall configuration. The names of all the files
+to be deployed need to be added to
+``modules/rtems/spec/build/testsuites/validation/model-0.yml``. Once this is
+done the tests can be built and run.
+Adding a new testsuite
+At present there is only one testsuite for formal methods tests, ``model-0``.
+There is no immediate plan to add another, but if this was required, then it
+would require adding two ``another-model.yml`` files, one in
+``spec/testsuites/``, the other in
+``modules/rtems/spec/build/testsuites/validation/``, following the same pattern
+as the two ``model-0.yml`` files.
diff --git a/eng/fv/methodology.rst b/eng/fv/methodology.rst
index 0000000..f6d781f
--- /dev/null
+++ b/eng/fv/methodology.rst
@@ -0,0 +1,228 @@
+Promela/SPIN Methodology
+Test Generation Methodology
+The general approach to using any model-checking technology for test generation
+has three major steps:
+**1.**
+  Construct a model that describes the desired properties (`P1`, ..., `PN`)
+  and use the model-checker to verify those properties.
+  In Promela we can specify properties using the ``assert()`` statement, to be
+  true at the point where it gets executed, and can use Linear Temporal Logic
+  (LTL) to specify more complex properties over execution sequences. SPIN will
+  also check generic correctness properties such as deadlock- and
+  livelock-freedom.
+.. blank
+**2.**
+  Given a fully verified model from Step 1, then systematically negate each
+  specified property (e.g. `not P1`). Given that we verified `P1` as true, then
+  this revised model will fail model-checking, and a counter-example will be
+  generated. This counter-example will in fact be a scenario describing correct
+  behaviour of the system, demonstrating that `P1` is true.
+  With Promela, there are a number of different ways we can do systematic
+  negation. The precise approach adopted depends the nature of the models, and
+  will be elaborated below. SPIN outputs counter-examples as "trail" files,
+  which it can then be  re-simulated producing readable output. This is hard to
+  parse, so we use ``printf()`` statements to produce our own output format
+  that is readable and easily parsed.
+  We explored two ways to do the negations. One is a "manual" approach in
+  which we manually edit the model to negate the properties. The second is an
+  "automatic" approach that parses the model, identifies all the property
+  statements, and for each of these, generates a new Promela source file with
+  that statement negated.
+.. blank
+**3.**
+  Define a mapping from counter-example output to test code, and automate the
+  process of constructing a test program.
+  We use a YAML file to define a mapping from our ``printf()`` output to
+  relevant fragments of RTEMS C test code, using the Test Framework described
+  in Section :numref:`RTEMSTestFramework`. We automate this with the
+  ``spin2test`` and ``testbuilder`` python scripts we developed.
+The automatic approach requires a Promela parser written in Python. For now, we
+only describe  tests delivered using the manual approach.
+Using the Tools
+The ``spin2test`` tool is run from a directory containing a Promela model
+along with supporting files,
+all linked together by a common model name
+For a model called `mymodel` we expect to see the following files:
+* ``mymodel.pml`` - the Promela model
+* ``mymodel-rfn.yml`` - the model refinement to C test code
+* ``tc-mymodel.c`` - the testcase setup C file
+* ``tr-mymodel.h`` - the test-runner header file
+* ``tr-mymodel.c`` - the test-runner setup C file
+The following files are templates used to assemble
+a single test-runner test file
+for each scenario generated by the Promela model:
+* ``mymodel-pre.h`` - preamble material at the start
+* ``mymodel-run.h`` - test runner material
+* ``mymodel-post.h`` - postamble material at the end.
+Steps to use ``spin2test`` to generate tests
+To generate all the test scenarios, invoke SPIN as follows:
+.. code-block:: shell
+  spin -run -E -c0 -e mymodel.pml
+This will generate N trail files, numbered 1..N:
+.. code-block:: none
+  ``mymodel.pml1.trail``
+  ``mymodel.pmlN.trail``
+Annotation Generation
+Use SPIN to produce scenario listings for I in {1,..,N} as follows, that we
+store in files with a ``.spn`` extension:
+  spin -T -t1 mymodel.pml > mymodel-0.spn
+  spin -T -t2 mymodel.pml > mymodel-1.spn
+  spin -T -tN mymodel.pml > mymodel-{N-1}.spn
+SPIN numbers files from 1 up, whereas RTEMS prefer to number things,
+including filenames, from zero.
+Test Code Generation
+Run ``spin2test`` on each ``.spn`` file as follows:
+  spin2test mymodel 0
+  spin2test mymodel 1
+  spin2test mymodel {N-1}
+These will generate test-runner test files as follows:
+  tr-mymodel-0.c
+  tr-mymodel-1.c
+  tr-mymodel-{N-1}.c
+Test Code Deployment
+All files starting with ``tc-`` or ``tr-`` need to be copied to the
+relevant testsuite directory.
+At present, this is ``testsuites/validation`` at the top level in
+the ``rtems`` repository.
+All the names of the above files with a ``.c`` extension need to be added
+into the testsuite specification directory,
+into a YAML file that
+defines the Promela generated-test sources.
+At present, this
+is ``spec/build/testsuites/validation/model-0.yml``
+at the top-level in the ``rtems`` repository.
+They should appear under the ``source`` key something like this:
+.. code-block:: yaml
+  source:
+  - testsuites/validation/ts-model-0.c
+  - testsuites/validation/tr-model-0.c
+  - testsuites/validation/tr-model-1.c
+  - testsuites/validation/tr-mymodel-{N-1}.c
+Building the Test Executable
+Just navigate to ``rtems`` and give the command ``./waf``
+The test executable will be stored in a build directory.
+At present this is
+``build/sparc/gr712rc/testsuites/validation/ts-model-0.exe``,
+assuming that ``sparc/gr712rc`` appears in ``config.ini``.
+Running the Test Executable
+Use the SIS simulator:
+  sparc-rtems6-sis -leon3 -r s -m 2 <path-to>/ts-model-0.exe
+TestBuilder
+The ``testbuilder`` tool automates most of the steps described above.
+It is also run from a directory configured as for ``spin2test`` above.
+It requires a file ``testbuilder.yml`` that supplies key pathnames
+so it knows where to find relevant tools and where to put the
+generated tests.
+The file ``formal/promela/src/testbuilder-template.yml``
+is a template that should be edited to match where RTEMS and RSB
+are installed,
+and saved as ``formal/promela/src/testbuilder.yml``
+If we have setup ``tbuild`` as an alias to run `testbuilder.py`,
+then the following sequence of commands will generate, deploy, and run tests
+as described above for `spin2test`:
+  tbuild generate mymodel
+  tbuild copy mymodel
+  tbuild compile
+  tbuild run
+Other commands include ``tbuild help`` and ``tbuild clean``.
+A planned future upgrade is to add a single command ``tbuild all``
+that does a ``clean`` followed by the four steps above.
diff --git a/eng/fv/model-guide.rst b/eng/fv/model-guide.rst
index 0000000..0598bd2
--- /dev/null
+++ b/eng/fv/model-guide.rst
@@ -0,0 +1,1482 @@
+RTEMS Formal Model Guide
+Here we describe the various formal models of RTEMS that are currently in
+existence. The following were delivered as part of the ESA-sponsored activity,
+and will be included as the initial set when the directory ``formal`` is added
+to ``rtems-central``:
+Chains API (ESA-sponsored Activity)
+    Models the unprotected chain "append" and "get" API calls in the Classic
+    Chains API Guide. This was an early model to develop the basic methodology.
+Events Manager (ESA-sponsored Activity, M.Sc. Dissertation :cite:`Jennings:2021:FV` )
+    Models the behaviour of all the API calls in the Classic Events Manager API
+    Guide. This had to tackle real concurrency and deal with multiple CPUs and priority
+    issues.
+Thread-Queues (ESA-sponsored Activity)
+    Models related to the SMP versions of the scheduler thread queues. These are
+    a work in progress and no test generation is currently available.
+A number of other Classic RTEMS Managers have been modelled and have had tests
+generated, as M.Sc. Dissertation topics. This need some final validation and
+will be added later. They will be used to assess the proposed mechanism for
+upgrade and maintenance (:numref:`FormalMaint`):
+Barrier Manager (M.Sc. Dissertation :cite:`Jaskuc:2022:TESTGEN` )
+    Models the Classic Barrier Manager API.
+Message Manager (M.Sc. Dissertation :cite:`Lynch:2022:TESTGEN` )
+    Models the Classic Message Manager API.
+.. _TestGenOverview:
+Test Generation Overview
+Given an RTEMS feature we want to test, we first define a rootname
+``feature-model`` that identifies the feature, and indicates that we are basing
+our tests on a model.
+We develop a Promela model of the feature as file ``feature-model.pml``. We
+ensure this model captures the correct behaviour and verify it correctness.
+We also add annotation ``printf()`` statements and a way to negate the
+relevant properties.
+We then use SPIN to generate the test scenarios and replay them so we have the
+annotation output available. This results in a number of text files named
+``feature-model-N.spn`` , where ``N`` ranges from 0 upwards.
+For each value of ``N`` we use a refinement mapping defined in
+``feature-model-rfn.yml`` to generate segments of C test code, one for each
+Promela process. We then generate the corresponding test code in file
+``tr-feature-model-N.c`` by concatenating the following pieces:
+1. ``feature-model-pre.h``  (The "Preamble")
+2. The segments of C test code produced by the refinement mapping
+3. ``feature-model-post.h``  (The "Postamble")
+4. The contents of ``feature-model-run.h`` (The "Runner") where the value of
+   ``N`` has been substituted in at key locations.
+The Runner defines a test case for this scenario. It is a file that contains
+substitution markers for use with Pythons ``format()`` substitution,
+and whose contents will generally look like this:
+.. code-block:: c
+   void RtemsFeatureModel_Run{0}()
+     Context ctx;
+     memset( &ctx, 0, sizeof( ctx ) );
+     T_set_verbosity( T_NORMAL );
+     TestSegment0( &ctx );
+   T_TEST_CASE( RtemsFeatureModel{0} )
+     RtemsFeatureModel_Run{0}( );
+All the ``{0}`` above will be replaced by ``N``, and the double braces by
+single ones, so for ``N`` equal to 42 (say), we get:
+.. code-block:: c
+   void RtemsFeatureModel_Run42()
+     Context ctx;
+   T_TEST_CASE( RtemsFeatureModel42 )
+     RtemsFeatureModel_Run42( );
+All the generated ``tr-feature-model-N.c`` sources are copied to the location
+for the testsuite sources.  Also so copied are the following files:
+``tr-feature-model.h``, ``tr-feature-model.c``, and ``tc-feature-model.c``
+(if present). The latter file is not required for simple test setups like the
+Chains API, but is needed for more complex cases like the Event Manager.
+Testing Chains
+The Chains API provides a doubly-linked list data-structure, optimised for fast
+operations in an SMP setting. We used it a proof of concept exercise.
+See https://docs.rtems.org/branches/master/c-user/chains.html
+Model Directory: ``formal/promela/models/chains``
+Model
+File: ``chains-api-model.pml``
+We focussed on just two API calls: ``rtems-chain-append-unprotected``
+and ``rtems-chain-get-unprotected`` (hereinafter just ``append`` and ``get``).
+The model produced is one in which we have 6 processes, 3 of which perform a
+single ``append``, and 3 of which do a single ``get`` when the chain is not
+empty. All processes terminate after they have performed their action.
+We initialize an empty chain and then run all six processes concurrently,
+and at the end, we assert that the chain is empty. We use the special
+``_nr_pr`` variable to ensure we wait for all six processes to terminate
+before checking the final condition.
+SPIN uses the C pre-processor, and the model-checker code can accept
+Environment Variables, so we use ``TEST_GEN`` as a way to distinguish normal
+model-checker operation from the test generation mode. For test generation,
+SPIN is invoked at the command-line with ``-DTEST_GEN``.
+.. code:: c
+  init {
+    pid nr;
+    atomic{ chain.head = 0; chain.tail = 0; chain.size = 0 } ;
+    nr = _nr_pr;
+    run doAppend(6,21);
+    run doAppend(3,22);
+    run doAppend(4,23);
+    run doNonNullGet();
+    nr == _nr_pr;
+  #ifdef TEST_GEN
+    assert (chain.size != 0);
+  #else
+    assert (chain.size == 0);
+  #endif
+As Promela does not have pointers, we re-coded the append algorithm using arrays
+with pointers being array indices. We treat array index 0 as the equivalent of a
+NULL pointer, so the first array element is never used.
+.. code:: c
+  typedef Node { unsigned nxt : PTR_SIZE; unsigned prv : PTR_SIZE; byte itm}
+  Node memory[MEM_SIZE] ;
+  typedef Control {
+    unsigned head : PTR_SIZE; unsigned tail : PTR_SIZE; unsigned size : PTR_SIZE
+  Control chain ;
+The chains implementation is a doubly-linked list of "nodes" that
+are accessed from a special "control" structure, using some subtle union
+overlays to ensure that node access can be done uniformly
+(no NULL pointer in any node).
+We abstract considerably from these details for now.
+In particular,
+we added an explicit ``size`` component
+to the Promela *model* we are developing,
+to allow us to easily write properties about chain length,
+and to prevent array out-of-bound errors in the model itself.
+Here is our model array version of the ``append`` code. We check that the
+node-pointer ``np`` is not null, and that we have space for the entry being
+added.
+.. code:: c
+  inline append(ch,np) {
+    assert(np!=0); assert(ch.size < (MEM_SIZE-1));
+    if
+    :: (ch.head == 0) -> ch.head = np; ch.tail = np; ch.size = 1;
+                         memory[np].nxt = 0; memory[np].prv = 0;
+    :: (ch.head != 0) -> memory[ch.tail].nxt = np; memory[np].prv = ch.tail;
+                         ch.tail = np; ch.size = ch.size + 1;
+    fi
+We then create a Promela process `doAppend` that puts the new chain value into
+the addressed node and then calls ``append``, and terminates. We make it all
+atomic because we don't want the chain operations to interleave internally. Such
+extra interleaving is unnecessary and would only make the model larger and
+produce more redundant tests.
+.. code:: c
+  proctype doAppend(int addr; int val) {
+    atomic{ memory[addr].itm = val; append(chain,addr); } ;
+We implement the ``get`` operation similarly. The ``doNonNullGet`` process
+waits for the chain to be non-empty before attempting to extract an element.
+Annotations
+However, this "pure" model of ``append`` and ``get`` is not, of itself, useful
+for test generation. We need to add in ``printf()`` statements to generate
+annotations. We do this for ``append`` by adding in two statements to the
+``doAppend`` process
+.. code:: c
+             printf("@@@ 0 CALL append %d %d\n",val,addr); show_chain(); } ;
+The ``printf`` statement output indicates a call (``CALL``) to the
+``append`` API with the actual values supplied for parameters ``addr`` and
+``val``. The statement ``show_chain()`` is an inline function that prints the
+contents of the chain after append returns.
+The resulting output is multi-line,
+starting with ``@@@ 0 SEQ chain``,
+ending with ``@@@ 0 END chain``,
+and with entries in between of the form ``@@@ 0 SCALAR _ val``
+displaying chain elements, line by line.
+We need more than just API calls annotated in this way.
+We also have to provide annotations for various declarations.
+These have to appear in the Promela main program (called ``init``)
+as they have to be printed out as the model starts to run.
+The atomic initialiser becomes somewhat larger:
+.. code:: c
+      atomic{
+        printf("\n\n Chain Model running.\n");
+        printf("@@@ 0 NAME Chain_AutoGen\n")
+        printf("@@@ 0 DEF MAX_SIZE 8\n");
+        printf("@@@ 0 DCLARRAY Node memory MAX_SIZE\n");
+        printf("@@@ 0 DECL unsigned nptr NULL\n")
+        printf("@@@ 0 DECL Control chain\n");
+        printf("\nInitialising...\n")
+        printf("@@@INIT\n");
+        chain.head = 0; chain.tail = 0; chain.size = 0;
+        show_chain();
+The problem is that a ``#define``, or a type or variable declaration,
+is a compile-time feature of the Promela language,
+so it won't output useful information at runtime.
+Here we are adding ``printf`` statements to the ``init`` block
+in Promela model to output this information.
+Note that we show the initialised (empty) chain at the end.
+We can now run the Promela model using SPIN in verification mode,
+to generate a "counter-example".
+This is done in two steps:
+the first writes the counter-example to a "trail file";
+while the second replays this trail file to run the counter-example.
+We can get SPIN to find all possible counterexamples at once with this model.
+This generates 21 scenarios.
+Part of one possible result of running SPIN to get counter-example output
+is shown below, from ``chains-api-model-8.spn`` . When we filter it to keep just
+the lines starting with ``@@@`` we get:
+.. code:: none
+    @@@ 0 NAME Chain_AutoGen
+    @@@ 0 DEF MAX_SIZE 8
+    @@@ 0 DCLARRAY Node memory MAX_SIZE
+    @@@ 0 DECL unsigned nptr NULL
+    @@@ 0 DECL Control chain
+    @@@ 0 INIT
+    @@@ 0 SEQ chain
+    @@@ 0 END chain
+    @@@ 0 PTR nptr 0
+    @@@ 0 CALL append 22 3
+    @@@ 0 SEQ chain
+    @@@ 0 SCALAR _ 22
+    @@@ 0 END chain
+Refinement
+Files:
+ | ``chains-api-model-N.spn`` where ``N`` ranges from 0 to 20.
+ | ``chains-api-model-rfn.yml``
+The ``spin2test`` script takes these annotations, along with the YAML
+refinement file defined for the model, and proceeds to generate testcode. All
+of these annotations have the same ``<pid>``, namely 0, so one test segment of
+code is produced. We show some examples of how this works below.
+Given ``@@@ 0 NAME Chain_AutoGen`` we lookup `NAME` in the refinement file,
+and get the following (which ignores the ``<name>`` parameter in this case):
+.. code-block:: c
+     const char rtems_test_name[] = "Model_Chain_API";
+For ``@@@ 0 DEF MAX_SIZE 8`` we directly output
+.. code-block:: c
+   #define MAX_SIZE 8
+For ``@@@ 0 DCLARRAY Node memory MAX_SIZE`` we lookup ``memory_DCL`` and get
+``item {0}[{1}];``. We substitute ``memory`` and ``MAX_SIZE`` to get
+.. code-block:: c
+   item memory[MAX_SIZE];
+For ``INIT`` we lookup ``INIT`` to get
+.. code-block:: c
+   rtems_chain_initialize_empty( &chain );
+The first ``SEQ`` ... ``END`` pair is intended to display the initial chain,
+which should be empty. The second shows the result of an ``append`` with one
+value in the chain. In both cases, the name ``chain`` is recorded, and for
+each ``SCALAR _ val``, the value of ``val`` is printed to a string with a
+leading space. When ``@@@ 0 END chain`` is encountered we lookup ``chain_SEQ``
+to obtain:
+.. code-block:: c
+     show_chain( &chain, ctx->buffer );
+     T_eq_str( ctx->buffer, "{0} 0" );
+Function ``show_chain`` is defined in the preamble C file used in test
+generation and is designed to display the chain contents in a string that
+matches the one generated here by the processing of ``SEQ`` ... ``SCALAR`` ...
+``END``. We substitute the accumulated string in for ``{0}``, which will be
+either empty, or just " 23." In the latter case we get the following code:
+.. code-block:: c
+     T_eq_str( ctx->buffer, "23 0" );
+For ``@@@ 0 CALL append 22 3`` we lookup ``append`` to get
+.. code-block:: c
+     memory[{1}].val = {0};
+     rtems_chain_append_unprotected( &chain, (rtems_chain_node*)&memory[{1}] );
+We substitute ``22`` and ``3`` in to get
+.. code-block:: c
+     memory[3].val = 22;
+     rtems_chain_append_unprotected( &chain, (rtems_chain_node*)&memory[3] );
+The following is the corresponding excerpt from the generated test-segment:
+.. code-block:: c
+  // @@@ 0 NAME Chain_AutoGen
+  // @@@ 0 DEF MAX_SIZE 8
+  // @@@ 0 DCLARRAY Node memory MAX_SIZE
+  static item memory[MAX_SIZE];
+  // @@@ 0 DECL unsigned nptr NULL
+  static item * nptr = NULL;
+  // @@@ 0 DECL Control chain
+  static rtems_chain_control chain;
+  //  ===== TEST CODE SEGMENT 0 =====
+  static void TestSegment0( Context* ctx ) {
+    T_log(T_NORMAL,"@@@ 0 INIT");
+    T_log(T_NORMAL,"@@@ 0 SEQ chain");
+    T_log(T_NORMAL,"@@@ 0 END chain");
+    T_eq_str( ctx->buffer, " 0" );
+    T_log(T_NORMAL,"@@@ 0 PTR nptr 0");
+    T_eq_ptr( nptr, NULL );
+    T_log(T_NORMAL,"@@@ 0 CALL append 22 3");
+    T_log(T_NORMAL,"@@@ 0 SCALAR _ 22");
+    T_eq_str( ctx->buffer, " 22 0" );
+Note the extensive use of ``T_log()``, and emitted comments showing the
+annotations when producing declarations. These help when debugging models,
+refinement files, and the resulting test code. There are plans to provide a
+mechanism that can be used to control the level of verbosity involved.
+Assembly
+Files:
+ | ``chains-api-model-pre.h`` (Preamble)
+ | ``chains-api-model-post.h`` (Postamble)
+ | ``chains-api-model-run.h`` (Runner)
+The ``spin2test`` script then generates the required C test code from the
+test segment generated using the refinement file, and the above-mentioned files,
+as described in the :ref:`TestGenOverview` sub-section. For the Chain model,
+the Preamble #includes ``<rtems.h>``, ``<rtems/test.h>``, ``<rtems/chain.h>``,
+and ``"tr-chains-api-model.h"``. The Postamble is empty.
+Deployment
+Files:
+ | ``tr-chains-api-model.h``
+ | ``tr-chains-api-model.c``
+ | ``tr-chains-api-model-N.c`` where ``N`` ranges from zero upwards.
+All the above files are copied to ``testsuites/validation`` in the ``rtems``
+repository, where they should be built and run using ``waf`` as normal.
+Testing Events
+The Event Manager is a central piece of code in RTEMS SMP, being at the basis
+of task communication and synchronization. It is used for instance in the
+implementation of semaphores or various essential high-level data-structures,
+and used in the Scheduling process. At the same time, its implementation is
+making use of concurrent features of C11, and contains many unprotected
+interactions with the Threads API. Having a Promela model faithfully modelling
+the Event Manager code of RTEMS represent thus a real challenge, especially
+with respect to formal testing. This application constitutes as well a way to
+measure the completeness of our manual and automatic test generation tools
+previously developed.
+he RTEMS Event Manager was chosen as the second case-study because
+it involved concurrency and communication, had a small number of API calls
+(just two),
+but also had somewhat complex requirements related to task priorities.
+The Event Manager allows tasks to send "events" to,
+and receive "events" from, other tasks.
+From the perspective of the Event Manager,
+"events" are just uninterpreted numbers in the range 0..31,
+encoded as a 32-bit bitset.
+``rtems_event_send(id,event_in)``
+  allows a task to send a bitset to a designated task
+``rtems_event_receive(event_in,option_set,ticks,event_out)``
+  allows a task to specify a desired bitset
+  with options on what to do if it is not present.
+Most of the requirements are pretty straightforward,
+but two were a little more complex,
+and drove the more complex parts of the modelling.
+1. If a task was blocked waiting to receive events,
+   and a lower priority task then sent the events that would wake that
+   blocked task,
+   then the sending task would be immediately preempted by the receiver task.
+2. There was a requirement that explicitly discussed the situation
+   where the two tasks involved were running on different processors.
+Annotated Model
+File: ``event-mgr-model.pml``
+The Event Manager model consists of
+five Promela processes:
+``init``
+    The first top-level Promela process that performs initialisation,
+    starts the other processes, waits for them to terminate, and finishes.
+``System``
+    A Promela process that models the behaviour of the operating system,
+    in particular that of the scheduler.
+``Clock``
+    A Promela process used to facilitate modelling timeouts.
+``Sender``
+    A Promela process used to model the RTEMS sender task.
+``Receiver``
+    A Promela process used to model the RTEMS receiver task.
+Model State
+The RTEMS Event set contains 32 values, but in our model we limit ourselves to
+just four, which is enough for test purposes. We envisage two RTEMS tasks
+involved, at most. We use two simple binary semaphores to synchronise the tasks.
+We provide some inline definitions to encode (``events``), display
+(``printevents``), and subtract (``setminus``) events.
+Our Task model only looks at an abstracted version of RTEMS Task states:
+``Zombie``
+    used to model a task that has just terminated. It can only be deleted.
+``Ready``
+    same as the RTEMS notion of ``Ready``.
+``EventWait``
+    is ``Blocked`` inside a call of ``event_receive()`` with no timeout.
+``TimeWait``
+    is ``Blocked`` inside a call of ``event_receive()`` with a timeout.
+``OtherWait``
+    is ``Blocked`` for some other reason, which arises in this model when a
+    sender gets pre-empted by a higher priority receiver it has just satisfied.
+We simplify the ``rtems_option_set`` to just two relevant bits: the timeout
+setting (``Wait``, ``NoWait``), and how much of the desired event set will
+satisfy the receiver (``All``, ``Any``).
+We represent tasks using a datastructure array. As array indices are proxies
+here for C pointers, the zeroth array entry is always unused, as we use index
+value 0 to model a NULL C pointer.
+.. code-block:: c
+   typedef Task {
+     byte nodeid; // So we can spot remote calls
+     byte pmlid; // Promela process id
+     mtype state ; // {Ready,EventWait,TickWait,OtherWait}
+     bool preemptable ;
+     byte prio ; // lower number is higher priority
+     int ticks; //
+     bool tout; // true if woken by a timeout
+     unsigned wanted  : NO_OF_EVENTS ; // EvtSet, those expected by receiver
+     unsigned pending : NO_OF_EVENTS ; // EvtSet, those already received
+     bool all; // Do we want All?
+   Task tasks[TASK_MAX]; // tasks[0] models a NULL dereference
+There is no notion of returning values from Promela ``proctype`` or ``inline``
+constructs, so we need to have global variables to model return values. Also,
+C pointers used to designate where to return a result need to be modelled
+by indices into global array variables.
+.. code-block:: c
+   byte sendrc;            // Sender global variable
+   byte recrc;             // Receiver global variable
+   byte recout[TASK_MAX] ; // models receive 'out' location.
+Task "Scheduling"
+In order to produce a model that captures real RTEMS Task behaviour, we need
+to have mechanisms that mimic the behaviour of the scheduler and other
+activities that can modify the execution state of these Tasks. Given a scenario
+generated by such a model, we need to add synchronisation to the generated C
+code to ensure test has the same execution patterns.
+For scheduling we use:
+``waitUntilReady``
+    ``waitUntilReady(id)`` logs that ``task[id]`` is waiting, and then attempts
+    to execute a statement that blocks, until some other process changes
+    ``task[id]``\ 's state to ``Ready``. It relies on the fact that if a
+    statement blocks inside an atomic block, the block loses its atomic
+    behaviour and yields to other Promela processes It is used to model a task
+    that has been suspended for any reason.
+``preemptIfRequired``
+    ``preemptIfRequired(sendid,rcvid)`` is executed, when ``task[rcvid]`` has had its receive request satisfied
+    by a send from ``task[sendid]``. It is invoked by the send operation in this
+    model. It checks if ``task[sendid]`` should be preempted, and makes it so.
+    This is achieved here by setting the task state to ``OtherWait``.
+For synchronisation we use simple boolean semaphores, where True means
+available, and False means the semaphore has been acquired.
+.. code-block:: c
+   bool semaphore[SEMA_MAX]; // Semaphore
+The synchronisation mechanisms are:
+``Obtain(sem_id)``
+   call that waits to obtain semaphore ``sem_id``.
+``Release(sem_id)``
+    call that releases semaphore ``sem_id``
+``Released(sem_id)``
+    simulates ecosystem behaviour that releases ``sem_id``.
+The difference between ``Release`` and ``Released`` is that the first issues
+a ``SIGNAL`` annotation, while the second does not.
+Event Send
+We start with the notion of when a event receive call is statisfied. The
+requirements for both send and receive depend on such satisfaction.
+``satisfied(task,out,sat)``
+    ``satisfied(task,out,sat)`` checks if a receive has been satisfied. It
+    updates its ``sat`` argument to reflect the check outcome.
+An RTEMS call ``rc = rtems_event_send(tid,evts)`` is modelled by an inline of
+the form:
+.. code-block:: c
+   event_send(self,tid,evts,rc)
+The four arguments are:
+ | ``self`` : id of process modelling the task/IDR making call.
+ | ``tid``  : id of process modelling the target task of the call.
+ | ``evts`` : event set being sent.
+ | ``rc``   : updated with the return code when the send completes.
+The main complication in the otherwise straightforward model is the requirement
+to preempt under certain circumstances.
+.. code-block:: c
+   inline event_send(self,tid,evts,rc) {
+     atomic{
+       if
+       ::  tid >= BAD_ID -> rc = RC_InvId
+       ::  tid < BAD_ID ->
+           tasks[tid].pending = tasks[tid].pending | evts
+           // at this point, have we woken the target task?
+           unsigned got : NO_OF_EVENTS;
+           bool sat;
+           satisfied(tasks[tid],got,sat);
+           if
+           ::  sat ->
+               tasks[tid].state = Ready;
+               printf("@@@ %d STATE %d Ready\n",_pid,tid)
+               preemptIfRequired(self,tid) ;
+               // tasks[self].state may now be OtherWait !
+               waitUntilReady(self);
+           ::  else -> skip
+           fi
+           rc = RC_OK;
+       fi
+Event Receive
+An RTEMS call ``rc = rtems_event_receive(evts,opts,interval,out)`` is modelled
+by an inline of
+the form:
+.. code-block:: c
+   event_receive(self,evts,wait,wantall,interval,out,rc)
+The seven arguments are:
+ | ``self`` : id of process modelling the task making call
+ | ``evts`` : input event set
+ | ``wait`` : true if receive should wait
+ | ``what`` : all, or some?
+ | ``interval`` : wait interval (0 waits forever)
+ | ``out`` : pointer to location for satisfying events when the receive
+     completes.
+ | ``rc`` : updated with the return code when the receive completes.
+There is a small complication, in that we have distinct variables in our model
+for receiver options that are combined into a single RTEMS option set. The
+actual calling sequence in C test code will be:
+.. code-block:: c
+   opts = mergeopts(wait,wantall);
+   rc = rtems_event_receive(evts,opts,interval,out);
+Here ``mergeopts`` is a C function defined in the C Preamble.
+.. code-block:: c
+   inline event_receive(self,evts,wait,wantall,interval,out,rc){
+     atomic{
+       printf("@@@ %d LOG pending[%d] = ",_pid,self);
+       printevents(tasks[self].pending); nl();
+       tasks[self].wanted = evts;
+       tasks[self].all = wantall
+       if
+       ::  out == 0 ->
+           printf("@@@ %d LOG Receive NULL out.\n",_pid);
+           rc = RC_InvAddr ;
+       ::  evts == EVTS_PENDING ->
+           printf("@@@ %d LOG Receive Pending.\n",_pid);
+           recout[out] = tasks[self].pending;
+           rc = RC_OK
+       ::  else ->
+           bool sat;
+           retry:  satisfied(tasks[self],recout[out],sat);
+           if
+           ::  sat ->
+               printf("@@@ %d LOG Receive Satisfied!\n",_pid);
+               setminus(tasks[self].pending,tasks[self].pending,recout[out]);
+               printf("@@@ %d LOG pending'[%d] = ",_pid,self);
+               rc = RC_OK;
+           ::  !sat && !wait ->
+               printf("@@@ %d LOG Receive Not Satisfied (no wait)\n",_pid);
+               rc = RC_Unsat;
+           ::  !sat && wait && interval > 0 ->
+               printf("@@@ %d LOG Receive Not Satisfied (timeout %d)\n",_pid,interval);
+               tasks[self].ticks = interval;
+               tasks[self].tout = false;
+               tasks[self].state = TimeWait;
+               printf("@@@ %d STATE %d TimeWait %d\n",_pid,self,interval)
+               if
+               ::  tasks[self].tout  ->  rc = RC_Timeout
+               ::  else              ->  goto retry
+               fi
+           ::  else -> // !sat && wait && interval <= 0
+               printf("@@@ %d LOG Receive Not Satisfied (wait).\n",_pid);
+               tasks[self].state = EventWait;
+               printf("@@@ %d STATE %d EventWait\n",_pid,self)
+               if
+               :: sendTwice && !sentFirst -> Released(sendSema);
+               :: else
+               fi
+               goto retry
+           fi
+       fi
+Scenarios
+We define a number of different scenario schemes that cover various aspects of
+Event Manager behaviour. Some schemes involve only one task, and are usually
+used to test error-handling or abnormal situations. Other schemes involve two
+tasks, with some mixture of event sending and receiving, with varying task
+priorities.
+For example, an event send operation can involve a target identifier that
+is invalid (``BAD_ID``), correctly identifies a receiver task (``RCV_ID``), or
+is sending events to itself (``SEND_ID``).
+.. code-block:: c
+   typedef SendInputs {
+     byte target_id ;
+     unsigned send_evts : NO_OF_EVENTS ;
+   SendInputs  send_in[MAX_STEPS];
+An event receive operation will be determined by values for desired events,
+and the relevant to bits of the option-set parameter.
+.. code-block:: c
+   typedef ReceiveInputs {
+     unsigned receive_evts : NO_OF_EVENTS ;
+     bool will_wait;
+     bool everything;
+     byte wait_length;
+   ReceiveInputs receive_in[MAX_STEPS];
+We have a range of global variables that define scenarios for both send and
+receive. We then have a two-step process for choosing a scenario.
+The first step is to select a scenario scheme. The poissible schemes are
+defined by the following ``mtype``:
+.. code-block:: c
+   mtype = {Send,Receive,SndRcv,RcvSnd,SndRcvSnd,SndPre,MultiCore};
+   mtype scenario;
+One of these is chosen by using a conditional where all alternatives are
+executable, so behaving as a non-deterministic choice of one of them.
+.. code-block:: c
+   if
+   ::  scenario = Send;
+   ::  scenario = Receive;
+   ::  scenario = SndRcv;
+   ::  scenario = SndPre;
+   ::  scenario = SndRcvSnd;
+   ::  scenario = MultiCore;
+   fi
+Once the value of ``scenario`` is chosen, it is used in another conditional
+to select a non-deterministic choice of the finer details of that scenario.
+.. code-block:: c
+    if
+    ::  scenario == Send ->
+          doReceive = false;
+          sendTarget = BAD_ID;
+    ::  scenario == Receive ->
+          doSend = false
+          if
+          :: rcvWait = false
+          :: rcvWait = true; rcvInterval = 4
+          :: rcvOut = 0;
+          fi
+          printf( "@@@ %d LOG sub-senario wait:%d interval:%d, out:%d\n",
+                  _pid, rcvWait, rcvInterval, rcvOut )
+    ::  scenario == SndRcv ->
+          if
+          ::  sendEvents = 14; // {1,1,1,0}
+          ::  sendEvents = 11; // {1,0,1,1}
+          fi
+          printf( "@@@ %d LOG sub-senario send-receive events:%d\n",
+                  _pid, sendEvents )
+    ::  scenario == SndPre ->
+          sendPrio = 3;
+          sendPreempt = true;
+          startSema = rcvSema;
+          printf( "@@@ %d LOG sub-senario send-preemptable events:%d\n",
+    ::  scenario == SndRcvSnd ->
+          sendEvents1 = 2; // {0,0,1,0}
+          sendEvents2 = 8; // {1,0,0,0}
+          sendEvents = sendEvents1;
+          sendTwice = true;
+          printf( "@@@ %d LOG sub-senario send-receive-send events:%d\n",
+    ::  scenario == MultiCore ->
+          multicore = true;
+          sendCore = 1;
+          printf( "@@@ %d LOG sub-senario multicore send-receive events:%d\n",
+    ::  else // go with defaults
+    fi
+We define default values for all the global scenario variables so that the
+above code focusses on what differs. The default scenario is a receiver waiting
+for a sender of the same priority which sends exactly what was requested.
+Sender Process
+The sender process then uses the scenario configuration to determine its
+behaviour. A key feature is the way it acquires its semaphore before doing a
+send, and releases the receiver semaphore when it has just finished sending.
+Both these semaphores are initialised in the unavailable state.
+.. code-block:: c
+   proctype Sender (byte nid, taskid) {
+     tasks[taskid].nodeid = nid;
+     tasks[taskid].pmlid = _pid;
+     tasks[taskid].prio = sendPrio;
+     tasks[taskid].preemptable = sendPreempt;
+     tasks[taskid].state = Ready;
+     printf("@@@ %d TASK Worker\n",_pid);
+     if
+     :: multicore ->
+          // printf("@@@ %d CALL OtherScheduler %d\n", _pid, sendCore);
+          printf("@@@ %d CALL SetProcessor %d\n", _pid, sendCore);
+     :: else
+     fi
+     if
+     :: sendPrio > rcvPrio -> printf("@@@ %d CALL LowerPriority\n", _pid);
+     :: sendPrio == rcvPrio -> printf("@@@ %d CALL EqualPriority\n", _pid);
+     :: sendPrio < rcvPrio -> printf("@@@ %d CALL HigherPriority\n", _pid);
+     :: else
+     fi
+   repeat:
+     Obtain(sendSema);
+     if
+     :: doSend ->
+       if
+       :: !sentFirst -> printf("@@@ %d CALL StartLog\n",_pid);
+       :: else
+       fi
+       printf("@@@ %d CALL event_send %d %d %d sendrc\n",_pid,taskid,sendTarget,sendEvents);
+       if
+       :: sendPreempt && !sentFirst -> printf("@@@ %d CALL CheckPreemption\n",_pid);
+       :: !sendPreempt && !sentFirst -> printf("@@@ %d CALL CheckNoPreemption\n",_pid);
+       :: else
+       fi
+       event_send(taskid,sendTarget,sendEvents,sendrc);
+       printf("@@@ %d SCALAR sendrc %d\n",_pid,sendrc);
+     :: else
+     fi
+     Release(rcvSema);
+     if
+        sentFirst = true;
+        sendEvents = sendEvents2;
+        goto repeat;
+     :: else
+     fi
+     printf("@@@ %d LOG Sender %d finished\n",_pid,taskid);
+     tasks[taskid].state = Zombie;
+     printf("@@@ %d STATE %d Zombie\n",_pid,taskid)
+Receiver Process
+The receiver process  uses the scenario configuration to determine its
+behaviour. It has the responsibility to trigger the start semaphore to allow
+either itself or the sender to start. The start semaphore corresponds to either
+the send or receive semaphore, depending on the scenario. The receiver acquires
+the receive semaphore before proceeding, and releases the send sempahore when
+done.
+.. code-block:: c
+   proctype Receiver (byte nid, taskid) {
+     tasks[taskid].prio = rcvPrio;
+     tasks[taskid].preemptable = false;
+     printf("@@@ %d TASK Runner\n",_pid,taskid);
+     if
+     :: multicore ->
+          printf("@@@ %d CALL SetProcessor %d\n", _pid, rcvCore);
+     :: else
+     fi
+     Release(startSema); // make sure stuff starts */
+     /* printf("@@@ %d LOG Receiver Task %d running on Node %d\n",_pid,taskid,nid); */
+     Obtain(rcvSema);
+     // If the receiver is higher priority then it will be running
+     // The sender is either blocked waiting for its semaphore
+     // or because it is lower priority.
+     // A high priority receiver needs to release the sender now, before it
+     // gets blocked on its own event receive.
+     if
+     :: rcvPrio < sendPrio -> Release(sendSema);  // Release send semaphore for preemption
+     :: else
+     fi
+     if
+     :: doReceive ->
+       printf("@@@ %d SCALAR pending %d %d\n",_pid,taskid,tasks[taskid].pending);
+       if
+       :: sendTwice && !sentFirst -> Release(sendSema)
+       :: else
+       fi
+       printf("@@@ %d CALL event_receive %d %d %d %d %d recrc\n",
+              _pid,rcvEvents,rcvWait,rcvAll,rcvInterval,rcvOut);
+                 /* (self,  evts,     when,   what,  ticks,      out,   rc) */
+       event_receive(taskid,rcvEvents,rcvWait,rcvAll,rcvInterval,rcvOut,recrc);
+       printf("@@@ %d SCALAR recrc %d\n",_pid,recrc);
+       if
+       :: rcvOut > 0 ->
+         printf("@@@ %d SCALAR recout %d %d\n",_pid,rcvOut,recout[rcvOut]);
+       :: else
+       fi
+     :: else
+     fi
+     Release(sendSema);
+     printf("@@@ %d LOG Receiver %d finished\n",_pid,taskid);
+System Process
+ We need a process that periodically wakes up blocked processes. This is
+ modelling background behaviour of the system, such as ISRs and scheduling. We
+ visit all tasks in round-robin order (to prevent starvation) and make them
+ ready if waiting on "other" things. Tasks waiting for events or timeouts are
+ not touched. This terminates when all tasks are zombies.
+.. code-block:: c
+   proctype System () {
+     byte taskid ;
+     bool liveSeen;
+     printf("@@@ %d LOG System running...\n",_pid);
+     loop:
+     taskid = 1;
+     liveSeen = false;
+     printf("@@@ %d LOG Loop through tasks...\n",_pid);
+     atomic {
+       printf("@@@ %d LOG Scenario is ",_pid);
+       printm(scenario); nl();
+     do   // while taskid < TASK_MAX ....
+     ::  taskid == TASK_MAX -> break;
+     ::  else ->
+         atomic {
+           printf("@@@ %d LOG Task %d state is ",_pid,taskid);
+           printm(tasks[taskid].state); nl()
+         if
+         :: tasks[taskid].state == Zombie -> taskid++
+         :: else ->
+            if
+            ::  tasks[taskid].state == OtherWait
+                -> tasks[taskid].state = Ready
+                   printf("@@@ %d STATE %d Ready\n",_pid,taskid)
+            ::  else -> skip
+            fi
+            liveSeen = true;
+            taskid++
+         fi
+     od
+     printf("@@@ %d LOG ...all visited, live:%d\n",_pid,liveSeen);
+     if
+     ::  liveSeen -> goto loop
+     ::  else
+     fi
+     printf("@@@ %d LOG All are Zombies, game over.\n",_pid);
+     stopclock = true;
+Clock Process
+We need a process that handles a clock tick, by decrementing the tick count for
+tasks waiting on a timeout. Such a task whose ticks become zero is then made
+Ready, and its timer status is flagged as a timeout. This terminates when all
+tasks are zombies (as signalled by ``System()`` via ``stopclock``).
+.. code-block:: c
+   proctype Clock () {
+     int tid, tix;
+     printf("@@@ %d LOG Clock Started\n",_pid)
+     do
+     ::  stopclock  -> goto stopped
+     ::  !stopclock ->
+         printf(" (tick) \n");
+         tid = 1;
+         do
+         ::  tid == TASK_MAX -> break
+         ::  else ->
+             atomic{
+               printf("Clock: tid=%d, state=",tid);
+               printm(tasks[tid].state); nl()
+             if
+             ::  tasks[tid].state == TimeWait ->
+                 tix = tasks[tid].ticks - 1;
+                 if
+                 ::  tix == 0
+                     tasks[tid].tout = true
+                 ::  else
+                     tasks[tid].ticks = tix
+                 fi
+             ::  else // state != TimeWait
+             fi
+             tid = tid + 1
+         od
+     od
+   stopped:
+     printf("@@@ %d LOG Clock Stopped\n",_pid);
+init Process
+The initial process outputs annotations for defines and declarations,
+generates a scenario non-deterministically and then starts the system, clock
+and send and receive processes running. It then waits for those to complete,
+and them, if test generation is underway, asserts ``false`` to trigger a
+seach for counterexamples:
+.. code-block:: c
+   init {
+     pid nr;
+     printf("@@@ %d NAME Event_Manager_TestGen\n",_pid)
+     outputDefines();
+     outputDeclarations();
+     printf("@@@ %d INIT\n",_pid);
+     chooseScenario();
+     run System();
+     run Clock();
+     run Sender(THIS_NODE,SEND_ID);
+     run Receiver(THIS_NODE,RCV_ID);
+     _nr_pr == 1;
+   #ifdef TEST_GEN
+     assert(false);
+   #endif
+The information regarding when tasks should wait and/or restart
+can be obtained by tracking the process identifiers,
+and noting when they change.
+The ``spin2test`` program does this,
+and also produces separate test code segments for each Promela process.
+Refinement
+Files:
+ | ``event-mgr-model-N.spn`` where ``N`` ranges from 0 to 8.
+ | ``event-mgr-model-rfn.yml``
+The test-code we generate here is based on the test-code generated from the
+specification items used to describe the Event Manager in the main (non-formal)
+part of the new qualification material.
+The relevant specification item is ``spec/rtems/event/req/send-receive.yml``
+found in ``rtems-central``. The corresponding C test code is
+``tr-event-send-receive.c`` found in ``rtems`` at ``testsuites/validation``.
+That automatically generated C code is a single file that uses a set of deeply
+nested loops to iterate through the scenarios it generates.
+Our approach is to generate a stand-alone C code file for each scenario
+(``tr-event-mgr-model-N.c`` for ``N`` in range 0..8.)
+The ``TASK`` annotations issued by the ``Sender`` and ``Receiver`` processes
+lookup the following refinement entries, to get code that tests that the C
+code Task does correspond to what is being defined in the model.
+   Runner: |
+     checkTaskIs( ctx->runner_id );
+   Worker: |
+     checkTaskIs( ctx->worker_id );
+The ``WAIT`` and ``SIGNAL`` annotations produced by ``Obtain()`` and
+``Release()`` respectively, are mapped to the corresponding operations on
+RTEMS semaphores in the test code.
+   code content
+   SIGNAL: |
+     Wakeup( semaphore[{}] );
+   WAIT: |
+     Wait( semaphore[{}] );
+Some of the ``CALL`` annotations are used to do more complex test setup
+involving priorities, or other processors and schedulers. For example:
+   HigherPriority: |
+     SetSelfPriority( PRIO_HIGH );
+     rtems_task_priority prio;
+     rtems_status_code sc;
+     sc = rtems_task_set_priority( RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &prio );
+     T_rsc_success( sc );
+     T_eq_u32( prio, PRIO_HIGH );
+   SetProcessor: |
+     T_ge_u32( rtems_scheduler_get_processor_maximum(), 2 );
+     uint32_t processor = {};
+     cpu_set_t cpuset;
+     CPU_ZERO(&cpuset);
+     CPU_SET(processor, &cpuset);
+Some handle more complicated test outcomes, such as observing context-switches:
+   CheckPreemption: |
+     log = &ctx->thread_switch_log;
+     T_eq_sz( log->header.recorded, 2 );
+     T_eq_u32( log->events[ 0 ].heir, ctx->runner_id );
+     T_eq_u32( log->events[ 1 ].heir, ctx->worker_id );
+Most of the other refinement  entries are similar to those described above for
+the Chains API.
+Assembly
+Files:
+ | ``tr-event-mgr-model.h``
+ | ``tr-event-mgr-model.c``
+ | ``event-mgr-model-pre.h`` (Preamble)
+ | ``event-mgr-model-post.h`` (Postamble)
+ | ``event-mgr-model-run.h`` (Runner)
+The assembly process is the same as described for Chains.
+Deployment
+Files:
+ | ``tc-event-mgr-model.c``
+ | ``tr-event-mgr-model-N.c`` where ``N`` ranges from 0 to 8.
+Modelling Thread Queues
+Below,
+we summarise the current state of the thread queue verification effort.
+All this verification material can be found at
+``formal/promela/models/threadq``, which contains the following directories:
+``MrsP-Code``
+    Contains Promela models of the MrsP semaphore implementation, based on a
+    reading of the actual code, assuming ``RTEMS_SMP`` is defined (among other
+    settings). It is intended to check for desirable properties, and the
+    absence of undesirable ones. It is not suitable for test generation. The
+    "main" module is found in ``MAIN.pml``.
+``MrsP-Tests``
+    Contains Promela models of the MrsP semaphore behaviour, at a high level of
+    abstraction. These are intended for test generation, which is not currently
+    completed. The "main" module is ``mrsp-threadq-model.pml``, which currently
+    generates 1092 scenarios. We go into more detail about this in sub-section
+    :ref:`TestingThreadQueues`.
+``Weak-Memory``
+    Contains models of various aspects of weak memory. Parts of these may find
+    their way into the MrsP models.
+``docs``
+    Contains LaTeX sources for early working documents. Currently out of scope.
+Weak Memory Models
+Files in ``Weak-Memory/``:
+ | ``memory_model.pml``
+ | ``RAM.pml``
+ | ``SPARC-TSO.pml``
+ | ``wmemory.pml``
+A model of generic weak memory is found in ``memory_model.pml`` (which includes
+``RAM.pml`` and ``wmemory.pml``). This replaces an ideal atomic load or store
+by one that has two phases, a move from register or RAM into some transport
+medium (aether), follwed by a subsequent move into RAM or register. The model
+has two threads that try to increment a memory location. At the end it asserts
+that the location has value 2. This can be simulated using:
+  spin memory_model.pml
+This will sometimes succeed, and sometimes fail, as expected. If we run the
+following commands:
+  spin -run memory_model.pml
+  spin -t -v memory_model.pml
+then the first command reports an assertion violation error, while the second
+replays the generated counter-example.
+The file ``SPARC-TSO.pml`` is a standalone model of the Sparc architectures
+Total Store Order (TSO) memory model. It is low-level, modelling individual
+memory access instructions.
+Modelling Thread Code
+Files in ``MrsP-Code/`` :
+ | ``MAIN.pml``
+ | ``Chains.pml``
+ | ``Concurrency.pml``
+ | ``Heaps.pml``
+ | ``Init.pml``
+ | ``Locks.pml``
+ | ``Priority.pml``
+ | ``RBTrees.pml``
+ | ``Scenarios.pml``
+ | ``Semaphores.pml``
+ | ``Sizing.pml``
+ | ``State.pml``
+ | ``Structs.pml``
+ | ``Values.pml``
+Scoping
+Scoping is complete, and at first glance seems reasonable in size.
+We are looking at scenarios involving a number of processors and schedulers
+running a number of tasks of varying priorities that simply create,
+obtain,
+and release MrsP semaphores.
+In practise, this touches a large part of the RTEMS code base.
+We need to handle a wide variety of queues, implemented using both chains
+and red-black trees, as well as different locking protocols.
+The datastructures that represent processors, schedulers and threads,
+are complex, with many linkages in between them. The MrsP protocols require
+task to migrate from one processor to another under certain circumstances.
+Modelling
+Modelling began by looking at the key RTEMS API calls involved,
+namely `rtems_semaphore_create()`, `rtems_semaphore_obtain()`,
+and `rtems_semaphore_release()`.
+Progress was good until an assertion from the RTEMS source failed
+when transcribed into the Promela model.
+This raised the need to model how the entire system is initialized,
+at least those parts that can influence the MrsP protocol behaviour.
+RTEMS initialization is very complex,
+and an initial working model has only just been completed.
+Validation
+In the current state of the model,
+the main methods of validation are:
+careful reading of the Promela code with respect to the corresponding C code;
+and implementing every C code assertion in Promela using the `assert()` construct.
+The C assertions capture the implementors understanding of good behaviour,
+and our model should at least check they are satisfied within the model.
+Verification
+We can perform simulation runs to observe behaviour,
+but the model is not at the stage where we can use the model-checker to check
+high-level properties, such as deadlock- or live-lock freedom.
+.. _TestingThreadQueues:
+Testing Thread Queues
+The test-generation code is found in ``MrsP-Tests/``.
+Model
+Files:
+ | ``Utilities.pml``
+ | ``Sizing.pml``
+ | ``Configure.pml``
+ | ``Run.pml``
+ | ``mrsp-threadq-model.pml``
+``Utilities.pml``
+Promela ``inline``\ s implementing useful calculations:
+.. code-block:: c
+    inline setMin( a, b, min ) { ... }
+    inline chooseLowHigh( low, high, choice ) { ... }
+    inline lowerRatio( n, p, lowerbound) { ... }
+``Sizing.pml``
+This Promela code makes a non-deterministic choice of various sizes as follows:
+  1. Choose number of cores, at least one
+  2. Choose number of tasks, at least two, and at least one per core
+  3. Choose number of resources, at least one
+The maximum number of cores and resources possible is four, while up to six
+tasks are possible.
+``Configure.pml``
+Given the number of cores, resources, and tasks, assign tasks to cores, and
+resources to tasks, so that:
+ 1. Every core has at least one task.
+ 2. Every resource is associated with at least two tasks.
+``Run.pml``
+This builds a Promela model of a task that takes its nominal behaviour (a.k.a.
+its "business logic") and interleaves this with regular checks to see if it is
+not blocked, doing its business, and then invoking a context switch.
+.. code-block:: c
+   WAIT_TO_RUN( tno );   // <1>
+   tryObtain( tno, 3 );   // <2>
+   contextSwitch( taskConfig[tno].taskCore );   // <3>
+.. topic:: Items:
+  1. Wait here until the scheduler makes me ``Ready``.
+  2. Do my business logic (here trying to obtain a semaphore).
+  3. Perform a context switch that allows the scheduler (model) to run.
+``mrsp-threadq-model.pml``
+Chooses a scenario, launches all the tasks, waits for them to complete, and then
+asserts ``false`` if test generation is active and we are about to terminate.
+Annotations
+The only annotations that have been developed at this point are those in
+``Sizing.pml`` that report the number of key elements in a scenario.
+Refinement
+No refinement has been developed at this point.
+Assembly
+Files:
+ | ``tr-mrsp-threadq-model.h``
+ | ``tr-mrsp-threadq-model.c``
+ | ``mrsp-threadq-model-pre.h`` (Preamble)
+ | ``mrsp-threadq-model-post.h`` (Postamble)
+ | ``mrsp-threadq-model-run.h`` (Runner)
+Deployment
+Files:
+ | ``tc-mrsp-threadq-model.c``
+ | ``tr-mrsp-threadq-model-N.c`` where ``N`` ranges from 0 to 1091.
diff --git a/eng/fv/overview.rst b/eng/fv/overview.rst
index 0000000..63bb01f
--- /dev/null
+++ b/eng/fv/overview.rst
@@ -0,0 +1,33 @@
+Formal Verification Overview
+Formal Verification is a technique based on writing key design artifacts using
+notations that have a well-defined mathematical **semantics**. This means that
+these descriptions can be rigorously analysed using logic and other mathematical
+tools. We will use the term "formal model" to refer to any such description.
+Having a formal model of a software engineering artifact (requirements,
+specification, code) allows it to be analysed to assess the behaviour it
+describes. This means we can check that the model has desired properties, and
+lacks undesired ones. A key feature of having a formal description is that we
+can develop tools that parse the notation and can perform much, if not most,
+of the analysis. An "industrial-strength" formalism is one that has very good
+tool support.
+When we have two formal models of the same software object at different levels
+of abstraction (specification and code, say) then we can compare them. In
+particular, we can formally analyse if a lower level artifact like code,
+satisfies the properties described by a higher level, such as a specification.
+This relationship is commonly referred to as a "refinement".
+Often it is quite difficult to get a useful formal model of real code. Some
+formal modelling approaches are capable of generating machine-readable
+"scenarios" that describe possible correct behaviours of the system at the
+relevant level of abstraction. We can define a refinement for these by
+using them to generate test code. This is the technique that is used here to
+verify parts of RTEMS. We construct formal models based on requirements
+documentation, and use these as a basis for test generation.
diff --git a/eng/fv/promela.rst b/eng/fv/promela.rst
index 0000000..2c1d472
--- /dev/null
+++ b/eng/fv/promela.rst
@@ -0,0 +1,320 @@
+Modelling RTEMS with Promela
+Guide to Promela subset in use
+Promela is a large language with many features. We only use a subset of those
+in our test generation scheme. Here we give a short overview of what we do use.
+The definitive documentation can be found at
+https://spinroot.com/spin/Man/promela.html .
+Promela "Execution"
+Promela is a *modelling* language, not a programming language. It is designed
+to describe the kind of runtime behaviours that make reasoning about low-level
+concurrency so difficult: namely shared mutable state and effectively
+non-deterministic interleaving of concurrent threads. This means that we have
+control constructs that specify non-deterministic outcomes on the one hand, and
+an execution model that allows us to specify when threads should block on the
+other hand. This allows us to model both what we cannot directly control, as
+well as techniques that allow us to get indirect control of behaviour.
+The execution model is based on the following concepts:
+Interleaving Concurrency
+    A running Promela system consists of one or more concurrent processes. Each
+    process is described by a segment of code that defines a sequence of
+    atomic steps. The scheduler looks at all the available next-steps and makes
+    a **non-deterministic choice** of which one will run. The scheduler is
+    invoked after every atomic step.
+Executability
+    At any point in time, a Promela process is either able to perform a step,
+    and is considered "executable", or is unable to do so, and is considered
+    "blocked". Whether a statement is executable or blocked may depend on the
+    global state of the model. The scheduler will only select from among the
+    executable processes.
+The Promela language is based loosely on C, and the SPIN model-checking tool
+converts a Promela model into a C program that has the specific model
+hard-coded and optimised for whatever analysis has been invoked. It also
+supports the use of the C pre-processor.
+Simulation vs. Verification
+SPIN can run a model in one of two modes.
+Simulation
+    SPIN simply makes random choices for the scheduler to produce a possible
+    execution sequence (a.k.a. "scenario") allowed by the model. A readable
+    transcript is written to ``stdout`` as the simulation runs.
+    The simplest SPIN invocation does simulation by default:
+    .. code:: C
+      spin model.pml
+Verification
+    SPIN does an analysis of the whole model by exploring all the possible
+    choices that the scheduler can make. This will continue until either all
+    possible choices have been covered, or some form of error is uncovered. If
+    an error occurs, verification stops, and the sequence of steps that lead
+    to that failure are output to a so-called "trail" file. If verification
+    ends successfully, then this is simply reported as "ok".
+    The simplest way to run a verification is to give the ``-run`` option:
+    .. code:: C
+       spin -run model.pml
+Replaying
+    A trail file is an uninformative list of number-triples, but can be replayed
+    in simulation mode to produce human-readable output.
+    .. code:: C
+    spin -t model.pml
+Promela Datatypes
+Promela supports a subset of C scalar types (``short'',``int``), but also
+adds some of its own (``bit``, ``bool``, ``byte``, ``unsigned``). It has support for one-dimensional arrays, and its own variation of the C struct concept
+(confusingly called a ``typedef``!). It has a single enumeration type called
+``mtype``. There are no pointers in Promela, which means that modelling pointer
+usage requires us to use arrays with their indices acting as proxies for
+pointers.
+Promela Declarations
+Variables and one-dimensional arrays can be declared in Promela in much the
+same way as they are done in C:
+.. code-block:: C
+  int x, y[3] ;
+All global variables and arrays are initialised to zero.
+The identifier ``unsigned`` is the name of a type, rather than a modifier.
+It is used to declare an unsigned number variable with a given bit-width:
+.. code-block:: C
+  unsigned mask : 4 ;
+Structure-like datatypes in Promela are defined using the ``typedef`` keyword
+(for reasons that are not very clear):
+.. code-block:: C
+  typedef CBuffer {
+    short count;
+    byte buffer[8]
+  CBuffers cbuf[6];
+Note that we can have arrays of ``typedef``\ s that themselves contain arrays.
+There is only one enumeration type, which can be defined "incrementally".
+Consider the following sequence of four declarations that defines the values in
+``mtype`` and declares two variables of that type:
+.. code-block:: C
+  mtype = { up, down } ;
+  mtype dir1;
+  mtype = { left, right} ;
+  mtype dir2;
+We get the same outcome with the following two declarations:
+.. code-block:: C
+  mtype = { left, right, up, down } ; // No, not a typo!
+  mtype dir1, dir2;
+Special Identifiers
+The are a number of variable identifiers that have a special meaning in Promela.
+These all start with an underscore. We use the following:
+Process Id
+    ``_pid`` holds the process id of the currently active process
+Process Count
+    ``_nr_pr`` gives the number of currently active processes.
+Promela Atomic Statements
+Assignment
+    ``x = e`` where ``x`` is a variable and ``e`` is an expression.
+    Expression ``e`` must have no side-effects. An assignment is always
+    executable. Its effect is to update the value of ``x`` with the current
+    value of ``e``.
+Condition Statement
+    ``e`` where ``e`` is an expression
+    Expression ``e``, used standalone as a statement, is executable if its
+    value in the current state is non-zero. If its current value is zero,
+    then it is blocked. It behaves like a NO-OP when executed.
+Skip
+    ``skip``, a keyword
+    ``skip`` is always executable, and behaves like a NO-OP when executed.
+Assertion
+    ``assert(e)`` where ``e`` is an expression
+    An assertion is always executable. When executed, it evaluates its
+    expression. If the value is non-zero, then it behaves like a NO-OP. If the
+    value is zero, then it generates an assertion error and aborts further
+    simulation/verification of the model.
+Printing
+    ``printf(string,args)`` where ``string`` is a format-string and ``args``
+    are values and expressions.
+    A ``printf`` statement is completely ignored in verification mode. In simulation mode, it is always executable, and generates output to ``stdout``
+    in much the same way as in C. We make use of this in a structured way
+    (see below) to assist with test generation.
+Goto
+    ``goto lbl`` where ``lbl`` is a statement label.
+    ``goto`` is always executable. When executed, flow of control goes to the
+    statement labelled by ``lbl:``.
+Break
+    ``break``, a keyword
+    Can only occur within a loop (``do ... od``, see below). It is always
+    executable, and when executed performs a ``goto`` to the statement just
+    after the end of the innermost enclosing loop.
+Promela Composite Statements
+Sequencing
+    ``{ <stmt> ; <stmt> ; ... ; <stmt> }`` where each ``<stmt>`` can be any
+    kind of statement, atomic or composite. The sub-statements execute in
+    sequence in the usual way.
+Selection
+    .. code-block:: none
+       if
+       :: <stmt>
+       :: <stmt>
+       :: <stmt>
+       fi
+   A selection construct is blocked if all the ``<stmt>`` are blocked. It is
+   executable if at least one ``<stmt>`` is executable. The scheduler will make
+   a non-deterministic choice from all of those ``<stmt>`` that are executable.
+   The construct terminates when/if the chosen ``<stmt>`` does.
+   Typically, a selection statement will be a sequence of the form
+   ``g ; s1 ; ... ; sN`` where ``g`` is an expression acting as a guard,
+   and the rest of the statements are intended to run if ``g`` is non-zero.
+   The symbol ``->`` plays the same syntactic role as ``;``, so this allows
+   for a more intuitive look and feel; ``g -> s1 ; ... ; sN``.
+   If the last ``<stmt>`` has the form ``else -> ...``, then the ``else`` is
+   executable only when all the other selection statements are blocked.
+Repetition
+       do
+       :: <stmt>
+       :: <stmt>
+       :: <stmt>
+       od
+    The executability rules here are the same as for Selection above. The key
+    difference is that when/if a chosen ``<stmt>`` terminates, then the whole
+    construct is re-executed, making it basically an infinite loop. The only
+    way to exit this loop is for an active ``<stmt>`` to execute a ``break``
+    or ``goto`` statement.
+    A ``break`` statement only makes sense inside a Repetition, is always
+    executable, and its effect is to jump to the next statement after the
+    next ``od``
+    keyword in text order.
+The selection and repetition syntax and semantics are based on Edsger
+Djikstra's "Guarded Command Language" :cite:`Djikstra:1975:GCL` .
+Atomic Composite
+    ``atomic{stmt}`` where ``stmt`` is usually a (sequential) composite.
+    Wrapping the ``atomic`` keyword around a statement makes its entire
+    execution proceed without any interference from the scheduler. Once it is
+    executable, if the scheduler chooses it to run, then it runs to completion.
+    There is one very important exception: if it should block internally because
+    some sub-statement is blocked, then the atomicity gets broken, and the
+    scheduler is free to find some other executable process to run. When/if the
+    sub-statement eventually becomes executable, and then gets chosen to run by
+    the scheduler, then it continues to run atomically.
+Processes
+    ``proctype name (args) { sequence }`` where ``args`` is a list of zero
+    or more typed parameter declarations, and ``sequence`` is a list of local declarations and statements.
+    This defines a process type called ``name`` which takes parameters defined
+    by ``args`` and has the behaviour defined by ``sequence``. When invoked, it
+    runs as a distinct concurrent process. Processes can be invoked explicitly
+    by an existing process using the ``run`` operator, or can be setup to start automatically.
+Inlining
+    ``inline name (names) { sequence }`` where ``names`` is a list of zero or
+    more identifiers, and ``sequence`` is a list of declarations and statements.
+    Inlining does textual substitution, and does not represent some kind of
+    function call. An invocation ``name(texts)`` gets replaced by
+    ``{ sequence }`` where each occurrence of an identifier in ``names`` is
+    replaced by the corresponding text in ``texts``. Such an invocation can
+    only appear in a context where a Promela statement can appear.
+Promela Top-Level
+At the top-level, a Promela model is a list of declarations, much like a C
+program. The Promela equivalent of ``main`` is a process called ``init`` that
+has no arguments. There must be at least one Promela process setup to be running
+at the start. This can be ``init``, or one or more ``proctype``\ s declared as
+``active``.
diff --git a/eng/fv/refinement.rst b/eng/fv/refinement.rst
new file mode 100644
index 0000000..2140b0e
--- /dev/null
+++ b/eng/fv/refinement.rst
@@ -0,0 +1,359 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2022 Trinity College Dublin
+Promela to C Refinement
+Promela models are more abstract than concrete C code. We need to establish a
+rigourous link, known as a "refinement", from Promela to C. This is composed of
+two parts: manual annotations in the Promela model to make its behaviour easy
+to identify and parse; and a refinement defined as a YAML file that maps from
+annotations to corresponding C code.
+Model Annotations
+We use ``printf`` statements in the Promela models to output information that
+is used by ``spin2test`` to generate test code. This information is used to
+lookup keys in a YAML file that defines the mapping to C code. It uses a simple
+format that makes it easy to parse and process, and is also designed to be
+easily understood by a human reader. This is important because any V&V process
+will require this information to be carefully assessed.
+Annotation Syntax
+Format, where :math:`N \geq 0`:
+  ``@@@ <pid> <KEYWORD> <parameter1> ... <parameterN>``
+The leading ``@@@`` is a marker that makes it easy to filter out this
+information from other SPIN output.
+Parameters take the following forms:
+  ``<pid>``  Promela Process Id of ``proctype`` generating annotation
+  ``<word>`` chunk of text containing no white space
+  ``<name>`` Promela variable/structure/constant identifier
+  ``<type>`` Promela type identifier
+  ``<tid>``  OS Task/Thread/Process Id
+  ``_``  unused argument (within containers)
+Each ``<KEYWORD>`` is associated with specific forms of parameters:
+.. code-block:: none
+  LOG <word1> ... <wordN>
+  NAME <name>
+  INIT
+  DEF <name> <value>
+  DECL <type> <name> [<value>]
+  DCLARRAY <type> <name> <value>
+  TASK <name>
+  SIGNAL <name> <value>
+  WAIT   <name> <value>
+  STATE tid <name>
+  SCALAR (<name>|_) [<index>] <value>
+  PTR <name> <value>
+  STRUCT <name>
+  SEQ <name>
+  END <name>
+  CALL <name> <value1> ... <valueN>
+Annotation Lookup
+The way that code is generated depends on the keyword in the annotation.
+In particular, the keyword determines how, or if,
+the YAML refinement file is looked up.
+  Direct Output - no lookup
+  (``LOG``, ``DEF``)
+  Keyword Refinement - lookup the ``<KEYWORD>``
+  (``NAME``, ``INIT``, ``SIGNAL``, ``WAIT``)
+  Name Refinement - lookup first parameter (considered as text)
+  (``TASK``, ``DECL``, ``DCLARRAY``, ``PTR``, ``CALL``, ``SCALAR``)
+The same name may appear in different contexts,
+and so we can extend the name with a suffix of the form
+``_XXX`` to lookup less frequent uses:
+  ``_DCL`` - A variable declaration
+  ``_PTR`` - The pointer value itself
+  ``_FSCALAR`` - A scalar that is a struct field
+  ``_FPTR`` - A pointer that is a struct field
+Generally, the keyword, or name is used to lookup ``mymodel-rfn.yml`` to get a
+string result. This string typically has substitution placeholders, as used by
+the Python ``format()`` method for strings. The other parameters in the
+annotation are then textually substituted in, to produce a segment of test code.
+This is all implemented in the source file
+``formal/promela/src/src/refine_command.coco``.
+Lookup Example
+Consider the following annotation, from the Events Manager model:
+  ``@@@ 1 CALL event_send 1 2 10 sendrc``
+This uses Name refinement so we lookup ``send``
+and get back the following text:
+.. code-block:: python3
+  T_log( T_NORMAL, "Calling Send(%d,%d)", mapid( ctx, {1}), {2} );
+  {3} = ( *ctx->send )( mapid( ctx, {1} ), {2} );
+  T_log( T_NORMAL, "Returned 0x%x from Send", {3} );
+We then substitute in arguments ``1``, ``2``, ``10``, and ``sendrc``
+to get the code:
+.. code-block:: c
+  T_log( T_NORMAL, "Calling Send(%d,%d)", mapid( ctx, 2), 10 );
+  sendrc = ( *ctx->send )( mapid( ctx, 2 ), 10 );
+  T_log( T_NORMAL, "Returned 0x%x from Send", sendrc );
+Given a Promela process id of ``1``, this code is put into a code segment
+for the corresponding RTEMS task.
+Specifying Refinement
+Using the terminology of the RTEMS Test Framework (Section
+:numref:`RTEMSTestFramework`) we convert each Promela model into a set of
+Test Cases, one for each complete scenario produced by test generation. We have
+a number of template files, tailored for each model, that are used to assemble
+the test code sources, along with code segments for each Promela process, based
+on the annotations output for any given scenario.
+The refinement mapping from annotations to code is defined in a YAML file that
+describes a Python dictionary that maps a name to some C code, with placeholders
+that are used to allow for substituting in actual test values.
+The YAML file has entries of the following form:
+.. code:: yaml
+    entity: |
+      C code line1{0}
+      C code lineM{2}
+The "entity" is a reference to an annotation concept, which can refer to key
+declarations, values, variables, types, API calls or model events. There can be
+zero or more arguments in the annotations, and any occurrence of braces
+enclosing a number in the C code means that the corresponding annotation
+argument string is substituted in (using the python string object `format()`
+method).
+The general pattern is that we work through all the annotations in order. The
+code we obtain by looking up the YAML file is collated into different
+"code-segments", on for each Promela process id (``<pid>``).
+In addition to the explicit annotations generated by the Promela models, there
+are two implicit annotations produced by the python refinement code. These
+occur when the ``<pid>`` part of a given explicit annotation is different to the
+one belonging to the immediately preceding annotation. This indicates a point in
+a test generation scenario where one task is suspended and another resumes. This
+generates internal annotations with keywords ``SUSPEND`` and ``WAKEUP`` which
+should have entries in the refinement file to provide code to ensure that the
+corresponding RTEMS tasks in the test behave accordingly.
+We can also emit the annotation as a comment into the generated test-code, so
+it is easy to check that parameters are correct, and the generated code is
+correct.
+If a lookup fails, we output a C comment line stating the lookup failed. We
+don't abort the translation but continue the translation.
+Annotation Refinement Guide
+LOG
+``LOG <word1> ... <wordN>`` (Direct Output)
+    We generate a call to ``T_log()`` with a message formed from the ``<word..>``
+    parameters.
+NAME
+``NAME <name>`` (Keyword Refinement)
+    We lookup ``NAME`` (currently ignoring ``<name>``) and returns the resulting
+    text as is as part of the code. This code should define the name of the
+    testcase, if needed.
+INIT
+``INIT`` (Keyword Refinement)
+    Lookup ``INIT`` and expect to obtain test initialisation code.
+TASK
+``TASK <name>`` (Name Refinement)
+    Lookup ``<name>`` and return corresponding C code.
+SIGNAL
+``SIGNAL <value>`` (Keyword Refinement)
+    Lookup `SIGNAL` and return code with `<value>` substituted in.
+WAIT
+``WAIT <value>`` (Keyword Refinement)
+    Lookup `WAIT` and return code with `<value>` substituted in.
+DEF
+``DEF <name> <value>`` (Direct Output)
+    Output ``#define <name> <value>``.
+DECL
+``DECL <type> <name> [<value>]`` (Name Refinement)
+    Lookup ``<name>_DCL`` and substitute ``<name>`` in. If ``<value>`` is
+    present, append `` = <value>``. Add a final semicolon. If the `<pid>` value
+    is zero, prepend ``static ``.
+DCLARRAY
+``DCLARRAY <type> <name> <value>`` (Name Refinement)
+    Lookup ``<name>_DCL`` and substitute ``<name>`` and ``<value>`` in. If the
+    `<pid>` value is zero, prepend ``static ``.
+CALL
+``CALL <name> <value0> .. <valueN>`` (Name refinement, ``N`` < 6)
+    Lookup ``<name>`` and substitute all ``<value..>`` in.
+STATE
+``STATE <tid> <name>`` (Name Refinement)
+    Lookup ``<name>`` and substitute in ``<tid>``.
+STRUCT
+``STRUCT <name>``
+    Declares that are we going to output the contents of variable ``<name>``
+    that is itself a structure. The ``<name>`` is noted, as is the fact we are
+    processing a structured value. We should not already be processing a
+    structure or a sequence.
+SEQ
+``SEQ <name>``
+    that is itself a sequence/array. The ``<name>`` is noted, as is the fact we
+    are processing a structured value. We will accumulate values in a string
+    that is now initialsed to empty. We should not already be processing a
+PTR
+``PTR <name> <value>`` (Name Refinement)
+    If not inside a ``STRUCT``, lookup ``<name>_PTR``. Two lines of code should
+    be returned. If the ``<value>`` is zero, use the first line, otherwise use
+    the second with ``<value>`` substituted in. This is required to handle NULL
+    pointers.
+    If inside a ``STRUCT``, lookup ``<name>_FPTR``. Two lines of code should
+    pointers.
+SCALAR
+We have quite a few variations here.
+``SCALAR _ <value>``
+    Should only be used inside a ``SEQ``. A space and ``<value>`` is appended
+    to the string being accumulated by this ``SEQ``.
+``SCALAR <name> <value>`` (Name Refinement)
+    If not inside a ``STRUCT``, lookup ``<name>``, and substitute ``<value>``
+    into the resulting code.
+    If inside a ``STRUCT``, lookup ``<name>_FSCALAR`` and substitute the saved
+    ``STRUCT`` name and ``<value>`` into the resulting code.
+    This should not be used inside a ``SEQ``.
+``SCALAR <name> <index> <value>`` (Name Refinement)
+    If not inside a ``STRUCT``, lookup ``<name>``, and substitute ``<index>``
+    and ``<value>`` into the resulting code.
+END
+``END <name>``
+    If inside a ``STRUCT``, indicate that we are no longer processing a
+    structured variable.
+    If inside a ``SEQ``, lookup ``<name>_SEQ``. For each line of code obtained,
+    substitute in the saved sequence string. Indicate that we are no longer
+    processing a sequence/array variable.
+    This should not be encountered outside of a ``STRUCT`` or ``SEQ``.
+SUSPEND and WAKEUP
+We have found a change of Promela process id from ``oldid`` to ``newid``. We
+have incremented a counter that tracks the number of such changes.
+``SUSPEND``  (Keyword Refinement)
+    Lookup ``SUSPEND`` and substitute in the counter value, ``oldid`` and
+    ``newid``.
+``WAKEUP``  (Keyword Refinement)
+    Lookup ``WAKEUP`` and substitute in the counter value, ``newid`` and
+    ``oldid``.
+Annotation Ordering
+While most annotations occur in an order determined by any given test scenario,
+there are some annotations that need to be issued first. These are, in order:
+``NAME``, ``DEF``, ``DECL`` and ``DCLARRAY``, and finally, ``INIT``.
diff --git a/eng/fv/tool-setup.rst b/eng/fv/tool-setup.rst
index 0000000..bf5b8df
--- /dev/null
+++ b/eng/fv/tool-setup.rst
@@ -0,0 +1,80 @@
+Formal Tools Setup
+A key requirement for methods and tools for RTEMS qualification was that they
+comply to a large degree with RTEMS community guidelines. We wanted to avoid
+having large complex tools with large library dependencies, and have tools and
+notations that would be easy to maintain.
+After reviewing a range of methods and tools, we settled on a technique based on
+the SPIN model checker :cite:`Holzmann:1997:SPIN`, with its modelling language
+called Promela (https://spinroot.com/). Promela is quite a low-level modelling
+language that makes it easy to get close to code level, and is specifically targeted to modelling software. It is one of the most widely
+used model-checkers, both in industry and education. It uses linear-time
+temporal logic (LTL) to express properties of interest.
+It is open-source (https://github.com/nimble-code/Spin), actively maintained,
+and very easy to install, needing only  a C compiler and the ``lex``/``yacc``
+utilities.
+Installing Tools
+The test generation tools are found in ``formal/promela/src``, written for
+Python3. That directory contains ``requirements.txt`` that identifies the
+required Python libraries. A key requirement is the "Coconut" package, that
+defines a form of pattern-matching syntax for Python. Source files have
+extension ``.coco`` and are compiled into equivalent Python scripts.
+To build, enter that directory and issue the commands:
+.. code:: shell
+  make env
+  . env/bin/activate
+To avoid using (long) absolute pathnames to the tools directory,
+it is worth defining some environment variables and aliases:
+.. code-block:: shell
+  SPIN2TEST="/..../formal/promela/src/manual"
+  export SPIN2TEST
+  alias spin2test="${SPIN2TEST}/spin2test.sh"
+  alias testgen="${SPIN2TEST}/testgen.sh"
+  alias tbuild='python3 $SPIN2TEST/testbuilder.py'
+**need to explain how to configure testbuilder**
+The C test code generated by these tools is installed into the main ``rtems``
+repository  at ``testsuites/validation`` in the exact same way as other RTMES
+testcode.
+This means that whenever ``waf`` is used at the top level to build and/or run
+tests, that the formally generated code is automatically included.
+This requires adding and modifying some *Specification Items*
+(See Section :numref:`%s <ReqEngSpecificationItems>` ). Details about how to
+do this are found in the :ref:`FormalMaint` sub-section.
+Running Test Generation
+The simplest way to check test generation is setup properly is to visit one of
+the models, found under ``formal/promela/models`` and execute the following list
+of commands:
+   tbuild generate mymodel
+   tbuild copy mymodel
+   tbuild compile
+   tbuild run
+Go to the main ``rtems`` top-level, and rebuild using ``waf``,
+and then use a simulator to run ``ts-model-0.exe`` directly.
diff --git a/eng/index.rst b/eng/index.rst
index d5d6f85..f7ca68b 100644
--- a/eng/index.rst
+++ b/eng/index.rst
@@ -11,6 +11,7 @@ RTEMS Software Engineering (|version|)
 .. topic:: Copyrights and License
+    | |copy| 2020 Trinity College Dublin
     | |copy| 2018, 2020 embedded brains GmbH
     | |copy| 2018, 2020 Sebastian Huber
     | |copy| 1988, 2015 On-Line Applications Research Corporation (OAR)
@@ -31,6 +32,7 @@ RTEMS Software Engineering (|version|)
     management
     test-plan
     test-framework
+    fv/index
     build-system
     release-mgmt
     users-manuals
2.32.1 (Apple Git-133)
Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
Lero at TCD, Head of Software Foundations & Verification Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
                         http://www.scss.tcd.ie/Andrew.Butterfield/
