Integrating the Formal Methods part of Qualification
Kuan-Hsun Chen
c0066c at gmail.com
Tue Sep 13 19:38:27 UTC 2022
Dear Andrew,
It's great to see a move toward formal verification for RTEMS.
>From our side (TU Dortmund in Germany and the University of Twente in the
Netherlands), we recently adopted Frama-C to verify ICPP and MrsP. A
potential deadlock is successfully identified, and a remedy is provided.
The result will be presented in EMSOFT this year (
https://ieeexplore.ieee.org/document/9852753/), and the verification
framework is publicly released here:
https://github.com/tu-dortmund-ls12-rt/Resource-Synchronization-Protocols-Verification-RTEMS
Due to the double-blind review process, I cannot chime in earlier in this
thread. Today earlier I have seen your patches regarding the chapter you
proposed. I wonder if you could take our contribution into account when you
organize the chapter?
A preprint can be found here
<https://www.researchgate.net/publication/362599165_Formal_Verification_of_Resource_Synchronization_Protocol_Implementations_A_Case_Study_in_RTEMS>.
(The corresponding ticket will be prepared, and the patch together with a
test case will be submitted)
Best,
Kuan-Hsun
On Fri, Jul 22, 2022 at 12:37 PM Andrew.Butterfield at scss.tcd.ie <
Andrew.Butterfield at scss.tcd.ie> wrote:
> Dear RTEMS developers,
> thanks for the feedback below - I want to wrap this up and move to the
> next step.
> I propose to produce a complete draft of a formal methods section for the
> Software Engineering manual in rtems-docs
> This will add a "Formal Verification" section just after the existing
> "Test Framework" section.
> This will allow developers to get a much better idea of what is proposed,
> and for me to get feedback.
> For now, the section will state clearly at the start that this is a
> proposal and that the tooling and resources it describes
> won't yet be available in RTEMS proper.
> Files likely to be modified in rtems-docs:
> eng/index.rst
> common/refs.bib
> I'll add in eng/formal-verification.rst
> I'll then submit patches for review in the usual way.
> Regards,
> Andrew
> Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
> http://www.scss.tcd.ie/Andrew.Butterfield/
> On 11/07/2022, 12:43, "devel on behalf of Andrew.Butterfield at scss.tcd.ie"
> <devel-bounces at rtems.org on behalf of Andrew.Butterfield at scss.tcd.ie>
> wrote:
> On 6 Jul 2022, at 20:07, Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Jul 3, 2022 at 7:49 PM Chris Johns <chrisj at rtems.org> wrote:
> On 2/7/2022 12:59 am, Andrew Butterfield wrote:
> On 1 Jul 2022, at 00:59, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 28/6/2022 11:09 pm, Andrew.Butterfield at scss.tcd.ie
> <mailto:Andrew.Butterfield at scss.tcd.ie> wrote:
> Dear RTEMS Developers,
> While the validation tests from the RTEMS pre-qualification activity are
> now merged into the RTEMS master, the work done in investigating and
> deploying formal methods techniques is not yet merged.
> The activity had two main phases: a planning phase (Nov 2018-Oct 2019)
> that explored various formal techniques, followed by an execution phase
> (Oct 2019-Nov 2021) that then applied selected techniques to selected
> parts of RTEMS. Some discussions occurred with the RTEMS community
> via the mailings lists over this time. A short third phase (Nov 2021 - Dec
> 2021)
> then reported on the outcomes. Each phase resulted in a technical report.
> The key decision made was to use Promela/SPIN for test generation, and
> to apply it to the Chains API, the Event Manager, and the SMP scheduler
> thread queues. This involved developing models in the Promela language
> and using the SPIN model-checker tool to both check their correctness
> and to generate execution scenarios that could be used to generate tests.
> Tools were developed using Python 3.8 to support this. Initial
> documentation
> about tools and how to use them was put into the 2nd phase report.
> Congratulations for the work and results you and others have managed to
> achieve.
> It is exciting to see this happening with RTEMS and being made public.
> We now come to the part where we explore the best way to integrate this
> into RTEMS. I am proposing to do this under the guidance of Sebastian
> Huber.
> The first suggested step is adding in new documentation to the RTEMS
> Software Engineering manual, as a new Formal Methods chapter. This would
> provide some motivation, as well as a "howto".
> I assume that I would initially describe the proposed changes using the
> patch
> review process described in the section on Preparing and Sending Patches in
> the User Manual.
> How do you feel I should best proceed?
> It is hard for me to answer until I understand what is being submitted and
> who
> maintains it? I am sure you understand this due to the specialised nature
> of the
> work.
> Indeed, I quite agree. I have some short answers below, with suggestions.
> Thanks.
> +1
> What will be submitted, ie SPIN files, scripts, etc?
> Promela/SPIN model files (ASCII text, C-like syntax)
> C template files (.h,.c) to assist test code generation
> YAML files to provide a mapping from model concepts to RTEMS C test code
> python scripts to automate the test generation
> Documentation - largely RTEMS compliant sphinx sources (.rst)
> Where are you looking to add these pieces?
> Everything except the documentation could live in a top-level folder
> ('formal')
> in rtems-central.
> In fact there is no particular constraint from my perspective for where
> they can go.
> Using rtems-central is fine.
> Do they require anything currently located in rtems-central? Are the
> models or YAML files related to the current specification files? I
> know I'm guilty of not spending the time yet to deeply learn
> rtems-central, but I would like to know that these files will fit
> within that repo as it currently is intended to operate.
> At the moment there is nothing in rtems-central directly related to this.
> All the python
> scripts there support the tools/specs that Sebastian and colleagues
> developed.
> I can see a new top-level script being added here to support the formal
> stuff.
> It is possible that we might introduce a new specification item that
> integrates
> in with the spec system that is used to trigger the Spin test generations.
> I'll discuss the
> best wat to do this with Sebastian.
> RSB should be taught how to build the necessary host tools to run
> Promela/SPIN.
> Spin is open source under a BSD 3-clause license, available from
> spinroot.com,
> and also via https://github.com/nimble-code/Spin. It is written in C and
> has very few
> dependencies. I'm not sure what is involved in adding it to the RSB, but I
> guess
> Sebastian will know.
> The plan would be to add the pertinent parts of our project documentation
> into
> new chapters
> in the RTEMS software engineering manual. So that would be eng/ in the
> rtems-docs repo.
> Great.
> +1
> A new section in the eng should be suitable. I would actually
> recommend using
> https://docs.rtems.org/branches/master/eng/test-framework.html# as a
> good example.
> Thanks - that very helpful. I think our section should immediately follow
> that one.
> All we need now is a suitable title. "Formal Test Framework"?
> How is the verification run against the code? Do we manage regression
> testing
> and is that even possible?
> The python scripts basically run SPIN in such a way as to generate
> scenarios
> that model
> correct behaviour which then get turned into standard RTEMS test programs.
> These all
> get added into a new testsuite in the rtems repo (testsuites/models, say).
> They are properly integrated into the RTEMS test system, so get built and
> run by
> waf.
> This is similar to how the tests generated by Sebastian in
> testsuites/validation
> are handled.
> From the perspective of a user that works out of git.rtems.org/rtems
> <http://git.rtems.org/rtems>,
> there will be no obvious impact - just some extra tests in among the ones
> that
> already exist.
> Thanks and this make sense.
> I hope my simple questions highlight a lack of understand on how this
> works and
> how we maintain it and use it once integrated.
> I intend to continue to work and maintain this for the foreseeable future.
> I
> would hope as this beds in that other Promela/SPIN users out there will
> also get
> more involved over time.
> Thank, it is appreciated.
> I'm also interested in tracking this, and I might be able to go after
> some resources on the US side. I'll be in touch on that later, but if
> any US users are tracking this too, or you know any with interest, I'd
> love to talk about it.
> Indeed - that would be good.
> Andrew
> It is expected that Promela models will be as static as the corresponding
> APIs.
> They capture the specified behaviour of API calls, not their detailed
> implementation.
> The python scripts should also be fairly stable, although I can see some
> tweaking for a while to improve workflow issues that might arise.
> There are some extra python libraries that are required over and above
> what is
> currently specified in rtems-central/requirements.txt
> This all makes sense to me. Thank you for taking the time to respond.
> Chris
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
Diese Mail wurde mobil geschrieben. Etwaige Rechtschreibfehler sind volle
Absicht und als großzügiges Geschenk zu verstehen.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220913/555e4d26/attachment-0001.htm>
