[PATCH 2/3] textproc/gsed: Add GNU sed build support
Wed Sep 14 13:30:48 UTC 2022
Unfortunately needed on some hosts. OK by me.
On Wed, Sep 14, 2022 at 2:02 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Updates #2300
>  bare/config/textproc/gsed-4.8.cfg       |  12 +++
>  bare/config/textproc/gsed-internal.bset |  12 +++
>  bare/config/textproc/gsed.bset          |   4 +
>  bare/config/textproc/gsed.cfg           |   8 ++
>  source-builder/config/gsed-1.cfg        | 108 ++++++++++++++++++++++++
>  5 files changed, 144 insertions(+)
>  create mode 100644 bare/config/textproc/gsed-4.8.cfg
>  create mode 100644 bare/config/textproc/gsed-internal.bset
>  create mode 100644 bare/config/textproc/gsed.bset
>  create mode 100644 bare/config/textproc/gsed.cfg
>  create mode 100644 source-builder/config/gsed-1.cfg
> diff --git a/bare/config/textproc/gsed-4.8.cfg
> b/bare/config/textproc/gsed-4.8.cfg
> new file mode 100644
> index 0000000..8806bef
> --- /dev/null
> +++ b/bare/config/textproc/gsed-4.8.cfg
> @@ -0,0 +1,12 @@
> +# GNU sed 4.8
> +%include %{_configdir}/base.cfg
> +%define gsed_version 4.8
> +%hash sha512 sed-%{gsed_version}.tar.gz \
> C94KIhaOMQCwIUKTsTu6CEzM5F/7WGtsV1OPUY52akRDn/vyR4mPK7j1BtBTHTbynAp7cIhJVbqTz8/YhjG/eQ==
> +%include %{_configdir}/gsed-1.cfg
> diff --git a/bare/config/textproc/gsed-internal.bset
> b/bare/config/textproc/gsed-internal.bset
> index 0000000..e93e1a5
> --- /dev/null
> +++ b/bare/config/textproc/gsed-internal.bset
> @@ -0,0 +1,12 @@
> +# Internal GNU sed
> +%define _internal_gsed      yes
> +%define _internal_gsed_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
> +%define _disable_collecting yes
> +%define _disable_packaging  yes
> +%define _disable_reporting  yes
> +%define _disable_installing yes
> +%include textproc/gsed.bset
> diff --git a/bare/config/textproc/gsed.bset
> b/bare/config/textproc/gsed.bset
> index 0000000..68f2e13
> --- /dev/null
> +++ b/bare/config/textproc/gsed.bset
> @@ -0,0 +1,4 @@
> +# GNU sed
> +textproc/gsed.cfg
> diff --git a/bare/config/textproc/gsed.cfg b/bare/config/textproc/gsed.cfg
> index 0000000..8287c74
> --- /dev/null
> +++ b/bare/config/textproc/gsed.cfg
> @@ -0,0 +1,8 @@
> +# GNU sed has a version option, check for it.
> +# If not found build it.
> +%define has_gnu_sed %(sed --version > /dev/null 2>&1; echo $?)
> +%if %{has_gnu_sed} != 0
> + %include %{_configdir}/textproc/gsed-4.8.cfg
> +%endif
> diff --git a/source-builder/config/gsed-1.cfg
> b/source-builder/config/gsed-1.cfg
> index 0000000..828da50
> --- /dev/null
> +++ b/source-builder/config/gsed-1.cfg
> @@ -0,0 +1,108 @@
> +# GNU sed 1.xx Version 1.
> +# This configuration file configure's, make's and install's GNU's sed
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +%ifn %{defined _internal_gsed}
> +  %define _internal_gsed no
> +%endif
> +%ifn %{defined _internal_gsed_path}
> +  %define _internal_gsed_path %{_prefix}
> +%endif
> +Name:      gsed-%{gsed_version}-%{_host}-%{release}
> +Summary:   GNU sed v%{gsed_version} for host %{_host}
> +Version:   %{gsed_version}
> +Release:   %{release}
> +URL:      https://www.gnu.org/software/sed/
> +# Source
> +%source set gsed https://ftp.gnu.org/gnu/sed/sed-%{gsed_version}.tar.gz
> +# Remap the install paths if it is an internal build
> +%if %{_internal_gsed} == yes
> +  %define gsed_prefix %{_internal_gsed_path}
> +%else
> +  %define gsed_prefix %{_prefix}
> +%endif
> +%define gsed_exec_prefix    %{gsed_prefix}
> +%define gsed_bindir         %{gsed_exec_prefix}/bin
> +%define gsed_sbindir        %{gsed_exec_prefix}/sbin
> +%define gsed_libexecdir     %{gsed_exec_prefix}/libexec
> +%define gsed_datarootdir    %{gsed_prefix}/share
> +%define gsed_datadir        %{gsed_datarootdir}
> +%define gsed_sysconfdir     %{gsed_prefix}/etc
> +%define gsed_sharedstatedir %{gsed_prefix}/com
> +%define gsed_localstatedir  %{gsed_prefix}/var
> +%define gsed_includedir     %{gsed_prefix}/include
> +%define gsed_libdir         %{gsed_exec_prefix}/%{_lib}
> +%define gsed_mandir         %{gsed_datarootdir}/man
> +%define gsed_infodir        %{gsed_datarootdir}/info
> +%define gsed_localedir      %{gsed_datarootdir}/locale
> +# Prepare the source code.
> +%prep
> +  build_top=$(pwd)
> +  source_dir_gsed="sed-%{gsed_version}"
> +  %source setup gsed -q -n sed-%{gsed_version}
> +  %patch setup gsed -p1
> +  cd ${build_top}
> +%build
> +  build_top=$(pwd)
> +  %if %{defined _internal_gsed_path}
> +    export PATH="%{_internal_gsed_path}/bin:${PATH}"
> +  %endif
> +  %{build_directory}
> +  mkdir -p ${build_dir}
> +  cd ${build_dir}
> +  %{host_build_flags}
> +  ../${source_dir_gsed}/configure \
> +    --prefix=%{gsed_prefix} \
> +    --bindir=%{gsed_bindir} \
> +    --exec_prefix=%{gsed_exec_prefix} \
> +    --includedir=%{gsed_includedir} \
> +    --libdir=%{gsed_libdir} \
> +    --libexecdir=%{gsed_libexecdir} \
> +    --mandir=%{gsed_mandir} \
> +    --infodir=%{gsed_infodir} \
> +    --datadir=%{gsed_datadir} \
> +    --build=%{_build} --host=%{_host}
> +  %{__make} %{?_smp_mflags} all
> +  cd ${build_top}
> +%install
> +  build_top=$(pwd)
> +  %{__rmdir} $SB_BUILD_ROOT
> +  cd ${build_dir}
> +  %if %{_internal_gsed} == yes
> +    %{__make} install
> +  %else
> +    %{__make} DESTDIR=$SB_BUILD_ROOT install
> +  %endif
> +  cd ${build_top}
> 2.37.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220914/a6281e6d/attachment-0001.htm>
