[PATCH 3/3] devel/gcc: Check and build GNU sed if not available on build host
Frank Kühndel
frank.kuehndel at embedded-brains.de
Thu Sep 15 11:21:00 UTC 2022
Hello Chris,
our CI build the tools (rtems-source-builder git) for revision
c0edd80bcd27b3dad7ee7acf5ea129e81e6a6f64 "rtems/jpeg: Update the checksum"
OK and failed for revision
468fc79e8c7c8076e8b65be82ba2009e41dd6c8e "devel/gcc: Check and build GNU
sed if not available on build host"
with missing dependencies for expat-devel (and as followup gmp-devel).
Excerpt from the source-builder log:
checking size of unsigned __int128... 16
checking for library containing dlopen... none required
checking whether to use expat... yes
checking for libexpat... no
configure: error: expat is missing or unusable
make[2]: *** [Makefile:10085: configure-gdb] Error 1
make[2]: *** Waiting for unfinished jobs....
This happens in an opensuse leap 15.4 container within a build for RTEMS
6 and ARM BSP. I tested on an almalinux container too and got the same
error.
"expat" and "gmp" are usually build by the source-builder itself. Hence,
I wonder whether these new additional dependencies on "expat-devel" and
"gmp-devel" packages are added by intention or whether this may be a
unwanted side effect of the patches?
Greetings
Frank
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone: +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
