[PATCH 1/2] sb/setbuilder: Install the build when stagging or configured to install
chrisj at rtems.org
chrisj at rtems.org
Fri Sep 16 06:59:28 UTC 2022
source-builder/sb/setbuilder.py | 9 ++++++---
1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index f24ac87..3e16111 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -226,6 +226,9 @@ class buildset:
def installing(self):
return self.install_mode() == 'installing'
+ def installable(self):
+ return not self.opts.no_install() or self.staging()
def staging(self):
return not self.installing()
@@ -553,14 +556,14 @@ class buildset:
', '.join([b.name() for b in builds])))
if deps is None and not have_errors:
for b in builds:
- log.trace('_bset: : %s: %r' % (self.install_mode(),
- b.installable()))
+ log.trace('_bset: : %s: installable=%r build-installable=%r' % \
+ (self.install_mode(), self.installable(), b.installable()))
if b.installable():
prefix = b.config.expand('%{_prefix}')
buildroot = path.join(b.config.expand('%{buildroot}'), prefix)
if self.staging():
prefix = b.config.expand('%{stagingroot}')
- if not self.opts.no_install():
+ if self.installable():
self.install(self.install_mode(), b.name(), buildroot, prefix)
# Sizes ...
2.37.1
