[PATCH v2 0/4] Microchip PolarFire SoC support
    Joel Sherrill
    joel at rtems.org
    Tue Sep 20 17:03:48 UTC 2022
I have pushed this patch set. Please check that the merge is OK and follow
up with an update to the Users Guide for those looking for this BSP.
Thanks.
On Tue, Sep 20, 2022 at 8:56 AM Joel Sherrill <joel.sherrill at gmail.com>
wrote:
> This procedure should be added to the Users Guide under the BSPs section.
> Otherwise, it looks like I should coordinate with Padmarao to make sure
> it's ok after I merged it
> On Tue, Sep 20, 2022, 1:50 AM <Padmarao.Begari at microchip.com> wrote:
>> RTEMS SMP on the Microchip PolarFire Icicle Kit
>> Test Procedure:
>> 1. Create the "config.ini" file with below content at rtems root
>>         [riscv/mpfs64imafdc]
>>         BUILD_TESTS = True
>>         RTEMS_POSIX_API=True
>>         RTEMS_SMP = True
>>         BSP_START_COPY_FDT_FROM_U_BOOT=False
>>         BSP_VERBOSE_FATAL_EXTENSION = False
>> 2. Build RTEMS
>>         $ ./waf configure --prefix=$HOME/rtems-start/rtems/6
>>         $ ./waf
>> 3. Convert .exe to .elf file
>> $ riscv-rtems6-objcopy  build/riscv/mpfs64imafdc/testsuites/smptests/sm
>> p01.exe
>>  build/riscv/mpfs64imafdc/testsuites/smptests/smp01.elf
>> 4. Generate the payload for the smp01.elf using the hss-payload-
>> generator with hart-entry-points/exec-addr: 0x1000000000
>> https://github.com/polarfire-soc/hart-software-services/tree/master/tools/hss-payload-generator
>> 5. Programming the'payload.bin' for the eMMC/SD
>>  5.1) Board setting and FPGA Programing
>> https://github.com/polarfire-soc/polarfire-soc-documentation/blob/master/boards/mpfs-icicle-kit-es/updating-icicle-kit/updating-icicle-kit-design-and-linux.md
>>  5.2). Power Cycle the Microchip PolarFire Icicle Kit and stop at the
>>        HSS.
>>  5.3) type "mmc" and then "usbdmsc" on the HSS terminal(UART0).
>>  5.4) Load payload from the Host PC.
>>         $ sudo dd if=payload.bin of=/dev/sdb bs=512
>>  5.5) Quit USB and Reset the Icicle Kit
>>  5.6) Serial terminal UART1 displays the SMP example messages
>> *** BEGIN OF TEST SMP 1 ***
>> *** TEST VERSION: 6.0.0.ef33f861e16de9bf4190a36e4d18062c7300986c
>> *** TEST STATE: EXPECTED_PASS
>> *** TEST BUILD: RTEMS_POSIX_API RTEMS_SMP
>> *** TEST TOOLS: 12.1.1 20220622 (RTEMS 6, RSB 3cb78b0b815ba05d17f5c6
>>                 5865d246a8333aa087, Newlib ea99f21)
>> CPU 3 start task TA0
>> CPU 2 running Task TA0
>> CPU 3 start task TA1
>> CPU 1 running Task TA1
>> CPU 3 start task TA2
>> CPU 0 running Task TA2
>> *** END OF TEST SMP 1 ***
>> Regards
>> Padmarao
>> On Mon, 2022-09-19 at 18:30 +0530, Padmarao Begari wrote:
>> > This patch set adds the Microchip PolarFire SoC BSP Variant
>> > support to RISC-V RTEMS.
>> > The PolarFire SoC is the 4x 64-bit RISC-V U54 cores and
>> > a 64-bit RISC-V E51 monitor core SoC from Microchip, more
>> > info available here:
>> >       https://www.microchip.com/en-us/products/fpgas-and-plds/
>> >       system-on-chip-fpgas/polarfire-soc-fpgas#Overview
>> > This new BSP variant is added for the 4x U54 cores not for E51
>> > because the E51 monitor core is resreved for first stage
>> > bootloader (Hart Software Services).
>> > The boot HARTID configurable is implemented for the riscv BSP
>> > to work with individual hart(cpu core) or SMP.
>> > This BSP support components: 4 CPU Cores (U54), Interrupt
>> > controller (PLIC), Timer (CLINT), UART (16550-compatible)
>> > work fine on actual Microchip PolarFire SoC Icicle Kit.
>> > v2:
>> > - Add a license and copyright information in dtb header file
>> > - Use RISCV_BOOT_HARDID instead of RTEMS_BOOT_HARDID
>> > - Add '_RISCV_Map_hardid_to_cpu_index()' and
>> > '_RISCV_Map_cpu_index_to_hardid()' functions
>> > - Change bsp_fdt_get() instead of bsp_fdt_copy() function for dtb
>> > - Move dtb and dtb header configurable build option to the bsps
>> > Padmarao Begari (4):
>> >   bsps/riscv: Add device tree blob
>> >   spec/build/bsps: Add dtb support
>> >   bsps/riscv: Add Microchip PolarFire SoC BSP variant
>> >   bsps/shared/: Use device tree blob
>> >  bsps/riscv/riscv/clock/clockdrv.c             |   6 +-
>> >  bsps/riscv/riscv/config/mpfs64imafdc.cfg      |   9 +
>> >  bsps/riscv/riscv/dts/mpfs.dts                 | 365 +++++++++++
>> >  bsps/riscv/riscv/include/bsp/mpfs-dtb.h       | 602
>> >  bsps/riscv/riscv/include/bsp/riscv.h          |  14 +
>> >  bsps/riscv/riscv/irq/irq.c                    |  81 +++
>> >  bsps/riscv/riscv/start/bsp_fatal_halt.c       |   3 +
>> >  bsps/riscv/riscv/start/bspsmp.c               |   2 +-
>> >  bsps/riscv/riscv/start/bspstart.c             |  19 +-
>> >  bsps/riscv/shared/start/start.S               |   2 +
>> >  bsps/shared/start/bsp-fdt.c                   |   8 +
>> >  .../score/cpu/riscv/include/rtems/score/cpu.h |   2 +-
>> >  .../cpu/riscv/include/rtems/score/cpuimpl.h   |   2 +-
>> >  spec/build/bsps/optdtb.yml                    |  19 +
>> >  spec/build/bsps/optdtbheaderpath.yml          |  20 +
>> >  spec/build/bsps/riscv/optextirqmax.yml        |   5 +-
>> >  spec/build/bsps/riscv/optrambegin.yml         |   5 +-
>> >  spec/build/bsps/riscv/optramsize.yml          |   5 +-
>> >  spec/build/bsps/riscv/riscv/abi.yml           |   6 +
>> >  .../bsps/riscv/riscv/bspmpfs64imafdc.yml      |  19 +
>> >  spec/build/bsps/riscv/riscv/grp.yml           |   6 +
>> >  spec/build/bsps/riscv/riscv/optmpfs.yml       |  18 +
>> >  spec/build/bsps/riscv/riscv/optns16550max.yml |   3 +
>> >  spec/build/cpukit/cpuopts.yml                 |   2 +
>> >  spec/build/cpukit/optarchbits.yml             |   1 +
>> >  spec/build/cpukit/optboothartid.yml           |  19 +
>> >  spec/build/cpukit/optsmp.yml                  |   1 +
>> >  27 files changed, 1235 insertions(+), 9 deletions(-)
>> >  create mode 100644 bsps/riscv/riscv/config/mpfs64imafdc.cfg
>> >  create mode 100644 bsps/riscv/riscv/dts/mpfs.dts
>> >  create mode 100644 bsps/riscv/riscv/include/bsp/mpfs-dtb.h
>> >  create mode 100644 spec/build/bsps/optdtb.yml
>> >  create mode 100644 spec/build/bsps/optdtbheaderpath.yml
>> >  create mode 100644 spec/build/bsps/riscv/riscv/bspmpfs64imafdc.yml
>> >  create mode 100644 spec/build/bsps/riscv/riscv/optmpfs.yml
>> >  create mode 100644 spec/build/cpukit/optboothartid.yml
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220920/e60e15d2/attachment-0001.htm>
