[PATCH v2 0/4] Microchip PolarFire SoC support
    Padmarao.Begari at microchip.com
    Wed Sep 21 05:40:14 UTC 2022
Hi Chris,
Thank You for a tar file build, will try to build same using your repo.
Regards
Padmarao
> On Wed, 2022-09-21 at 14:34 +1000, Chris Johns wrote:
> On 21/9/2022 3:03 am, Joel Sherrill wrote:
> > I have pushed this patch set. Please check that the merge is OK and
> > follow up
> > with an update to the Users Guide for those looking for this BSP.
> Thanks. Great to see the addition of this BSP.
> I have updated the RSB to include this BSP. I have also added this
> BSP to my
> deployment repo:
>   https://git.rtems.org/chrisj/rtems-deployment.git/
> https://git.rtems.org/chrisj/rtems-deployment.git/tree/config/6/polarfire-icicle-bsp-smp.ini
> To build a tar file:
>  git clone git://git.rtems.org/rtems-source-builder.git
>  git clone git://git.rtems.org/chrisj/rtems-deployment.git
>  cd rtems-deployment
>  ./waf configure --prefix=/opt/rtems --rsb=../rtems-source-builder
>  ./waf --targets=6/polarfire-icicle-bsp dry-run
> The results:
> $ ls tar
> polarfire-icicle-bsp.tar.bz2
> To have the tools and BSP installed when built add to configure `
> --install`.
> Chris
