[PATCH v6 00/10] New GPIO, ADC API and STM32F4 BSP implementation
Karel Gardas
karel at functional.vision
Wed Sep 21 13:48:05 UTC 2022
The problem is that we still need to discuss licensing here. Randomly
checked files from the HAL patch contains this as a license:
* This software is licensed under terms that can be found in the
LICENSE file
* in the root directory of this software component.
* If no LICENSE file comes with this software, it is provided AS-IS.
and in the past Sebastian suggested to clear the message hence I used
something used here:
https://github.com/dtbpkmte/GSoC-2022-RTEMS/blob/master/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/system_stm32h7xx.c
unfortunately whole F4 HAL would probably need such modification.
On the bright side, it looks like STM still holds on BSD-3 for their HAL
code for F4?
https://github.com/STMicroelectronics/STM32CubeF4/blob/master/LICENSE.md
Would be great indeed.
BTW: sorry, I'm really out of the loop on this still trying to catch up
with all the development in RTEMS over summer...
Karel
On 9/21/22 15:25, Joel Sherrill wrote:
> This patch set has been sitting for almost 7 weeks. I was going to commit
> it today but was asked to give one last the patch merge equivalent of
> ""if anyone can show just cause why this patch and RTEMS cannot be
> joined together, let them speak now or forever hold their peace"
> Or at least be nice about not holding their peace. :)
> Two days and I merge this. I will aim for high noon on Friday.
> --joel
> On Sun, Aug 7, 2022 at 5:58 AM Duc Doan <dtbpkmte at gmail.com
> <mailto:dtbpkmte at gmail.com>> wrote:
> Dear all,
> These patches are to address the issues in my previous versions. These
> include GPIO API, ADC API and STM32F4 BSP implementation for them.
> My repository is at: https://github.com/dtbpkmte/GSoC-2022-RTEMS
> <https://github.com/dtbpkmte/GSoC-2022-RTEMS> (master
> branch).
> The sample application code for these APIs can be found at:
> https://github.com/dtbpkmte/GSoC-2022-RTEMS-Sample-Apps
> <https://github.com/dtbpkmte/GSoC-2022-RTEMS-Sample-Apps>.
> STM32F4 HAL source code is taken from ST's repo at:
> https://github.com/STMicroelectronics/STM32CubeF4.git
> <https://github.com/STMicroelectronics/STM32CubeF4.git> (Commit ID:
> 52757b5,
> Release v1.27.1).
> v2:
> - Made get_gpio_from_base() a macro instead of a function
> - Added missing cppflags in spec/build/bsps/arm/grp.yml
> - Optimized STM32F4_GET_HAL_GPIO_PIN() and STM32F4_GET_LL_EXTI_LINE()
> - Optimized functions by switching from HAL to LL
> - Made stm32f4_gpio_deinit() return RTEMS_NOT_IMPLEMENTED, because
> disabling
> clock might affect all pins in a port
> - Add const to static helper arrays to make sure they are placed on ROM
> v3:
> - Removed rtems_gpio_begin()
> - bsp_gpio_register_controllers() now needs to be called from hook1
> (can be configured by option STM32F4_ENABLE_GENERIC_GPIO)
> - Updated license text for API files and STM32F4 GPIO files
> v4:
> - Fixed GPIO port guards
> - Fixed potential memory-leak bug of STM32F4 GPIO interrupt system
> - Added comments to STM32F4 GPIO functions and made them extern
> v5:
> - Replace old HAL source code with the one from official repository
> to remove
> CRLF
> - Added a peripherals API, which is a framework to add more APIs
> that operates
> on a GPIO pin
> - Changed GPIO API to comply with the peripherals API
> - Changed ADC API to comply with the peripherals API
> - Changed STM32F4 implementation
> v6:
> - Split commits that add CMSIS and HAL
> - Removed peripheral API
> - Changed ADC API: this is now separate from GPIO API
> Duc Doan (10):
> bsps/arm: Convert CMSIS files from CRLF to LF
> bsps/arm: Changed CMSIS files to v5
> build/bsps/arm: Add new CMSIS files v5 to build
> bsps/arm/stm32f4: Include STM32F4 HAL
> bsps/arm/stm32f4: Add HAL to build
> bsps/arm/stm32f4: Make bspstart use HAL
> bsps: Add GPIO API
> bsps/arm/stm32f4: GPIO Implementation
> bsps: Add ADC API
> bsps/arm/stm32f4: ADC API implementation
> bsps/arm/include/cmsis_compiler.h | 266 +
> bsps/arm/include/cmsis_gcc.h | 3460 +--
> bsps/arm/include/cmsis_version.h | 39 +
> bsps/arm/include/core_cm4.h | 524 +-
> bsps/arm/include/core_cm7.h | 5186 ++--
> bsps/arm/include/core_cmFunc.h | 172 +-
> bsps/arm/include/core_cmInstr.h | 174 +-
> bsps/arm/include/core_cmSimd.h | 192 +-
> bsps/arm/include/mpu_armv7.h | 270 +
> bsps/arm/stm32f4/adc/adc.c | 495 +
> bsps/arm/stm32f4/gpio/gpio.c | 557 +
> .../stm32f4/hal/Legacy/stm32f4xx_hal_can.c | 1679 ++
> .../stm32f4/hal/Legacy/stm32f4xx_hal_eth.c | 2307 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal.c | 615 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c | 2110 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c | 1112 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c | 2462 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c | 996 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c | 502 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c | 328 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c | 7132 ++++++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c | 680 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c | 1341 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c | 495 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c | 1161 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c | 182 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c | 4423 ++++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c | 1305 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c | 2126 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c | 313 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c | 2760 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c | 3220 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c | 547 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c | 775 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c | 1347 +
> .../stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c | 172 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c | 6864 ++++++
> .../arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c | 258 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c | 2749 +++
> .../stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c | 145 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c | 533 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c | 3514 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c | 1040 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c | 1728 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c | 7524 ++++++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c | 182 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c | 2094 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c | 1135 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c | 2687 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c | 262 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c | 2484 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c | 2215 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c | 151 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c | 3201 +++
> .../stm32f4/hal/stm32f4xx_hal_msp_template.c | 100 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c | 2405 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c | 1543 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c | 946 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c | 2387 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c | 341 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c | 571 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c | 600 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c | 2915 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c | 1122 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c | 3784 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c | 867 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c | 1896 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c | 1878 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c | 2554 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c | 310 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c | 3277 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c | 1308 +
> .../arm/stm32f4/hal/stm32f4xx_hal_smartcard.c | 2364 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c | 2784 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c | 1627 ++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c | 3915 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c | 1110 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c | 7621 ++++++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c | 2428 ++
> ...tm32f4xx_hal_timebase_rtc_alarm_template.c | 318 +
> ...m32f4xx_hal_timebase_rtc_wakeup_template.c | 293 +
> .../hal/stm32f4xx_hal_timebase_tim_template.c | 177 +
> bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c | 3751 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c | 2838 +++
> bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c | 420 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c | 922 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c | 103 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c | 280 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c | 423 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c | 594 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c | 212 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c | 1498 ++
> bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c | 217 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c | 1062 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c | 303 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c | 251 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c | 301 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c | 81 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c | 1660 ++
> bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c | 111 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c | 838 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c | 1578 ++
> bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c | 624 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c | 1189 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c | 500 +
> bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c | 2224 ++
> bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c | 749 +
> bsps/arm/stm32f4/hal/system_stm32f4xx.c | 747 +
> .../stm32f4/include/Legacy/stm32_hal_legacy.h | 4014 +++
> .../include/Legacy/stm32f4xx_hal_can_legacy.h | 765 +
> .../include/Legacy/stm32f4xx_hal_eth_legacy.h | 2209 ++
> bsps/arm/stm32f4/include/bsp/io.h | 4 +
> bsps/arm/stm32f4/include/bsp/stm32f4_adc.h | 198 +
> bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h | 281 +
> bsps/arm/stm32f4/include/stm32f401xc.h | 8641 +++++++
> bsps/arm/stm32f4/include/stm32f401xe.h | 8641 +++++++
> bsps/arm/stm32f4/include/stm32f405xx.h | 14310 +++++++++++
> bsps/arm/stm32f4/include/stm32f407xx.h | 15607 ++++++++++++
> bsps/arm/stm32f4/include/stm32f410cx.h | 7357 ++++++
> bsps/arm/stm32f4/include/stm32f410rx.h | 7361 ++++++
> bsps/arm/stm32f4/include/stm32f410tx.h | 7306 ++++++
> bsps/arm/stm32f4/include/stm32f411xe.h | 8680 +++++++
> bsps/arm/stm32f4/include/stm32f412cx.h | 13507 ++++++++++
> bsps/arm/stm32f4/include/stm32f412rx.h | 14500 +++++++++++
> bsps/arm/stm32f4/include/stm32f412vx.h | 14512 +++++++++++
> bsps/arm/stm32f4/include/stm32f412zx.h | 14537 +++++++++++
> bsps/arm/stm32f4/include/stm32f413xx.h | 15462 ++++++++++++
> bsps/arm/stm32f4/include/stm32f415xx.h | 14595 +++++++++++
> bsps/arm/stm32f4/include/stm32f417xx.h | 15887 ++++++++++++
> bsps/arm/stm32f4/include/stm32f423xx.h | 15615 ++++++++++++
> bsps/arm/stm32f4/include/stm32f427xx.h | 16827 +++++++++++++
> bsps/arm/stm32f4/include/stm32f429xx.h | 17185 +++++++++++++
> bsps/arm/stm32f4/include/stm32f437xx.h | 17129 +++++++++++++
> bsps/arm/stm32f4/include/stm32f439xx.h | 17479 +++++++++++++
> bsps/arm/stm32f4/include/stm32f446xx.h | 15981 ++++++++++++
> bsps/arm/stm32f4/include/stm32f469xx.h | 20278 +++++++++++++++
> bsps/arm/stm32f4/include/stm32f479xx.h | 20575 ++++++++++++++++
> bsps/arm/stm32f4/include/stm32f4xx.h | 305 +
> bsps/arm/stm32f4/include/stm32f4xx_hal.h | 297 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h | 898 +
> .../stm32f4/include/stm32f4xx_hal_adc_ex.h | 407 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_can.h | 844 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h | 792 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h | 506 +
> .../stm32f4/include/stm32f4xx_hal_cortex.h | 407 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h | 181 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h | 683 +
> .../stm32f4/include/stm32f4xx_hal_cryp_ex.h | 142 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h | 480 +
> .../stm32f4/include/stm32f4xx_hal_dac_ex.h | 205 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h | 563 +
> .../stm32f4/include/stm32f4xx_hal_dcmi_ex.h | 208 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_def.h | 210 +
> .../arm/stm32f4/include/stm32f4xx_hal_dfsdm.h | 1141 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h | 802 +
> .../arm/stm32f4/include/stm32f4xx_hal_dma2d.h | 638 +
> .../stm32f4/include/stm32f4xx_hal_dma_ex.h | 102 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h | 1377 ++
> bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h | 2144 ++
> bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h | 366 +
> .../arm/stm32f4/include/stm32f4xx_hal_flash.h | 425 +
> .../stm32f4/include/stm32f4xx_hal_flash_ex.h | 1063 +
> .../include/stm32f4xx_hal_flash_ramfunc.h | 76 +
> .../stm32f4/include/stm32f4xx_hal_fmpi2c.h | 837 +
> .../stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h | 150 +
> .../stm32f4/include/stm32f4xx_hal_fmpsmbus.h | 790 +
> .../include/stm32f4xx_hal_fmpsmbus_ex.h | 136 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h | 325 +
> .../stm32f4/include/stm32f4xx_hal_gpio_ex.h | 1590 ++
> bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h | 634 +
> .../stm32f4/include/stm32f4xx_hal_hash_ex.h | 175 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h | 316 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h | 741 +
> .../stm32f4/include/stm32f4xx_hal_i2c_ex.h | 115 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h | 618 +
> .../stm32f4/include/stm32f4xx_hal_i2s_ex.h | 183 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h | 682 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h | 220 +
> .../arm/stm32f4/include/stm32f4xx_hal_lptim.h | 857 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h | 719 +
> .../stm32f4/include/stm32f4xx_hal_ltdc_ex.h | 83 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h | 747 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h | 388 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h | 330 +
> .../stm32f4/include/stm32f4xx_hal_pccard.h | 285 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h | 459 +
> .../stm32f4/include/stm32f4xx_hal_pcd_ex.h | 88 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h | 427 +
> .../stm32f4/include/stm32f4xx_hal_pwr_ex.h | 340 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h | 750 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h | 1459 ++
> .../stm32f4/include/stm32f4xx_hal_rcc_ex.h | 7111 ++++++
> bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h | 361 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h | 915 +
> .../stm32f4/include/stm32f4xx_hal_rtc_ex.h | 1079 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h | 895 +
> .../stm32f4/include/stm32f4xx_hal_sai_ex.h | 114 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h | 758 +
> .../arm/stm32f4/include/stm32f4xx_hal_sdram.h | 238 +
> .../stm32f4/include/stm32f4xx_hal_smartcard.h | 755 +
> .../arm/stm32f4/include/stm32f4xx_hal_smbus.h | 731 +
> .../stm32f4/include/stm32f4xx_hal_spdifrx.h | 604 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h | 729 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h | 236 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h | 2146 ++
> .../stm32f4/include/stm32f4xx_hal_tim_ex.h | 354 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h | 884 +
> .../arm/stm32f4/include/stm32f4xx_hal_usart.h | 648 +
> bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h | 298 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h | 4779 ++++
> bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h | 2105 ++
> .../arm/stm32f4/include/stm32f4xx_ll_cortex.h | 637 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h | 201 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h | 1455 ++
> bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h | 2868 +++
> bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h | 1901 ++
> bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h | 954 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h | 1416 ++
> .../arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h | 2234 ++
> bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h | 1086 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h | 981 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h | 1890 ++
> bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h | 302 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h | 1378 ++
> bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h | 985 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h | 7096 ++++++
> bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h | 335 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h | 3663 +++
> bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h | 1141 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h | 2027 ++
> .../arm/stm32f4/include/stm32f4xx_ll_system.h | 1711 ++
> bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h | 4093 +++
> bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h | 2521 ++
> bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h | 536 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h | 307 +
> bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h | 316 +
> bsps/arm/stm32f4/include/system_stm32f4xx.h | 104 +
> bsps/arm/stm32f4/start/bspstart.c | 199 +-
> bsps/include/bsp/adc.h | 407 +
> bsps/include/bsp/gpio2.h | 524 +
> bsps/shared/dev/adc/adc.c | 249 +
> bsps/shared/dev/gpio/gpio2.c | 207 +
> spec/build/bsps/arm/grp.yml | 3 +
> spec/build/bsps/arm/stm32f4/grp.yml | 18 +-
> spec/build/bsps/arm/stm32f4/obj.yml | 225 +
> spec/build/bsps/arm/stm32f4/optenhal.yml | 16 +
> spec/build/bsps/arm/stm32f4/opthse.yml | 17 +
> spec/build/bsps/arm/stm32f4/optnumadcctrl.yml | 16 +
> .../build/bsps/arm/stm32f4/optnumgpioctrl.yml | 16 +
> spec/build/bsps/arm/stm32f4/optusehse.yml | 16 +
> spec/build/bsps/arm/stm32f4/optvariant.yml | 24 +
> spec/build/bsps/bspopts.yml | 4 +
> spec/build/bsps/obj.yml | 3 +-
> spec/build/bsps/optmaxnumadc.yml | 16 +
> spec/build/bsps/optmaxnumgpio.yml | 16 +
> 255 files changed, 589769 insertions(+), 4342 deletions(-)
> create mode 100644 bsps/arm/include/cmsis_compiler.h
> create mode 100644 bsps/arm/include/cmsis_version.h
> create mode 100644 bsps/arm/include/mpu_armv7.h
> create mode 100644 bsps/arm/stm32f4/adc/adc.c
> create mode 100644 bsps/arm/stm32f4/gpio/gpio.c
> create mode 100644 bsps/arm/stm32f4/hal/Legacy/stm32f4xx_hal_can.c
> create mode 100644 bsps/arm/stm32f4/hal/Legacy/stm32f4xx_hal_eth.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_msp_template.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_smartcard.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c
> create mode 100644
> bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_rtc_alarm_template.c
> create mode 100644
> bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_rtc_wakeup_template.c
> create mode 100644
> bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_tim_template.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c
> create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c
> create mode 100644 bsps/arm/stm32f4/hal/system_stm32f4xx.c
> create mode 100644 bsps/arm/stm32f4/include/Legacy/stm32_hal_legacy.h
> create mode 100644
> bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_can_legacy.h
> create mode 100644
> bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_eth_legacy.h
> create mode 100644 bsps/arm/stm32f4/include/bsp/stm32f4_adc.h
> create mode 100644 bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f401xc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f401xe.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f405xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f407xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f410cx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f410rx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f410tx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f411xe.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f412cx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f412rx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f412vx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f412zx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f413xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f415xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f417xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f423xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f427xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f429xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f437xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f439xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f446xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f469xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f479xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_adc_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_can.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cortex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cryp_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dac_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_def.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dfsdm.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma2d.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_flash.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ex.h
> create mode 100644
> bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ramfunc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus.h
> create mode 100644
> bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_gpio_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hash_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2c_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2s_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_lptim.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pccard.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pcd_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pwr_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rcc_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rtc_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sai_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sdram.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_smartcard.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_smbus.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_spdifrx.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_tim_ex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_usart.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_cortex.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_system.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h
> create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h
> create mode 100644 bsps/arm/stm32f4/include/system_stm32f4xx.h
> create mode 100644 bsps/include/bsp/adc.h
> create mode 100644 bsps/include/bsp/gpio2.h
> create mode 100644 bsps/shared/dev/adc/adc.c
> create mode 100644 bsps/shared/dev/gpio/gpio2.c
> create mode 100644 spec/build/bsps/arm/stm32f4/optenhal.yml
> create mode 100644 spec/build/bsps/arm/stm32f4/opthse.yml
> create mode 100644 spec/build/bsps/arm/stm32f4/optnumadcctrl.yml
> create mode 100644 spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml
> create mode 100644 spec/build/bsps/arm/stm32f4/optusehse.yml
> create mode 100644 spec/build/bsps/arm/stm32f4/optvariant.yml
> create mode 100644 spec/build/bsps/optmaxnumadc.yml
> create mode 100644 spec/build/bsps/optmaxnumgpio.yml
> 2.37.1
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
