[PATCH v6 00/10] New GPIO, ADC API and STM32F4 BSP implementation
Gedare Bloom
gedare at rtems.org
Wed Sep 21 22:00:18 UTC 2022
On Wed, Sep 21, 2022 at 9:12 AM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Sep 21, 2022 at 8:48 AM Karel Gardas <karel at functional.vision> wrote:
>> The problem is that we still need to discuss licensing here. Randomly
>> checked files from the HAL patch contains this as a license:
>> * This software is licensed under terms that can be found in the
>> LICENSE file
>> * in the root directory of this software component.
>> * If no LICENSE file comes with this software, it is provided AS-IS.
>> and in the past Sebastian suggested to clear the message hence I used
>> something used here:
>> https://github.com/dtbpkmte/GSoC-2022-RTEMS/blob/master/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/system_stm32h7xx.c
> I'm OK with an explanation like that but I hate to see that much duplicated
> over and over. Would it be possible to put the lengthy explanation in one
> place with the HAL addition and then have a short explanation in each file:
> * RTEMS committer clarification comment on license above:
> * This file comes from STM32CubeH7 project from its Projects subdirectory. See
> * RTEMS_PATH_TBD for details on the license for this file.
> With RTEMS_PATH_TBD probably easy to identify because it would
> be something like bsps/arm/shared/STMHM7 and then the single
> file with a name that is like LICENSE_STM32CubeH7.txt so it isn't just
> LICENSE.txt which is easy to confuse.
> Just a practical matter of avoiding duplication. We have precedence
> for this over the project history.
> This is just record keeping to maintain proper attribution, origin URL,
> licensing, etc. without burden of duplication. They obviously thought it
> was a duplication burden. We should use their trick and just point to
> our location for that file. :)
> It's not like we are trying to nick the code and not give credit. We are
> likely in the small minority even doing this much. My expectations are
> pretty low for most people/projects.
We had a discussion about this topic over on Discord. The general
resolution there was that we should consider importing the HAL code
as-is, and then layer on another patch to inject SPDX tags for the
appropriate license into each imported file. Then the committer (In
this case, Duk) should write up an ORIGIN kind of file to put into the
directory above the HAL to explain the history of the code there,
where it came from (URLs), how the licenses were sorted, and any other
information that helps understand the source of that code. This
balances the effort needed to update the HAL code later, since if it
changes only minimally, we can just re-import it, re-inject the SPDX
tags, and update the ORIGIN file. In this case, I'd say add something
like ORIGIN.HAL in the stm32f4 directory to capture the documentation
about the import process for the HAL.
>> unfortunately whole F4 HAL would probably need such modification.
> And even a better reason to make a short note in each file and put the
> details in a single file in the HAL top directory.
>> On the bright side, it looks like STM still holds on BSD-3 for their HAL
>> code for F4?
>> https://github.com/STMicroelectronics/STM32CubeF4/blob/master/LICENSE.md
> +1
>> Would be great indeed.
>> BTW: sorry, I'm really out of the loop on this still trying to catch up
>> with all the development in RTEMS over summer...
> Understood. Work is busy. RTEMS is busy. And with things getting back
> to normal, I've even been busy going to concerts and other outings that
> I missed. :)
+1
> --joel
>> Karel
>> On 9/21/22 15:25, Joel Sherrill wrote:
>> > This patch set has been sitting for almost 7 weeks. I was going to commit
>> > it today but was asked to give one last the patch merge equivalent of
>> > ""if anyone can show just cause why this patch and RTEMS cannot be
>> > joined together, let them speak now or forever hold their peace"
>> > Or at least be nice about not holding their peace. :)
>> > Two days and I merge this. I will aim for high noon on Friday.
>> > --joel
>> > On Sun, Aug 7, 2022 at 5:58 AM Duc Doan <dtbpkmte at gmail.com
>> > <mailto:dtbpkmte at gmail.com>> wrote:
>> > Dear all,
>> > These patches are to address the issues in my previous versions. These
>> > include GPIO API, ADC API and STM32F4 BSP implementation for them.
>> > My repository is at: https://github.com/dtbpkmte/GSoC-2022-RTEMS
>> > <https://github.com/dtbpkmte/GSoC-2022-RTEMS> (master
>> > branch).
>> > The sample application code for these APIs can be found at:
>> > https://github.com/dtbpkmte/GSoC-2022-RTEMS-Sample-Apps
>> > <https://github.com/dtbpkmte/GSoC-2022-RTEMS-Sample-Apps>.
>> > STM32F4 HAL source code is taken from ST's repo at:
>> > https://github.com/STMicroelectronics/STM32CubeF4.git
>> > <https://github.com/STMicroelectronics/STM32CubeF4.git> (Commit ID:
>> > 52757b5,
>> > Release v1.27.1).
>> > v2:
>> > - Made get_gpio_from_base() a macro instead of a function
>> > - Added missing cppflags in spec/build/bsps/arm/grp.yml
>> > - Optimized STM32F4_GET_HAL_GPIO_PIN() and STM32F4_GET_LL_EXTI_LINE()
>> > - Optimized functions by switching from HAL to LL
>> > - Made stm32f4_gpio_deinit() return RTEMS_NOT_IMPLEMENTED, because
>> > disabling
>> > clock might affect all pins in a port
>> > - Add const to static helper arrays to make sure they are placed on ROM
>> > v3:
>> > - Removed rtems_gpio_begin()
>> > - bsp_gpio_register_controllers() now needs to be called from hook1
>> > (can be configured by option STM32F4_ENABLE_GENERIC_GPIO)
>> > - Updated license text for API files and STM32F4 GPIO files
>> > v4:
>> > - Fixed GPIO port guards
>> > - Fixed potential memory-leak bug of STM32F4 GPIO interrupt system
>> > - Added comments to STM32F4 GPIO functions and made them extern
>> > v5:
>> > - Replace old HAL source code with the one from official repository
>> > to remove
>> > CRLF
>> > - Added a peripherals API, which is a framework to add more APIs
>> > that operates
>> > on a GPIO pin
>> > - Changed GPIO API to comply with the peripherals API
>> > - Changed ADC API to comply with the peripherals API
>> > - Changed STM32F4 implementation
>> > v6:
>> > - Split commits that add CMSIS and HAL
>> > - Removed peripheral API
>> > - Changed ADC API: this is now separate from GPIO API
>> > Duc Doan (10):
>> > bsps/arm: Convert CMSIS files from CRLF to LF
>> > bsps/arm: Changed CMSIS files to v5
>> > build/bsps/arm: Add new CMSIS files v5 to build
>> > bsps/arm/stm32f4: Include STM32F4 HAL
>> > bsps/arm/stm32f4: Add HAL to build
>> > bsps/arm/stm32f4: Make bspstart use HAL
>> > bsps: Add GPIO API
>> > bsps/arm/stm32f4: GPIO Implementation
>> > bsps: Add ADC API
>> > bsps/arm/stm32f4: ADC API implementation
>> > bsps/arm/include/cmsis_compiler.h | 266 +
>> > bsps/arm/include/cmsis_gcc.h | 3460 +--
>> > bsps/arm/include/cmsis_version.h | 39 +
>> > bsps/arm/include/core_cm4.h | 524 +-
>> > bsps/arm/include/core_cm7.h | 5186 ++--
>> > bsps/arm/include/core_cmFunc.h | 172 +-
>> > bsps/arm/include/core_cmInstr.h | 174 +-
>> > bsps/arm/include/core_cmSimd.h | 192 +-
>> > bsps/arm/include/mpu_armv7.h | 270 +
>> > bsps/arm/stm32f4/adc/adc.c | 495 +
>> > bsps/arm/stm32f4/gpio/gpio.c | 557 +
>> > .../stm32f4/hal/Legacy/stm32f4xx_hal_can.c | 1679 ++
>> > .../stm32f4/hal/Legacy/stm32f4xx_hal_eth.c | 2307 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal.c | 615 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c | 2110 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c | 1112 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c | 2462 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c | 996 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c | 502 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c | 328 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c | 7132 ++++++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c | 680 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c | 1341 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c | 495 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c | 1161 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c | 182 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c | 4423 ++++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c | 1305 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c | 2126 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c | 313 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c | 2760 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c | 3220 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c | 547 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c | 775 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c | 1347 +
>> > .../stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c | 172 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c | 6864 ++++++
>> > .../arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c | 258 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c | 2749 +++
>> > .../stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c | 145 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c | 533 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c | 3514 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c | 1040 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c | 1728 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c | 7524 ++++++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c | 182 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c | 2094 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c | 1135 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c | 2687 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c | 262 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c | 2484 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c | 2215 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c | 151 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c | 3201 +++
>> > .../stm32f4/hal/stm32f4xx_hal_msp_template.c | 100 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c | 2405 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c | 1543 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c | 946 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c | 2387 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c | 341 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c | 571 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c | 600 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c | 2915 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c | 1122 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c | 3784 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c | 867 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c | 1896 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c | 1878 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c | 2554 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c | 310 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c | 3277 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c | 1308 +
>> > .../arm/stm32f4/hal/stm32f4xx_hal_smartcard.c | 2364 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c | 2784 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c | 1627 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c | 3915 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c | 1110 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c | 7621 ++++++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c | 2428 ++
>> > ...tm32f4xx_hal_timebase_rtc_alarm_template.c | 318 +
>> > ...m32f4xx_hal_timebase_rtc_wakeup_template.c | 293 +
>> > .../hal/stm32f4xx_hal_timebase_tim_template.c | 177 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c | 3751 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c | 2838 +++
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c | 420 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c | 922 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c | 103 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c | 280 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c | 423 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c | 594 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c | 212 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c | 1498 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c | 217 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c | 1062 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c | 303 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c | 251 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c | 301 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c | 81 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c | 1660 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c | 111 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c | 838 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c | 1578 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c | 624 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c | 1189 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c | 500 +
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c | 2224 ++
>> > bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c | 749 +
>> > bsps/arm/stm32f4/hal/system_stm32f4xx.c | 747 +
>> > .../stm32f4/include/Legacy/stm32_hal_legacy.h | 4014 +++
>> > .../include/Legacy/stm32f4xx_hal_can_legacy.h | 765 +
>> > .../include/Legacy/stm32f4xx_hal_eth_legacy.h | 2209 ++
>> > bsps/arm/stm32f4/include/bsp/io.h | 4 +
>> > bsps/arm/stm32f4/include/bsp/stm32f4_adc.h | 198 +
>> > bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h | 281 +
>> > bsps/arm/stm32f4/include/stm32f401xc.h | 8641 +++++++
>> > bsps/arm/stm32f4/include/stm32f401xe.h | 8641 +++++++
>> > bsps/arm/stm32f4/include/stm32f405xx.h | 14310 +++++++++++
>> > bsps/arm/stm32f4/include/stm32f407xx.h | 15607 ++++++++++++
>> > bsps/arm/stm32f4/include/stm32f410cx.h | 7357 ++++++
>> > bsps/arm/stm32f4/include/stm32f410rx.h | 7361 ++++++
>> > bsps/arm/stm32f4/include/stm32f410tx.h | 7306 ++++++
>> > bsps/arm/stm32f4/include/stm32f411xe.h | 8680 +++++++
>> > bsps/arm/stm32f4/include/stm32f412cx.h | 13507 ++++++++++
>> > bsps/arm/stm32f4/include/stm32f412rx.h | 14500 +++++++++++
>> > bsps/arm/stm32f4/include/stm32f412vx.h | 14512 +++++++++++
>> > bsps/arm/stm32f4/include/stm32f412zx.h | 14537 +++++++++++
>> > bsps/arm/stm32f4/include/stm32f413xx.h | 15462 ++++++++++++
>> > bsps/arm/stm32f4/include/stm32f415xx.h | 14595 +++++++++++
>> > bsps/arm/stm32f4/include/stm32f417xx.h | 15887 ++++++++++++
>> > bsps/arm/stm32f4/include/stm32f423xx.h | 15615 ++++++++++++
>> > bsps/arm/stm32f4/include/stm32f427xx.h | 16827 +++++++++++++
>> > bsps/arm/stm32f4/include/stm32f429xx.h | 17185 +++++++++++++
>> > bsps/arm/stm32f4/include/stm32f437xx.h | 17129 +++++++++++++
>> > bsps/arm/stm32f4/include/stm32f439xx.h | 17479 +++++++++++++
>> > bsps/arm/stm32f4/include/stm32f446xx.h | 15981 ++++++++++++
>> > bsps/arm/stm32f4/include/stm32f469xx.h | 20278 +++++++++++++++
>> > bsps/arm/stm32f4/include/stm32f479xx.h | 20575 ++++++++++++++++
>> > bsps/arm/stm32f4/include/stm32f4xx.h | 305 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal.h | 297 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h | 898 +
>> > .../stm32f4/include/stm32f4xx_hal_adc_ex.h | 407 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_can.h | 844 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h | 792 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h | 506 +
>> > .../stm32f4/include/stm32f4xx_hal_cortex.h | 407 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h | 181 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h | 683 +
>> > .../stm32f4/include/stm32f4xx_hal_cryp_ex.h | 142 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h | 480 +
>> > .../stm32f4/include/stm32f4xx_hal_dac_ex.h | 205 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h | 563 +
>> > .../stm32f4/include/stm32f4xx_hal_dcmi_ex.h | 208 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_def.h | 210 +
>> > .../arm/stm32f4/include/stm32f4xx_hal_dfsdm.h | 1141 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h | 802 +
>> > .../arm/stm32f4/include/stm32f4xx_hal_dma2d.h | 638 +
>> > .../stm32f4/include/stm32f4xx_hal_dma_ex.h | 102 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h | 1377 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h | 2144 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h | 366 +
>> > .../arm/stm32f4/include/stm32f4xx_hal_flash.h | 425 +
>> > .../stm32f4/include/stm32f4xx_hal_flash_ex.h | 1063 +
>> > .../include/stm32f4xx_hal_flash_ramfunc.h | 76 +
>> > .../stm32f4/include/stm32f4xx_hal_fmpi2c.h | 837 +
>> > .../stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h | 150 +
>> > .../stm32f4/include/stm32f4xx_hal_fmpsmbus.h | 790 +
>> > .../include/stm32f4xx_hal_fmpsmbus_ex.h | 136 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h | 325 +
>> > .../stm32f4/include/stm32f4xx_hal_gpio_ex.h | 1590 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h | 634 +
>> > .../stm32f4/include/stm32f4xx_hal_hash_ex.h | 175 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h | 316 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h | 741 +
>> > .../stm32f4/include/stm32f4xx_hal_i2c_ex.h | 115 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h | 618 +
>> > .../stm32f4/include/stm32f4xx_hal_i2s_ex.h | 183 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h | 682 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h | 220 +
>> > .../arm/stm32f4/include/stm32f4xx_hal_lptim.h | 857 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h | 719 +
>> > .../stm32f4/include/stm32f4xx_hal_ltdc_ex.h | 83 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h | 747 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h | 388 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h | 330 +
>> > .../stm32f4/include/stm32f4xx_hal_pccard.h | 285 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h | 459 +
>> > .../stm32f4/include/stm32f4xx_hal_pcd_ex.h | 88 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h | 427 +
>> > .../stm32f4/include/stm32f4xx_hal_pwr_ex.h | 340 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h | 750 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h | 1459 ++
>> > .../stm32f4/include/stm32f4xx_hal_rcc_ex.h | 7111 ++++++
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h | 361 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h | 915 +
>> > .../stm32f4/include/stm32f4xx_hal_rtc_ex.h | 1079 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h | 895 +
>> > .../stm32f4/include/stm32f4xx_hal_sai_ex.h | 114 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h | 758 +
>> > .../arm/stm32f4/include/stm32f4xx_hal_sdram.h | 238 +
>> > .../stm32f4/include/stm32f4xx_hal_smartcard.h | 755 +
>> > .../arm/stm32f4/include/stm32f4xx_hal_smbus.h | 731 +
>> > .../stm32f4/include/stm32f4xx_hal_spdifrx.h | 604 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h | 729 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h | 236 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h | 2146 ++
>> > .../stm32f4/include/stm32f4xx_hal_tim_ex.h | 354 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h | 884 +
>> > .../arm/stm32f4/include/stm32f4xx_hal_usart.h | 648 +
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h | 298 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h | 4779 ++++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h | 2105 ++
>> > .../arm/stm32f4/include/stm32f4xx_ll_cortex.h | 637 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h | 201 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h | 1455 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h | 2868 +++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h | 1901 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h | 954 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h | 1416 ++
>> > .../arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h | 2234 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h | 1086 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h | 981 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h | 1890 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h | 302 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h | 1378 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h | 985 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h | 7096 ++++++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h | 335 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h | 3663 +++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h | 1141 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h | 2027 ++
>> > .../arm/stm32f4/include/stm32f4xx_ll_system.h | 1711 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h | 4093 +++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h | 2521 ++
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h | 536 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h | 307 +
>> > bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h | 316 +
>> > bsps/arm/stm32f4/include/system_stm32f4xx.h | 104 +
>> > bsps/arm/stm32f4/start/bspstart.c | 199 +-
>> > bsps/include/bsp/adc.h | 407 +
>> > bsps/include/bsp/gpio2.h | 524 +
>> > bsps/shared/dev/adc/adc.c | 249 +
>> > bsps/shared/dev/gpio/gpio2.c | 207 +
>> > spec/build/bsps/arm/grp.yml | 3 +
>> > spec/build/bsps/arm/stm32f4/grp.yml | 18 +-
>> > spec/build/bsps/arm/stm32f4/obj.yml | 225 +
>> > spec/build/bsps/arm/stm32f4/optenhal.yml | 16 +
>> > spec/build/bsps/arm/stm32f4/opthse.yml | 17 +
>> > spec/build/bsps/arm/stm32f4/optnumadcctrl.yml | 16 +
>> > .../build/bsps/arm/stm32f4/optnumgpioctrl.yml | 16 +
>> > spec/build/bsps/arm/stm32f4/optusehse.yml | 16 +
>> > spec/build/bsps/arm/stm32f4/optvariant.yml | 24 +
>> > spec/build/bsps/bspopts.yml | 4 +
>> > spec/build/bsps/obj.yml | 3 +-
>> > spec/build/bsps/optmaxnumadc.yml | 16 +
>> > spec/build/bsps/optmaxnumgpio.yml | 16 +
>> > 255 files changed, 589769 insertions(+), 4342 deletions(-)
>> > create mode 100644 bsps/arm/include/cmsis_compiler.h
>> > create mode 100644 bsps/arm/include/cmsis_version.h
>> > create mode 100644 bsps/arm/include/mpu_armv7.h
>> > create mode 100644 bsps/arm/stm32f4/adc/adc.c
>> > create mode 100644 bsps/arm/stm32f4/gpio/gpio.c
>> > create mode 100644 bsps/arm/stm32f4/hal/Legacy/stm32f4xx_hal_can.c
>> > create mode 100644 bsps/arm/stm32f4/hal/Legacy/stm32f4xx_hal_eth.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_msp_template.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_smartcard.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c
>> > create mode 100644
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_rtc_alarm_template.c
>> > create mode 100644
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_rtc_wakeup_template.c
>> > create mode 100644
>> > bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_tim_template.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c
>> > create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c
>> > create mode 100644 bsps/arm/stm32f4/hal/system_stm32f4xx.c
>> > create mode 100644 bsps/arm/stm32f4/include/Legacy/stm32_hal_legacy.h
>> > create mode 100644
>> > bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_can_legacy.h
>> > create mode 100644
>> > bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_eth_legacy.h
>> > create mode 100644 bsps/arm/stm32f4/include/bsp/stm32f4_adc.h
>> > create mode 100644 bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f401xc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f401xe.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f405xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f407xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f410cx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f410rx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f410tx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f411xe.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f412cx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f412rx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f412vx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f412zx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f413xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f415xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f417xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f423xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f427xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f429xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f437xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f439xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f446xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f469xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f479xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_adc_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_can.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cortex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cryp_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dac_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_def.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dfsdm.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma2d.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_flash.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ex.h
>> > create mode 100644
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ramfunc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus.h
>> > create mode 100644
>> > bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_gpio_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hash_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2c_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2s_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_lptim.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pccard.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pcd_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pwr_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rcc_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rtc_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sai_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sdram.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_smartcard.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_smbus.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_spdifrx.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_tim_ex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_usart.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_cortex.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_system.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h
>> > create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h
>> > create mode 100644 bsps/arm/stm32f4/include/system_stm32f4xx.h
>> > create mode 100644 bsps/include/bsp/adc.h
>> > create mode 100644 bsps/include/bsp/gpio2.h
>> > create mode 100644 bsps/shared/dev/adc/adc.c
>> > create mode 100644 bsps/shared/dev/gpio/gpio2.c
>> > create mode 100644 spec/build/bsps/arm/stm32f4/optenhal.yml
>> > create mode 100644 spec/build/bsps/arm/stm32f4/opthse.yml
>> > create mode 100644 spec/build/bsps/arm/stm32f4/optnumadcctrl.yml
>> > create mode 100644 spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml
>> > create mode 100644 spec/build/bsps/arm/stm32f4/optusehse.yml
>> > create mode 100644 spec/build/bsps/arm/stm32f4/optvariant.yml
>> > create mode 100644 spec/build/bsps/optmaxnumadc.yml
>> > create mode 100644 spec/build/bsps/optmaxnumgpio.yml
>> > 2.37.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org <mailto:devel at rtems.org>
>> > http://lists.rtems.org/mailman/listinfo/devel
>> > <http://lists.rtems.org/mailman/listinfo/devel>
>> > devel mailing list
>> > devel at rtems.org
> devel mailing list
> devel at rtems.org
