[PATCH 6/7] bsp/aarch64: Starthooks and MMU Sections for Raspberry pi 4B AArch64 BSP
    Mohd Noor Aman
    nooraman5718 at gmail.com
    Thu Sep 22 06:20:42 UTC 2022
This commit add starthooks and MMU files for the BSP. The MMU sections include peripheral, ARM Local regs, FIQs-IRQs, Watchdog, Videocore Timer, System Timer, GIC Timer, EMMC and UART Addresses.
 bsps/aarch64/raspberrypi/start/bspstart.c     |  49 ++++++++
 .../aarch64/raspberrypi/start/bspstarthooks.c |  53 ++++++++
 bsps/aarch64/raspberrypi/start/bspstartmmu.c  | 119 ++++++++++++++++++
 3 files changed, 221 insertions(+)
 create mode 100644 bsps/aarch64/raspberrypi/start/bspstart.c
 create mode 100644 bsps/aarch64/raspberrypi/start/bspstarthooks.c
 create mode 100644 bsps/aarch64/raspberrypi/start/bspstartmmu.c
diff --git a/bsps/aarch64/raspberrypi/start/bspstart.c b/bsps/aarch64/raspberrypi/start/bspstart.c
new file mode 100644
index 0000000000..56f52a2231
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/start/bspstart.c
@@ -0,0 +1,49 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64Raspberrypi4
+ * @brief BSP Startup
+ * Copyright (C) 2022 Mohd Noor Aman
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/irq-generic.h>
+#include <bsp/linker-symbols.h>
+void bsp_start( void )
+  bsp_interrupt_initialize();
+  rtems_cache_coherent_add_area(
+    bsp_section_nocacheheap_begin,
+    (uintptr_t) bsp_section_nocacheheap_size
diff --git a/bsps/aarch64/raspberrypi/start/bspstarthooks.c b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
index 0000000000..fe0fe77c09
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
@@ -0,0 +1,53 @@
+ * @file
+ * @brief BSP Startup Hooks
+ * are met:
+#include <bsp.h>
+#include <bsp/start.h>
+#include <rtems/score/cpu.h>
+BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+  /* Do nothing */
+BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+  AArch64_start_set_vector_base();
+  bsp_start_copy_sections();
+  raspberrypi_4_setup_mmu_and_cache();
+  bsp_start_clear_bss();
\ No newline at end of file
diff --git a/bsps/aarch64/raspberrypi/start/bspstartmmu.c b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
index 0000000000..cdf8b39d2d
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
@@ -0,0 +1,119 @@
+ * @file
+ * @brief This source file contains the default MMU tables and setup.
+ * are met:
+#include <bsp.h>
+#include <bsp/aarch64-mmu.h>
+#include <bsp/raspberrypi.h>
+#include <libcpu/mmu-vmsav8-64.h>
+BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
+raspberrypi_4_mmu_config_table[] = {
+  AARCH64_MMU_DEFAULT_SECTIONS,
+  { /*RPI peripheral address*/
+    .begin = (unsigned)RPI_PERIPHERAL_BASE,
+    .end = (unsigned)RPI_PERIPHERAL_BASE + (unsigned)RPI_PERIPHERAL_SIZE,
+    .flags = AARCH64_MMU_DEVICE
+  { /*RPI ARM local registers*/
+    .begin = (unsigned)BCM2711_LOCAL_REGS_BASE,
+    .end = (unsigned)BCM2711_LOCAL_REGS_BASE + (unsigned)BCM2711_LOCAL_REGS_SIZE,
+  { /*RPI ARM_C FIQ and IRQ registers*/
+    .begin = (unsigned)BCM2711_ARMC_REGS_BASE,
+    .end = (unsigned)BCM2711_ARMC_REGS_BASE + (unsigned)BCM2711_ARMC_REGS_SIZE,
+  { /*RPI Watchdog Timer*/
+    .begin = (unsigned)BCM2711_PM_BASE,
+    .end = (unsigned)BCM2711_PM_BASE + 0x1000U,
+  { /*RPI GPU System Timer*/
+    .begin = (unsigned)BCM2711_GPU_TIMER_BASE,
+    .end = (unsigned)BCM2711_GPU_TIMER_BASE + 0x200000U,
+  { /*RPI ARM System Timer*/
+    .begin = (unsigned)BCM2711_TIMER_BASE,
+    .end = (unsigned)BCM2711_TIMER_BASE + 0x200000U,
+  { /*RPI GIC Timer*/
+    .begin = 0xFF800000U,
+    .end = 0xFFA00000U,
+  { /*RPI MMC */
+    .begin = 0xFE340000U,
+    .end = 0xFE340000U + 0x200000U,
+  { /*RPI UART*/
+    .begin = 0xFE200000U,
+    .end = 0xFE200000U,
+ * Make weak and let the user override.
+raspberrypi_4_setup_mmu_and_cache( void ) __attribute__ ((weak));
+  aarch64_mmu_setup();
+  aarch64_mmu_setup_translation_table(
+    &raspberrypi_4_mmu_config_table[ 0 ],
+    RTEMS_ARRAY_SIZE( raspberrypi_4_mmu_config_table )
+  aarch64_mmu_enable();
2.34.1
