[PATCH 7/7] bsp/aarch64: Console initialization for Raspberry Pi 4B AArch64 BSP
Mohd Noor Aman
nooraman5718 at gmail.com
Thu Sep 22 06:20:43 UTC 2022
This commit adds console initialization for the BSP using Polled mode. This is similar to the QEMU-A72 and QEMU-A53 console initialization.
bsps/aarch64/raspberrypi/console/console.c | 69 ++++++++++++++++++++++
1 file changed, 69 insertions(+)
create mode 100644 bsps/aarch64/raspberrypi/console/console.c
diff --git a/bsps/aarch64/raspberrypi/console/console.c b/bsps/aarch64/raspberrypi/console/console.c
new file mode 100644
index 0000000000..73bb0036ff
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/console/console.c
@@ -0,0 +1,69 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64Raspberrypi4
+ * @brief Console Configuration
+ * Copyright (C) 2022 Mohd Noor Aman
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/bspIo.h>
+#include <bsp.h>
+#include <dev/serial/arm-pl011.h>
+#include <bsp/console-termios.h>
+#include <bspopts.h>
+arm_pl011_context raspberrypi_4_context = {
+ .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
+ .regs = (volatile pl011 *) BSP_RPI4_PL011_BASE,
+ .initial_baud = 115200
+const console_device console_device_table[] = {
+ .device_file = "/dev/ttyS0",
+ .probe = console_device_probe_default,
+ .handler = &arm_pl011_fns,
+ .context = &raspberrypi_4_context.base
+const size_t console_device_count = RTEMS_ARRAY_SIZE(console_device_table);
+static void output_char( char c )
+ arm_pl011_write_polled(&raspberrypi_4_context.base, c);
+BSP_output_char_function_type BSP_output_char = output_char;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
2.34.1
